1482
1482
    ADAFRUIT
    ROUND SPACER #8 BRASS 1/2"
1482 数据手册
13.56MHz RFID/NFC Leather Keychain Fob - 1KB PRODUCT ID: 1482  Description This is a blank 13.56MHz RFID/NFC keychain fob. The fob contains a small RFID chip and an antenna, and is passively powered by the reader/writer when placed a couple inches away. These can be read by almost any 13.56MHz RFID/NFC reader but make sure it can handle ISO/IEC 14443 Type A cards as there are a few other encoding standards (like FeLica) They are tested and work great with both our PN532 NFC/RFID breakout board and Adafruit NFC/RFID Shield for Arduino! These chips can be written to & store up to 1 KB of data in writable EEPROM divided into banks, and can handle over 100,000 re-writes. You can use our PN532 NFC/RFID breakout board or Adafruit NFC/RFID Shield for Arduino to read and write data to the EEPROM inside the tag. There is also a permanent 4-byte ID burned into the chip that you can use to identify one tag from another - the ID number cannot be changed. These use a ISO/IEC 14443 Type A chipset, which used to be the 'classic' NFC chipset. In ~2014, the NFC forum decided not to support this chipset anymore, so newer phones do not support it. This only matters if you're trying to use this tag with a phone/tablet  Technical Details RFID chip specification: o 1 KiloByte (8 KiloBit) non-volatile EEPROM storage o Built in encryption engine with 48-bit key o 4 Byte unique identifier burned into the chip o 13.56 MHz frequency Tag specification: o o o 38.39mm / 1.51" x 38.39mm / 1.51" x 5.04mm / 0.2" 8.68g Works about 2" away from reader        Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“1482”相匹配的价格&库存,您可以联系我们找货
