M6E-MICRO
M6E-MICRO
    THINGMAGIC
    模块
    MOD RFID 2-PORT MICRO LTE UHF
M6E-MICRO 数据手册
Micro-LTE High Performance Multi-Protocol Embedded UHF RFID Module The 2-port Micro-LTE delivers the size, operating efficiency, RF power, and flexibility needed to embed UHF RFID in best-in-class fixed position, portable, and hand held applications where small form factor is important. The Micro-LTE is optimized for applications with small tag populations reading up to 50 tags/second and features low power consumption needed for battery operated solutions. Micro-LTE’s wide RF output range (-5 dBm to +30 dBm) is a key requirement for RFID enabled printers, tag commissioning stations, and point of sales readers. Edge connections allow the Micro-LTE to be soldered directly to a motherboard as a standard component. The on-board connectors allow the module to be mated to a motherboard. Ordering Information Power Module M6E-MICRO DC Power Required Developers Kit M6E-MICRO-DEVKIT DC Voltage: 3.5 to 5.25 V** DC power consumption @ RF level: 5.5 W @ +30 dBm *** 3.5 W @ +27 dBm 2.5 W @ +23 dBm 2.0 W @ 0 dBm Power Consumption when not transmit ting 0.32 W Idle Power Saving Options Standby: 0.06 W Sleep: 0.008 W Shutdown: 0.0003 W Physical Dimensions 46 mm L x 26 mm W x 4.0 mm H Tag / Transponder Protocols RFID Protocol Support EPCglobal Gen 2 (ISO 18000-6C) with DRM IP-X and ISO 18000-6B optional Environment RF Interface Antennas Two 50 Ω connections (board-edge or U.FL) sup porting two monostatic antennas RF Power Output Separate read and write levels, command adjust able from -5 dBm to 30 dBm* in 0.5 dB steps, accurate to +/- 1 dBm Regulatory Pre-configured for the following regions: • FCC (NA, SA) 902-928 MHz • ETSI (EU, India) 865.6-867.6 MHz • TRAI (Inida) 865-867 MHz • KCC (Korea) 917-920.8 MHz • ACMA (Australia) 920-926 MHz • SRRC-MII (P.R.China) 920-925 MHz • MIC (Japan) 916.8-923.4 MHz • ‘Open’ (Customizable channel plan; 865-868 MHz and 902-928 MHz) Certification FCC 47 CFR Ch. 1 Part 15 Industrie Canada RSS-21 0 ETSI EN 302 208 v1.4.1 Operating Temp. -20C to +60C (case temperature) Storage Temp. -40C to +85C Shock and Vibra tion Survives 1 meter drop during handling Performance Max Read Rate 50 tags/second MaxTag Read Distance Over 30 feet (9 m) with 6 dBiL antenna (36 dBm EIRP) Data/Control Interface Physical 28 board-edge connections or Molex low profile connector (53748-0208) providing DC power, communication, control and GPIO signals Control/Data Interfaces • UART; 3.3V logic levels 9.6 to 921.6 kbps • USB 2.0 interface (12 Mbps) GPIO Sensors and Indicators Two 3.3V bidirectional ports configurable as input (sensor) ports or output (indicator) ports API support C#/.NET, Java, C Specifications subject to change without notice *Duty cycle restrictions, based on temperature, apply at power levels above +23 dBm **Will operate below +3.5 V with reduced input line noise immunity ***Best case with good antenna matching MAKING RFID EASY TO USE ThingMagic is dedicated to driving the barriers to deploying RFID technology as low as possible. We design our products to be easy to use out-of-the box and to deliver predictable, reliable, and repeatable performance. Our development tools require little RFID expertise, enabling you to rapidly design, test, and deploy your RFID solutions. Developers Kit Mercury API Universal Reader Assistant Included with every ThingMagic reader Developer Kit, the MercuryAPI supports the entire line of ThingMagic finished readers and embedded RFID modules A common development platform, supporting an extensive variety of hardware to connect, configure, and control ThingMagic readers. A utility for advanced demo, testing, and tuning of all ThingMagic readers. Reduces complexity for novice users while permitting low-level control for advanced developers. - Test chassis - Cables - Antenna - Sample Tags - Full schematics to help you design your own complimentary components M6e Reader DevKit shown ISO 9001 : 2008 REGISTERED FIRM ISO 13485 : 2003 REGISTERED FIRM © 2015 JADAK LLC 01.30.17 USA Office European Office +1 315.701.0678 Phone +1 315.701.0679 Fax email: info@jadaktech.com +31 (0)76.522.5588 Phone +31 (0)76.522.4747 Fax email: info@jadak.eu 7279 William Barry Blvd. North Syracuse, NY 13212-3349 Emmastraat 16 4811 AG Breda The Netherlands Asia Pacific Office Building 8 Gangtian Industrial Square GangTian Road Suzhou Industrial Park JiangSu, China 215024 +86 512.6283.7080 Phone email: info@jadaktech.com www.jadaktech.com
M6E-MICRO 价格&库存
很抱歉,暂时无法提供与“M6E-MICRO”相匹配的价格&库存,您可以联系我们找货
M6E-MICRO
  • 1+3088.700641+399.57058
库存:15
