ThingMagic USBPro RFID Reader
UHF RAIN RFID Desktop Reader
97 mm L x 61 mm W x 25 mm H
(3.8”L x 2.4” W x 1.0”H)
The ThingMagic USBPro RFID Reader allows solutions developers to support
applications that require desktop reading and writing of EPC Global Gen2 tags, as
well as other protocols such as ISO18000-6B, IPx and AEI ATA (read only) through
additional license. Based on ThingMagic’s M6e-Micro module, the USBPro RFID
Reader is controlled and powered by a host P or laptop through a USB interface and
supports autonomous operation. The USBPro RFID Reader is compatible with
ThingMagic’s MercuryAPI application development tools, including Universal Reader
Assistant, permitting rapid creation of solutions. USBPro supports a wide range of
applications, including tag commissioning, manufacturing work in progress, document
tracking, retail Point of Sale, and workflows for healthcare, events, and hospitality.
Ordering Information
Reader
Development Kit
USB-6EP
USB-6EP-DEVKIT
Tag / Transponder Protocols
RFID Protocol
Support
EPC Gen2V2 ISO18000-63 standard ISO180006B, IPx, AEI ATA (read only) are available through
additional license
Regulatory
FCC 47 CFR Ch. 1 Part 15,
Industrie Canada RSS-21 0,
ETSI EN 302 208 v3.1.1 (RED 2014/53/EU)
Safety
IEC 60950-1 (ed.2)
US-17650-UL
Power
DC Power
Required
RF Interface
Antenna Ports
Internal antenna with an average gain of
+1 dBi from 865-869MHz and 902-928MHz,
External RP-SMA antenna connector
RF Power
Output
Separate read and write levels (into the antenna) are
command-adjustable from
-5 dBm to 30 dBm* (1W), +/- 1.0 dBm accuracy with
+20dBm default
Frequency
Regulatory Information
Pre-configured for the following regions:
FCC 902-928,917.4-927,917.5-922.5 MHz
(Americas)
ETSI 865.6-867.6 MHz, 869.85 MHz (EU) TRAI 865867 MHz (India)
KCC 917-920.8 MHz (Korea)
ACMA 920-926 MHz (Australia) SRRC-MII
920-925 MHz (P. R. China) MIC 916.7-920.9
MHz (Japan)
Open (Customizable) 865-869 and 902-928 MHz
Idle Power
Consumption
USB Micro-B connector, with removable six (6)
foot cable with dual USB-A type plug
Signaling
USB 2.0
Input/Output
Two I/O command controlled LEDs
and two I/O command queried switches
Protocol
Command-response protocol protected by length field
and 16-bit CRC
Supplied interface cable terminates in two
type-A plugs: one for power and signal,
the second for additional power if needed
0.35 W max at idle
(Power management modes can be used to
reduce this to as little as 0.1 W)
Environment
Operating Temp.
-40°C to +60°C*
Storage Temp.
-40°C to +85°C
Architecture
User Memory
16 kB
Tag Buffer
200 tags
Tag Read Rate
50 tags/second
Tag Read
Distance
Up to 10 m (30 feet) with external antenna
and up to 1.2 m (4 feet) depending on tag
Sensitivity and orientation with internal
Antenna with max RF power.
Performance
Data/Control Interface
Physical
DC Voltage: 4.5 to 5.5 VDC from USB cable
DC Power: 6.2 W max
*Duty cycle restrictions based on temperature, tx
power >23dB
© 2022 Novanta Inc. and its affiliated companies. All rights reserved. Rev 04262022
很抱歉,暂时无法提供与“USB-6EP”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+4096.134141+529.89748
