100347
100347
    AVERYDENNISON(艾利丹尼森)
100347 数据手册
UHF RFID Inlays AD-237r6 Dimensions Operating Frequency RF Protocol Chip EPC Memory TID Memory 70 x 14.5 mm Global (860 – 960 MHz) ISO-18000-6C, EPC Class 1, Gen 2 Impinj Monza R6 96 bit 48-bit unique serialized TID Number Common Applications Supply Chain, Inventory and Logistics Apparel Home Goods Toll free US 866-903- RFID (7343) / rfid.info@averydennison.com International +1-770-965-0807 PART NUMBER Format Antenna dimensions (CDxMD) Die-cut dimensions RF600597 Dry Inlay 2.756 x 0.571 in (70.0 x 14.5 mm) N/A Inlay substrate material Inlay-to-liner adhesive Liner material Face Sheet Standard pitch Standard web width Total thickness over chip White PET N/A N/A N/A 0.875 in (22.2 mm) 3.75 in (95.25 mm) 7-9 mils (178-229 microns) RF600598 Wet Inlay 2.756 x 0.571 in (70.0 x 14.5 mm) 2.881 x 0.696 in (73.18 x 17.68 mm) White PET S-490 1.5M Clear PET White PET 0.875 in (22.2 mm) 3.0 in (76.2 mm) 7-9 mils (178-229 microns) Operating temperature -40 to 185F (-40 to 85C) -40 to 185F (-40 to 85C) RoHS EU Directive 2011/65/EU Compliant 100% read tested with-oftolerance inlay marked EU Directive 2011/65/EU Compliant 100% read tested with-oftolerance inlay marked Inlay-side Out 6 in (152.4 mm) 17 in (431.8 mm) PS Inlay-side Out 3 in (76.2mm) 13 in (330.2mm) 2.756 x 0.571 in (70.0 x 14.5 mm) 3.0 x 0.8 in (76.2 x 20.3 mm) N/A S-490 40# SCK 55# 2C Bright White 1.5 in (38.1 mm) 3.25 in (82.6 mm) 9 -11 mils (229-279 microns) -40 to 185F (-40 to 85C) EU Directive 2011/65/EU Compliant 100% read tested withof-tolerance inlay marked Label-side Out 3 in (76.2 mm) 15.25 in (387.4 mm) 40,000 good +/- 10% 01 10,000 good +/- 10% 01 12,500 good +/- 10% 01 Quality assurance Un-wind direction Core size with adaptor insert Maximum roll outer diameter (not to exceed) Average # of units per roll Rev RF100309 Pressure Sensitive Label Care and handling: RFID inlays are sensitive to ESD. Observe standard industry practices relating to electronics/RFID to keep environmental impact and static charge to a minimum. Applications: This product should be tested by the customer/ user thoroughly under end use conditions to ensure the product meets the particular requirements. Avery Dennison does not represent that this product is fit for any particular purpose or use. Warranty: Please refer to Avery Dennison RFID standard terms and conditions. Product Information: Avery Dennison reserves the right to modify, change, supplement or discontinue product offerings at any time without notice. The information contained herein is believed to be reliable but Avery Dennison makes no representation concerning the accuracy or correctness of the data. Trademark statement: Avery Dennison, S490 and Fasson are trademarks of Avery Dennison Corporation. For the most recent information on Avery Dennison products, visit www.rfid.averydennison.com. © 2016 Avery Dennison Corp. All rights reserved. 170 Monarch Lane, Miamisburg, OH 45342, USA Third party trademarks and/or trade names used herein are the property of their respective owner(s). Some of the trademarks appear for identification purposes only.
100347 价格&库存
很抱歉,暂时无法提供与“100347”相匹配的价格&库存,您可以联系我们找货
