600544
600544
    AVERYDENNISON(艾利丹尼森)
600544 数据手册
Avery Dennison Smartrac Product Data Sheet Inlays and Tags AD-370u7-NEL/03/21/DS AD-370u7 NEL Overview Frequency Band UHF 860 - 960 MHz Chip NXP UCODE 7 Antenna Dimensions 19 x 53 mm / 0.75 x 2.09 in International Standard ISO/IEC 18000-63 Type C Ideal for apparel and many other items Industry Segments Apparel Logistics AD-370u7 NEL inlays from Avery Dennison are designed for tagging a broad range of retail items, particularly apparel. They are also well suited for applications related to supply chain, inventory and logistics. Applications Home Essentials Supply Chain Management RoHs EU Directive 2011/65/EU and 2015/863 Compliant Built for the UHF frequency band, the inlays features a 19 x 53 mm antenna with global broadband performance (860-930 MHz) for reliable operation on a broad range of surfaces and materials. AD-370u7 inlays are equipped with the UCODE 7 ICs from NXP, featuring 128-bit of EPC memory and 96-bit TID memory, with a 48-bit unique serial number factoryencoded. The product is also available in wide-edge leading (WEL) format. Delivery formats include Dry Inlay, Wet Inlay and Pressure Sensitive Label. Like all RFID products from Avery Dennison, AD-370u7 NEL inlays are manufactured according to the industry’s highest quality standards, as confirmed by the RFID Lab at Auburn University: The inspection body awarded Avery Dennison its first comprehensive and significant ARC accreditation for quality. rfid.averydennison.com Avery Dennison Smartrac Product Data Sheet Inlays and Tags AD-370u7-NEL/03/21/DS Technical features Chip NXP UCODE 7 EPC and User Memory 128-bit and n/a TID Memory 96-bit / 48-bit unique serial number Product Code RF600425 RF600544 RF100251 Delivery Format Dry inlay Wet inlay Label / sticker Die-cut Dimension - 22 x 56 mm / 0.87 x 2.21 in 25 x 57 mm / 1 x 2.25 in Inlay Substrate PET PET 5pt Integrity Total Thickness 10 - 12 mils / 261 - 312 microns 12 - 14 mils / 300 - 350 microns 16 - 18 mils / 399 - 450 microns Standard Pitch 63.5 mm / 2.5 in 63.5 mm / 2.5 in 69.85 mm / 2.75 in Web Width 31.8 mm / 1 in 31.8 mm / 1 in 30.5 mm / 1 in Core Size 76 mm / 3 in Quantity / Reel 12500 pcs/reel 11000 pcs/reel 1769 pcs/reel Operating Temperature -40 °C to 85 °C -40 °F to 185 °F On-Metal Non metal Certificate ARC Contact information rfid.averydennison.com/contact North America: +1-866-903-7343 (toll free US) International: +1-678-617-2359 © 2021 Avery Dennison Corp. All rights reserved. 170 Monarch Lane, Miamisburg, OH 45342, USA Third party trademarks and/or trade names used herein are the property of their respective owner(s). Some of the trademarks appear for identification purposes only. Warranty: Please refer to Avery Dennison standard terms and conditions: rfid.averydennison.com/termsandconditions Care and handling: RFID inlays are sensitive to ESD. Observe standard industry practices relating to electronics / RFID to keep environmental impact and static charge to a minimum. Applications: This product should be tested by the customer / user thoroughly under end use conditions to ensure the product meets the particular requirements. Avery Dennison does not represent that this product is fit for any particular purpose or use. Avery Dennison reserves the right to modify, change, supplement or discontinue product offerings at any time without notice. The information contained herein is believed to be reliable but Avery Dennison makes no representation concerning the accuracy or correctness of the data. Avery Dennison Smartrac Product Data Sheet Inlays and Tags AD-370u7-WEL/03/21/DS AD-370u7 WEL Overview Frequency Band UHF 860 - 960 MHz Chip NXP UCODE 7 Antenna Dimensions 53 x 19 mm / 2.09 x 0.75 in International Standard ISO/IEC 18000-63 Type C Ideal for apparel and many other items Industry Segments Apparel Logistics AD-370u7 inlays from Avery Dennison are designed for tagging a broad range of retail items, particularly apparel. They are also well suited for applications related to supply chain, inventory and logistics. Applications Home Essentials Supply Chain Management RoHs EU Directive 2011/65/EU and 2015/863 Compliant Built for the UHF frequency band, the inlays feature a 53 x 19 mm antenna with global broadband performance (860-930 MHz) for reliable operation on a broad range of surfaces and materials. AD-370u7 inlays are equipped with a UCODE 7 ICs from NXP, featuring 128-bit of EPC memory and 96-bit TID memory, with a 48-bit unique serial number factoryencoded. The product is also available in narrow-edge leading (NEL) format. Delivery formats include Dry Inlay, Wet Inlay and Pressure Sensitive Label. Like all RFID products from Avery Dennison, AD-370u7 inlays are manufactured according to the industry’s highest quality standards, as confirmed by the RFID Lab at Auburn University: The inspection body awarded Avery Dennison its first comprehensive and significant ARC accreditation for quality. rfid.averydennison.com Avery Dennison Smartrac Product Data Sheet Inlays and Tags AD-370u7-WEL/03/21/DS Technical features Chip NXP UCODE 7 EPC and User Memory 128-bit and n/a TID Memory 96-bit / 48-bit unique serial number Product Code RF600902 RF600740 RF100357 Delivery Format Dry inlay Wet inlay Label / sticker Die-cut Dimension - 56 x 22 mm / 2.21 x 0.87 in 57 x 25 mm / 2.25 x 1 in Inlay Substrate 40# SC Paper Face Sheet - - 55# TT2C Bright White Total Thickness 11 - 13 mils / 270 - 320 microns 14 - 16 mils / 349 - 400 microns 15 - 17 mils / 389 - 439 microns Standard Pitch 25.4 mm / 1 in 25.4 mm / 1 in 38.1 mm / 1.5 in Web Width 56 mm / 2 in 60.5 mm / 2 in 63.5 mm / 3 in Core Size 76 mm / 3 in Quantity / Reel 30000 pcs/reel 17500 pcs/reel 3319 pcs/reel Operating Temperature -40 °C to 85 °C -40 °F to 185 °F On-Metal Non metal Certificate ARC Contact information rfid.averydennison.com/contact North America: +1-866-903-7343 (toll free US) International: +1-678-617-2359 © 2021 Avery Dennison Corp. All rights reserved. 170 Monarch Lane, Miamisburg, OH 45342, USA Third party trademarks and/or trade names used herein are the property of their respective owner(s). Some of the trademarks appear for identification purposes only. Warranty: Please refer to Avery Dennison standard terms and conditions: rfid.averydennison.com/termsandconditions Care and handling: RFID inlays are sensitive to ESD. Observe standard industry practices relating to electronics / RFID to keep environmental impact and static charge to a minimum. Applications: This product should be tested by the customer / user thoroughly under end use conditions to ensure the product meets the particular requirements. Avery Dennison does not represent that this product is fit for any particular purpose or use. Avery Dennison reserves the right to modify, change, supplement or discontinue product offerings at any time without notice. The information contained herein is believed to be reliable but Avery Dennison makes no representation concerning the accuracy or correctness of the data.
600544 价格&库存
很抱歉,暂时无法提供与“600544”相匹配的价格&库存,您可以联系我们找货
  • 11000+1.0491311000+0.13613
