AS3911-DK-ST
AS3911-DK-ST
    AMSOSRAM(艾迈斯半导体)
    DEVELOPMENT SYSTEM AS3911
AS3911-DK-ST 数据手册
Application Note: General Purpose Demo Hardware Description AS3911 NFC Initiator / HF Reader IC www.ams.com Revision 1.04 / 2012/06/26 AS3911 – General Purpose Demo Hardware Description Table of Contents 1. Introduction ............................................................................................................................ 2 2. Hardware ............................................................................................................................... 2 2.1. Block diagram ............................................................................................................ 2 2.2. EMC and Power Supply Concept ............................................................................... 3 2.3. Digital Section (Microcontroller) ................................................................................. 4 2.3.1. 2.4. 3. Programming Header P1........................................................................................ 5 Analog Section ........................................................................................................... 6 2.4.1. Power concept ....................................................................................................... 7 2.4.2. Antenna stage ........................................................................................................ 7 2.4.3. Capacitive wake up ................................................................................................ 8 Measurement ......................................................................................................................... 8 3.1. Current consumption .................................................................................................. 8 3.2. Antenna stage ............................................................................................................ 9 3.3. Antenna stage ............................................................................................................ 9 3.4. Determination of the antenna resistor .......................................................................11 3.5. Determination of the antenna resistor .......................................................................12 3.6. Verification of the Q factor in the time domain ..........................................................14 3.7. Measurement with standard assembly of 2200 Ω .....................................................14 4. Layout recommendation ...................................................................................................... 16 5. PCB stack ............................................................................................................................ 16 6. Gerber top ........................................................................................................................... 17 7. Gerber bottom ..................................................................................................................... 17 8. Assembly top ....................................................................................................................... 18 9. Bill of material ...................................................................................................................... 19 Copyright ..................................................................................................................................... 22 Disclaimer ................................................................................................................................... 22 www.ams.com Revision 1.04 / 6/22/12 Page 1/22 AS3911 – General Purpose Demo Hardware Description 1. Introduction This application note describes the AS3911 general purpose demo board and its usage. The general purpose board is made for a flexible use; hence the digital part can be separated from the analog part. This enables fast software development since the analog part can be used out of the box. The analog section has several jumpers to allow a custom antenna and capacitive electrodes to be used. 2. Hardware 2.1. Block diagram The board includes a microcontroller with USB support, a LDO to supply the microcontroller and the HF reader IC AS3911. Figure 1: Blockdiagram of the demo board www.ams.com Revision 1.04 / 6/22/12 Page 2/22 AS3911 – General Purpose Demo Hardware Description 2.2. EMC and Power Supply Concept For EMC rejection due to the rectangular carrier field generation, ferrite beads are placed close to the supply with additional capacitors next to the connector. Figure 2: EMC and power Supply concept Since the worst case specification for USB-supply voltage is 4.5V, the supply voltage of the device might vary. AS3911 features an internal regulator that measures the voltage and adjusts the voltage on the output driver (i.e. the antenna driver) to 0.3V below the supply voltage. This adjustment assures that the digital noise on the antenna driver supply can be rejected and the voltage maximized. For evaluation purposes, the jumper P5 is placed. It can be used to apply an external voltage supply or measure the current of the reader IC. www.ams.com Revision 1.04 / 6/22/12 Page 3/22 AS3911 – General Purpose Demo Hardware Description 2.3. Digital Section (Microcontroller) Figure 3: Microcontroller schematic • The microcontroller is a PIC24 FJGB002 with internal USB. • Three pins (Pin 1, 2 and 3 of the microcontroller) are used to select different board versions. • Four diodes (D5-D8) display the various conditions of the board. • The connector P2 can be used as an alternative connection to either an external microcontroller or to connect to a new developed analog system of AS3911. The selection can be done by unmounting the coupling resistors (R13-17). www.ams.com Revision 1.04 / 6/22/12 Page 4/22 AS3911 – General Purpose Demo Hardware Description 2.3.1. Programming Header P1 P1 is the programming header for the microchip controller. The pin order on the header P1 is exactly the same as used by the microchip tool chain. Therefore no special adapter is needed. Figure 4: Microcontroller schematic Pin 1 of programmer tool www.ams.com Revision 1.04 / 6/22/12 Page 5/22 AS3911 – General Purpose Demo Hardware Description 2.4. Analog Section The following schematic shows the analog section incl. AS3911 and its external components. Figure 5: Analog schematic www.ams.com Revision 1.04 / 6/22/12 Page 6/22 AS3911 – General Purpose Demo Hardware Description This setup is made to demonstrate almost all the capabilities of AS3911. The salient features are: • Differential antenna • Capacitive wakeup (possibility to attach external electrodes) • Antenna tuning trimming capacitors • 27MHz Crystal • Supply noise rejection • High sensitivity • Low impedance driver stage 2.4.1. Power concept AS3911 features an internal LDO that needs to be decoupled with capacitors of 2.2 µF and 10 nF. These pins are: • AGD (analogue ground) • VSP_D (to supply the logic of AS3911) • VSP_A (to supply the analog part of AS3911) • VSP_RF (to supply the driver stage of AS3911) AS3911 contains an internal level shifter that enables the connection to a microcontroller with different VDD than AS3911. Pin 1 should be connected to the same voltage as the supply of the microcontroller. GND as well as the supply line are connected with a ferrite bead to reject the EMC disturbances caused by the HF driver. 2.4.2. Antenna stage The antenna stage consists of a two stage filter and a matching network. The two stage filter rejects higher harmonics of the 13,56 MHz carrier. Since inductors are non-ideal components and the self-resonant frequency of the second coil is around 400 MHz, a two staged filter is implemented. www.ams.com Revision 1.04 / 6/22/12 Page 7/22 AS3911 – General Purpose Demo Hardware Description The first stage has a corner frequency above 200 MHz and will reduce harmonics at higher frequencies. The second stage has a corner frequency below 10 MHz and will reject frequencie s in the lower frequency band. The matching network follows the filter and adapts the power from the driver to the antenna. The tuning network consists of external capacitors and chip internal switches. In case the switches are open, the antenna voltage is directly applied to the input pin of the chip. Since the expected voltage of the antenna can be high, additional capacitors for voltage limitation can be applied. The AS3911 can accept voltages up to 30V on its antenna tuning pins. The input pins are connected by a capacitive divider. The voltage on these pins should be less than 3.3 Volt. 2.4.3. Capacitive wake up The capacitive wakeup comprises two pins that are each connected to an electrode. They are protected against ESD with a gas discharge element. Since these pins can also be used as test outputs, an additional UFL connector is mounted. 3. Measurement 3.1. Current consumption The measurement is performed across the AS3911 supply jumper P5. AS3911 working condition Current consumption in mA After startup 7.58 en=1, rx_en=0, tx_en=0 en=1, rx_en=1, tx_en=0 14.97 en=1, rx_en=1, tx_en=1 150 en=0, rx_en=0, tx_en=0, wu=1 0.002 www.ams.com Revision 1.04 / 6/22/12 Page 8/22 AS3911 – General Purpose Demo Hardware Description 3.2. Antenna stage Used equipment: • Network Analyser HP 8753C Network Analyser • Parameter test set 85047A Test set 3.3. Antenna parameter measurement The parameter measurements are done in the following sequence: 1. Start with the measurement of the serial inductance and the serial resistor at a frequency that is far off the self-resonance of the antenna. The chosen frequency is 1MHz. @ 1 MHz: LPC = 940 nH RSDC = 470 mOhm 2. Measurement of the self-resonance (point at which the impedance is real) => fres ~ 59 MHz Rres = 5000 Ohm Using the inductance values measured at 1 MHz, the resonance capacitance can be calculated with the formula: C 1 (2    f res )  LPC 2  1  7.74 pF (2    59MHz) 2  940nH The value of the parallel resistor has to be converted from the self -resonance to the working frequency. The main reason for that conversion is the skin effect of the antenna. A correction factor can be given by: K www.ams.com f res 59   2,085 f tune 13,56 Revision 1.04 / 6/22/12 Page 9/22 AS3911 – General Purpose Demo Hardware Description Rres2 can then be calculated as: Rres2 = K ⋅ R res ≅ 10.4 kΩ All antenna components are now known and a replacement for the antenna circuit can be drawn. The serial resistor of the coil can be converted with the approximation formula of the Q -factor Q L RSDC RPDC  L 2   RP DC   14k L RSDC The complete resistance will thus be a parallel connection of the resistor due to the DC component and the self-resonance component. RPC  RPDC  Rres 2  6.02k RPDC  Rres 2 The values for the wanted resonance circuit are therefore: • RPC =6.02 kΩ • CPC= 7.74 pF • LPC= 940 nH www.ams.com Revision 1.04 / 6/22/12 Page 10/22 AS3911 – General Purpose Demo Hardware Description 3.4. Determination of the antenna resistor The bandwidth – time product and the definition of the quality factor Q results in the following equations: B T  1 ; Q  f res B  Q  f res  T  Q  13,56MHz  3s  41 The time T is defined by the lowest data rate of the ISO 14443 standard, 106kbits/s: For the current board it is set to 20. The parallel target resistor can then be calculated as: RT  Q  L RT  20  2    13MHz  940nH  1601 Taking the parasitic resistor RPC from the antenna into account, the effective resistance can be calculated to RP  R PC RT 6020 1601   2181 R PC  RT 6020  1601 The next available value is 2200Ω. www.ams.com Revision 1.04 / 6/22/12 Page 11/22 AS3911 – General Purpose Demo Hardware Description 3.5. Determination of the matching network • The matching is done from the driver resistor towards the antenna impedance. • The driver resistor can be assumed with 2Ω • Converting the antenna parameters into single-ended ones for the Smith chart: Parallel target antenna resistor: RT/2 = 800 Ω Antenna coil inductance LP/2 = 470 nH Antenna coil capacitance 2*CP = 15,5 pF The matching was done with ADS (Advanced Design System): www.ams.com Revision 1.04 / 6/22/12 Page 12/22 AS3911 – General Purpose Demo Hardware Description According to the simulations, the parallel capacitor should be 86 pF/2 (because of the conversion from single-ended to differential). The procedure of splitting up this 43 pF capacitance is shown in the excel sheet “PCD_AntennaMatching_V1”. www.ams.com Revision 1.04 / 6/22/12 Page 13/22 AS3911 – General Purpose Demo Hardware Description 3.6. Verification of the Q factor in the time domain The resonance circuit envelope can be calculated with an exponential function Falling edge: t  2    fc   U f  e   exp   t  Q   Rising edge: t 2   fc    U r  1  e   1  exp   t  Q   Thus if the time constant (37% of the maximum amplitude) is known, the Q factor is calculated to: QB    2    f c 3.7. Measurement with standard assembly of 2200 Ω • TF=310 ns • QF=17 www.ams.com Revision 1.04 / 6/22/12 Page 14/22 AS3911 – General Purpose Demo Hardware Description • With TR=205 ns • QR=26 www.ams.com Revision 1.04 / 6/22/12 Page 15/22 AS3911 – General Purpose Demo Hardware Description 4. Layout recommendation  Use a solid ground plane under the chip and thermal vias under the chip that are being used to dissipate the heat of and enable a low ohmic connection of the exposed pad to the ground plane.  Take care that the decoupling capacitors of the LDO are close to the chip. Use thick wires for the decoupling tracks and place the 10nF capacitor closest to the chip.  Use a symmetric layout for the antenna stage  Do not cross digital lines with analog lines.  Take care on the signals VSN_RF, VSP_RF and the two output pins RFO1 and RFO2. These pins build up the internal driver stage. Tracks on those four pins shall be short and ground connections must be solid. 5. PCB stack The PCB stack is made of a two layer PCB with 1.6 mm core materia l and 35micro (43 micro final ) copper. www.ams.com Revision 1.04 / 6/22/12 Page 16/22 AS3911 – General Purpose Demo Hardware Description 6. Gerber top 7. Gerber bottom www.ams.com Revision 1.04 / 6/22/12 Page 17/22 AS3911 – General Purpose Demo Hardware Description 8. Assembly top www.ams.com Revision 1.04 / 6/22/12 Page 18/22 AS3911 – General Purpose Demo Hardware Description 9. Bill of material Part Info Reference Distributor Distributor Number count Integrated Circuits (IC) AS3911 AS1 1 AS1360 U2 1 PIC27FJ64GB002 U3 1 SMD resistor 10k R1, R2, R4, R5, R7, R18, R20, R100 Digikey 0R R6,R29 Digikey 220R R8, R9, R10, R11, R12, R13, R14, R15, R16, R17 Digikey 311-10KGRTR-ND 8 311-0.0JRTR-ND 2 P220GTR-ND 10 Digikey RMCF0402JT470RTRND 5 470R R19, R23, R24, R25, R26 27R R21, R22 Digikey 311-27JRTR-ND 2 330R R27 Digikey 311-330JRTR-ND 1 2k2 R28 Digikey 311-2.2KJRTR-ND 1 10u C1,C4,C10 Digikey 445-1371-2-ND 3 10p C2,C3 Digikey 1u C5,C6 Digikey 587-2834-2-ND 2 10n C7, C15, C18, C24, C29, C30 Digikey 311-1042-2-ND 6 100n C8, C9 Digikey 478-1239-2-ND 2 18p C11, C12 Digikey 445-1238-2-ND 4 8p2 C13, C16 Digikey 511-1029-2-ND 2 2u2 C14, C17, C21, C32, C33 Digikey 587-2983-2-ND 5 6p8 C20, C34 Digikey 445-4887-2-ND 2 SMD capacitors www.ams.com Revision 1.04 / 6/22/12 2 Page 19/22 AS3911 – General Purpose Demo Hardware Description 12p C23, C35 Digikey 311-1016-2-ND 2 100p C25 Digikey 311-1024-2-ND 1 27p C27, C36 Digikey 311-1019-2-ND 2 56p C31, C37 Digikey 311-1022-2-ND 2 47p C38, C43 Digikey 311-1021-2-ND 2 470p C44, C47 Digikey 311-1028-2-ND 2 680p C45, C46 Digikey 511-1068-2-ND 2 330p C48, C49 Digikey 587-1217-2-ND 2 6p8 C50 Digikey 445-5039-2-ND 1 100p C51, C54 Digikey 445-1281-2-ND 2 10p C52, C53 Digikey 399-1049-2-ND 2 10n L4,L5 Digikey 445-1492-2-ND 2 220n L7,L8 Digikey 490-5669-2-ND 2 Ferritbead L1, L2, L3, L6, L9 Digikey 587-1911-2-ND 5 24V D1, D2, D4 Farnell 1470613 3 Zener D3 Digikey 641-1068-2-ND 1 D5,D6,D7,D8 Digikey 754-1104-2-ND 4 Q1 Digikey 490-5581-2-ND 1 SMD inductors SMD diodes SMD LED LED_LUMEX Oscillator 27.12MHz Mechanical components Header 2 P5 USB_MINI_B U1 1 Digikey H2959TR-ND 1 Not Used www.ams.com Revision 1.04 / 6/22/12 Page 20/22 AS3911 – General Purpose Demo Hardware Description U FL Socket Surface Mount P3, P4 2 Header 8H P1, P2 2 8MHz Y1 1 MHDR1X2 P6, P7 2 Header 3 P8 1 Plug T1 1 Plug T2, T3, T4, T5 4 dnp C19, C22, C26, C28, C39, C40, C41, C42 8 dnp R3 1 CSA20-141N DNP U4, U5 2 Tolerance if not other specified Capacitor NP0/COG 2% Capacitor X7R: 10% Capacitor Y5V: +80% 20% Tantalum 20% Resistor 5% Inductivity 5% Version History Version Originator Change log 1.00 tlu Initial Version 1.02 tlu Changed load cap on 27 MHz crystal, BOM 1.03 mram Changing of the ams corporate design 1.04 mram Correction of chapters 3.4 & 3.5 www.ams.com Revision 1.04 / 6/22/12 Page 21/22 AS3911 – General Purpose Demo Hardware Description Copyright Copyright © 1997-2012, ams AG, Tobelbader Strasse 30, 8141 Unterpremstaetten, Austria-Europe. Trademarks Registered ®. All rights reserved. The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the copyright owner. All products and companies mentioned are trademarks or registered trademarks of their respective companies. Disclaimer Devices sold by ams AG are covered by the warranty and patent indemnification provisions appearing in its Term of Sale. ams AG makes no warranty, express, statutory, implied, or by description regarding the information set forth herein or regarding the freedom of the described devices from patent infringement. ams AG reserves the right to change specifications and prices at any time and without notice. Therefore, prior to designing this product into a system, it is necessary to check with ams AG for current information. This product is intended for use in normal commercial applications. Applications requiring extended temperature range, unusual environmental requirements, or high reliability applications, such as military, medical life-support or life sustaining equipment are specifically not recommended without additional processing by ams AG for each application. For shipments of less than 100 parts the manufacturing flow might show deviations from the standard production flow, such as test flow or test location. The information furnished here by ams AG is believed to be correct and accurate. However, ams AG shall not be liable to recipient or any third party for any damages, including but not limited to personal injury, property damage, loss of profits, loss of use, interruption of business or indirect, special, incidental or consequential damages, of any kind, in connection with or arising out of the furnishing, performance or use of the technical data herein. No obligation or liability to recipient or any third party shall arise or flow out of ams AG rendering of technical or other services. Contact Information Headquarters ams AG Tobelbader Strasse 30 8141 Unterpremstaetten Austria T. +43 (0) 3136 500 0 For Sales Offices, Distributors and Representatives, please visit: http://www.ams.com/contact www.ams.com Revision 1.04 / 6/22/12 Page 22/22
AS3911-DK-ST 价格&库存
很抱歉,暂时无法提供与“AS3911-DK-ST”相匹配的价格&库存,您可以联系我们找货
