M5E-C
M5E-C
    THINGMAGIC
    模块
    MOD RFID 1PORT UHF UART GEN2
M5E-C 数据手册
UHF RFID Module Family Performance, Efficiency, and Flexibility Radio Frequency Identification (RFID) is rapidly growing from a vertically-oriented technology to an integrated element of critical business processes. At ThingMagic, a Division of Trimble, we believe that RFID-enabled products and solutions will fundamentally change the way we interact with the physical world. By embedding RFID and sensing technology into everyday products, productivity can be improved and inefficiencies can be reduced across nearly every market imaginable. Hundreds of companies from printer and handheld manufacturers, to asset tracking, supply chain, healthcare andtransportation organizations are using ThingMagic embedded RFID modules to drive innovation and benet frombusiness process improvement.Using an RFID module, as opposed to creating a reader with discrete components or a chip and reference design, provides developers with significant advantages. ThingMagic modules are designed to meet performance demands, are market proven, and have been fully tested and certified for regional use – reducing time to market and overall system costs. Mercury® 6e Series High Performance Multi-Protocol Embedded UHF RFID Modules The 2-port Micro and Micro-LTE deliver the form factor, efficiency, RF power, and flexibility needed to embed UHF RFID in your best-in-class portable and hand held applications. The Micro reads 750 tags/second and the Micro-LTE is optimized for applications with small populations and reads 50 tags/second. The low power consumption of both modules fits battery operated applications and wider RF output range (-5 dBm to +30 dBm) is a key requirement for RFID enabled printers, tag commissioning stations, and point of sales readers. Edge connections allow the Micro and Micro-LTE to be soldered directly to a motherboard as a standard component. The on-board connectors allow the module to be mated to a motherboard.The 4-port M6e will meet or exceed the performance requirements of the most demanding fixed position multi-antenna reader applications, delivering the highest read rate and RF power. The M6e will transmit up to +31.5 dBm and can read more than 750 tags/seconds. This performance makes M6e the ideal RFID engine for challenging applications like race timing, portals with long cable runs, and conveyors requiring multiple antennas. The M6e has both serial and USB inter-faces to support both board-to-board and board-to-host connectivity. Mercury®5e Embedded UHF RFID Modules The 2-port M5e is designed for adding UHF RFID read/write capabilities to a wide range of products and solutions, from high-speed label printing and inlay testing, to stationary, mobile, and handheld computers. The M5e will transmit up to +30 dBm. The single-port Compact is ideal for adding basic UHF RFID read/write capabilities to table top printers, battery-powered mobile printers, and handheld readers. The Compact will transmit up to +23 dBm and is the right choice for applications where small size, low cost, and low power consumption are essential and where the higher RF power and high tag read rate and advanced anti-jamming capabilities are not required. TECHNICAL SPECIFICATIONS FEATURES SUMMARY MERCURY5E SERIES MERCURY6E SERIES M6e Micro Micro-LTE M5e Compact Dimensions 69 mm L x 43 mm W x 7.5 mm H (2.7 in L by 1.7 in W by 0.3 inches H) 46 mm L x 26 mm W x 4.0 mm H (1.8 in L x 1.0 in W x 0.16 in H) 82 mm L x 54 mm W x 5 mm H (3.23 in L by 2.13 in W by 0.20 in H) 56 mm L x 36 mm W x 5 mm H (2.2 in L x 1.4 in W x 0.2 in H) RFID Protocol Support EPCglobal Gen 2 (ISO 180006C) with DRM; ISO 18000-6B and IP-X optional EPCglobal Gen 2 (ISO 180006C) with DRM; ISO 18000-6B and IP-X optional EPCglobal Gen 2 (ISO 18000-6C) with DRM EPCglobal Gen 2 (ISO 180006C) with DRM Antenna Connector Four 50 Ohm MMCX connectors supporting four monostatic antennas Two 50 Ohm connections (board-edge or U.FL) support ing two monostatic antennas Two MMCX connectors support ing two monostatic antennas or one bistatic antenna MMCX connector supporting one monostatic antenna RF Power Output Separate read and write levels, command adjustable from 5 dBm to 31.5 dBm (1.4W) with +/-0.5 dBm accuracy above +15 dBm1 Separate read and write levels, commanded adjustable from -5 dBm to 30 dBm in 0.5 dB steps, accurate to +/- 1 dBm3 Separate read and write levels, command adjustable from 5 dBm to 30 dBm (1 W), +/- 1.0 dBm accuracy1 Separate read and write levels, command adjustable from 10 dBm to 23 dBm (200mW), +/- 1.0 dBm accuracy1 Regulatory Pre-configured for the follow ing regions: FCC (NA, SA), ETSI (EU, India), TRAI (India), KCC (Korea), ACMA (Australia), SRRC-MII (P.R.China), ‘Open’ (Customizable) 865-869 MHz and 902-928 MHz Pre-configured for the following regions: FCC (NA, SA), ETSI (EU, India), TRAI (India), KCC (Korea), ACMA (Australia), SRPC-MII (P.R. China), MIC (Japan), ‘Open’ (Customizable) 865-868 MHz and 902-928 MHz Pre-configured for the follow ing regions: FCC (NA, SA), ETSI (EU, India), TRAI (India), KCC (Korea), ACMA (Australia), SRRC-MII (P.R.China), ‘Open’ (Customizable) 860-960 MHz Pre-configured for the follow ing regions: FCC (Americas), ETSI (EU), KCC (Korea), TRAI (India), ACMA (Australia), SRRC-MII (P.R.China), ‘Open’ (Customizable) 860-960 MHz Physical 15-pin low-profile connector providing DC power, commu nication, control and GPIO signals 28 board-edge connections or Molex low profile connector (53748-0208) providing DC power, communication, control and GPIO signals 12-pin ZIF connector providing DC power, communication, control and GPIO signals 12-pin ZIF connector providing DC power, communication, control and GPIO signals Control/Data Interfaces UART with 3.3/5V logic levels from 9600 to 921,600 bps; USB 2.0 full speed device port (up to 12 Mbps) UART with 3.3/5V logic levels from 9600 to 921,600 bps; USB 2.0 full speed device port (up to 12 Mbps) UART; 3.3/5V logic levels (5 V input tolerant); 9.6 to 921.6 kbps UART; 3.3/5V logic levels (5 V input tolerant); 9.6 to 921.6 kbps GPIO Sensors and Indicators Four 3.3V bidirectional ports configurable as input (sensor) ports or output (indicator) ports Two 3.3V bidirectional ports configurable as input (sensor) ports or output (indicator) ports Two 3.3/5V input (sensor) ports and 2 output (indicator) ports Two 3.3/5V input (sensor) ports and 2 output (indicator) ports API support C#/.NET, Java, C C#/.NET, Java, C C#/.NET, Java, C C#/.NET, Java, C DC Power Required DC Voltage: 5.0 VDC +/- 5% DC power: 6.7 W @ 31.5 dBm 4.2 W @ power levels under +17 dBm DC Voltage: 3.5 to 5.25 V 4 DC power consumption @ RF level: 5.5 W @ +30 dBm 3.5 W @ +27 dBm 2.5 W @ +23 dBm 2.0 W @ 0 dBm DC Voltage: 5.0 VDC +/- 4% DC power: 3.5 - 6.5W when transmitting (depends on RF level) DC Voltage: 3.0 to 5.5 VDC DC Power: 2.7 W TECHNICAL SPECIFICATIONS FEATURES SUMMARY MERCURY5E SERIES MERCURY6E SERIES M6e M5e Compact 0.25 W w/ 15 Power Saving Options: 0.07 W 0.05 W --- Micro Micro-LTE 0.25 W w/ 15 Power Saving Options: 0.07 W 0.05 W --- 1.1 W w/ 15 Power Saving Options: 0.3 W 0.08 W 0.03 W 1.43 W w/ 5 Power Saving Options: 0.35 W 0.10 W 0.03 W Certification FCC 47 CFR Ch. 1 Part 15 Industrie Canada RSS-21 0 ETSI EN 302 208 v1.4.1 FCC 47 CFR Ch. 1 Part 15 Industrie Canada RSS-21 0 ETSI EN 302 208 v1.4.1 FCC 47 CFR Ch. 1 Part 15 Industrie Canada RSS-21 0 ETSI EN 302 208 v1.4.1 ETSI EN 300 220 FCC 47 CFR Ch. 1 Part 15 Industrie Canada RSS-21 0 ETSI EN 302 208 v1.4.1 ETSI EN 300 220 Operating Temp. (case temperature) -40C to +60C -20C to +60C -20C to +60C -20C to +60C Storage Temp. -40C to +85C -40C to +85C -40C to +85C -40C to +85C Shock and Vibration Designed to be installed in host devices which are required to survive 5-foot drops to concrete Survives 1 meter drop during handling Designed to be installed in host devices which are required to survive 5-foot drops to concrete Designed to be installed in host devicesthat are required to survive 5-foot drops to concrete Max Read Rate Up to 750 tags/second using high-performance settings Micro: Up to 750 tags/second us ing high-performance settings Micro-LTE : 50 tags/second Max Tag Read Distance Over 30 feet (9 m) with 6 dBiL antenna (36 dBm EIRP) Over 30 feet (9 m) with 6 dBiL antenna (36 dBm EIRP Idle Power Consumption Ready: Standby: Sleep: - Up to 200 tags/second Over 30 feet (9 m) with 6 dBiL antenna (36 dBm EIRP) Up to 200 tags/second Over 13 feet (4 m) with 6 dBiL antenna (29 dBm EIRP) 2 Maximum power may have to be reduced to meet regulatory limits, which specify the combined e ect of the module, antenna, cable, and enclosure shielding of the integrated product. Typical values shown. 3 4 See User Guide for design limits. Duty cycle restrictions, based on temperature, apply at power levels above +23 dBm. Will operate below +3.5 V with reduced input line noise immunity. Specifications subject to change without notice. 1 ORDERING INFORMATION Mercury6e Series Embedded RFID Readers SKU M6e - Embedded (+30 dBm in North America, +31.5 dBm in Europe) M6E M6e-A - Embedded (+31.5 dBm in all regions, requires contract) M6E-A M6e-PRC - Embedded (PRC high and low bands) M6E-PRC Micro (M6E-M) - North America, Europe, Mainland China M6E-M Micro-LTE (M6E-MICRO) - North America, Europe, Mainland China M6E-MICRO M6e license for optional IPX and ISO 18K-6B protocols (Gen2 standard) M6E-LIC-2F Micro (M6E-M) license for optional IPX and ISO 18K-6B protocols (Gen2 standard) M6E-M-LIC-2F Micro-LTE (M6E-MICRO) license for optional IPX and ISO 18k-6B protocols (Gen2 standard) M6E-MICRO-LIC-2F Mercury6e Series Embedded RFID Reader Development Kits M6e Development Kit (North/South America, EU, IN, KR) M6E-DEVKIT Micro (M6E-M) - Development Kit (North/South America, EU, IN, KR, PRC) M6E-M-DEVKIT Micro-LTE (M6E-MICRO) - Development Kit (North/South America, EU, IN, KR, PRC) M6E-MICRO-DEVKIT Mercury5e Series Embedded RFID Readers *M5e - Embedded (North America) M5E *M5e-EU - Europe Embedded (Europe) M5E-EU *M5e-PRC - China Embedded (Mainland China) M5E-PRC Compact (M5E-C) – Embedded M5E-C Mercury5e Series Embedded RFID Reader Development Kits Compact (M5E-C) Development Kit (North/South America, EU, IN, KR) *Developer Note: For new designs, the M5e has been replaced by the Micro which o ers improved efficiency, added flexibility, and smaller form factor. Contact ThingMagic for more information. M5E-C-DEVKIT MAKING RFID EASY TO USE ThingMagic is dedicated to driving the barriers to deploying RFID technology as low as possible. We design our products to be easy to use out-of-the box and to deliver predictable, reliable, and repeatable performance. Our development tools require little RFID expertise, enabling you to rapidly design, test, and deploy your RFID solutions. Developers Kit Mercury API Universal Reader Assistant Everything needed to read and write RFID tags and begin developing RFID-enabled applications: A common development platform, supporting an extensive variety of hardware re, and control to connect, con ThingMagic readers. A utility for advanced demo, testing, and tuning of all ThingMagic readers. Reduces complexity for novice users while permitting low-level control for advanced developers. - Test chassis - Cables - Antenna - Sample Tags - Full schematics to help you design your own complementary components ISO 9001 : 2008 REGISTERED FIRM ISO 13485 : 2003 REGISTERED FIRM © 2015 JADAK LLC 02.21.17 USA Office European Office +1 315.701.0678 Phone +1 315.701.0679 Fax email: info@jadaktech.com +31 (0)76.522.5588 Phone +31 (0)76.522.4747 Fax email: info@jadak.eu 7279 William Barry Blvd. North Syracuse, NY 13212-3349 Emmastraat 16 4811 AG Breda The Netherlands Asia Pacific Office Building 8 Gangtian Industrial Square GangTian Road Suzhou Industrial Park JiangSu, China 215024 +86 512.6283.7080 Phone email: info@jadaktech.com www.jadaktech.com
M5E-C 价格&库存
很抱歉,暂时无法提供与“M5E-C”相匹配的价格&库存,您可以联系我们找货
