20926410202
20926410202
    HARTING(浩亭)
20926410202 数据手册
Ha-VIS Han® 24 RFID HPR VTenlarged 86 (HT) Passive UHF Transponder Ha-VIS VT 86 (HT) Advantages Applications • Robust housing, resistant against chemicals • Extremly robust and durable transponder for maintenance and life cycle applications in rough environments • EPC C1 Gen2 compatible • Functions on metal • Degree of protection IP 69K • Read range (on metal plate, 2 W ERP, 868 MHz): ≥ 2.5 m • Extended memory • Flexible mounting • Integration into type label possible Identification Part number Drawing Dimensions in mm Passive UHF Transponder Ha-VIS RFID VT 86 (HT) set with clip holder Pack with 10 pieces 20 92 641 0201 Pack with 50 pieces 20 92 641 0202 Technical characteristics Frequency range Protocol Chip Memory 860 MHz ... 960 MHz EPC C1Gen2 Alien Higgs 3 512 Bit Temperature range Operational range (read / write) Storage Thermal shock 0 °C to 210 °C Max. duration at max. temperature 210 °C -50 °C ... +85 °C -65 °C ... +160 °C 5000 cycles 5000 h Housing Size (W x D x H) Degrees of protection Mounting Colour 41 x 11 x 5 mm IP 64 / IP 67 / IP 69K Screw, rivet, adhere Black HARTING Electric GmbH & Co. KG Wilhelm-Harting-Straße 1 | D-32339 Espelkamp | P.O.Box 14 73 | D-32328 Espelkamp Phone: +49 5772 47-97 100 | Fax: +49 5772 47-97 688 | RFID@HARTING.com | www.HARTING-RFID.com 2011-10-25 Han® Data Sheet 0665
20926410202 价格&库存
很抱歉,暂时无法提供与“20926410202”相匹配的价格&库存,您可以联系我们找货
