SP-AN-04
SP-AN-04
    SKYETEK
    M2/M4HFANTENNA
SP-AN-04 数据手册
HF Antenna rfid enabled skyetek OEM HF 13.56 MHz Antenna FEATURES: Product Overview • Compatible with nearly all 13.56 MHz RFID readers The SkyeTek RFID HF Antenna for OEMs allows you to quickly and costcost effectively supplement your RFID application by adding additional reading points. For RFID systems in the HF frequency band (13.56 MHz), this can save significant development and production costs. • Standard SMA connection BENEFITS: All antennas are equipped with SMA female male connectors for easy integration integr and have 50 Ohms impedance. • Easy to integrate Applications • Can extend range of some RFID readers read range needs to be achieved than can be realized with an internal antenna, or • OEM Ready any application that uses a multiplexer to connect multiple antennas to one RFID The SkyeTek HF Antenna can be used for any OEM applications application in which a larger reader. www.skyetek.com SkyeTek HF Antenna About Skyetek: SkyeTek delivers stand-alone and embedded reader solutions that make RFID work easily, reliably, and economically for enterprises and OEMs. SkyeTek offers a complete line of both HF (High Frequency, 13.56 MHz) and UHF (Ultra High Frequency, 860 - 960 MHz) readers that can be used in a multitude of unique applications. Contact Sales today to see how we can make RFID work for your application. SkyeTek is a privately held, venturebacked company headquartered in Denver, Colorado, with sales operations in North America, Europe and Asia. For more information, visit www.skyetek.com. Mechanical Specifications Operating Frequency 13.56 MHz RF Output Power 1.0 W Max Operating Temperature 0 to 55°C Physical Dimensions Width: 3.075 in (78.1 mm) Connector Type Storage Temperature Length: 3.500 in (88.9 mm) Height: 0.375 in (9.5mm) SMA female Impedance For more information: 50 Ohms 1525 Market Street, Ste 200 Weight Denver, Colorado 80202 USA -20 20 to 70°C 28g ph: 720.328.3425 www.skyetek.com Other Offerings from SkyeTek SkyeTek provides a variety of reader technology at both 13.56 MHz (HF) and ~900 MHz (UHF). The M1, also part of the SkyeModule HF line, is sl slightly larger than the M1-Mini Mini and adds 8 GPIO pins and native support for RS232 host interface. ReaderDNA, a comprehensive reference design, is available for component level integration of the technology including complete design files, BOM, and test fixt fixture. ReaderWare, an open-architected architected software suite residing on all SkyeTek’s modules, provides intelligence for th the RFID reader. The SkyeModule M9 is a low power, compact, UHF reader compatible with EPC and ISO transponders. All SkyeModules are controlled via the SkyeTek Protocol, a powerful but simple communication protocol that grants the user access to all features of an RFID transponder. Further, they have been designed with flexible and modular embedded software that allows one to select only the desi desired features. Copyright © 2012 SkyeTek, Inc. TagnosticTM, ReaderWareTM, and SkyeModuleTM are trademarks or registered trademarks of SkyeTek, Inc. All other trademarks or brand names are the properties of their respective holders. Features and specifications are subject to change without notice.
SP-AN-04 价格&库存
很抱歉,暂时无法提供与“SP-AN-04”相匹配的价格&库存,您可以联系我们找货
