2093610120020
2093610120020
    HARTING(浩亭)
    DO-214AC(SMA)
    LOCFIELDANTENNASMAFCC
2093610120020 数据手册
® Ha-VIS LOCFIELD Han® 24 HPR enlarged New thinking – design your RFID reading field Ha-VIS LOCFIELD® Traveling wave RFID antenna Part number Identification Ha-VIS LOCFIELD ® 2 m (active length), total length 2,5 m, diameter 3 mm, SMA (m), EU ® 2093 610 110010 2 m (active length), total length 3 m, low loss coax, diameter 5 mm, SMA (m), EU 2093 610 210010 1 m (active length), total length 1,5 m, diameter 3 mm, SMA (m), EU 2093 610 110020 0,3 m (active length), total length 0.6 m, diameter 3 mm, SMA (m), EU 2 m (active length), total length 3 m, low loss coax, diameter 5 mm, SMA (m), FCC 1 m (active length), total length 1,5 m, diameter 3 mm, SMA (m), FCC 0,3 m (active length), total length 0.6 m, diameter 3 mm, SMA (m), FCC Idea 2093 610 110030 2093 610 220010 The Ha-VIS LOCFIELD changes everything. Instead of installing patch antennas, the coax antenna cable itself becomes the antenna. The read range can be varied from a few centimeters to about 2 m just by changing the power of the RFID reader. The ® LOCFIELD antenna can easily be installed in any shape which serves the project in the best possible way. Applications: - Tool identification in machines - Door and window pass-throughs - Wireless sensor networks - Smart shelf 2093 610 120020 2093 610 120030 All data represent the current state of development at the time of print and are therefore non-binding. HARTING reserves the right to modify designs without prior notice. Ha-VIS LOCFIELD® Technical characteristics General characteristics Read range from a few cm up to 2 m (strongly depending on reader, configured power and tags) Optimized for Identification of tools in machines Door openings and pass throughs Wireless sensor networks Smart shelf / smart work bench Electric properties Frequency range EU: 865 ... 868 MHz; FCC: 902 …928 MHz Impedance 50 Ohm VSWR < 1.8:1 Polarisation Linear (tags are read in any orientation) Gain approx. -7 dBi Opening angle / read angle 360° Max. power 2 W (applied to antenna) Connection SMA male TNC-rev (on request) Mechanical properties Length see first page Degree of protection IP 65 Installation Can be mounted directly on any non-conducting surface. On conducting surfaces a distance of at least 2 cm is recommended Operating temperature range –20 °C ... +65 °C Storage temperature range –40 °C ... +85 °C HARTING Software Development GmbH & Co. KG Marienwerder Str. 2 | D-32339 Espelkamp | P.O.Box 14 73 | D-32328 Espelkamp Phone: +49 5772 47-0 | auto-ID@HARTING.com | www.HARTING-RFID.com 2014-06-25
2093610120020 价格&库存
很抱歉,暂时无法提供与“2093610120020”相匹配的价格&库存,您可以联系我们找货
