700065
700065
    AVERYDENNISON(艾利丹尼森)
    RFID Tag 13.56MHz ISO 15693, ISO 18000-3 Inlay
700065 数据手册
HF RFID Inlays AD-730x Dimensions: 0.55 x 1.22 in [14 x 31 mm] Common Applications: Pharmaceutical and Healthcare Operating Frequency: 13.56MHz RF Protocol: ISO-15693, 18000-3 Mode 1 Chip: NXP ICODE SLIX EPC Memory: TID Memory: 866-903- RFID (7343) / rfid.info@averydennison.com Part Number 700047 700048 Format N/ A N/ A Antenna dimensions (CDxMD) 1.221 x 0.551 in [31 x 14 mm] 1.221 x 0.551 in [31 x 14 mm] Die- cut dimensions N/ A 1.417 x 0.709 in [36 x 18 mm] Inlay substrate material PET PET Inlay- to- liner adhesive N/ A S-490 (Fasson) Liner material N/ A 40# SCK (Fasson) Face sheet N/ A N/ A Standard pitch 1 in [25.4 mm] 1 in [25.4 mm] Standard web width 1.875 in [47.63 mm] 1.875 in [47.63 mm] Total thickness over chip N/ A N/ A Operating temperature -40 to 185 F [-40 to 85 C] -40 to 185 F [-40 to 85 C] RoHS EU Directive 2011/65/ EU Compliant EU Directive 2011/65/ EU Compliant Quality assurance 100% read tested with out- of- tolerance inlay marked 100% edit and replace Un- wind direction Inlay- side Out Inlay- side Out Core size with adaptor insert 3 in [76.2 mm] 3 in [76.2 mm] Maximum roll outer diameter (not to exceed) 13 in [330.2 mm] 13 in [330.2 mm] Average # of units per roll 7500 7500 Rev 00 00 CARE AND HANDLING RFID inlays are sensitive to ESD. Observe standard practices to keep environmental static charge to a minimum. APPLICATIONS This product should be tested by the customer/ user thoroughly under end use conditions to ensure the product meets the particular requirements. Avery Dennison does not represent that this product is fit for any particular purpose or use. WARRANTY Please refer to Avery Dennison RFID standard terms and conditions. The information contained herein is believed to be reliable but Avery Dennison makes no representation concerning the accuracy or correctness of the data. PRODUCT CHANGES Avery Dennison reserves the right to modify, change, supplement or discontinue product offerings at any time without notice. TRADEMARK STATEMENT Avery Dennison, S490 and Fasson are trademarks of Avery Dennison Corporation. For the most recent information on Avery Dennison products, visit www.rfid.averydennison.com. © 2013 Avery Dennison Inc. All rights reserved. 4350 Avery Drive, Flowery Branch, GA 30542
700065 价格&库存
很抱歉,暂时无法提供与“700065”相匹配的价格&库存,您可以联系我们找货
