600486
600486
    AVERYDENNISON(艾利丹尼森)
    RFID INLAY DRY UHF AD-381M5
600486 数据手册
UHF RFID Inlays AD-381m5 Preliminary Narrow Edge Leading Common Applications: Dimensions: 1.181 x 1.969 in (30 x 50 mm) Apparel and Retail Shoes Operating Frequency: Global (860 - 960MHz) RF Protocol: ISO-18000-6C, EPC Class 1 Gen 2 Chip: Impinj Monza 5 EPC Memory: 128 bits TID Memory: 48 bit serialized, factory programmed and locked 866-903- RFID (7343) / rfid.info@averydennison.com 600395 Part Number 600396 Format Dry Inlay Wet Inlay (pressure sensitive) Antenna dimensions (CDxMD) 1.181 x 1.969 in [30 x 50mm] 1.181 x 1.969 in [30 x 50mm] Die- cut dimensions N/ A 1.34 x 2.126 in [34.01 x 54 mm] Inlay substrate material PET PET Inlay- to- liner adhesive N/ A S-490 (FASSON) Liner material N/ A N/ A Face sheet N/ A 1.5M Standard pitch 2.50in [63.5mm] 2.50in[63.5mm] Standard web width 1.50in [38.1mm] 1.50in [38.1mm] Total thickness over chip 10 -13 mils [254 - 330.2 microns] 10 -13 mils [254 - 330.2 microns] Operating temperature -40 to 185F [-40 to 85C] -40 to 185F [-40 to 85C] RoHS EU Directive 2011/65/EU EU Directive 2011/65/EU Clear PET Compliant 100% read tested with out- of tolerance Compliant 100% read tested with out- of tolerance Quality assurance inlay marked inlay marked Un- wind direction Inlay - side Out Inlay - side Out Core size with adaptor insert 3 in [76.2mm] 3 in [76.2mm] Maximum roll outer diameter (not to exceed) 17in [431.8mm] 13 in [330.2mm] Average # of units per roll 15,000 good 7,500 good Rev 00 00 CARE AND HANDLING RFID inlays are sensitive to ESD. Observe standard practices to keep environmental static charge to a minimum. APPLICATIONS This product should be tested by the customer/ user thoroughly under end use conditions to ensure the product meets the particular requirements. Avery Dennison does not represent that this product is fit for any particular purpose or use. WARRANTY Please refer to Avery Dennison RFID standard terms and conditions. The information contained herein is believed to be reliable but Avery Dennison makes no representation concerning the accuracy or correctness of the data. PRODUCT CHANGES Avery Dennison reserves the right to modify, change, supplement or discontinue product offerings at any time without notice. TRADEMARK STATEMENT Avery Dennison, S490 and Fasson are trademarks of Avery Dennison Corporation. For the most recent information on Avery Dennison products, visit www.rfid.averydennison.com. © 2013 Avery Dennison Inc. All rights reserved. 170 Monarch Lanes, Miamisburg, OH 45342
600486 价格&库存
很抱歉,暂时无法提供与“600486”相匹配的价格&库存,您可以联系我们找货
