28142
28142
    PARALLAXINC.
    Modular
28142 数据手册
599 Menlo Drive, Suite 100 Rocklin, California 95765, USA Office: (916) 624-8333 Fax: (916) 624-8003 General: info@parallax.com Technical: support@parallax.com Web Site: www.parallax.com Educational: www.stampsinclass.com RFID Reader Module (#28140) RFID 54 mm x 85 mm Rectangle Tag (#28141) RFID 50 mm Round Tag (#28142) 2.45” (62.2mm) 3.25” (82.5mm) VCC /ENABLE SOUT GND idea studio 2.95” (75mm) 2.15” (54.5mm) 0.14” (3.6mm) 0.1” (2.5mm) Introduction Designed in cooperation with Grand Idea Studio (http://www.grandideastudio.com/), the Parallax Radio Frequency Identification (RFID) Reader Module is the first low-cost solution to read passive RFID transponder tags up to 1¾” - 3” inches away depending on the tag (see list below). The RFID Reader Module can be used in a wide variety of hobbyist and commercial applications, including access control, automatic identification, robotics navigation, inventory tracking, payment systems, and car immobilization.      Fully-integrated, low-cost method of reading passive RFID transponder tags Single-wire, 2400 baud Serial TTL interface to PC, BASIC Stamp® and other processors Requires single +5VDC supply Bi-color LED for visual indication of activity 0.100” pin spacing for easy prototyping and integration Parallax, Inc. • RFID Reader Module (#28140) •Updated 02/2006 v1.2 Page 1 The Parallax RFID Reader Module works exclusively with the EM Microelectronics-Marin SA EM4100-family of passive read-only transponder tags. A variety of different tag types and styles exist with the most popular made available from Parallax. Each transponder tag contains a unique identifier (one of 240, or 1,099,511,627,776, possible combinations) that is read by the RFID Reader Module and transmitted to the host via a simple serial interface. Electronic Connections The Parallax RFID Reader Module can be integrated into any design using only four connections (VCC, /ENABLE, SOUT, GND). Use the following circuit for connecting the Parallax RFID Reader Module to the BASIC Stamp microcontroller: Pin 1 2 Pin Name VCC /ENABLE Type P I Function System power, +5V DC input. Module enable pin. Active LOW digital input. Bring this pin LOW to enable the RFID reader and activate the antenna. 3 SOUT O Serial Out. TTL-level interface, 2400bps, 8 data bits, no parity, 1 stop bit. 4 GND G System ground. Connect to power supply’s ground (GND) terminal. Note: Type: I = Input, O = Output, P = Power, G = Ground Parallax, Inc. • RFID Reader Module (#28140) •Updated 02/2006 v1.1 Page 2 Communication Protocol Implementation and usage of the RFID Reader Module is straightforward. BASIC Stamp 1, 2, and SX28AC/DP code examples (SX/B) are included at the end of this documentation. The RFID Reader Module is controlled with a single TTL-level active-low /ENABLE pin. When the /ENABLE pin is pulled LOW, the module will enter its active state and enable the antenna to interrogate for tags. The current consumption of the module will increase dramatically when the module is active. A visual indication of the state of the RFID Reader Module is given with the on-board LED. When the module is successfully powered-up and is in an idle state, the LED will be GREEN. When the module is in an active state and the antenna is transmitting, the LED will be RED. The face of the RFID tag should be held parallel to the front or back face of the antenna (where the majority of RF energy is focused). If the tag is held sideways (perpendicular to the antenna) you'll either get no reading or a poor reading. Only one transponder tag should be held up to the antenna at any time. The use of multiple tags at one time will cause tag collisions and confuse the reader. The two tags available in the Parallax store have a read distance of approximately 3 inches. Actual distance may vary slightly depending on the size of the transponder tag and environmental conditions of the application. When a valid RFID transponder tag is placed within range of the activated reader, the unique ID will be transmitted as a 12-byte ASCII string via the TTL-level SOUT (Serial Output) pin in the following format: MSB Start Byte (0x0A) LSB Unique ID Digit 1 Unique ID Digit 2 Unique ID Digit 3 Unique ID Digit 4 Unique ID Digit 5 Unique ID Digit 6 Unique ID Digit 7 Unique ID Digit 8 Unique ID Digit 9 Unique ID Digit 10 Stop Byte (0x0D) The start byte and stop byte are used to easily identify that a correct string has been received from the reader (they correspond to a line feed and carriage return characters, respectively). The middle ten bytes are the actual tag's unique ID. All communication is 8 data bits, no parity, 1 stop bit, non-inverted, least significant bit first (8N1). The baud rate is configured for 2400bps, a standard communications speed supported by most any microprocessor or PC, and cannot be changed. The Parallax RFID Reader Module initiates all communication. The Parallax RFID Reader Module can connect directly to any TTL-compatible UART or to an RS232-compatible interface by using an external level shifter. Absolute Maximum Ratings and Electrical Characteristics Condition Operating Temperature Storage Temperature Supply Voltage (VCC) Ground Voltage (VSS) Voltage on any pin with respect to VSS Value -40ºC to +85ºC -55ºC to +125ºC +4.5V to +5.5V 0V -0.3V to +7.0V Stresses above those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at those or any other conditions above those indicated in the operation listings of this specification is not implied. Exposure to maximum rating conditions for extended periods may affect device reliability. Parallax, Inc. • RFID Reader Module (#28140) •Updated 02/2006 v1.1 Page 3 DC Characteristics At VCC = +5.0V and TA = 25ºC unless otherwise noted Parameter Supply Voltage Supply Current, Idle Supply Current, Active Input LOW voltage Input HIGH voltage Output LOW voltage Output HIGH voltage Symbol VCC IIDLE ICC VIL VIH VOL VOH Test Conditions ------+4.5V
28142 价格&库存
很抱歉,暂时无法提供与“28142”相匹配的价格&库存,您可以联系我们找货
