1834.000.00
1834.000.00
    FEIGELECTRONIC
    模块
    ID ISC.M02-B READER MODULE
1834.000.00 数据手册
 HF Proximity Reader Module ID ISC.M02-B Features:  Operation with integrated or external antenna  Anti-collision function  Multi-tag Reader for ISO15693  Possible applications in the sector of access control due to data-/clock interface  TECHNICAL DATA Order description: ID ISC.M02-B HF Reader Module Accessories: ID ISC.ANT40/30-A HF Antenna ID ISC.ANT100/100-A HF Antenna Dimensions (W x H x D) 50 mm x 50 mm x 15 mm (1.97 x 1.97 x 0.55 inch) Connector 10 pin connector Spacing 2.54 mm (0.1 inch) Operating frequency 13.56 MHz Supply voltage 5V DC + 5% RF transmitting power 90 mW +/- 2dB Power consumption maximum 1 W Supported transponders ISO 15693 Antenna integrated (48 mm x 48 mm) External 50Ω antennas optional Read range 10 cm* with integrated antenna, up to 14 cm* with ext. antennas Interfaces RS232-TTL, Data-/Clock (magnet card emulation and Wiegand emulation) Signal generator 2 LED (red/green) Temperature range Operation Storage –20 °C up to 70 °C –40 °C up to 85 °C EEPROM 1 kB (10.000 write-cycles) FLASH 64 kB (Software Update via interface possible) * Read ranges depend on the transponder size. Here made statements relate on a inlet size of 76 mm x 45 mm STANDARD CONFORMITY Not recommended for new design. Radio licence Europe USA EN 300 330 FCC 47 CFR Part 15 EMC EN 301 489 Safety EN 60950 FEIG ELECTRONIC reserves the right to change specification without notice at any time. State of information: November 2016.
1834.000.00 价格&库存
很抱歉,暂时无法提供与“1834.000.00”相匹配的价格&库存,您可以联系我们找货
