20911041104
20911041104
    HARTING(浩亭)
    RF-R500 UHF LR RFID READER
20911041104 数据手册
HARTING Ha-VIS RFID System Components HARTING Ha-VIS RFID System Components HARTING Ha-VIS RFID System Components 2 HARTING Smart Network Infrastructure – Ha-VIS RFID System Components Real-time information and the close synchronization of computer data and real processes play a critical role in process management and process optimization. Ensuring that information precisely maps and concurs with reality is the only way to control processes optimally and reap savings potentials accordingly. One important prerequisite for guaranteeing that data and processes are synchronized is an intelligent infrastructure that makes data transparent and available throughout a company in order to achieve the maximum savings potentials. RFID offers you the full potential to create intelligent infrastructures: benefit from the simultaneous identification of up to several hundred objects – without the need for the direct line of sight as required by barcode solutions. The collected data are immediately ready for further processing throughout the company. HARTING offers smart infrastructure solutions based on optimally coordinated components from a single source. These solutions enable the reliable control and steering of production and business processes, thereby resulting in lower costs. The HARTING RFID Reader and components have been designed for harsh industrial applications. Deployed in the transportation, machinery and energy markets, HARTING RFID components guarantee secure and reliable information processing – also under the most challenging environmental conditions. Moreover, a transponder can be used to store information directly on the product at the same time it is identified. This means that these data are also always available wherever the product may happen to be located. 3 HARTING Ha-VIS RFID System Components HARTING Smart Infrastructure Solutions Real time information and the close synchronization of the virtual data world and the real process world play a crucial role in process management and process optimization. Information constitutes the basis of decisions. Missing information is detrimental here, while information that is present in the company but that remains hidden due to incompatible and impermeable infrastructures is even more damaging as this costs money without being able to return the full benefits. Flexible use in the industrial environment Ha-VIS RF-R500 RFID reader Use in switch cabinet on DIN rail Installation directly on cross arms thanks to rugged aluminum housing Up to IP 64 with protection cap, otherwise IP 53 4 Rugged Ha-VIS RF-ANT-LR10 UHF RFID antenna with very short read range Protection class IP 67 Optimized for near-field applications Identification of tools in machines or ensuring the correct positioning of objects, for example Material tracking Ha-VIS RFID SL 89 (MT) > 4-m range Functions when integrated into metal Low space requirements Networking of the automation application Ha-VIS FTS 3100-A Ethernet Switch with Fast Track Switching technology Determinism with Standard Ethernet Preference given to automation data Tool management / maintenance Ha-VIS RFID VT 86 (HT) > 2,5 m range on metal in connection with highly compact footprint Variable installation possibilities Especially resistant to heat, chemicals, such as during autoclaving Ha-VIS RFID CS/CF 89 (NT) Also readable in damp environments Rugged housing EPC C1 Gen2 compatibility Protection class IP 69K Expanded memory HARTING Smart Network Infrastructure – Ha-VIS RFID System Components RFID out of the Box-Lösung Complete RFID system incl. RFID reader, switch, protection against overvoltage, and power supply Protection class IP65 Customer specific configurations possible Robust housing Measuring device administration for calibration > 4m range Function in metal guaranteed Compact space requirements Finished part monitoring in building management Monitoring of static characteristics in prefabricated building parts using RFID technology Automatic process mapping using RFID reader Ha-VIS RF-R500 Read range to 16 m 4 antennas can be connected Up to IP 64 with protection cap Localization of transport means for automatic booking processes Ha-VIS RFID CT 89 (NT) > 4,5 m range Function in and on precast concrete units Development for the construction trade Incoming goods inspection via RFID gate Extremely rugged outdoor antenna for Ha-VIS RF-ANTWR80-30 for gate applications Ruggedized housing 30°/70° aperture angle Protection class IP 65 Maintenance management Cyclic maintenance of safetyrelated equipment is automated with modern RFID transponders Container management Selective identification of containers with Ha-VIS RFID antennas, especially in harsh industrial environments. Ha-VIS RF-ANT-WR30 High read range Flat, compact design Protection class IP 65 5 HARTING Ha-VIS RFID System Components RFID Products & Accessories Ha-VIS UHF long range RFID Reader RF-R500 Features   Suitable for harsh industrial environments Very high read range of up to 16 m Power over Ethernet capability (PoE) (RF-R500-p) 4 antennas can be connected Up to 4 W transmitter power (RF-R500-p), otherwise 2 W (RF-R500-c) Up to IP 64 with protection cap (optional) Interfaces (Ethernet, USB, RS 232, RS 485) Fast readout of >150 transponders 860 - 960 MHz Profibus / Profinet: optional via gateway PLC connection – templates of function blocks on request Web interface Identification Part. no. RF-R500-c-EU 20 91 104 1103 RF-R500-c-US 20 91 104 1104 RF-R500-p-EU 20 91 104 1101 RF-R500-p-US 20 91 104 1102 Ha-VIS UHF mid range Reader RF-R200 Features External antenna (max. read range up to 2m) Internal antenna (max. read range up to 30cm) 500mW transmission power Power over Ethernet SMA connector Automatic reporting of tags (notification mode) Identification Part. no. Ha-VIS RF-R200 (expected availability 2nd Q. 2013) 20 91 106 1101 Accessories DIN rail mounting kit RF-R200 20 93 102 0202 Mounting Kit RF-R200 20 93 102 0203 Desktop power supply for RF-R200 (EU) 20 93 310 0203 Ha-VIS RFID Box Features Completely installed RFID system in cabinet Tested and ready for connection Modular system Customer specific configurations possible 2 mm VA steel Railway norms Protection class IP65 6 Identification Part. no. Ha-VIS RFID Box (RF-R500-p-EU, eCon 2050-A) 20 91 421 1001 Ha-VIS RFID Box (RF-R500-c-EU, eCon 2050-A) (both variants expected availability Q1 / 2013) 20 91 411 1001 HARTING Ha-VIS RFID System Components Ha-VIS UHF mobile Reader RF-M3000 Features Read range up 2 m IP 65 protection Several drops on concrete from 1.8 m (handheld switched on incl. WiFi, Barcode scanner, imager) WiFi 1 GB Flash 3.6” TFT Display Identification Part. no. RFID Handheld RF-M3000 20 91 211 1011 RFID Handheld RF-M3001 1D Laser Scanner 20 91 211 1111 RFID Handheld RF-M3002 2D Imager 20 91 211 1311 Mobile reading devices with higher read ranges on request Accessories Ha-VIS RF-M3000 battery 4400 mAh 20 93 405 0101 Ha-VIS RF-M3000 Stylus 5 Pack (spare pen for touch screen) 20 93 405 0102 Power Supply AC universal 5 V / 3 A 20 93 405 0103 RF-M3000 Docking Station Desktop 20 93 305 0101 RF-M3000 Docking Station Quad (4-fold incl. RJ45) 20 93 305 0102 RF-M3000 Cradle Vehicle Powered 12 V 20 93 305 0103 RF-M3000 Ram mounting system 20 93 305 0104 RF-M3000 Plastic pistol grip 20 93 705 0101 RF-M3000 Soft holster kit 20 93 705 0102 DIN Rail mounting kit Features Board inc. screws for installing the Ha-VIS RF-R500 on DIN rail Identification Part. no. DIN rail mounting kit 20 93 102 0201 Ha-VIS RFID reader protection cap Features Increased protection class IP 64 Up to 8 PG lead-throughs Simple and reliable installation on Ha-VIS RF-R500 Identification Part. no. Ha-VIS Protection cap RF-R500 20 93 901 0101 7 HARTING Ha-VIS RFID System Components Ha-VIS RFID UHF wide range antenna Features Compact design High read range Suitable for industrial environment Optimized for portal applications 69° aperture angle Antenna gain 8.5 dBic High IP 65 protection Suitable for outside areas TNC socket 865 - 870 MHz (EU) or 902 - 928 MHz (US) Identification Part. no. RF-ANT-WR30-EU 20 93 201 0102 RF-ANT-WR30-US 20 93 201 0103 Ha-VIS RFID UHF ruggedized wide range antenna, 30° aperture angle Features Different aperture angles for azimuth and elevation planes (30° / 70°) Ruggedized housing Compact design High read range Antenna gain 11 dBic Suitable for industrial environment Optimized for portal applications High IP 65 protection Suitable for outside areas N socket 865 - 870 MHz (EU) or 902 - 928 MHz (US) 8 Identification Part. no. RF-ANT-WR80-30-EU 20 93 201 0203 RF-ANT-WR80-30-US 20 93 201 0204 HARTING Ha-VIS RFID System Components Ha-VIS RFID UHF mid range antenna Features Very compact design Medium read range (0.2 m - 2 m) Suitable for industrial environment with near- and far-field applications 100° aperture angle Antenna gain 4 dBic High IP 67 protection Suitable for outside areas TNC socket 865 - 870 MHz (EU) or 902 - 928 MHz (US) Identification Part. no. RF-ANT-MR20-EU 20 93 201 0301 RF-ANT-MR20-US 20 93 201 0302 Ha-VIS RFID UHF short mid range antenna Features Very compact design Medium read range (0.2 m - 1 m) Worldwide applicable (860 - 930 MHz) 100° aperture angle High IP 67 protection Max. input power 1 W Ideally suitable for metallic environments because of -12 dBic@866 MHz TNC socket Identification Part. no. RF-ANT-sMR20 (expected availability Q2 / 2013) 20 93 201 0304 Ha-VIS RFID UHF ultra-low range antenna Features Minimal size Extremely high spatial selectivity Suitable for industrial environment Optimized for near-field applications (< 5 cm) High IP 67 protection Suitable for outside areas TNC socket worldwide applicable (860-930 MHz) Identification Part. no. RF-ANT-LR10 20 93 201 0303 9 HARTING Ha-VIS RFID System Components Ha-VIS RFID wall/mast antenna mounting kit Features Very rugged Can be aligned in two directions Wide adjustment angle Identification Part. no. RF-MOUNT-ANT-A (for RF-ANT-WR30) 20 93 102 0103 Ha-VIS RFID mast antenna mounting kit Features Diameter of post 25 - 76 mm Turnable by two links Precision of angle adjustment 2° Max. weight to carry 20 kg Identification Part. no. RF-MOUNT-ANT-C (for RF-ANT-WR30) 20 93 102 0105 Ha-VIS RFID mast mounting Features Very rugged Can be tipped Stainless steel Necessary pipe (diameter 50 - 115 mm) not included Identification Part. no. RF-Mount-ANT-B (for RF-ANT-WR80-30) 20 93 102 0104 10 HARTING Ha-VIS RFID System Components Ha-VIS RFID standard antenna cable Features 3 m standard cable TNC - SMA Attentuation 68 dB/100 m (@800 MHz) Identification Part. no. Ha-VIS Coax SMA-TNC, RG58, 3 m 20 93 204 0101 Ha-VIS RFID low loss antenna cable Features 3 m and 10 m low loss cable Attenuation 28 dB / 100 m (@800 MHz) Outer diameter 5.4 mm Left side: SMA connector Right side: TNC or N connector Identification Part. no. Ha-VIS Coax SMA-TNC, LL 240 flex, 3 m 20 93 204 0102 Ha-VIS Coax SMA-TNC, LL 240 flex, 10 m 20 93 204 0103 Ha-VIS Coax SMA-N, LL 240 flex, 3 m 20 93 204 0104 Ha-VIS Coax SMA-N, LL 240 flex, 10 m 20 93 204 0105 Ha-VIS RFID heavy duty low loss antenna cable Features 3 m and 10 m low loss cable Suitable for harsh environments Attenuation 22 dB / 100 m (@800 MHz) Outer diameter 10.3 mm TNC - N Identification Part. no. Ha-VIS Coax TNC-N, RG 213, 3 m 20 93 204 0106 Ha-VIS Coax TNC-N, RG 213, 10 m 20 93 204 0107 11 HARTING Ha-VIS RFID System Components Ha-VIS RFID SMA TNC antenna cable adapter Features Adaptor for connecting RG213 cable to reader Identification Part. no. Adapter TNC-SMA 20 93 204 0301 Ha-VIS RFID PT 86 (HT) Features Functions on metal Rugged, chemical resistant housing EPC C1 Gen2 compatibility Protection class IP 69K Expanded memory Identification Part. no. Ha-VIS RFID PT 86 (HT) 10 units 20 92 641 0101 Ha-VIS RFID PT 86 (HT) 50 units 20 92 641 0102 Ha-VIS RFID VT 86 (HT) Features Functions on metal Rugged, chemical resistant housing EPC C1 Gen2 compatibility Protection class IP 69K Expanded memory Flexible mounting 12 Identification Part. no. Ha-VIS RFID VT 86 (HT) 10 units 20 92 641 0201 Ha-VIS RFID VT 86 (HT) 50 units 20 92 641 0202 Ha-VIS RFID VT868 (HT) 0.43k (EU, 0,43 kByte memory) (expected availability Q2 / 2013) on request Ha-VIS RFID VT92 (HT) 0.43k (US, Asia, 0.43 kByte memory) (expected availability Q2 / 2013 on request HARTING Ha-VIS RFID System Components Ha-VIS SL89 Set Features Extremly high level of mechanical protection Protection class IP 69K EPC C1 Gen2 compatibility Expanded memory Customer specific shapes of metal pieces for individual customer requests Identification Part. no. Ha-VIS SL89 Set On definition of metal piece Ha-VIS RFID CT/CF/CS 89 (NT) product family Features Can also be read in damp environments Rugged housing EPC C1 Gen2 compatibility Protection class IP 69K Expanded memory Identification Part. no. Ha-VIS RFID CT89 (NT) 10 units 20 92 641 0301 Ha-VIS RFID CT89 (NT) 50 units 20 92 641 0302 Ha-VIS RFID CF89 (NT) 10 units 20 92 641 0401 Ha-VIS RFID CF89 (NT) 50 units 20 92 641 0402 Ha-VIS RFID CS89 (NT) 10 units 20 92 641 0501 Ha-VIS RFID CS89 (NT) 50 units 20 92 641 0502 Ha-VIS RFID Transponder FT 89 Features For non-conductive surfaces Extremly mechanical robust Barcode and company logo possible Flexible mounting on different surfaces Adhesive mounting Identification Part. no. Ha-VIS RFID FT 89 passiv Tr. 50 units 20 92 641 0702 Ha-VIS RFID FT 89 passiv Tr. 500 units 20 92 641 0703 13 HARTING Ha-VIS RFID System Components Ha-VIS Middleware Features The bridge between RFID readers and company software Easy integration of HARTING RFID Reader Filtering, grouping and aggregation based on various tag information Application flow triggered by manual, digital IO or scheduled events Report of cumulated data in standardized or customized formats Central RFID Reader management Advanced reading, writing, locking and muting of RFID transponders Conform to EPCglobal® ALE 1.1 standard Identification Part. no. Ha-VIS Middleware Incl. XML Subscriber and Connector for one Ha-VIS RF-R500 RFID Reader 20 16 210 1110 Subscriber (software side) Easy API MySQL Subscriber 20 16 220 3110 20 16 220 4110 Connector (hardware side) Connector for up to 5 RF-R500 Connector for up to 15 RF-R500 Connector for up to 25 RF-R500 Connector for up to 50 RF-R500 20 16 230 1120 20 16 230 1130 20 16 230 1140 20 16 230 1150 Ha-VIS Dashboard Ne nt Ne tw or k Cent ra lis ed geme ana km r o tw g rin ito on M Features Centralised management of managed Ethernet devices Network monitoring Event- and Alarm-Management Performance Monitoring Administration of complex RFID Reader-Installations me nt m an ag e 20 16 111 2110 20 16 111 3110 20 16 111 4110 ni to rin g o M Ha-VIS Dashboard License 64 Ha-VIS Dashboard License 128 Ha-VIS Dashboard License 256 ce Part. no. an rm Perfo Identification t Even rm la dA an ICPN Service RFID Proof-of-Concept at the site of customer or in the RFID laboratory Configuration service for Ha-VIS RFID Reader and Middleware Commissioning at site of customer Consulting for RFID systems Trainings Telephone hotline Email support 14 HARTING Ha-VIS RFID System Components AE – United Arab Emirates HARTING Middle East FZ-LLC Knowledge Village Block 2A, Office F72 Dubai, United Arab Emirates E-Mail: uae@HARTING.com, www.HARTING.ae AT – Austria HARTING Ges. m. b. H. Deutschstraße 19, A-1230 Wien E-Mail: at@HARTING.com, www.HARTING.at AU – Australia HARTING Pty Ltd Suite 11 / 2 Enterprise Drive Bundoora 3083, AUS-Victoria E-Mail: au@HARTING.com, www.HARTING.com.au BE – Belgium HARTING N.V./S.A. Z.3 Doornveld 23, B-1731 Zellik E-Mail: be@HARTING.com, www.HARTING.be BR – Brazil HARTING Ltda. Rua Major Paladino 128 – Prédio 11 CEP 05307-000 – São Paulo – SP – Brasil E-Mail: br@HARTING.com, www.HARTING.com.br CA – Canada HARTING Canada Inc. 8455 Trans-Canada Hwy., Suite 202 St. Laurent, QC, H4S1Z1, Canada E-Mail: info.ca@HARTING.com, www.HARTING.ca CH – Switzerland HARTING AG Industriestrasse 26, CH-8604 Volketswil E-Mail: ch@HARTING.com, www.HARTING.ch CH – Switzerland HARTING AG Mitronics Leugenestrasse 10, CH-2500 Biel 6 E-Mail: mit@HARTING.com www.HARTING-mitronics.ch CN – China Zhuhai HARTING Ltd. Shanghai Branch, Room 5403 300 Huai Hai Road (M.) , Luwan District Shanghai 200021, China E-Mail: cn@HARTING.com, www.HARTING.com.cn CZ – Czech Republic HARTING s.r.o. Mlýnská 2, CZ-160 00 Praha 6 E-Mail: cz@HARTING.com, www.HARTING.cz DE – Germany HARTING Deutschland GmbH & Co. KG P.O. Box 2451, D-32381 Minden Simeonscarré 1, D-32427 Minden E-Mail: de@HARTING.com, www.HARTING.de DK – Denmark HARTING ApS Hjulmagervej 4a, DK – 7100 Vejle E-Mail: dk@HARTING.com, www.HARTING.com EE – Eastern Europe HARTING Eastern Europe GmbH Bamberger Straße 7, D-01187 Dresden E-Mail: Eastern.Europe@HARTING.com www.HARTING.com ES – Spain HARTING Iberia S.A. Avda. Josep Tarradellas 20-30 4o 6a, E-08029 Barcelona E-Mail: es@HARTING.com, www.HARTING.es FI – Finland HARTING Oy Teknobulevardi 3-5, FI-01530 Vantaa E-Mail: fi@HARTING.com, www.HARTING.fi FR – France HARTING France 181 avenue des Nations, Paris Nord 2 BP 66058 Tremblay en France F-95972 Roissy Charles de Gaulle Cédex E-Mail: fr@HARTING.com, www.HARTING.fr GB – Great Britain HARTING Ltd. Caswell Road, Brackmills Industrial Estate GB-Northampton, NN4 7PW E-Mail: gb@HARTING.com, www.HARTING.co.uk HK – Hong Kong HARTING (HK) Limited Regional Office Asia Pacific 3512 Metroplaza Tower 1, 233 Hing Fong Road Kwai Fong, N. T., Hong Kong E-Mail: ap@HARTING.com, www.HARTING.com.hk HU – Hungary HARTING Magyarország Kft. Fehérvári út 89-95, H-1119 Budapest E-Mail: hu@HARTING.com, www.HARTING.hu IN – India HARTING India Private Limited No. D, 4th Floor, ‚Doshi Towers‘ No. 156 Poonamallee High Road, Kilpauk, Chennai 600 010, Tamil Nadu, India E-Mail: in@HARTING.com, www.HARTING.co.in IT – Italy HARTING SpA Via dell‘Industria 7, I-20090 Vimodrone (Milano) E-Mail: it@HARTING.com, www.HARTING.it JP – Japan HARTING K. K. Yusen Shin-Yokohama 1 Chome Bldg., 2F 1-7-9, Shin-Yokohama, Kohoku Yokohama 222-0033 Japan E-Mail: jp@HARTING.com, www.HARTING.co.jp KR – Korea HARTING Korea Limited #308 Yatap Leaders Building, 342-1 Yatap-dong Bundang-gu, Sungnam-City, Kyunggi-do 463-828 Republic of Korea E-Mail: kr@HARTING.com, www.HARTING.co.kr NO – Norway HARTING A/S Østensjøveien 36, N-0667 Oslo E-Mail: no@HARTING.com, www.HARTING.no PL – Poland HARTING Polska Sp. z o.o. ul. Duńska 9, PL-54-427 Wrocław E-Mail: pl@HARTING.com, www.HARTING.pl PT – Portugal HARTING Iberia, S. A. Avda. Josep Tarradellas, 20-30, 4o 6a, E-08029 Barcelona E-Mail: es@HARTING.com, www.HARTING.es/pt RO – Romania HARTING Romania SCS Europa Unita str. 21, 550018-Sibiu, Romania E-Mail: ro@HARTING.com, www.HARTING.com RU – Russia HARTING ZAO Maily Sampsoniyevsky prospect 2A 194044 Saint Petersburg, Russia E-Mail: ru@HARTING.com, www.HARTING.ru SE – Sweden HARTING AB Gustavslundsvägen 141 B 4tr, S-167 51 Bromma E-Mail: se@HARTING.com, www.HARTING.se SG – Singapore HARTING Singapore Pte Ltd. 25 International Business Park #04-108 German Centre, Singapore 609916 E-Mail: sg@HARTING.com, www.HARTING.sg SK – Slovakia HARTING s.r.o. Sales office Slovakia J. Simora 5, SK – 940 67 Nové Zámky E-Mail: sk@HARTING.com, www.HARTING.sk TR – Turkey HARTING TURKEI Elektronik Ltd. Şti. Barbaros Mah. Dereboyu Cad. Fesleğen Sok. Uphill Towers, A-1b Kat:8 D:45 34746 AtaŞehir, İstanbul E-Mail: tr@HARTING.com, www.HARTING.com.tr TW – Taiwan HARTING TaiwanLimited Room 1, 5/F, 495 GuangFu South Road RC-110 Taipei, Taiwan E-Mail: tw@HARTING.com, www.HARTING.com.tw US – USA HARTING Inc. of North America 1370 Bowes Road, USA-Elgin, Illinois 60123 E-Mail: us@HARTING.com, www.HARTING-USA.com MY – Malaysia (Office) HARTING Singapore Pte Ltd Malaysia Branch, 11-02 Menara Amcorp, Jln. Persiaran Barat, 46200 PJ, Sel. D. E., Malaysia E-Mail: sg@HARTING.com, www.HARTING.com NL – Netherlands HARTING B.V. Larenweg 44, NL-5234 KA ’s-Hertogenbosch Postbus 3526, NL-5203 DM ’s-Hertogenbosch E-Mail: nl@HARTING.com, www.HARTINGbv.nl 15 MO/2012-10-30/1.0 98 42 137 0201 HARTING Technology Group Marienwerderstraße 3, 32339 Espelkamp – Germany P.O. Box 11 33, 32325 Espelkamp – Germany Phone +49 5772 47-0, Fax +49 5772 47-400 RFID@HARTING.com www.HARTING-RFID.com
20911041104 价格&库存
很抱歉,暂时无法提供与“20911041104”相匹配的价格&库存,您可以联系我们找货
