600361
600361
    AVERYDENNISON(艾利丹尼森)
    RFID Tag Read/Write 128b (EPC) Memory 860MHz ~ 960MHz EPC, ISO 18000-6 Inlay
600361 数据手册
UHF RFID Inlays AD-232iL Dimensions: 2.76 x 0.57 in [70 x 14.5 mm] Common Applications: Apparel and Retail Supply Chain, Inventory and Logistics Operating Frequency: Global (860 - 960MHz) RF Protocol: ISO-18000-6C, EPC Class 1 Gen 2 Chip: NXP G2iL EPC Memory: 128 bit TID Memory: 64 bit Tag IDentifier (TID) including 32 bit factory locked unique 866-903- RFID (7343) / rfid.info@averydennison.com Part Number 600361 600358 Format N/ A N/ A Antenna dimensions (CDxMD) 2.756 x 0.571 in [70 x 14.5 mm] 2.756 x 0.571 in [70 x 14.5 mm] Die- cut dimensions N/ A 2.881 x 0.696 in [73.18 x 17.68 mm] Inlay substrate material PET PET Inlay- to- liner adhesive N/ A S-490 (Fasson) Liner material N/ A 1.5M Clear PET Face sheet N/ A N/ A Standard pitch 0.875 in [22.23 mm] .875 in [22.23 mm] Standard web width 3.875 in [98.43 mm] 3 in [76.2 mm] Total thickness over chip 10 - 13 mils [254 - 330.2 microns] 14 - 17 mils [356 - 431.8 microns] Operating temperature -40 to 185 F [-40 to 85 C] -40 to 185 F [-40 to 85 C] RoHS EU Directive 2011/95/ EU Compliant EU Directive 2011/95/ EU Compliant Quality assurance 100% read tested with out- of- tolerance inlay marked 100% read tested with out- of- tolerance inlay marked Un- wind direction Inlay- side Out Inlay- side Out Core size with adaptor insert 6 in with 3 in 152 mm x 76.2 mm adaptor 3 in [76.2 mm] Maximum roll outer diameter (not to exceed) 17 in [431.8 mm] 13 in [330.2 mm] Average # of units per roll 40,000 10,000 Rev 00 00 CARE AND HANDLING RFID inlays are sensitive to ESD. Observe standard practices to keep environmental static charge to a minimum. APPLICATIONS This product should be tested by the customer/ user thoroughly under end use conditions to ensure the product meets the particular requirements. Avery Dennison does not represent that this product is fit for any particular purpose or use. WARRANTY Please refer to Avery Dennison RFID standard terms and conditions. The information contained herein is believed to be reliable but Avery Dennison makes no representation concerning the accuracy or correctness of the data. PRODUCT CHANGES Avery Dennison reserves the right to modify, change, supplement or discontinue product offerings at any time without notice. TRADEMARK STATEMENT Avery Dennison, S490 and Fasson are trademarks of Avery Dennison Corporation. For the most recent information on Avery Dennison products, visit www.rfid.averydennison.com. © 2014 Avery Dennison Inc. All rights reserved. 170 Monarch Lane, Miamisburg, OH 45342
600361 价格&库存
很抱歉,暂时无法提供与“600361”相匹配的价格&库存,您可以联系我们找货
