M6E-NANO
M6E-NANO
    THINGMAGIC
    模块
    MOD RFID 1-PORT NANO SMD GEN2
M6E-NANO 数据手册
ThingMagic Nano Embedded UHF RFID Module ThingMagic Nano delivers the smallest form factor for a Mercury Series embedded UHF RFID module with very low power consumption and is ideal for battery operated, low cost, small form-factor portable readers. ThingMagic Nano’s wide RF output range (0 dBm to +27 dBm) is important for the read/write requirements for RFID-enabled printers and tag commissioning stations. It features a surface mount package designed for the efficiency of SMT manufacturing, driving down the total cost for embedding RFID in volume applications, including handheld devices, consumables authentication, device configuration and access control. Physical Dimensions Power 22 mm L x 26 mm W x 3.0 mm H (0.866 in L x 1.024 in W x 0.118 in H) DC Power Required • DC Voltage: 3.3 to 5.5 V for +25 dBm out 3.7 to 5.5 V for +27 dBm out • DC power consumption when reading: 3.2 W @ 5 VDC for +27 dBm out 2.9 W @ 5 VDC for +25 dBm out 1.5 W @ 5 VDC for 0 dBm out Idle Power Consumption • 0.84 W in ready mode • 0.015 W in sleep mode • 0.00025 W in shutdown mode Tag / Transponder Protocols RFID Protocol Support EPCglobal Gen 2 (ISO 18000-6C) RF Interface Antennas Single 50 Ω connection (board-edge) RF Power Output Separate read and write levels, commandadjustable from 0 dBm to +27 dBm in 0.01 dB steps Regulatory Pre-configured for the following regions: • FCC (NA, SA) 917.4 – 927.2 MHz • ETSI (EU) 865.6 – 867.6 MHz • TRAI (India) 865 – 867 MHz • KCC (Korea) 917– 923.5 MHz • MIC (Japan) 916.8 – 923.4 MHz • ACMA (Australia) 920 – 926 MHz • SRRC-MII (P.R.China) 920.1– 924.9 MHz • ‘Open’ (Customizable channel plan; 859 – 873 MHz and 915 – 930 MHz) Data/Control Interface Physical 41 board-edge connections providing access to RF, DC power, communication, and GPIO signals Control/Data Interfaces • UART; 3.3V logic levels; 9.6 to 921.6 kbps • Shutdown control GPIO Sensors and Indicators API support as input (sensor) ports or output (indicator) ports C#/.NET, Java, and Embedded “C” APIs Environment Certification • FCC 47 CFR Ch. 1 Part 15 • Industrie Canada RSS-21 0 • ETSI EN 302 208 v1.4.1 Operating Temp. -20C to +60C (case temperature) Storage Temp. -40C to +85C Shock and Vibration Survives 1 meter drop during handling Performance Boot time Less than 30 msec after initial calibration boot Performance Up to 200 tags/sec reading 96-bit EPC Specifications subject to change without notice Develop Create RFID-enabled solutions using industry-standard tools Deploy Enable rapid deployment and reliable operation of RFID solutions within a wide variety of new and existing environments Optimize Maximize productivity, improve ROI and lower operating costs ISO 9001 : 2008 REGISTERED FIRM ISO 13485 : 2003 REGISTERED FIRM © 2015 JADAK LLC 01.30.17 USA Office European Office +1 315.701.0678 Phone +1 315.701.0679 Fax email: info@jadaktech.com +31 (0)76.522.5588 Phone +31 (0)76.522.4747 Fax email: info@jadak.eu 7279 William Barry Blvd. North Syracuse, NY 13212-3349 Emmastraat 16 4811 AG Breda The Netherlands Asia Pacific Office Building 8 Gangtian Industrial Square GangTian Road Suzhou Industrial Park JiangSu, China 215024 +86 512.6283.7080 Phone email: info@jadaktech.com www.jadaktech.com
M6E-NANO 价格&库存
很抱歉,暂时无法提供与“M6E-NANO”相匹配的价格&库存,您可以联系我们找货
