2241.002.12.00
2241.002.12.00
    FEIGELECTRONIC
    170MMX320MMX48MM,RS232
    ID ISC.LRU1000-A0-FCC UHF READER
2241.002.12.00 数据手册
® R O B ID Long Range Reader ID ISC.LRU1000 Multi-protocol Long Range Reader for identification of UHF transponders (865-928 MHz) in the fields of retail, industry, logistics etc. Features: Multi-protocol technology (ISO 18000-6-A/B, EPC UHF class 1, EPC UHF Gen 2) Connection of up to 4 external antennas BRM-function: Data filtering and -buffering Solid housing (protection class IP 54) Interfaces: RS232, RS485,Ethernet, WLAN Variants for use in Europe and North America Problemless Firmware-updates R OBID -- RFID by FEIG ELECTRONIC Short description and technical information Long Range Reader ID ISC.LRU1000 Technical Data Short description Housing Plastic with heatsink Dimensions (WxLxH) 180 x 320 x 110 mm Protection class IP 54 Power supply 12-24 V DC Power consumption max. 30 VA Operating frequency 869,525 MHz ; 865,6-867,6 MHz (200 kHz-steps); 902-928 MHz (500 kHz-steps) Transmitting power 100 mW - 4 W (100 mW-steps) 4 Watt EIRP 2 Watt ERP (0,5 Watt ERP) Modulation 20% - 40% and 100% (scalable via Software) Receiver Data rates 40 - 320 kbps Antenna connectors 4 x SMA connector (50 Ohm) Outputs - 1 Optocoupler - 1 Differential output - 1 Relay (1x NO/NC) 24 V DC / 30 mA Reader synchronization 24 V DC / 2 A Inputs - 1 Optocoupler - 1 Differential input max. 24 V DC / 20 mA Reader synchronization Interfaces RS232 and RS485 Ethernet (TCP/IP) Compact Flash-2 (WLAN) Protocol modes FEIG ISO HOST; BRM (data filtering and -buffering) Processable transponders ISO 18000-6-A and -B (U-Code), EPC class 1 and Gen 2 Optional: EPC class 0 Indicators 5 LED´s Temperature range - Operation - Storage -25°C up to 55°C (-25°C up to 70°C) -25°C up to 85°C R C 2004 FEIG ELECTRONIC reserves the right to change the specification at any time FEIG ELECTRONIC GmbH Lange Straße 4, D-35781 Weilburg Tel.: +49 (0) 6471 / 3109-0, Fax: -99 Internet: http://www.feig.de e-mail: OBID@feig.de
2241.002.12.00
物料型号:ISC.LRU1000
器件简介: - UHF 长距离阅读器,适用于零售、工业、物流等领域。 - 支持多协议技术(ISO 18000-6-A/B, EPC UHF 类1, EPC UHF Gen 2)。 - 可连接最多4个外部天线。 - 坚固的外壳(防护等级IP 54)。 - 适用于欧洲和北美。
引脚分配: - 4个SMA连接器(50欧姆)。
参数特性: - 工作频率:869.525MHz; 865.6-867.6 MHz(200 kHz步进); 902-928 MHz(500 kHz步进)。 - 发射功率:100 mW-4 W(100 mW步进),4瓦EIRP,2瓦ERP(0.5瓦ERP)。 - 调制:20%-40%和100%(可通过软件调整)。 - 接收器数据速率:40 - 320 kbps。
功能详解: - 支持多种标签,减少未来新标签和标准的集成。 - 内置多路复用器,支持多天线应用。 - 多种接口(RS232, RS485, Ethernet, WLAN)确保与个人系统的连接灵活性。 - 坚固的外壳适用于恶劣的工业环境。
应用信息: - 特别适用于资产管理和物流应用,尤其是需要同时识别多个标签和非常高的读取范围的地方。
封装信息: - 外壳材料:带散热器的塑料。 - 尺寸(宽x长x高):180x320x110mm。 - 保护等级:IP54。 - 电源:12-24VDC。 - 功耗:最大30 VA。
2241.002.12.00 价格&库存
很抱歉,暂时无法提供与“2241.002.12.00”相匹配的价格&库存,您可以联系我们找货
