600411
600411
    AVERYDENNISON(艾利丹尼森)
    RFID Tag Read/Write 128b (EPC) Memory 860MHz ~ 960MHz EPC, ISO 18000-6 Inlay
600411 数据手册
UHF RFID Inlays AD-235u7 Dimensions: Common Applications: Apparel and Retail Supply Chain, Inventory and Logistics Operating Frequency: Global (860 - 960MHz) RF Protocol: ISO-18000-6C, EPC Class 1 Gen 2 Chip: NXP UCODE 7 EPC Memory: 128 bit TID Memory: 96 bit, pre- encoded for multi- vendor chip (MCS) based serialization, factory programmed 866-903- RFID (7343) / rfid.info@averydennison.com Part Number 600411 600414 Format Dry Inlay Wet Inlay (pressure sensitive) Antenna dimensions (CDxMD) 2.7560 0.571 in [70.5 x 14.5mm] 2.7560 0.571 in [70.5 x 14.5mm] Die- cut dimensions N/ A 2.881 x 0.696 in [73 x 18 mm] Inlay substrate material PET PET Inlay- to- liner adhesive N/ A S-490 (FASSON) Liner material N/ A 1.5 M PET Face sheet N/ A N/ A Standard pitch 0.875 in [22.23mm] 0.875 in [22.23mm] Standard web width 3.75 in [95.25 mm] 3.0 in [76.2 mm] Total thickness over chip 10 -13 mils [254 - 330.2 microns] 10 -13 mils [254 - 330.2 microns] Operating temperature -40 to 185F [-40 to 85C] -40 to 185F [-40 to 85C] RoHS EU Directive 2002/95/ EC EU Directive 2002/95/ EC Quality assurance Compliant 100% read tested with out- of tolerance Compliant 100% read tested with out- of tolerance inlay marked inlay marked Un- wind direction Inlay - side Out Inlay - side Out Core size with adaptor insert 6 in [152.4mm] 3 in [76.2mm] Maximum roll outer diameter (not to exceed) 17in [431.8mm] 13 in [330.2mm] Average # of units per roll 40,000 10,000 Rev 00 00 CARE AND HANDLING RFID inlays are sensitive to ESD. Observe standard practices to keep environmental static charge to a minimum. APPLICATIONS This product should be tested by the customer/ user thoroughly under end use conditions to ensure the product meets the particular requirements. Avery Dennison does not represent that this product is fit for any particular purpose or use. WARRANTY Please refer to Avery Dennison RFID standard terms and conditions. The information contained herein is believed to be reliable but Avery Dennison makes no representation concerning the accuracy or correctness of the data. PRODUCT CHANGES Avery Dennison reserves the right to modify, change, supplement or discontinue product offerings at any time without notice. TRADEMARK STATEMENT Avery Dennison, S490 and Fasson are trademarks of Avery Dennison Corporation. For the most recent information on Avery Dennison products, visit www.rfid.averydennison.com. © 2014 Avery Dennison Inc. All rights reserved. 170 Monarch Lane, Miamisburg, OH 45342
600411 价格&库存
很抱歉,暂时无法提供与“600411”相匹配的价格&库存,您可以联系我们找货
