750027
750027
    AVERYDENNISON(艾利丹尼森)
    RFID NFC HF LABEL INLAY AD-721
750027 数据手册
Type A NFC RFID Inlay AD-721 Dimensions Operating Frequency RF Protocol Chip User Memory UID 0.827 in [21 mm] Diameter 13.56 MHz ISO-14443A NXP NTAG213 144 bytes 7 bytes Common Applications Retail Environment Print Media Miscellaneous Applications Toll free US 866-903- RFID (7343) / rfid.info@averydennison.com International +1-770-965-0807 PART NUMBER RF700069 RF700070 RF750027 Format Antenna dimensions (CDxMD) Die-cut dimensions Inlay substrate material Inlay-to-liner adhesive Dry Inlay 0.827 in [21 mm] Diameter N/A PET N/A Liner material Face Sheet Standard pitch Standard web width Total thickness over chip Operating temperature RoHS N/A N/A 1.25 in (31.75 mm) 2.36 in (60 mm) Nominal 200 um -40º to 158 ºF (-40º to 70 ºC) EU Directive 2011/65/EU Compliant 100% read tested with-oftolerance inlay marked Inlay-side Out 3 in (76.2 mm) 12.6 in (320 mm) PS Inlay 0.827 in [21 mm] Diameter 0.984 in [25 mm] Diameter PET General purpose permanent hot melt 65 g Paper Liner N/A 1.25 in (31.75 mm) 2.36 in (60 mm) Nominal 290 um -4º to 122 ºF (-25º to 50 ºC) EU Directive 2011/65/EU Compliant 100% read tested with-oftolerance inlay marked Inlay-side Out 3 in (76.2mm) 7.48 in (190 mm) Label 0.827 in [21 mm] Diameter 0.984 in [25 mm] Diameter PET General purpose permanent hot melt 65 g Paper Liner 80 g Paper 1.25 in (31.75 mm) 2.36 in (60 mm) Nominal 360 um -4º to 122 ºF (-25º to 50 ºC) EU Directive 2011/65/EU Compliant 100% read tested with-oftolerance inlay marked Inlay-side Out 3 in (76.2 mm) 7.48 in (190 mm) 15,000 verified 00 4,000 verified 00 2,000 verified 00 Quality assurance Un-wind direction Core size with adaptor insert Maximum roll outer diameter (not to exceed) Average # of units per roll Rev Avery Dennison is pleased to introduce AD-721, a smartphone compliant, NFC RFID inlay optimized for a growing number of RFID tagging applications requiring close range (near field) communication. Care and handling: RFID inlays are sensitive to ESD. Observe standard industry practices relating to electronics/RFID to keep environmental impact and static charge to a minimum. Applications: This product should be tested by the customer/ user thoroughly under end use conditions to ensure the product meets the particular requirements. Avery Dennison does not represent that this product is fit for any particular purpose or use. Warranty: Please refer to Avery Dennison RFID standard terms and conditions. Product Information: Avery Dennison reserves the right to modify, change, supplement or discontinue product offerings at any time without notice. The information contained herein is believed to be reliable but Avery Dennison makes no representation concerning the accuracy or correctness of the data. Trademark statement: Avery Dennison, S490 and Fasson are trademarks of Avery Dennison Corporation. For the most recent information on Avery Dennison products, visit www.rfid.averydennison.com. © 2016 Avery Dennison Corp. All rights reserved. 170 Monarch Lane, Miamisburg, OH 45342, USA
750027 价格&库存
很抱歉,暂时无法提供与“750027”相匹配的价格&库存,您可以联系我们找货
