USB-6EP-DEVKIT
USB-6EP-DEVKIT
    THINGMAGIC
    USB PRO RFID READER DEVELOPMENT
USB-6EP-DEVKIT 数据手册
ThingMagic USBPro RFID Reader UHF RAIN RFID Desktop Reader 97 mm L x 61 mm W x 25 mm H (3.8”L x 2.4” W x 1.0”H) The ThingMagic USBPro RFID Reader allows solutions developers to support applications that require desktop reading and writing of EPC Global Gen2 tags, as well as other protocols such as ISO18000-6B, IPx and AEI ATA (read only) through additional license. Based on ThingMagic’s M6e-Micro module, the USBPro RFID Reader is controlled and powered by a host P or laptop through a USB interface and supports autonomous operation. The USBPro RFID Reader is compatible with ThingMagic’s MercuryAPI application development tools, including Universal Reader Assistant, permitting rapid creation of solutions. USBPro supports a wide range of applications, including tag commissioning, manufacturing work in progress, document tracking, retail Point of Sale, and workflows for healthcare, events, and hospitality. Ordering Information Reader Development Kit USB-6EP USB-6EP-DEVKIT Tag / Transponder Protocols RFID Protocol Support EPC Gen2V2 ISO18000-63 standard ISO180006B, IPx, AEI ATA (read only) are available through additional license Regulatory FCC 47 CFR Ch. 1 Part 15, Industrie Canada RSS-21 0, ETSI EN 302 208 v3.1.1 (RED 2014/53/EU) Safety IEC 60950-1 (ed.2) US-17650-UL Power DC Power Required RF Interface Antenna Ports Internal antenna with an average gain of +1 dBi from 865-869MHz and 902-928MHz, External RP-SMA antenna connector RF Power Output Separate read and write levels (into the antenna) are command-adjustable from -5 dBm to 30 dBm* (1W), +/- 1.0 dBm accuracy with +20dBm default Frequency Regulatory Information Pre-configured for the following regions: FCC 902-928,917.4-927,917.5-922.5 MHz (Americas) ETSI 865.6-867.6 MHz, 869.85 MHz (EU) TRAI 865867 MHz (India) KCC 917-920.8 MHz (Korea) ACMA 920-926 MHz (Australia) SRRC-MII 920-925 MHz (P. R. China) MIC 916.7-920.9 MHz (Japan) Open (Customizable) 865-869 and 902-928 MHz Idle Power Consumption USB Micro-B connector, with removable six (6) foot cable with dual USB-A type plug Signaling USB 2.0 Input/Output Two I/O command controlled LEDs and two I/O command queried switches Protocol Command-response protocol protected by length field and 16-bit CRC Supplied interface cable terminates in two type-A plugs: one for power and signal, the second for additional power if needed 0.35 W max at idle (Power management modes can be used to reduce this to as little as 0.1 W) Environment Operating Temp. -40°C to +60°C* Storage Temp. -40°C to +85°C Architecture User Memory 16 kB Tag Buffer 200 tags Tag Read Rate 50 tags/second Tag Read Distance Up to 10 m (30 feet) with external antenna and up to 1.2 m (4 feet) depending on tag Sensitivity and orientation with internal Antenna with max RF power. Performance Data/Control Interface Physical DC Voltage: 4.5 to 5.5 VDC from USB cable DC Power: 6.2 W max *Duty cycle restrictions based on temperature, tx power >23dB © 2022 Novanta Inc. and its affiliated companies. All rights reserved. Rev 04262022
USB-6EP-DEVKIT 价格&库存
很抱歉,暂时无法提供与“USB-6EP-DEVKIT”相匹配的价格&库存,您可以联系我们找货
USB-6EP-DEVKIT
  • 1+7567.744691+980.28761
库存:15
