FXR.08.52.0075X.A.DG
    TAOGLASLIMITED
FXR.08.52.0075X.A.DG 数据手册
SPECIFICATION Part No. : FXR.08.52.0075X.A.dg Product Name : Rectangular Flexible Near-Field Communications Ferrite Antenna with 75mm Twisted Pair 28AWG Cable and ACH(F) connector Features : 13.56 MHz RFID / NFC Antenna Layered with Ferrite Flux Director Low Profile Embedded Antenna Dimensions: 53.34 mm x 37.3 mm Thickness: 0.30 mm Peel and stick Nitto UTD-30 adhesive on back 75mm Twisted Pair 28AWG Cable with Teflon and ACH(F) Connector Customized solutions available RoHS Compliant SPE-15-8-079/A/CM Page 1 of 10 1. Introduction The FXR.08.52.0075X.A.dg is an NFC Ferrite antenna with 75mm twisted pair 28AWG cable and JST connector. It works with specific NFC chips which need to connect via JST ACH connector. NFC antennas can be applied in areas not traditionally available to other types of antennas. A common example is the ability to apply NFC antennas to batteries or other conductive surfaces. To enable this usage, however, a ferrite flux director layer is required. This ferrite layer acts to steer the magnetic flux away from the metal or other conductor, where it would otherwise result in loss or complete failure to communicate. Taoglas NFC antennas can therefore be customized with flux director layers to enable this flexibility in usage. The coil inductance noted below can help estimate a capacitance value for creating resonance at 13.56MHz. Typical applications - Mobile devices - Electronic wallets - Health care ID scanners - Payment readers - Office ID - Access control - Internet Of Things Customized antennas for specific applications, shape, and impedance match can also be provided for an NRE and subject to MOQ. Contact your regional Taoglas sales office for more information and support on our NFC antenna range. SPE-15-8-079/A/CM Page 2 of 10 2. Specification Flexible PCB Near-Field Communications Antenna Frequency 13.56 MHz Inductance @ 13.56 MHz 4.5 µH Flexible NFC Mechanical Cable Length Dimensions: 53.34 mm x 37.3 mm Thickness: 0.15 mm 75 mm Connector Type ACH(F) Adhesive 3M 467 Weight 3g Antenna Dimensions Ferrite Sheet Mechanical PET Ferrite Sheet Adhesive Type Dimension: 53.34*37.3 mm Thickness: 0.02 mm Dimension: 53.34*37.3 mm Thickness: 0.10 mm Nitto UTD-30 (W) Thickness: 0.03 mm Environmental Operation Temperature -40°C to 85°C Storage Temperature -40°C to 85°C Humidity Non-condensing 65°C 95% RH SPE-15-8-079/A/CM Page 3 of 10 3. Antenna Application 3.1. Test setup A test fixture is used to measure the maximum interrogation distance. The FXR.08.52.0075X.A.dg antenna is connected to a NFC evaluation board and then placed on the fixed part of the fixture. Evaluation Board Test Fixture Passively Powered Tag Sample on thin plastic sheet Measuring Scale Measurement Arm RFID Reader Module Antenna The test sample is placed on a thin sheet of plastic connected to the movable part of the fixture. Then the distance is carefully adjusted until the reader can no longer read the sample, thus the maximum interrogation distance is displayed in the ruler. SPE-15-8-079/A/CM Page 4 of 10 3.2. RFID tags used for test A total of 8 RFID tags were used to measure the interrogation distances. The next picture shows type 1 and type 2 tags, respectively. Type 1 Type 2 Type 1 tag is based on ISO/IEC 14443A standard and has 512 bytes of memory. Type 2 tag is based on ISO/IEC 14443A standard and has 192 bytes of memory. The next picture shows the Tag-it HF-I RFID tags from Texas Instruments: RI-102112, RI-I11-112, RI-I03-112, RI-I16-112, button type, and RI-I17-112. The Tag-it HF-I Plus Transponder Inlay family of Texas Instruments RFID is based on the ISO/IEC 15693 standard for contactless integrated circuit cards (vicinity cards) and ISO/IEC 18000-3 standard for item management. SPE-15-8-079/A/CM Page 5 of 10 3.3. Matching The interrogation distances presented here were taken with the antenna connected directly to the evaluation boards with the default matching circuit. This is not necessarily the optimal matching circuit that could be designed for a particular antenna. We kept the default matching of each evaluation board to minimize the number of variables in testing and keep integration as simple as possible. As with any matching network the exact circuit and values for an optimal network depend on the combination of antenna, NFC circuit, any intervening transmission line and the environment presented to the antenna. These factors are specific to the particular end product. As a starting point, to achieve the read range results presented here, use the matching network detailed in the schematic of the evaluation board for your particular NFC chip and keep the antenna free of any obstruction. Once you can demonstrate successful reads you can then optimize performance as desired. If the matching network is required, you should implement the following topology: The matching circuit should be designed to match the IC impedance 𝑍"# to 100Ω and then connect the antenna through a 100Ω differential pair. SPE-15-8-079/A/CM Page 6 of 10 3.4. Test Results A total of 8 sample devices were used to measure the interrogation distances in two scenarios, over plastic and over metal, using the Texas Instruments TRF7970AEVM evaluation board. The results are: • Over plastic: Dimensions (mm.) Interrogation Distance (mm.) Topaz512 (Type 1) 43 x 43 12 NTAG203 (Type 2) F 42 14 Tag-it HFI Plus RI-I11-112 45 x 45 21 Tag-it HFI Plus RI-I02-112 76 x 48 23 Tag-it HFI Plus RI-I03-112 38 x 22.5 10 Tag-it HFI Plus RI-I16-112 F 24.2 12 F 22 10 F 32.5 15 Dimensions (mm.) Interrogation Distance (mm.) Topaz512 (Type 1) 43 x 43 7 NTAG203 (Type 2) F 42 9 Tag-it HFI Plus RI-I11-112 45 x 45 14 Tag-it HFI Plus RI-I02-112 76 x 48 16 Tag-it HFI Plus RI-I03-112 38 x 22.5 7 Tag-it HFI Plus RI-I16-112 F 24.2 9 F 22 8 F 32.5 11 Device Button type Tag-it HFI Plus RI-I17-112 • Over metal: Device Button type Tag-it HFI Plus RI-I17-112 SPE-15-8-079/A/CM Page 7 of 10 4. Mechanical Drawing (Unit:mm) SPE-15-8-079/A/CM Page 8 of 10 5. Packaging SPE-15-8-079/A/CM Page 9 of 10 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © Taoglas Ltd. SPE-15-8-079/A/CM Page 10 of 10
FXR.08.52.0075X.A.DG 价格&库存
很抱歉,暂时无法提供与“FXR.08.52.0075X.A.DG”相匹配的价格&库存,您可以联系我们找货
  • 15+72.36465
  • 35+71.03464
  • 65+69.70463
  • 100+67.04461
库存:175
  • 6+119.16912
  • 30+107.25101
库存:24
  • 1+109.704601+14.19322
  • 35+81.1583635+10.50000
  • 65+79.6163565+10.30050
  • 100+76.61349100+9.91200
库存:175
    • 6+128.305196+16.59970
    • 30+115.4659330+14.93860
    库存:24
