UHF RFID Inlays
AD-171m5
Dimensions:
Common Applications:
Apparel and Retail
Operating Frequency: Global (860 — 960 MHz)
RF Protocol: ISO-18000-6C, EPC Class 1, Gen 2
Chip: Impinj® Monza® 5
EPC Memory: 128 bit
TID Memory: 96 bits with 48 bit unique serial number
866-903- RFID (7343) / rfid.info@averydennison.com
Part Number
600385
600386
Format
Dry Inlay
Wet Inlay
Antenna dimensions (CDxMD)
1.063 x 0.551 in [27 x 14mm]
1.063 x 0.551 in [27 x 14 mm]
Die- cut dimensions
N/ A
1.2 x 0.7 in [41.17 X 79.17 mm]
Inlay substrate material
PET
PET
Inlay- to- liner adhesive
N/ A
S-490 (FASSON)
Liner material
N/ A
1.5M Clear PET
Face sheet
N/ A
N/ A
Standard pitch
1.5 in [38.1 mm]
1.5 in [38.1 mm]
Standard web width
1.45 in [36.83 mm]
1.45 in [36.83 mm]
Total thickness over chip
10-13 mils [254-330.2 microns]
14-17 mils [356-431.8 microns]
Operating temperature
-40 to 185F [-40 to 85C]
-40 to 185 F [-40 to 85 C]
RoHS
EU Directive 2002/95/ EC Compliant
Quality assurance
100% read tested with out – of- tolerance inlay
marked
100% read tested with out- of- tolerance inlay
marked
Un- wind direction
Inlay- side Out
Inlay- side Out
Core size
with adaptor insert
3 in [76.2 mm] w/ foam on core
3 in [76.2 mm]
Maximum roll outer
diameter (not to exceed)
13 in [330.2mm]
13 in [330.2 mm]
Average # of units per roll
15,000 good
15,000 good
Rev
00
00
CARE AND HANDLING RFID inlays are sensitive to ESD. Observe standard practices to keep environmental static charge to a minimum.
APPLICATIONS This product should be tested by the customer/ user thoroughly under end use conditions to ensure the product meets the particular requirements. Avery Dennison does
not represent that this product is fit for any particular purpose or use.
WARRANTY Please refer to Avery Dennison RFID standard terms and conditions. The information contained herein is believed to be reliable but Avery Dennison makes no representation
concerning the accuracy or correctness of the data.
PRODUCT CHANGES Avery Dennison reserves the right to modify, change, supplement or discontinue product offerings at any time without notice.
TRADEMARK STATEMENT Avery Dennison, S490 and Fasson are trademarks of Avery Dennison Corporation. For the most recent information on Avery Dennison products, visit
www.rfid.averydennison.com.
© 2013 Avery Dennison Inc. All rights reserved. 170 Monarch Lane, Miamisburg, OH 45342
很抱歉,暂时无法提供与“600386”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2.671451+0.34701
