600385
600385
    AVERYDENNISON(艾利丹尼森)
    RFID INLAY DRY UHF AD-171M5
600385 数据手册
UHF RFID Inlays AD-171m5 Dimensions: Common Applications: Apparel and Retail Operating Frequency: Global (860 — 960 MHz) RF Protocol: ISO-18000-6C, EPC Class 1, Gen 2 Chip: Impinj® Monza® 5 EPC Memory: 128 bit TID Memory: 96 bits with 48 bit unique serial number 866-903- RFID (7343) / rfid.info@averydennison.com Part Number 600385 600386 Format Dry Inlay Wet Inlay Antenna dimensions (CDxMD) 1.063 x 0.551 in [27 x 14mm] 1.063 x 0.551 in [27 x 14 mm] Die- cut dimensions N/ A 1.2 x 0.7 in [41.17 X 79.17 mm] Inlay substrate material PET PET Inlay- to- liner adhesive N/ A S-490 (FASSON) Liner material N/ A 1.5M Clear PET Face sheet N/ A N/ A Standard pitch 1.5 in [38.1 mm] 1.5 in [38.1 mm] Standard web width 1.45 in [36.83 mm] 1.45 in [36.83 mm] Total thickness over chip 10-13 mils [254-330.2 microns] 14-17 mils [356-431.8 microns] Operating temperature -40 to 185F [-40 to 85C] -40 to 185 F [-40 to 85 C] RoHS EU Directive 2002/95/ EC Compliant EU Directive 2002/95/ EC Compliant Quality assurance 100% read tested with out – of- tolerance inlay marked 100% read tested with out- of- tolerance inlay marked Un- wind direction Inlay- side Out Inlay- side Out Core size with adaptor insert 3 in [76.2 mm] w/ foam on core 3 in [76.2 mm] Maximum roll outer diameter (not to exceed) 13 in [330.2mm] 13 in [330.2 mm] Average # of units per roll 15,000 good 15,000 good Rev 00 00 CARE AND HANDLING RFID inlays are sensitive to ESD. Observe standard practices to keep environmental static charge to a minimum. APPLICATIONS This product should be tested by the customer/ user thoroughly under end use conditions to ensure the product meets the particular requirements. Avery Dennison does not represent that this product is fit for any particular purpose or use. WARRANTY Please refer to Avery Dennison RFID standard terms and conditions. The information contained herein is believed to be reliable but Avery Dennison makes no representation concerning the accuracy or correctness of the data. PRODUCT CHANGES Avery Dennison reserves the right to modify, change, supplement or discontinue product offerings at any time without notice. TRADEMARK STATEMENT Avery Dennison, S490 and Fasson are trademarks of Avery Dennison Corporation. For the most recent information on Avery Dennison products, visit www.rfid.averydennison.com. © 2013 Avery Dennison Inc. All rights reserved. 170 Monarch Lane, Miamisburg, OH 45342
600385 价格&库存
很抱歉,暂时无法提供与“600385”相匹配的价格&库存,您可以联系我们找货
