20932010203
20932010203
    HARTING(浩亭)
    RF-ANT-WR80-30-EU
20932010203 数据手册
Ha-VIS RFID overview C2 Ha-VIS RFID Transponder C.1   1 Ha-VIS RFID Reader C.2   1 Ha-VIS RFID Antennas C.3 1 Cables and Accessories C.4   1 RFID Reader C – Ha-VIS RFID components RFID Antennas Page Cables + Accessories Contents RFID Transponder Ha -VIS RFID C omp onent s C 1 Cables + Accessories RFID Antennas RFID Reader RFID Transponder Ha-VIS RFID Components C 2 General HARTING Ha-VIS RFID System components Real-time information and the close synchronization of computer data and real processes play a critical role in process management and process optimization. Ensuring that information precisely maps and concurs with reality is the only way to control processes optimally and reap savings potentials accordingly. One important prerequisite for guaranteeing that data and processes are synchronized is an intelligent infrastructure that makes data transparent and available throughout a company in order to achieve the maximum savings potentials. RFID offers you the full potential to create intelligent infrastructures: benefit from the simultaneous identification of up to several hundred objects - without the need for the direct line of sight as required by barcode solutions. The collected data are immediately ready for further processing throughout the company. Moreover, a transponder can be used to store information directly on the product at the same time it is identified. This means that these data are also always available wherever the product may happen to be located. HARTING offers smart infrastructure solutions based on optimally coordinated components from a single source. These solutions enable the reliable control and steering of production and business processes, thereby resulting in lower costs. The HARTING RFID Reader and components have been designed for harsh industrial applications. Deployed in the transportation, machinery and energy markets, HARTING RFID components guarantee secure and reliable information processing - also under the most challenging environmental conditions Contents Page RFID Transponder Ha -VIS RFID Tr ansp onder RFID Transponder Ha-VIS RFID LT89 C.1 2 Ha-VIS RFID PT86 C.1 3 Ha-VIS RFID SL89 C.1 4 Ha-VIS RFID CT89 C.1 5 Ha-VIS RFID CF89 C.1 6 Ha-VIS RFID CS89 C.1 7 C·1 1 RFID Transponder Ha-VIS RFID Transponder Passive UHF Transponder Ha-VIS RFID LT 89 (NT)-G2AH3 Technical characteristics Frequency range 860 MHz ... 960 MHz Protocol EPC C1Gen2 Chip Alien Higgs 3 Memory 512 bit Lesereichweite (Freiraum, 2 W ERP) ≥ 2.5 m Abmessungen (B x H x T) 123 x 30 x 8 mm Degrees of protection IP 64 / IP 67 / IP 69K Temperature range Operational range (read) Operational range (write) Storage Mounting -40 °C ... +85 °C -40 °C ... +85 °C -50 °C ... +85 °C M4 screws or rivets with washers Colour Black Merkmale • On any objects including metallic surfaces like skeleton boxes or over fluids (e.g. container) • Robust housing • EPC C1 Gen2 compatible • Extended memory Identification Part number Passive UHF Transponder Ha-VIS RFID LT 89 (NT)-G2AH3 C·1 2 Package with 10 units 20 92 641 0001 Package with 50 units 20 92 641 0002 Drawing Dimensions in mm RFID Transponder Ha-VIS RFID Transponder Passive UHF Transponder Ha-VIS RFID LT 89 (NT)-G2AH3 Technical characteristics Frequency range 860 MHz ... 960 MHz Protocol EPC C1Gen2 Chip Alien Higgs 3 Memory 512 bit Lesereichweite (Freiraum, 2 W ERP) ≥ 2.5 m Abmessungen (B x H x T) 41 x 11 x 5 mm Degrees of protection IP 64 / IP 67 / IP 69K Temperature range Operational range (read) Operational range (write) Storage Mounting -50 °C ... +85 °C -50 °C ... +85 °C -65 °C ... +160 °C Adhesive film Colour Black Merkmale • Extremly robust and durable transponder for maintenance and life cycle applications in rough environments • Robust housing, resistant against chemicals • EPC C1 Gen2 compatible • Extended memory Identification Part number Drawing Dimensions in mm Passive UHF Transponder Ha-VIS RFID LT 89 (NT)-G2AH3 Package with 10 units 20 92 641 0101 Package with 50 units 20 92 641 0102 C·1 3 RFID Transponder Ha-VIS RFID Transponder Passive UHF Transponder Ha-VIS RFID SL 89 (MT)-G2AH3 Technical characteristics Frequency range 860 MHz ... 960 MHz Protocol EPC C1Gen2 Chip Alien Higgs 3 Memory 512 bit Lesereichweite (Freiraum, 2 W ERP) ≥ 4.0 m Abmessungen (B x H x T) 30 x 26 x 5 mm Degrees of protection IP 64 / IP 67 / IP 69K Temperature range Operational range (read) Operational range (write) Storage Mounting -50 °C ... +85 °C -50 °C ... +85 °C -65 °C ... +130 °C M3 screws or rivets with washers Slot dimensions 140 x 6 mm Colour Black Merkmale • Slot tag for integration in metallic objects like barrels, pallets or extruded profiles (slot dimensions 140 x 6 mm) • Extremly high mechanical protection • EPC C1 Gen2 compatible • Extended memory Identification Part number Passive UHF Transponder Ha-VIS RFID SL 89 (MT)-G2AH3 C·1 4 Package with 10 units 20 92 641 0601 Package with 50 units 20 92 641 0602 Drawing Dimensions in mm RFID Transponder Ha-VIS RFID Transponder Passive UHF Transponder Ha-VIS RFID CT 89 (NT)-G2UCXM Technical characteristics Frequency range 860 MHz ... 960 MHz Protocol EPC C1Gen2 Chip NXP UCODE G2XM Memory 512 bit Lesereichweite (Freiraum, 2 W ERP) ≥ 5.0 m Abmessungen (B x H x T) 165 x 51 x 2 mm Degrees of protection IP 64 / IP 67 / IP 69K Temperature range Operational range (read) Operational range (write) Storage Mounting -40 °C ... +85 °C -40 °C ... +85 °C -50 °C ... +85 °C M4 screws or rivets with washers Colour Black Merkmale • Identification of reinforced concrete parts for the building industry • Integration in concrete floors for location of storage areas • High read range also in wet materials • Robust housing • EPC C1 Gen2 compatible • Extended memory Identification Part number Drawing Dimensions in mm Passive UHF Transponder Ha-VIS RFID CT 89 (NT)-G2UCXM Package with 10 units 20 92 641 0301 Package with 50 units 20 92 641 0302 C·1 5 RFID Transponder Ha-VIS RFID Transponder Passive UHF Transponder Ha-VIS RFID CF 89 (NT)-G2UCXM Technical characteristics Frequency range 860 MHz ... 960 MHz Protocol EPC C1Gen2 Chip NXP UCODE G2XM Memory 512 bit Lesereichweite (Freiraum, 2 W ERP) ≥ 5.0 m Abmessungen (B x H x T) 108 x 48 x 2 mm Degrees of protection IP 64 / IP 67 / IP 69K Temperature range Operational range (read) Operational range (write) Storage Mounting -40 °C ... +85 °C -40 °C ... +85 °C -50 °C ... +85 °C M4 screws or rivets with washers Colour Black Merkmale • Identification of reinforced concrete parts for the building industry • Integration in concrete floors for location of storage areas • High read range also in wet materials • Robust housing • EPC C1 Gen2 compatible • Extended memory Identification Part number Passive UHF Transponder Ha-VIS RFID CF 89 (NT)-G2UCXM C·1 6 Package with 10 units 20 92 641 0401 Package with 50 units 20 92 641 0402 Drawing Dimensions in mm RFID Transponder Ha-VIS RFID Transponder Passive UHF Transponder Ha-VIS RFID CS 89 (NT)-G2UCXM Technical characteristics Frequency range 860 MHz ... 960 MHz Protocol EPC C1Gen2 Chip NXP UCODE G2XM Memory 512 bit Lesereichweite (Freiraum, 2 W ERP) ≥ 5.0 m Abmessungen (B x H x T) 108 x 27 x 2 mm Degrees of protection IP 64 / IP 67 / IP 69K Temperature range Operational range (read) Operational range (write) Storage Mounting -40 °C ... +85 °C -40 °C ... +85 °C -50 °C ... +85 °C M4 screws or rivets with washers Colour Black Merkmale • Identification of reinforced concrete parts for the building industry • Integration in concrete floors for location of storage areas • High read range also in wet materials • Robust housing • EPC C1 Gen2 compatible • Extended memory Identification Part number Drawing Dimensions in mm Passive UHF Transponder Ha-VIS RFID CS 89 (NT)-G2UCXM Package with 10 units 20 92 641 0501 Package with 50 units 20 92 641 0502 C·1 7 RFID Transponder Ha-VIS RFID Transponder C·1 8 Notes Ha -VIS RFID Reader Page Ha-VIS RFID RF-R500 Introduction and features C.2 2 Technical characteristics C.2 3 Ha-VIS RFID RF-R500-c-EU C.2 5 Ha-VIS RFID RF-R500-p-EU C.2 6 Ha-VIS RFID RF-R500-c-US C.2 7 Ha-VIS RFID RF-R500-p-US C.2 8 RFID Reader Contents C·2 1 RFID Reader Ha-VIS RFID RF-R500 Reader - Introduction and features RFID Reader Ha-VIS RFID RF-R500 General description Features The Ha-VIS® RFID RF-R500 is a high performance UHF RFID long range reader. It supports up to 4 antennas simultaneously reducing costs and easing integration of RFID technology. Due to its robust aluminium housing and up to IP 64, it is ideally suited for industrial applications. The reader was designed for very high reading sensitivity combined with impressive reading and data processing speed. The reader brings wireless RFID communication into industrial environments. The reader can directly control lamps, sirens or gates via the integrated GPIOs. • Up to 4 antenna • Up to 4 W transmitting power • Impressive bulk reading • Power over Ethernet (PoE) • Up to IP 64 with an optional protection cap (otherwise IP 53) • 5 hardware interfaces: Ethernet, RS 232, RS 485, USB, and a USB port for external memory Advantages Application fields • High receiver sensitivity for enlarged and homogeneous tag detection range • Smart infrastructure • Logistics • Metal housing • Integrated antenna multiplexer • Simple installation C·2 2 • Versatile hardware and software configuration • Asset management • Machinery Ha-VIS RFID RF-R500 Reader Technical characteristics Transponder protocol EPC Gen2 (ISO 18000-6-c) Antenna connection 4x SMA connector (50 Ohm); Reader internally multiplexed Frequency area 860 MHz ... 960 MHz (depending on specific reader) Radio license Europe EN 302 208 Supply voltage on antenna outputs 24 V DC / 200 mA (Ha-VIS RFID RF-R500-p only) Interfaces • Ethernet (TCP/IP) 10/100 Mbit/s; Full Spec. 802.3 • RS 232 / RS 485 • USB / USB-Port for WLAN dongle or external memory Inputs 5 Optocoupler (max. 24 V DC / 20 mA) Outputs • 2 Optocoupler (24 V DC / 30 mA) • 3 Relays (24 V DC / 1 A) RFID Reader UHF RFID antenna interface LED Diagnosis 8 LEDs (from left to right) • Run • Host communication • Warning • Input / output • Antenna 1 • Antenna 2 • Antenna 3 • Antenna 4 Performance Max.Operating Distance Up to 16 m, depending on kind of transponder & environmental conditions Protocol Modi • HARTING Host Mode • Scan Mode • Notification Mode • Buffered Read Mode Power Supply Current consumption max. 2 A Design features Material of housing Aluminium, powder coated Dimensions (W x H x D) 260 x 157 x 68 mm Weight 2000 g Degree of protection acc. to DIN 60 529 IP 64 (with protection cap) / IP 53 (without protection cap) Installation on DIN rail DIN rail mounting kit (optional accessories) C·2 3 Ha-VIS RFID RF-R500 Reader Technical characteristics RFID Reader Environmental conditions Operating temperature -25 °C ... +50 °C Storage temperature -25 °C ... +85 °C Relative humidity 5 % ... 95 % (non-condensing) Vibration EN 60 068-2-6 10 Hz ... 150 Hz: 0.075 mm / 1 g Shock EN 60 068-2-27 Acceleration: 30 g Norms & Safety Radio license • EN 302 208 • FCC 47 FCR Part 15 • IC RSS-GEN, RSS-210 EMC EN 301 489 Low voltage EN 60 950 Human Exposure EN 50 364 RoHS compliant RF diagnosis • RF Channel monitoring • Antenna SWR control • Internal overheating control Operating system Linux (Kernel 3.x.x) 64 MB RAM, 256 MB Flash Others • Anticollision function • Real time clock • RSSI Software C·2 4 Demo- and configuration software Ha-VIS RFID config Minimal hardware requirements • Personal computer IBM PC Pentium III 1000 MHz or faster recommended • Windows XP® (32 Bit) with 256 MB RAM or Windows® 7 (32 / 64 Bit) • Hard disk with minimum free 30 MB memory space • Windows® compatible mouse • Windows® compatible super VGA graphic card (800 x 600) (1024x768 recommended) RFID Reader Ha-VIS RFID RF-R500 Reader UHF RFID Long Range Reader Ha-VIS RFID RF-500-c-EU Technical characteristics Antenna connection 4x SMA connector (50 Ohm); reader internally multiplexed Transmitting Power max. 2 W Frequency area 865 MHz ... 870 MHz Radio license EN 302 208 Inputs 5 optocoupler (max. 24 V DC / 20 mA) Outputs • 2 optocoupler (24 V DC / 30 mA) • 3 relays (24 V DC / 1 A) Bulk-Read capability < 150 transponders/sec Max.Operating Distance < 10 m, depending on kind of transponder & environmental conditions Power supply +24 V DC (±5 %) Current consumption max. 2 A Dimensions (W x H x D) 260 x 157 x 68 mm Weight 2000 g Degree of protection acc. to DIN 60 529 IP 64 (with protection cap) / IP 53 (without protection cap) Operating temperature -25 °C ... +50 °C Identification Part number Drawing Dimensions in mm UHF RFID long range Reader Ha-VIS RFID RF-500-c-EU 2 W transmission power EU version 20 91 104 1103 C·2 5 RFID Reader Ha-VIS RFID RF-R500 Reader UHF RFID Long Range Reader Ha-VIS RFID RF-500-p-EU Technical characteristics Antenna connection 4x SMA connector (50 Ohm); reader internally multiplexed Transmitting Power max. 4 W / max. 1 W in PoE modi Frequency area 865 MHz ... 870 MHz Radio license EN 302 208 Supply voltage on antenna outputs 24 V DC / 200 mA Inputs 5 optocoupler (max. 24 V DC / 20 mA) Outputs • 2 optocoupler (24 V DC / 30 mA) • 3 relays (24 V DC / 1 A) Bulk-Read capability > 150 transponders/sec Max.Operating Distance Up to 16 m, depending on kind of transponder & environmental conditions Power supply +24 V DC (±5 %) / Power over Ethernet (PoE) Current consumption max. 2 A Dimensions (W x H x D) 260 x 157 x 70 mm Weight 2000 g Degree of protection acc. to DIN 60 529 IP 64 (with protection cap) / IP 53 (without protection cap) Operating temperature -25 °C ... +50 °C Identification Part number UHF RFID long range Reader Ha-VIS RFID RF-500-p-EU 4 W transmission power with PoE EU version C·2 6 20 91 104 1101 Drawing Dimensions in mm RFID Reader Ha-VIS RFID RF-R500 Reader UHF RFID Long Range Reader Ha-VIS RFID RF-500-c-US Technical characteristics Antenna connection 4x SMA connector (50 Ohm); reader internally multiplexed Transmitting Power max. 2 W Frequency area 902 MHz ... 928 MHz Radio license FCC 47 CFR Part 15; IC RSS-GEN; IC RSS -210 Inputs 5 optocoupler (max. 24 V DC / 20 mA) Outputs • 2 optocoupler (24 V DC / 30 mA) • 3 relays (24 V DC / 1 A) Bulk-Read capability < 150 transponders/sec Max.Operating Distance Up to 10 m, depending on kind of transponder & environmental conditions Power supply +24 V DC (±5 %) Current consumption max. 2 A Dimensions (W x H x D) 260 x 157 x 68 mm Weight 2000 g Degree of protection acc. to DIN 60 529 IP 64 (with protection cap) / IP 53 (without protection cap) Operating temperature -25 °C ... +50 °C Identification Part number Drawing Dimensions in mm UHF RFID long range Reader Ha-VIS RFID RF-500-c-US 2 W transmission power US version 20 91 104 1104 C·2 7 RFID Reader Ha-VIS RFID RF-R500 Reader RFID Reader Ha-VIS RFID RF-500-p-US Technical characteristics Antenna connection 4x SMA connector (50 Ohm); reader internally multiplexed Transmitting Power max. 4 W / max. 1 W in PoE modi Frequency area 902 MHz ... 928 MHz Radio license FCC 47 CFR Part 15; IC RSS-GEN; IC RSS -210 Supply voltage on antenna outputs 24 V DC / 200 mA Inputs 5 optocoupler (max. 24 V DC / 20 mA) Outputs • 2 optocoupler (24 V DC / 30 mA) • 3 relays (24 V DC / 1 A) Bulk-Read capability > 150 transponders/sec Max.Operating Distance Up to 16 m, depending on kind of transponder & environmental conditions Power supply +24 V DC (±5 %) / Power over Ethernet (PoE) Current consumption max. 2 A Dimensions (W x H x D) 260 x 157 x 70 mm Weight 2000 g Degree of protection acc. to DIN 60 529 IP 64 (with protection cap) / IP 53 (without protection cap) Operating temperature -25 °C ... +50 °C Identification Part number UHF RFID long range Reader Ha-VIS RFID RF-500-p-US 4 W transmission power with PoE US version C·2 8 20 91 104 1102 Drawing Dimensions in mm Ha -VIS RFID Antennas Contents Page Introduction and features C.3 2 Technical characteristics C.3 3 Ha-VIS RF-ANT-WR30-EU C.3 4 RFID Antennas UHF Wide range antennas Ruggedized UHF Wide range antennas Introduction and features C.3 5 Technical characteristics C.3 6 Ha-VIS RF-ANT-WR80-30-EU C.3 7 Ha-VIS RF-ANT-WR80-30-US C.3 8 C·3 1 Ha-VIS RF-ANT-WR30 - Introduction and features UHF Wide range antenna Ha-VIS RF-ANT-WR30 RFID Antennas General description Features • UHD RFID wide range antenna • Reading range up to 16 m (depending upon tag properties, environment and requirements) • Compact construction • Optimized for portal applications • Suitable for industrial environments • High IP 65 protection class • Suitable for outdoor usage Advantages Application fields • Smart infrastructure • Gate applications • Asset management • Machinery C·3 2 Ha-VIS RF-ANT-WR30 Polarization circular Axial ratio typ. 1 dB VSWR < 1.2:1 Impedance 50 Ohm Front-to-back ratio >18 dB Far field half-power beam width 69° Connection TNC socket Protection class IP 65 Weight approx. 1.7 kg Dimensions (WxDxH) 270 x 270 x 45 mm RFID Antennas Technical characteristics Material Antenna cover tough, weather-resistant polymer blend colour RAL 7045 Chassis Aluminium Seals thermoplastic elastomer Installation four M5 drill holes 100 x 100 mm Temperature range storage -40 °C … +85 °C ambient -20 °C … +55 °C C·3 3 Ha-VIS RF-ANT-WR30 RFID Antennas UHF Wide range antenna Ha-VIS RF-ANT-WR30-EU Technical characteristics Frequency range 865 MHz ... 870 MHz Antenna gain 8.5 dBic @ 866 MHz Max. radiated power (ETSI EN 302 208) 2 W ERP Identification Part number UHF Wide range antenna Ha-VIS RF-ANT-WR30-EU EU version C·3 4 20 93 201 0102 Drawing Dimensions in mm Ha-VIS RF-ANT-WR80-30 - Introduction and features Ruggedized UHF Wide range antenna Ha-VIS RF-ANT-WR80-30 Features • UHD RFID wide range antenna • Reading range up to 16 m (depending upon tag properties, environment and requirements) RFID Antennas General description • Compact design for ruggedized environmental applications • Optimized for portal applications • Different half power beam widths in azimuth and elevation plane • Suitable for industrial environments • High IP 65 protection class • Suitable for outdoor usage Advantages Application fields • Smart infrastructure • Gate applications • Asset management C·3 5 Ha-VIS RF-ANT-WR80-30 RFID Antennas Technical characteristics Polarization circular Axial ratio < 2 dB VSWR < 1.2:1 Impedance 50 Ohm Front-to-back ratio >20 dB Half-power beam width 30° vertical 70° horizontal Connection N (female) Protection class IP 65 Weight approx. 3.7 kg Dimensions (WxDxH) 557 x 262 x 59 mm Material Antenna cover fiberglass radome (UV resistance), gray Chassis stainless steel Plate patch brass tin-plated Gasket thermoplastic elastomer Installation four M5 drill holes 100 x 100 mm Temperature range C·3 6 storage -40 °C … +85 °C ambient -20 °C … +65 °C Ha-VIS RF-ANT-WR80-30 Ruggedized UHF Wide range antenna Ha-VIS RF-ANT-WR30-EU Frequency range 865 MHz ... 870 MHz Antenna gain 11.0 dBic Max. radiated power (ETSI EN 302 208) 2 W ERP Identification Part number Drawing RFID Antennas Technical characteristics Dimensions in mm Ruggedized UHF Wide range antenna Ha-VIS RF-ANT-WR80-30-EU EU version 20 93 201 0203 C·3 7 Ha-VIS RF-ANT-WR80-30 RFID Antennas Ruggedized UHF Wide range antenna Ha-VIS RF-ANT-WR30-US Technical characteristics Frequency range 902 MHz ... 928 MHz Antenna gain 10.5 dBic Max. input power (FCC 15.247) 700 mW (28.5 dBm) conducted for a max. radiated power of 4 W EIRP Identification Part number Ruggedized UHF Wide range antenna Ha-VIS RF-ANT-WR80-30-US US version C·3 8 20 93 201 0204 Drawing Dimensions in mm Ha -VIS RFID Cables and Acessories Contents Page Accessories Ha-VIS Coax, SMA-TNC, RG58 C.4 2 Ha-VIS Coax, SMA-TNC, LL240flex C.4 3 Ha-VIS Coax, SMA-N, LL240flex C.4 4 Ha-VIS Coax, TNC-N, RG213 C.4 5 C.4 6 Cables + Accessories Ha-VIS RFID Antenna cables C·4 1 Ha-VIS RFID Cabling Antenna cables Ha-VIS Coax, SMA-TNC, RG58 Low cost coax cable, left side TNC connector, right side SMA connector Cables + Accessories IP 20 IP 65 / IP 67 to IP 20 IP 65 / IP 67 Cat. 5 Cat. 6 Connector types left side TNC connector, right side SMA connector Sheath material Outer diameter Cable weight Minimum bend radius (single bend) Operating temperature range Impedance Attentuation PE, Black 4.95 mm 35 kg/km 25 mm -20 °C … +70 °C 50 Ohm 63 dB/100 m @ 800MHz (depending on application and environmental conditions) Standard lengths 3m Colour Black Identification Part number Ha-VIS Coax, SMA-TNC, RG58 Black Length   3.0 m C·4 2 20 93 204 0101 Drawing Dimensions in mm Ha-VIS RFID Cabling Antenna cables Ha-VIS Coax, SMA-TNC, LL240 flex Low loss coax cable, left side TNC connector, right side SMA connector IP 65 / IP 67 to IP 20 IP 65 / IP 67 Cat. 5 Cat. 6 Connector types left side TNC connector, right side SMA connector Sheath material Outer diameter Cable weight Minimum bend radius (single bend) Operating temperature range Impedance Screening effectiveness Attentuation PE, Black 5.4 ± 0.2 mm 39 kg/km 35 mm -40 °C … +80 °C 50 Ohm > 75 dB (30 ... 1000 MHz) 28 dB/100 m @ 800MHz (depending on application and environmental conditions) Cables + Accessories IP 20 Standard lengths 3 m / 10 m Colour Black Identification Part number Ha-VIS Coax, SMA-TNC, LL240flex Length   3.0 m Length 10.0 m Drawing Dimensions in mm Black 20 93 204 0102 20 93 204 0103 C·4 3 Ha-VIS RFID Cabling Antenna cables Ha-VIS Coax, SMA-N, LL240 flex Low loss coax cable, left side N connector, right side SMA connector Cables + Accessories IP 20 IP 65 / IP 67 to IP 20 IP 65 / IP 67 Cat. 5 Cat. 6 Connector types left side N connector, right side SMA connector Sheath material Outer diameter Cable weight Minimum bend radius (single bend) Operating temperature range Impedance Screening effectiveness Attentuation PE, Black 5.4 ± 0.2 mm 39 kg/km 35 mm -40 °C … +80 °C 50 Ohm > 75 dB (30 ... 1000 MHz) 28 dB/100 m @ 800MHz (depending on application and environmental conditions) Standard lengths 3 m / 10 m Colour Black Identification Part number Ha-VIS Coax, SMA-N, LL240flex Black Length   3.0 m Length 10.0 m C·4 4 20 93 204 0104 20 93 204 0105 Drawing Dimensions in mm Ha-VIS RFID Cabling Antenna cables Ha-VIS Coax, TNC-N, RG213 Low loss ruggedized coax cable, left side N connector, right side TNC connector IP 65 / IP 67 to IP 20 IP 65 / IP 67 Cat. 5 Cat. 6 Connector types left side N connector, right side TNC connector Sheath material Outer diameter Cable weight Minimum bend radius (single bend) Operating temperature range Impedance Screening effectiveness Attentuation PVC, Black 10.3 ± 0.2 mm 161.7 kg/km 35 mm -55 °C … +85 °C 50 Ohm > 55 dB (100 ... 900 MHz) 22 dB/100 m @ 800MHz (depending on application and environmental conditions) Cables + Accessories IP 20 Standard lengths 3 m / 10 m Colour Black Optional accessory Identification SMA-TNC adapter, necessary to connect to Ha-VIS RF-R500 Part number Drawing Dimensions in mm Ha-VIS Coax, TNC-N, RG213 Black Length   3.0 m Length 10.0 m 20 93 204 0106 20 93 204 0107 C·4 5 HARTING Accessories Identification Part number DIN rail Mounting kit Mounting kit for Ha-VIS RF-R500 for easy mounting on a DIN rail 20 93 102 0201 Cables + Accessories Inclusive necessary screws Protection cap for Ha-VIS RF-R500 Protection cap for increased degree of protection from IP 53 to IP 64 Easy assembly PG openings for different cable diameters 20 93 901 0101 Adapter SMA-TNC necessary adapter to connect Ha-VIS coax RG213 cords to the Ha-VIS RF-R500 C·4 6 20 93 204 0301 Drawing Dimensions in mm Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: HARTING: 20932040104 20911041104 20926410401 20926410601 20932040107 20926410302 20926410502 20926410501 20926410402 20932010204 20932040105 20939010101 20932040301 20926410602 20932040101 20932010102 20932040102 20931020201 20911041102 20932040103 20911041103 20911041101 20932010203 20926410301 20932040106
20932010203 价格&库存
很抱歉,暂时无法提供与“20932010203”相匹配的价格&库存,您可以联系我们找货
