125Khz RFID module – UART
RDM 125KHz card mini-module is designed for reading code from 125KHz card compatible
read-only tags and read/write card . It can be applied in office/home security, personal
identification, access control, anti-forgery, interactive toy and production control systems etc.
Note: Module will notify whenever 125khz tag approaches, tag serial number will be
send via TX pin. Easy way for a RFID module on MCU projects or PC connnection via
UartSB.
Features
Support external antenna
Maximum effective distance up to 50mm
Less than 100ms decoding time
UART TTL interface
Support EM4100 compatible read only or read/write tags
Built-in external bi-color LED and buzzer driver
Small outline design
Specification
May include key specification and other specifications.
Key Specification
Frequency
125KHz
Baud Rate
9600 (TTL Electricity Level RS232 format)
interface
Weigang26 Or TTL Electricity Level RS232 format
Power supply
DC 5V(±5%)
Current
50mm(Depend on Card/Tag shape, manufacturer)
Expand I/O port
N/A
Indication light
N/A
Working temperature
-10℃~ +70℃
Storage temperature
-20℃~ +80℃
Max. humidity
Relative humidity 0 ~ 95%
Size
38.5mm ×19mm×9mm
Pin definition and Rating
Look the image below(Mechanic Dimensions), and check the pin definition list here:
Pin Definition :
P1:
PIN1
TX
PIN2
RX
PIN3
PIN4
GND
PIN5
+5V(DC)
P2:
PIN1
ANT1
PIN2
ANT2
P3:
PIN1
LED
PIN2
+5V(DC)
PIN3
GND
Mechanic Dimensions
Usage
TTL Interface RS232 Data output format
1. 9600bps,N,8,1
2. CHECKSUM: card 10byte DATA entire do XOR operation
02
10ASCII Data Characters
Chechsum
Example: card number: 62E3086CED
Output data:36H、32H、45H、33H、30H、38H、36H、43H、45H、44H
CHECKSUM: (62H) XOR (E3H) XOR (08H) XOR (6CH) XOR (EDH)=08H
03
Time sequence chart
Exampel
Output date(HEX): 02 | 30 31 30 30 30 37 33 34 45 30 | 44 32 | 03 ->Change to Decimal
CardNumber Decimal: 48 49 48 48 48 55 51 52 69 48 CheckSum Decimal: 68 50 >Refer to ASCII table,get Ascill value CardNumber Ascill: 0 1 0 0 0 7 3 4 E 0 CheckSum
Ascill : D 2 (01H) xor (00H) xor (07H) xor (34H) xor (E0H) = D2H
Programming
Connect RX/TX to Arduino UART port , Uart demo code :
void setup()
Serial.begin(9600);
void loop()
if(Serial.available())
while(Serial.available())
Serial.write(Serial.read());
Resources
Datasheet: RDM630-Spec.pdf
How to connect Arduino and RFID
http://wiki.seeedstudio.com/125Khz_RFID_module-UART/ 7-18-18
很抱歉,暂时无法提供与“113990014”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+231.26040
- 200+89.49960
- 500+86.35680
- 1000+84.80160
