100217
100217
    AVERYDENNISON(艾利丹尼森)
    FIXED IND 6.8UH 1.3A 170 MOHM TH
100217 数据手册
UHF RFID Inlays AD-380iL Dimensions: 1.97 x 1.18 in [50 x 30 mm] Common Applications: Apparel and Retail Supply Chain, Inventory and Logistics Operating Frequency: Global (860 - 960MHz) RF Protocol: ISO-18000-6C, EPC Class 1 Gen 2 Chip: NXP UCODE G2iL EPC Memory: 128 bit TID Memory: 96 bits with 48 bit unique serial number 866-903- RFID (7343) / rfid.info@averydennison.com Part Number 600349 Contact Avery Dennison 600351 Format Dry Inlay Opaque Inlay Wet (pressure- sensitive) Inlay Antenna dimensions (CDxMD) 1.969 x 1.181 in [50 x 29.99 mm] 1.969 x 1.181 in [50 x 29.99 mm] 1.969 x 1.181 in [50 x 29.99 mm] Die- cut dimensions N/ A 2.126 x 1.339 in [54 x 34 mm] 2.126 x 1.339 in [54 x 34 mm] Inlay substrate material PET PET PET Inlay- to- liner adhesive N/ A S-490 (Fasson) S-490 (Fasson) Liner material N/ A 40# SCK (Fasson) 1.5M Clear PET Face sheet N/ A Fasson Trans- Therm 2C N/ A Standard pitch 1.5 in [38.1 mm] 1.5 in [38.1 mm] 1.5 in [38.1mm] Standard web width 2.75 in [69.85 mm] 2.284 in [50 mm] 2.284 in [50 mm] Total thickness over chip 10-13 mils [254-330.2 microns] 15-17 mils [381-431.8 microns] 14-17 mils [356-431.8 microns] Operating temperature -40 to 185 F [-40 to 85 C] -40 to 185 F [-40 to 85 C] -40 to 185 F [-40 to 85 C] RoHS EU Directive 2011/65/ EU Compliant EU Directive 2011/65/ EU Compliant EU Directive 2011/65/ EU Compliant Quality assurance 100% read tested with out- oftolerance inlay marked 100% read tested with out- oftolerance inlay marked 100% read tested with out- oftolerance inlay marked Un- wind direction Inlay- side Out Inlay- side Out Inlay- side Out Core size with adaptor insert 6 in with 3 in 152 mm x 76.2 mm adaptor 3 in [76.2 mm] 3 in [76.2 mm] Maximum roll outer diameter (not to exceed) 13 in [330.2 mm] 7 in [177.7 mm] 13 in [330.2 mm] Average # of units per roll 15,000 4000 10000 Rev 00 00 00 CARE AND HANDLING RFID inlays are sensitive to ESD. Observe standard practices to keep environmental static charge to a minimum. APPLICATIONS This product should be tested by the customer/ user thoroughly under end use conditions to ensure the product meets the particular requirements. Avery Dennison does not represent that this product is fit for any particular purpose or use. WARRANTY Please refer to Avery Dennison RFID standard terms and conditions. The information contained herein is believed to be reliable but Avery Dennison makes no representation concerning the accuracy or correctness of the data. PRODUCT CHANGES Avery Dennison reserves the right to modify, change, supplement or discontinue product offerings at any time without notice. TRADEMARK STATEMENT Avery Dennison, S490 and Fasson are trademarks of Avery Dennison Corporation. For the most recent information on Avery Dennison products, visit www.rfid.averydennison.com. © 2014 Avery Dennison Inc. All rights reserved. 170 Monarch Lane, Miamisburg, OH 45342
100217 价格&库存
很抱歉,暂时无法提供与“100217”相匹配的价格&库存,您可以联系我们找货
