FXR.06.52.0075X.A
FXR.06.52.0075X.A
    TAOGLASLIMITED
    FXR.06.52.0075X.A
FXR.06.52.0075X.A 数据手册
SPECIFICATION Part No. : FXR.06.52.0075X.A Product Name : Square Flexible Near-Field Communications Antenna with 75mm Twisted Pair 28AWG Cable and ACH(F) connector Features : 13.56 MHz RFID / NFC Antenna Flexible Low Profile Embedded Antenna Dimensions: 47 mm x 47 mm Thickness: 0.24 mm Peel and stick 3M adhesive on back 75mm Twisted Pair 28AWG Cable with Teflon and ACH(F) Connector RoHS Compliant SPE-15-8-073/A/CM Page 1 of 10 1. Introduction The FXR.06.52.0075X.A is a square, flexible, NFC (Near Field Communications) antenna for use in mobile devices and other applications such as keycards, payment systems, and boarding passes. The design provides a flexible NFC antenna with 75mm twisted pair 28AWG cable that can be adhered to the plastic enclosure of the device for ease of installation and work with specific 13.56MHz RFID and NFC chips which need to connect via JST ACH connector. With NFC antennas being commonly attached to the battery of mobile devices, they can be customized with a ferrite flux director to provide isolation from the battery or other components within the device. Using the antenna on a conductive surface without a ferrite layer will result in extremely short range or complete failure to communicate. The coil inductance noted below can help estimate a capacitance value for creating resonance at 13.56MHz. Typical applications - Mobile devices - Electronic wallets - Health care ID scanners - Payment readers - Office ID - Access control - Internet Of Things Customized antennas for specific applications, shape, and impedance match can also be provided for a NRE and are subject to MOQ. Contact your regional Taoglas sales office for more information and support on our NFC antenna range. SPE-15-8-073/A/CM Page 2 of 10 2. Specification Flexible PCB Near-Field Communications Antenna Frequency 13.56 MHz Inductance @ 13.56 MHz 5.2 µH Mechanical Cable Length Dimensions: 47 mm x 47 mm Thickness: 0.24 mm 75 mm Connector Type ACH(F) Adhesive 3M 467 Weight 2g Antenna Dimensions Environmental Operation Temperature -40°C to 85°C Storage Temperature -40°C to 85°C Humidity Non-condensing 65°C 95% RH SPE-15-8-073/A/CM Page 3 of 10 3. Antenna Application 3.1. Test setup A test fixture is used to measure the maximum interrogation distance. The FXR.06.52.0075.A antenna is connected to a NFC evaluation board and then placed on the fixed part of the fixture. Evaluation Board Test Fixture Measuring Scale Measurement Arm Passively Powered Tag Sample on thin plastic sheet RFID Reader Module Antenna The test sample is placed on a thin sheet of plastic connected to the movable part of the fixture. Then the distance is carefully adjusted until the reader can no longer read the sample, thus the maximum interrogation distance is displayed in the ruler. SPE-15-8-073/A/CM Page 4 of 10 3.2. RFID tags used for test A total of 7 RFID tags were used to measure the interrogation distances. The next picture shows type 1 and type 2 respectively. Type 1 Type 2 Type 1 tag is based on ISO/IEC 14443A standard and has 512 bytes of memory. Type 2 tag is based on ISO/IEC 14443A standard and has 192 bytes of memory. The next picture shows the Tag-it HF-I RFID tags from Texas Instruments: RI-102112, RI-I11-112, RI-I03-112, RI-I16-112, button type, and RI-I17-112. The Tag-it HF-I Plus Transponder Inlay family of Texas Instruments RFID is based on the ISO/IEC 15693 standard for contactless integrated circuit cards (vicinity cards) and ISO/IEC 18000-3 standard for item management. SPE-15-8-073/A/CM Page 5 of 10 3.3. Matching The interrogation distances presented here were taken with the antenna connected directly to the evaluation boards with the default matching circuit. This is not necessarily the optimal matching circuit that could be designed for a particular antenna. We kept the default matching of each evaluation board to minimize the number of variables in testing and keep integration as simple as possible. As with any matching network the exact circuit and values for an optimal network depend on the combination of antenna, NFC circuit, any intervening transmission line and the environment presented to the antenna. These factors are specific to the particular end product. As a starting point, to achieve the read range results presented here, use the matching network detailed in the schematic of the evaluation board for your particular NFC chip and keep the antenna free of any obstruction. Once you can demonstrate successful reads you can then optimize performance as desired. If the matching network is required, you should implement the following topology: The matching circuit should be designed to match the IC impedance 𝑍"# to 100Ω and then connect the antenna through a 100Ω differential pair. SPE-15-8-073/A/CM Page 6 of 10 3.4. Test Results A total of 7 sample devices were used to measure the interrogation distances in two scenarios, over plastic and over metal, using the Texas Instruments TRF7970AEVM evaluation board. The results are: • Over plastic: Dimensions (mm) Interrogation Distance (mm) Topaz512 (Type 1) 43 x 43 19 NTAG203 (Type 2) F 42 20 Tag-it HFI Plus RI-I11-112 45 x 45 27 Tag-it HFI Plus RI-I02-112 76 x 48 23 Tag-it HFI Plus RI-I03-112 38 x 22.5 15 Tag-it HFI Plus RI-I16-112 F 24.2 14 Tag-it HFI Plus RI-I17-112 F 32.5 24 Dimensions (mm) Interrogation Distance (mm) Topaz512 (Type 1) 43 x 43 9 NTAG203 (Type 2) F 42 10 Tag-it HFI Plus RI-I11-112 45 x 45 14 Tag-it HFI Plus RI-I02-112 76 x 48 20 Tag-it HFI Plus RI-I16-112 F 24.2 10 F 22 10 F 32.5 12 RFID Tag • Over metal: RFID Tag Button type Tag-it HFI Plus RI-I17-112 SPE-15-8-073/A/CM Page 7 of 10 4. Mechanical Drawing (unit: mm) SPE-15-8-073/A/CM Page 8 of 10 5. Packaging SPE-15-8-073/A/CM Page 9 of 10 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © Taoglas Ltd. SPE-15-8-073/A/CM Page 10 of 10
FXR.06.52.0075X.A
1. 物料型号:FXR.06.52.0075X.A 2. 器件简介:该天线是一款用于移动设备和其他应用(如智能卡、支付系统、登机牌等)的方形、柔性、近场通信(NFC)天线。设计提供了一种灵活的NFC天线,带有75毫米的双绞线28AWG电缆,可粘贴在设备的塑料外壳上,便于安装。 3. 引脚分配:文档中未明确列出引脚分配,但提到了通过JST ACH连接器连接。 4. 参数特性: - 频率:13.56 MHz - 电感@13.56 MHz:5.2 uH - 天线尺寸:47 mm x 47 mm,厚度:0.24 mm - 电缆长度:75 mm - 连接器类型:ACH(F) - 粘合剂:3M467 - 重量:2g - 工作温度:-40°C至85°C - 存储温度:-40°C至85°C - 湿度:非凝结65°C 95% RH 5. 功能详解:文档详细描述了天线的应用测试设置、使用的RFID标签类型、匹配网络设计以及测试结果。 6. 应用信息:典型应用包括移动设备、电子钱包、医疗保健ID扫描器、支付阅读器、办公室ID、门禁控制和物联网。 7. 封装信息:提供了详细的机械绘图和包装规格,包括ACH连接器、PVDF电缆、FPCB以及3M467双面粘合剂。
FXR.06.52.0075X.A 价格&库存
很抱歉,暂时无法提供与“FXR.06.52.0075X.A”相匹配的价格&库存,您可以联系我们找货
FXR.06.52.0075X.A
    • 100+76.56106100+9.94490
