AS3955-ATDM-S4
AS3955-ATDM-S4
    AMSOSRAM(艾迈斯半导体)
    VFDFN10_EP
    RFID Transponder IC 13.56MHz ISO 14443, NFC I²C, SPI 1.65 V ~ 5.5 V 10-VFDFN Exposed Pad
AS3955-ATDM-S4 数据手册
AS3955 NFC Forum Compliant Dynamic Tag General Description AS3955 NFC Dynamic Tag IC is the ultimate solution to easily add NFC functionality to electronic devices. Thanks to a high sensitivity ISO14443A frontend and high integrated resonance capacitor, AS3955 offers standalone NFC passive tag functionality in a small footprint. Fast system integration and high speed data transfer are guaranteed by the available SPI and I²C interfaces and by the optimized protocols (Tunneling Mode and Extended Mode), allowing bidirectional communication between the device microcontroller and an external NFC compliant device or ISO14443A reader device (PCD). AS3955 is able to operate fully powered by the RF field, without any external supply. This, combined with an advanced energy harvesting feature, greatly increases battery life time or even allows battery-less designs. AS3955 is used with an appropriate antenna coil connected to the terminals LC1 and LC2, and behaves as a standard passive ISO 14443A tag (PICC). After the anti-collision protocol stage, based on configuration, AS3955 can operate as a standalone NFC Forum Type 2 Tag or, when tunneling mode is activated, as a bridge between the PCD and the microcontroller, e.g. to emulate a custom or standard ISO14443A Level 3 or Level 4 PICC or a NFC Forum tag. A configurable wake-up signal notifies the microcontroller on ongoing RF activities, in order to minimize overall power consumption. AS3955 includes an embedded EEPROM memory that can be accessed from the PCD through the RF link or from the microcontroller through the SPI or I²C interfaces. Part or all memory can be protected by a 32-bit password, or permanently locked. AS3955 supports ISO 14443A up to Level 4 and is designed according to EMVCo requirements, to enable the emulation of contactless smart cards or NFC Forum compliant Type 2 or Type 4 Tags. AS3955 is designed for high reliability, and can operate in a wide power supply range from 1.65V to 5.5V, in a wide temperature range from -40 °C to 125 °C. EEPROM memory reaches automotive grade quality with endurance of 100,000 cycles and data retention of 10 years at 125 °C. Ordering Information and Content Guide appear at end of datasheet. ams Datasheet [v1-04] 2016-Feb-03 Page 1 Document Feedback AS3955 − General Description Key Benefits & Features The benefits and features of AS3955, NFC Forum Compliant Dynamic Tag are listed below: Figure 1: Added Value of Using AS3955 Benefits Features • NFC Forum compliance for full interoperability • Type 2 Tag standalone functionality • Type 4 Tag emulation with external MCU • NFC Forum compliance • ISO 14443A compliance up to Level 4 • Operating frequency at 13.56 MHz • Bit rate at 106 kbps • 7-byte UID • Choice of memory size based on application • 2 kbit EEPROM (216 bytes of user data) or • 4 kbit EEPROM (472 bytes of user data) • Allows zero-power standby • Configurable passive wake-up interrupt • Enables long battery life time, or battery-less designs • Energy harvesting to supply up to 5mA @ 4.5V (regulated) • Allows fast antenna prototyping (ISO antenna classes 1 to 6) • 45 pF integrated resonant capacitor • Design flexibility, easy integration. Fits requirements for various embedded applications • 3/4-wire SPI slave interface up to 5 Mbps • I²C slave interface up to 1 Mbps • Design flexibility, easy integration • Programmable I²C address • Fits supply requirements for various applications, including industrial • Wide interface supply range (1.65V to 5.5V) • Support for multiple applications, and storage of sensitive data • 32-bit password memory protection • High performance and robust data communication, allows custom protocols to be implemented • Tunneling and Extended modes for MCU communication • Consistent NFC behavior of battery supplied devices in e.g. pairing applications • Silent mode (MCU power status detection), configurable between 1.42V and 3.65V • Possibility to disable RF communication • Configurable Chip Kill mode • Small outline, compatibility to common inlay and card manufacturing lines, surface-mount assembly • Sawn wafer • WL-CSP package • 10-pin MLPD 3x3mm package Page 2 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − General Description Applications AS3955 is suited to a wide range of applications, including • NFC connection handover (Bluetooth™, Bluetooth Low Energy, Wi-Fi pairing) • Equipment setup, service and configuration • Firmware upgrades • Activity and status logging • Wireless authentication (e.g. access control to buildings and equipment) Typical Markets: • EMV payment cards • Consumer electronics, wearables and smart clothing • Home appliances • Automotive • Industrial equipment and building automation • Remote sensing • Gaming A typical system diagram is depicted in Figure 2. At the presence of a 13.56 MHz field generated by a NFC device, AS3955 powers up, notifies the microcontroller through a wake-up signal and handles the tag activation sequence. Depending on configuration, several operations are then possible: • AS3955 exchanges with the NFC device NDEF data stored in the internal EEPROM • The microcontroller exchanges with the NFC device NDEF data stored in external memory • The microcontroller exchanges data with AS3955. This operation can be performed concurrently with communication over the RF link, or also in absence of RF power, in presence of an external supply. Figure 2: Typical System Diagram I²C or SPI AS3955 ams Datasheet [v1-04] 2016-Feb-03 wake-up microcontroller Page 3 Document Feedback AS3955 − General Description This built-in flexibility makes it ideal for a number of applications requiring non-volatile memory to be accessed when the system is not powered, e.g.: • personalization data is programmed by the NFC device (even in case SPI / I²C is not powered) and it is later read by microcontroller through SPI / I²C interface • Log data is stored periodically by the microcontroller and can then be read by the NFC device even when the microcontroller is not powered • A NDEF message is regularly modified by the microcontroller (e.g. Bluetooth pin code, or Wi-Fi key, or dynamic URL) and it is later read by a NFC device. Block Diagram The functional blocks of this device are shown below: Figure 3: AS3955 Block Diagram VP_REG VP_INT AS3955 VP_IO POWER MANAGER VDD LC1 IRQ AFE LC2 Page 4 Document Feedback NFC FORUM TYPE 2 TAG LOGIC EEPROM 2k or 4kbit I²C/SPI INTERFACE I²C/SPI VSS ams Datasheet [v1-04] 2016-Feb-03 AS3955 − General Description AS3955 is composed of NFC-A Analog Front End (AFE), NFC Type 2 Tag Logic, EEPROM, SPI / I²C Interface and Power Supply Manager Block (Power Manager). The AFE is connected to an external tag coil which forms, together with integrated resonant capacitor, a LC tank resonating with the external electromagnetic field frequency of 13.56 MHz. The AFE has built-in rectifier and regulators. The output of the internal regulator (VP_INT) is used to supply the AFE and also the Logic and EEPROM (through Power Supply Manager). A regulator output VP_REG is available on a pin to supply external circuitry by harvesting energy from the RF field. The Power Manager is controlling the power supply of Logic and EEPROM. The two blocks can be supplied either from VP_ INT or from VP_IO (SPI / I²C power supply) depending on the power mode of the chip. AS3955 offers a power mode where VP_IO supply is switched to VP_INT whenever the RF field is present. VP_IO is typically used when some activity is started over the SPI / I²C and the VP_INT is too low to be used as a power supply. The Logic is responsible for handling the anti-collision sequence, when acting as NFC Type 2 Tag, and other data transfer. The interface logic contains also a 32-byte buffer for block transmission between NFC device and AS3955. The EEPROM is used to store the UID, configuration and control bits, and user data which can be accessed also via the SPI / I²C. ams Datasheet [v1-04] 2016-Feb-03 Page 5 Document Feedback AS3955 − Pin Assignment Pin Assignment Figure 4: AS3955 Pin Diagram GND VP_IO 1 10 IRQ VP_REG 2 9 MISO / SDA LC1 3 8 MOSI LC2 4 7 SCLK / SCL VSS 5 6 /SS AS3955 MLPD (Top view) /SS MOSI A1 A2 SCLK / SCL MISO / SDA A3 A4 VP_REG IRQ B1 B4 VSS LC2 LC1 VP_IO C1 C2 C3 C4 AS3955 WL-CSP (Top view) Page 6 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Pin Assignment Pin Description Figure 5: Pin Description 10-pin MLPD 10-pin WL-CSP Die Pin Name NA NA 1 meas Analog I/O Analog test pin (1) 1 C4 2 VP_IO Supply Pad Positive supply of the interface / IC 2 B1 3 VP_REG Analog Output Regulator output 3 C3 4 LC1 Pin Type Description Connection to tag coil Analog I/O 4 C2 5 LC2 Connection to tag coil 5 C1 6 VSS 6 A1 9 /SS 7 A3 10 SCLK / SCL 8 A2 11 MOSI 9 A4 12 MISO / SDA Digital Output / Tristate SPI data output / I²C data line 10 B4 13 IRQ Digital Output Interrupt request output (active high) Supply Pad Ground, die substrate potential SPI enable (active low) / I²C interface enable Digital Input SPI / I²C clock SPI data input Note(s): 1. Pin meas is not bonded in MLPD package. It is only used during wafer sort test. ams Datasheet [v1-04] 2016-Feb-03 Page 7 Document Feedback AS3955 − Absolute Maximum Ratings Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only. Functional operation of the device at these or any other conditions beyond those indicated under Operating Conditions is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Absolute Maximum Ratings Figure 6: Absolute Maximum Ratings Symbol Parameter Min Max Unit Comments Electrical Parameters VDD Vin DC supply voltage -0.5 6.5 V Input pin voltage except LC1 and LC2 -0.5 6.5 V Input pin voltage pins LC1 and LC2 -0.5 6.5 V 100 mA 100 mA Norm: Jedec 78 Norm: MIL 883 E method 3015 (Human Body Model) Peak current induced on pins LC1 and LC2 Iscr Input current (latch-up immunity) -100 Electrostatic Discharge ESDHBM Electrostatic discharge HBM ±2 kV ESDCDM ESD – machine and charged device models ±500 V Temperature Ranges and Storage Conditions Tstrg Storage temperature Tbody Package body temperature RHNC Relative humidity non-condensing MSL Moisture sensitivity level Page 8 Document Feedback -55 150 5 3 °C 260 °C 85 % Norm: IPC/JEDEC J-STD-020. The reflow peak soldering temperature (body temperature) is specified according IPC/JEDEC J-STD-020 “Moisture/Reflow Sensitivity Classification for Non-hermetic Solid State Surface Mount Devices.” The lead finish for Pb-free leaded packages is matte tin (100% Sn). Represents a max. floor life time of 168h ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Electrical Characteristics Electrical Characteristics All limits are guaranteed. The parameters with min and max values are guaranteed with production tests or SQC (Statistical Quality Control) methods. Operating Conditions All in this specification defined tolerances for external components need to be assured over the whole operation conditions range and also over lifetime. Figure 7: Electrical Characteristics Symbol Parameter Ilim Min Limiter current Max Unit 30 mA Notes VVP_IO SPI power supply 1.65 5.5 V When logic powered from RF interface VVP_IO SPI power supply 1.65 5.5 V When logic powered from VP_IO Junction temperature -40 125 °C Tjunc DC/AC Characteristics for Digital Inputs and Outputs Figure 8: CMOS Inputs Symbol Parameter VIH High level input voltage VIL Low level input voltage ILEAK Input leakage current Min Typ Max 0.7 * VDD_IO Unit Note V 0.3 * VDD_IO V 10 μA @125°C Note(s): 1. Valid for input pins /SS, MOSI and SCLK ams Datasheet [v1-04] 2016-Feb-03 Page 9 Document Feedback AS3955 − Electrical Characteristics Figure 9: CMOS Outputs Symbol VOH Parameter High level output voltage Min Typ Max Unit 0.85 * VDD_ IO Note V VOL Low level output voltage RO Output resistance 200 RPD Pull-down resistance pad MISO 10 Isource=1mA VP_IO = 5V 0.15 * VDD_IO V 400 Ω kΩ See note (1) Note(s):Valid for output pins MISO and IRQ 1. Pull down can be enabled while MISO output is in tristate. The activation is controlled by register setting. Electrical Specifications Figure 10: Electrical Specifications Symbol Typ Max Unit Note Stand by consumption on VP_IO 65 100 nA @ 25°C (RF field not applied) VLIM Limiter voltage 5.2 5.5 V ILC=30mA (DC) (2) IS Supply current 350 μA See note (3) VHF_PON HF_PON threshold (rising VREG) 1.6 2.3 V See note (4) VPOR_HY HF_PON hysteresis 0.8 V VMOD Modulator ON voltage drop 1.2 2.6 V CRES Resonance capacitor 45 pF EEEN EEPROM endurance EERET EEPROM retention ISB_SPI Parameter Min ILC=1mA (2) ILC=30mA (2) 100 000 cycles @ 125°C (5) 10 years @ 125°C (6) Note(s): 1. VP_IO=1.8V, Temperature 25°C unless noted otherwise. 2. I LC is the current flowing through LC1 and LC2 pins 3. Internal supply current measured over VP_IO pin, by forcing internal digital supply to 2.0V, and applying 13.56 MHz alternative pulses with amplitude 3.0Vpp to LC1 and LC2. 4. 1.6V is set in Power Mode 2 only. 5. See Figure 11. Page 10 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Electrical Characteristics 6. See Figure 12. Figure 11: EEPROM Endurance Over Temperature Endurance EEPROM 2,500,000 Number of Cycles 2,000,000 1,500,000 1,000,000 500,000 0 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 100 110 120 130 Temperature [°C] ams Datasheet [v1-04] 2016-Feb-03 Page 11 Document Feedback AS3955 − Electrical Characteristics Figure 12: EEPROM Data Retention Over Temperature Data retention EEPROM 10,000 data retention [years] 1,000 100 10 1 0 25 50 75 100 125 150 Temperature [°C] Page 12 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Detailed Description Detailed Description Analog Frontend (AFE) The AFE is connected to external tag coil, which together with the integrated resonant capacitor forms an LC tank resonating at the external electromagnetic field frequency (13.56 MHz). Figure 13 depicts the main AFE building blocks. Figure 13: PICC AFE Block Diagram VP_REG RECTIFIER VREC VP_INT EXTERNAL REGULATOR INTERNAL REGULATOR LIMITER LC1 MODULATOR SWITCH BIAS HF PON NFC Type 2 Tag Logic LC2 DEMODULATOR CLOCK EXTRACTOR Rectifier extracts DC power supply from the AC voltage induced on coil terminals. Limiter limits the maximum voltage on coil terminals to protect AFE from destruction. At voltages that exceed limiter voltage it starts to absorb current (acts as some sort of shunt regulator). Modulator Switch is used for communication the NFC tag to a NFC device. When switched on it will draw current from coil terminals. This mechanism is called load modulation. Variation of current in the modulator switch (ON and OFF state) is seen as modulation by the NFC device. ams Datasheet [v1-04] 2016-Feb-03 Page 13 Document Feedback AS3955 − Detailed Description Demodulator is used for communication NFC device to NFC tag. It detects AM modulation of the NFC device magnetic field. The demodulator is designed to accept modulation according to NFC-A specifications ([NFC Analog] [NFC Digital]). Clock Extractor extracts a digital clock signal from the PCD carrier field frequency which is used as clock signal by logic blocks. HF_PON enables operation of the AFE and the logic when the supply voltage is sufficiently high. A buffer capacitor and HF_ PON hysteresis guarantee that there is no reset during NFC device modulation. Internal Regulator provides regulated voltage VP_INT to the AFE and in most cases also to EEPROM and logic blocks. Typical regulated voltage VP_INT is 2.0V. A buffer capacitor is also integrated. External Regulator provides regulated voltage on external pin VP_REG where it can be used to supply some external circuitry. The regulated voltage and output resistance can be adjusted using EEPROM settings. Appropriate external buffer capacitor is needed in case VP_REG is used in the application. Current which may be provided depends on reader field strength, antenna size and Q factor, but it is limited to maximum 5mA. Bias provides bias currents and reference voltages to AFE analog blocks. Power Management AS3955 power management comprises of four different modes to fit requirements of different applications. AS3955 supports two power sources, whose activation depends on the selected power mode. Power Mode 0 In this power mode, the Power Manager is controlling the supply of the PICC Logic, EEPROM and SPI / I²C Interface (VDD). Its inputs are VP_INT (rectified and regulated supply extracted from RF field) and the VP_IO (supplied by external battery). In standby mode, when AS3955 is not in the RF field (the condition is that rectified supply voltage is below HF_PON threshold) and the SPI / I²C is not active (/SS is high), the VDD supply is disconnected. The only current consumption in this state is leakage on VP_IO, mainly due to level shifters and SPI / I²C pins. When AS3955 is placed in a RF field, VDD is connected to VP_ INT. This happens once the VP_INT level is above the HF_PON threshold. Page 14 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Detailed Description VP_IO is connected to VDD only when AS3955 is not in the RF field (rectified supply voltage is below HF_PON threshold) and the SPI / I²C interface is activated by pulling /SS signal low. The switch to VP_IO is controlled by /SS signal. The deactivation is delayed by 0.7ms minimum, so that the switch shall stay closed in case of shorter times between successive SPI / I²C activations. The switch is also closed during EEPROM writes activated over SPI / I²C. At activation of the switch, the time between the falling edge of the /SS signal and rising edge of SCLK shall be at least 300μs to allow charging of internal VDD buffer capacitor, expiration of POR signal and to perform a complete IC initialization. Please note that the only SPI / I²C operations, which are allowed in this mode, are read and write of EEPROM and registers. If the RF filed is lost during operation and the external system (MCU) is supplied over battery and /SS is low then power manager will automatically connect the VDD to VP_IO. To enable low power mode where tag consumes less than 1uA at room temperature following conditions must be met: • SPI interface configured • All SPI interface input lines (including /SS) must be set to high • All SPI output lines must be open Figure 14: Power Manager Concept ams Datasheet [v1-04] 2016-Feb-03 Page 15 Document Feedback AS3955 − Detailed Description Power Mode 1 AS3955 is fully supplied by RF field. AS3955 checks if Extended or Tunneling mode are enabled. In this case, VP_REG supplies the system (SPI / I²C pads, pull-ups, MCU), otherwise energy harvesting is turned off and VP_REG is set in tristate. Such power mode can be used in battery-less systems where the system is fully powered by the RF field. In such configuration, the VP_REG output pin for energy harvesting and VP_IO input supply shall be externally connected. Battery, even when present, will not be involved. If this power mode is enabled and neither tunneling nor extended mode are enabled, rreg value from IC Configuration Register 1 will be forced to zero. This will disable energy harvesting. Power Mode 2 In this case, the external supply is used to provide power to digital blocks, EEPROM, SPI / I²C pads and MCU. External supply VP_REG is not used. Since this mode can be enabled only after initialization of the chip, the /SS line must be either permanently set to low or pulled low for short time (400μs) to complete the initialization. This mode is specifically designed to operate with AS392x products (ams’ Active Boost). In this mode, the HF_PON threshold of the chip will be decreased so that it will operate with external voltage on LC pin in the range of 2.7-3.6Vpp. If this mode is enabled, AS3955 will not be turned off as long as there is an external supply present. Power Mode 3 In this case the external supply shall be used to provide power to digital blocks, EEPROM, SPI / I²C pads and MCU. External supply VP_REG is not used. Since this mode can be enabled only after initialization of the chip, the /SS line must be either permanently set to low or pulled low for short time to complete the initialization. In this mode, the HF_PON threshold of the chip is set so that it will operate with external voltage on LC pin in the range of 4.1-5Vpp. If this mode is enabled, AS3955 will not be turned off as long as there is an external power present. Page 16 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Detailed Description Interface Arbitration Concurrent access to AS3955 internal EEPROM from RF or SPI / I²C requires arbitration, to resolve conflicts or undesired behaviour. AS3955 implements two arbitration modes, which can be set in Configuration Byte IC_CFG0. Arbitration Mode 0 AS3955 arbitrates EEPROM write accesses according to first-come-first-serve principle. • In case no write access is currently ongoing, both RF and SPI / I²C interfaces are allowed to write into EEPROM. • In case a write request comes over RF, while SPI / I²C is writing, AS3955 will return a NAK. • In case a write request comes over SPI / I²C while RF is writing, AS3955 will trigger a I_err_acc interrupt (see Figure 94). Arbitration Mode 1 AS3955 gives always priority to RF accesses. In this mode, AS3955 behaves over RF as a pure contactless tag. • In case SPI / I²C is performing a EEPROM write while the RF field is turned on, the write operation is interrupted to allow the initialization of the RF communication • In case the RF field is already on and SPI / I²C performs a write to EEPROM and a READ or WRITE command is received via RF, the write operation of SPI / I²C is interrupted so that the RF operation can be performed In both cases, a I_err_acc interrupt (see Figure 94) will be triggered. Please note that the interruption of an EEPROM write may result in an undefined or “weak” state for the cell being programmed, and a second successful write attempt is suggested. ams Datasheet [v1-04] 2016-Feb-03 Page 17 Document Feedback AS3955 − Detailed Description Energy Harvesting AS3955 has energy harvesting capability. The regulated voltage output pin for energy harvesting is VP_REG. The energy harvesting is enabled only in Power Mode 0 and 1. Figure 16 shows settings of the regulated voltage output. The output can be set between 1.8V and 4.5V in 100mV step. The output voltage and resistance can be set by Configuration Byte IC_CFG1.The energy harvesting can be disabled by setting the output resistance register to 0 as shown in Figure 15. Figure 15: Output Resistance Settings rreg Output Resistance Comment 00b X Disabled – output pin is in tristate 01b 100Ω 10b 50Ω 11b 25Ω Figure 15 shows settings of the regulated voltage output. The output can be set between 1.8V and 4.5V in 100mV step. Figure 16: Regulated Voltage Output Settings Page 18 Document Feedback vreg Output Voltage Abs. Accuracy 00000b 1.8V ±115mV 00001b : : Step 100mV ±20mV Linearly increasing over range 11011b 4.5V ±225mV ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Detailed Description Silent Mode The Silent mode enables detection of the power status of a circuit whose supply (Vdd) is connected to VP_IO pin. If this mode is enabled and the voltage measured on pin VP_IO is below the configured threshold value, the RF part of AS3955 will be disabled, and the IC will not be responsive to incoming commands. Silent mode settings can be performed by using Configuration Byte IC_CFG0. This feature overcomes a potentially inconsistent behavior in a battery powered system, where a passive NFC tag can always communicate with a NFC device, also in case the battery is not sufficiently charged to supply the rest of the system. A typical example is when the NFC tag is used for Bluetooth pairing: AS3955 would trigger a pairing procedure only in case the system is fully operational by monitoring the supply voltage. Memory Protection AS3955 internal memory can be protected from unauthorized access by enabling password authentication. A 32-bit password can be set to protect the full user memory, or part of it, to allow the creation of a public data and a private data area. Password protection can be applied for read and write accesses. Password authentication is performed through a standard WRITE command to the Authentication Password block. A maximum of 7 negative attempts are permitted before the chip is locked. Once authenticated, the user can modify the password. Password protection applies to RF communication only. Further information on how to handle password authentication can be found in Authentication Password, Configuration Byte AUTH_CFG, Configuration Byte AUTH_CNT and Configuration Byte AUTH_LIM. Passive Wake-Up AS3955 is able to operate NFC tag operations standalone and fully powered by the RF field. The connected MCU can remain is standby/sleep mode as long as its intervention is not required by the application, in order to save power. AS3955 can be configured to notify the MCU through a wake-up interrupt. A number of triggering events can be selected, e.g.: • Power up • SELECTED state entered • Reception of SLP_REQ command • NFC device has updated memory content For a complete interrupt source list, please refer to the section Interrupt Registers. ams Datasheet [v1-04] 2016-Feb-03 Page 19 Document Feedback AS3955 − Detailed Description Chip Kill Some applications require that the RF link is active only under certain conditions, e.g. during device configuration only in a controlled environment like a production facility. AS3955 can be configured by the MCU in order to restrict the NFC device access to the system. By setting the Configuration Byte CHIP_KILL in EEPROM, the MCU can disable access to SPI / I²C from the RF link (i.e. Tunneling and Extended mode are permanently disabled), or even disable RF communication completely. In the latter case, AS3955 will not respond to incoming RF commands. This configuration can be modified only by the MCU through SPI / I²C interfaces. NFC Tag Functionality Communication Principle AS3955 autonomously executes complete NFC-A anti-collision communication sequence, during which the 7-byte UID is used ([NFC Analog] [NFC Digital]). After anti-collision, the NFC tag is brought into SELECTED state where read and write commands can be processed. The NFC tag will accept only read and write command issued to the address space actually available in AS3955 EEPROM. Any attempt to access an address outside the internal memory address space will be rejected. This default behavior of the NFC tag can be modified by enabling Tunneling or Extended mode. A simplified AS3955 state diagram is shown in Figure 17. Page 20 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Detailed Description Figure 17: AS3955 State Diagram POWER OFF (RF field off) Reset SLEEP SENSE SENS_REQ ALL_REQ ALL_REQ RESOLUTION ANTI-COLLISION SLP_REQ SEL_REQ SLP_REQ SELECTED READ (16 bytes) WRITE (4 bytes) GET VERSION WRITE Authentication Password AUTHENTICATED READ (16 bytes) WRITE (4 bytes) GET VERSION SENSE State After a power-on reset (POR), AS3955 switches to the SENSE state. This state is exited when a SENS_REQ or an ALL_REQ command is received from the NFC device. Any other data received while in this state is interpreted as an error and AS3955 remains in SENSE state. When in SELECTED or AUTHENTICATED state, a correctly executed SLP_REQ command will modify the default waiting state from SENSE to SLEEP state. SLEEP state can be exited when an ALL_REQ command is received. ams Datasheet [v1-04] 2016-Feb-03 Page 21 Document Feedback AS3955 − Detailed Description SLEEP State Together with SENSE state, SLEEP state is the other waiting state for AS3955. SLEEP state can be entered upon reception of a SLP_ REQ command. The distinction between SENSE and SLEEP state is made necessary to discriminate selected and not yet selected tags. AS3955 can only exit this state upon reception of an ALL_REQ command. Any other command received in this state is interpreted as an error and AS3955 state remains unchanged. RESOLUTION State In RESOLUTION state, the NFC device is resolving the tag UID. Since AS3955 has a double size UID, the RESOLUTION state actually comprises of two sub-states, where the anti-collision procedure is carried out in Cascade Level 1 and 2. Please refer to [ISO18092] for further information. SELECTED State All memory operations are operated in SELECTED state. Upon reception of a SLP_REQ command, SELECTED state is exited and AS3955 transits to SLEEP state. Any other command received when the device is in this state is interpreted as an error. Depending on its previous state, AS3955 returns to either SENSE or SLEEP state. Upon reception of a SECTOR SELECT command, AS3955 returns a NAK and transits to SENSE or SLEEP state, depending on its previous state. AS3955 transits to the AUTHENTICATED state after successful password verification, using a standard WRITE command to a dedicated memory address (see Authentication Password). The number of permitted failed authentications is set to 7, after which AS3955 transits to LOCKED sub-state (not shown in the picture). When LOCKED state is entered, only the MCU can bring AS3955 back to SENSE state by resetting the authentication counter (Configuration Byte AUTH_CNT) back to 0 and issue a Set Default, or Go To Sense, or Go To Sleep command. When in LOCKED sub-state, all memory operations are only allowed in the memory area not password protected, as defined by the configuration byte Configuration Byte AUTH_LIM. Upon reception of a SLP_REQ command, SELECTED state is exited and AS3955 transits to SLEEP state. Any other command received when the device is in this state is interpreted as an error and, depending on its previous state, AS3955 returns to either SENSE or SLEEP state. Page 22 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Detailed Description AUTHENTICATED State In this state, all operations on memory blocks, which are configured as password verification protected, can be performed. Upon reception of a SECTOR SELECT command, AS3955 returns a NAK and transits to SENSE or SLEEP state, depending on its previous state. Upon reception of a SLP_REQ command, AUTHENTICATED state is exited and AS3955 transits to SLEEP state. Any other command received when the device is in this state is interpreted as an error and, depending on its previous state, AS3955 returns to either SENSE state or SLEEP state. NFC Forum Type 2 Tag Support NFC Forum NFC-A commands ALL_REQ, SENS_REQ, SDD_REQ, SEL_REQ, SLP_REQ are required for anti-collision. Commands READ and WRITE are used for internal memory access. If NFC device issues a SECTOR SELECT command, AS3955 shall always reply with NAK. Figure 18: NFC-A vs ISO14443 Terminology NFC-A Term ISO14443 Term States SENSE IDLE SLEEP HALT RESOLUTION READY SELECTED ACTIVE Commands / Responses ams Datasheet [v1-04] 2016-Feb-03 SENS_REQ REQA ALL_REQ WUPA SENS_RES ATQA SSD_REQ AC SEL_REQ SELECT SLP_REQ HLTA Page 23 Document Feedback AS3955 − Detailed Description UID Coding Anti-collision procedure is based on the Unique Identification Number (UID). AS3955 supports double size UID (7 bytes). First three bytes of the UID are hardwired inputs to the PICC Logic (uid). The last 4 bytes of the UID are stored in EEPROM UID block. First UID Byte (uid0) The first byte of UID is Manufacturer ID according to [ISO7816-6]. It is coded on bits uid. ams IC Manufacturer ID is 3Fh. Second UID Byte (uid1) The second byte of UID (uid) is reserved for ams’ chip type (IC Type). Every ams’ RFID tag IC has its own chip type assigned. AS3955 IC type is 14h. Third UID Byte (uid2) The third byte of UID (uid) is set to 00h. Figure 19: Coding of First Three UID Bytes UID Byte Value (Hex) uid0 3F uid1 14 uid2 00 Last Four UID Bytes (uid3-uid6) The last 4 bytes of UID are read from EEPROM (UID block) and pre-programmed during IC production. Those 4 bytes are unique, and cannot be modified. Figure 20: Last Four UID Bytes Page 24 Document Feedback UID Byte UID Block Bits uid3 b7-b0 uid4 b15-b8 uid5 b23-b16 uid6 b31-b24 ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Detailed Description Coding of SENS_RES, SEL_REQ, ACK and NACK Several bits in certain responses are defined as don’t-care in the NFC-A standard [NFC Digital], some others are defined by optional choices in standard protocol. This chapter defines how these bits are actually set in AS3955. SENS_RES Response SENS_RES is a response on ALL_REQ and SENS_REQ commands. The SENS_RES is defined by Configuration Bytes SENSR1 and SENSR2 stored in EEPROM. Figure 21: Coding of SENS_RES Response b15 b14 b13 b12 b11 b10 b9 b8 b7 b6 b5 b4 SENSR2 b3 b2 b1 b0 SENSR1 SEL_RES Response, Cascade Level 1 and 2 SEL_RES is the response to SEL_REQ command. Since AS3955 UID is double sized, SEL_RES responses for Cascade Level 1 and Cascade Level 2 are defined. SEL_RES on Cascade Level 1 and 2 is defined with Configuration Byte SELR except for cascade bit 3. The response on Cascade Level 2 is also configured by selr_ b6_inv bit which, when set, inverts cascade bit 6 in SEL_RES response on Cascade Level 2 (see IC_CFG2). Figure 22: SEL_RES CL1 Coding b8 MSB b7 b6 b5 b4 sel_res b3 b2 b1 LSB 1 sel_res b4 b3 Description Cascade bit set: UID not complete Figure 23: SEL_RES CL2 Coding b8 MSB b7 b6 b5 b2 b1 LSB sel_res sel_res selr_b6_inv set to 0 sel_res NOT sel_res Description 0 sel_res selr_b6_inv set to 1 Note(s): 1. According to [ISO14443-3], all bits except b3 are “don’t care” for Cascade Level 1, and all bits except b6 and b3 are “don’t care” for Cascade Level 2. Bit b6 in CL2 indicates whether the tag is compliant to [ISO14443] or not (resp. b6=1 and b6=0). In case of applications requiring EMVCo compliance, bit b6 in Cascade Level 1 shall be set as bit b6 in Cascade Level 2 ([EMVCO-1]). ams Datasheet [v1-04] 2016-Feb-03 Page 25 Document Feedback AS3955 − Detailed Description ACK Response The ACK response of AS3955 is a 4-bit value Ah. NACK Response The AS3955 uses all four combinations of NAK values. The usage of various NAK values is explained in section Error Handling. Access to UID, SENS_RES and SEL_REQ During Anti-Collision UID block, SENSR1, SENSR2 and SELR bytes are stored in a buffer. The purpose of storing these data into the buffer is faster access to the data and UID verification during the anti-collision procedure. Buffer access over SPI / I²C is locked until NFC tag enters SELECTED state. Get Version Command In addition to standard NFC tag commands, AS3955 supports a custom Get Version command. This command consists of 8 bits and shall be transmitted only in standalone and Extended mode when the tag is SELECTED state. The command code and the tag response are shown resp. in Figure 24 and Figure 25. Figure 24: Coding of Get Version Command Page 26 Document Feedback b8 b7 b6 b5 b4 b3 b2 b1 0 1 1 0 0 0 0 0 ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Detailed Description Figure 25: Response to Get Version Command Byte No. Description Comment 0 Fixed Header 00h 1 Vendor Id 3Fh ams AG 2 Product Type 14h AS395x 3 Product Subtype 01h AS3955 4 Major Product Version 01h 1 5 Minor Product Version 00h V0 6 Storage Size 7 Supported Features 15h 17h See note (1) 01h or 02h See note (2) Note(s):Notes: 1. The most significant 7 bits of the storage size byte are interpreted as an unsigned integer value n. As a result, it codes the total available user memory size as 2 n. If the least significant bit is 0b, the user memory size is exactly 2n . If the least significant bit is 1b, the user memory size is between 2n and 2n+1. The user memory is the memory available for user data (Capability Container and lock bits are excluded) 2. The figure below is maintained consistently across the whole AS395x family, where Get Version command is supported. Figure 26: Get Version Response, Byte 7 Get Version Byte No. 7 Description b7 b6 b5 b4 00000b: ISO14443A Level 3 supported, max baudrate 106 kbps, Tunneling and Extended mode present, Password protection available, energy harvesting available Others: RFU b3 b2 b1 000b: No wired interface available 001b: SPI slave, passive wake-up available 010b: I²C slave, passive wake-up available b0 ams Datasheet [v1-04] 2016-Feb-03 Page 27 Document Feedback AS3955 − Detailed Description Memory Organization AS3955 contains an embedded EEPROM module which can be accessed via RF or SPI / I²C interface. EEPROM contains 4096 bits (512 bytes) organized in 128 blocks of 4 bytes each. Blocks in EEPROM are numbered from 00h to 7Fh. Bits in a block are numbered from 0 to 31. Most of the EEPROM is NFC Type 2 Tag user data area (472 bytes). The position of the dynamic lock bits is fixed at the end of NFC Type 2 Tag user data area (blocks 7Ah and 7Bh). The configuration bits which define AS3955 operating options are stored in blocks 01h, 7Ch, 7Dh, 7Eh, 7Fh. Housekeeping information is stored in block 00h. 4kbit EEPROM organization is shown in Figure 27. AS3955 is also available in 2kbit version. In this case the data area is reduced to 216 byte. AS3955 internal user memory implements static and dynamic lock bits according to NFC Forum Type 2 Tag standard. Configuration and lock bits, as well as the full 2kbit EEPROM organization, are shown in Figure 28. 4kbit EEPROM Organization Numbers of dynamic lock bits: • Data area size in bytes: 4*(127 – 3) – 7 – 17 = 472 bytes • Number of dynamic lock bits: (472 – 48) / 8 = 53 bits (53 bits) Page 28 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Detailed Description Figure 27: 4kbit EEPROM Organization Byte Number in Block Block 0 1 2 3 Description Access 00h UID0 UID1 UID2 UID3 UID / Internal RO 01h FAB_CFG0 FAB_CFG1 FAB_CFG2 FAB_CFG3 Fabrication data RO 02h Internal 8 Internal 9 Lock 0 Lock 1 Internal / Lock OTP 03h CC 0 CC 1 CC 2 CC 3 CC OTP 04h Data 0 Data 1 Data 2 Data 3 Data RW 05h Data 4 Data 5 Data 6 Data 7 Data RW 06h Data 8 Data 9 Data 10 Data 11 Data RW Data RW 07h : : 79h 7Ah Lock 2 Lock 3 Lock 4 Lock 5 Lock OTP 7Bh Lock 6 Lock 7 Lock 8 (1) Reserved 0 Lock / Reserved OTP 7Ch RFP0 RFP1 RFP2 RFP3 Authentication password RW 7Dh CHIP_KILL AUTH_CNT AUTH_LIM AUTH_CFG Authentication settings RW 7Eh SENSR1 SENSR2 SELR IC_CFG0 Config. block 0 RW 7Fh IC_CFG1 IC_CFG2 MIRQ_0 MIRQ_1 Config. block 1 RW Note(s): 1. Bits that are not used should be set to 0. Access properties: RO: Read only, writing to this word is not possible RW: Reading and writing to this word is possible OTP: One time programmable. A bit of this word once set to 1 cannot be set back to 0. ams Datasheet [v1-04] 2016-Feb-03 Page 29 Document Feedback AS3955 − Detailed Description 2kbit EEPROM Organization Numbers of dynamic lock bits: • Data area size in bytes: 4*(63 – 3) – 3 – 21 = 216 bytes • Number of dynamic lock bits: (200 – 48) / 8 = 21 bits (21 bits) Figure 28: 2kbit EEPROM Organization Byte Number in Block Block 0 1 2 3 Description Access Byte number in block Block 0 1 2 3 Description Access 00h UID0 UID1 UID2 UID3 UID / Internal RO 01h FAB_CFG0 FAB_CFG1 FAB_CFG2 FAB_CFG3 Fabrication data RO 02h Internal 8 Internal 9 Lock 0 Lock 1 Internal / Lock OTP 03h CC 0 CC 1 CC 2 CC 3 CC OTP 04h Data 0 Data 1 Data 2 Data 3 Data RW 05h Data 4 Data 5 Data 6 Data 7 Data RW 06h Data 8 Data 9 Data 10 Data 11 Data RW Data RW 07h : : 39h 3Ah Lock 2 Lock 3 Lock 4 Lock 5 Lock OTP 3Bh Lock 6 Lock 7 Lock 8 (1) Reserved 0 Lock / Reserved OTP 3Ch RFP0 RFP1 RFP2 RFP3 Authentication password RW 3Dh CHIP_KILL AUTH_CNT AUTH_LIM AUTH_CFG Authentication settings RW 3Eh SENSR1 SENSR2 SELR IC_CFG0 Config. block 0 RW 3Fh IC_CFG1 IC_CFG2 MIRQ_0 MIRQ_1 Config. block 1 RW Note(s): 1. Bits that are not used should be set to 0. Access properties: RO: Read only, writing to this word is not possible RW: Reading and writing to this word is possible OTP: One time programmable. A bit of this word once set to 1 cannot be set back to 0. Page 30 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Detailed Description UID Bytes The UID block contains four LSB bytes of the 7-byte UID which is used during anti-collision and selection process. Every IC is programmed by a unique number during fabrication process at ams. See UID Coding about details on UID. This block stores some IC manufacturer data which is programmed and locked during fabrication process at ams. UID is treated as IC internal configuration, and is permanently locked during IC production. Fabrication Data Fabrication data are used to set internal configuration and trimming values. They are treated as IC internal configuration. Fabrication Data FAB_CFG0 Figure 29: Fabrication Data FAB_CFG0 Conf. Bit Name Default b7 0 b6 0 b5 0 b4 0 b3 0 b2 0 b1 0 b0 0 Function Note Internal configuration Note(s): 1. This byte can be set only during production. ams Datasheet [v1-04] 2016-Feb-03 Page 31 Document Feedback AS3955 − Detailed Description Fabrication Data FAB_CFG1 Figure 30: Fabrication Data FAB_CFG1 Conf. Bit Name Default b7 fdel 0 b6 fdel 0 b5 fdel 0 b4 fdel 0 b3 osct 0 b2 osct 0 b1 decc 0 b0 decc 0 Function Note PCD to PICC frame delay time compensation; frame compensation defined as fdel*1/fc Oscillator trimming bits Decoder compensation register Note(s): 1. This byte can be set only during production. The fdel bits define frame delay time (FDT) adjustment and represent a time compensation in number of clocks of carrier frequency. The osct bits are trimming bits for the internal oscillator. Fabrication Data FAB_CFG2 Figure 31: Fabrication Data FAB_CFG2 Conf. Bit Name Default Function Note b7 test_mode 0 b6 mod_r 0 1: decreased modulator switch resistance b5 miso_pd2 0 1: pull down on MISO, when \SS is low and MISO is not driven by the AS3955 b4 miso_pd1 0 1: pull down on MISO when \SS is high b3 rfu 0 b2 rfu 0 b1 rfu 0 b0 rfu 0 Note(s): 1. This byte can be set only during production. Page 32 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Detailed Description Fabrication Data FAB_CFG3 Figure 32: Fabrication Data FAB_CFG3 Conf. Bit Name b7 uid_crc b6 uid_crc b5 uid_crc b4 uid_crc b3 uid_crc b2 uid_crc b1 uid_crc b0 uid_crc Default Function Note CRC value calculated on UID Note(s): 1. This byte can be set only during production. Reserved Bytes The reserved bytes belong to reserved memory areas. OTP Blocks Write and Read Lock blocks are OTP (One Time Programmable). This means that once they are set to 1, they cannot be set back to 0. Since setting OTP bits is an irreversible operation, it is strongly recommended to perform this operation in controlled environment. Lock Bits The bits of byte 2 and 3 of block 02h represent the field-programmable read-only locking mechanism called “static lock bytes”. They are called static because their position in memory is fixed. When data memory is larger than 16 blocks (64 bytes), also “dynamic lock bytes” are required. They are located starting at address 7Ah (4kbit version) and address 3Ah (2kbit version). Block lock granularity is 1 block per bit for the first 16 blocks, 2 blocks per bit for the remaining blocks. Lock bits are OTP, i.e. setting bits to 1b is an irreversible operation. Bits at 0b can be set to 1b through a WRITE operation, the result being a bit-wise OR with the current value. ams Datasheet [v1-04] 2016-Feb-03 Page 33 Document Feedback AS3955 − Detailed Description Lock bits apply only to RF interface, as SPI / I²C interface has unlimited access to user data area. • Lock 0 byte locks 8 blocks starting from address 00h where lock bit 0 locks block on address 00h • Lock 1 byte locks 8 blocks starting from address 08h where lock bit 0 locks block on address 08h • Lock 2 byte locks 16 blocks starting from address 10h where lock bit 0 locks block on address 10h and 11h • Lock 3 byte locks 16 blocks starting from address 20h where lock bit 0 locks block on address 20h and 21h • Lock 4 byte locks 16 blocks starting from address 30h where lock bit 0 locks block on address 30h and 31h • Lock 5 byte locks 16 blocks starting from address 40h where lock bit 0 locks block on address 40h and 41h • Lock 6 byte locks 16 blocks starting from address 50h where lock bit 0 locks block on address 50h and 51h • Lock 7 byte locks 16 blocks starting from address 60h where lock bit 0 locks block on address 60h and 61h • Lock 8 byte locks 16 blocks starting from address 70h where lock bit 0 locks block on address 70h and 71h Figure 33: Example of Lock Bits Lock 0 byte b7 b6 b5 b4 b3 Lock 1 byte b2 b1 b0 b7 b6 b5 locks block 07h 06h 05h 04h 03h b4 b3 b2 b1 b0 0Ah 09h 08h locks block 02h 01h 00h 0Fh 0Eh 0Dh 0Ch 0Bh Capability Container Block 03h in AS3955 EEPROM contains the Capability Container (CC), pre-programmed during IC production according to NFC Forum Type 2 Tag specifications [T2T]. CC bits are OTP, i.e. setting bits to 1b is an irreversible operation. Bits at 0b can be set to 1b through a WRITE operation, the result being a bit-wise OR with the current value. Figure 34 and Figure 35 show the Capability Container content at delivery. Figure 34: CC Content at Delivery (4kbit Option) Byte number in block Block address 0 1 2 3 03h E1h 10h 3Bh 00h Page 34 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Detailed Description Figure 35: CC Content at Delivery (2kbit Option) Byte number in block Block address 0 1 2 3 03h E1h 10h 1Bh 00h Configuration Bytes The Configuration bytes are used to define AS3955 operating options. AS3955 is delivered by ams with default settings. Authentication Password The Authentication password block (bytes RFP0, RFP1, RFP2, and RFP3) contains the 32-bit password. This password is used for authentication over RF side. The NFC tag is set into AUTHENTICATED state when a write command is issued via the RF to write password address with the data that has same content as the data stored in Authentication password block. If the NFC tries to authenticate with a wrong password, AS3955 shall not respond and returns into SENSE / SLEEP state and the value of the AUTH_CNT is decreased. The password can be overwritten via RF only in AUTHENTICATED state and can always be set via SPI / I²C. Configuration register AUTH_CFG defines access rights controlled by the password. The RF password can’t be read via RF. The authentication for read or write is required only to the memory portion defined by AUTH_LIM. The chip is no longer in AUTHENTICATED state when the tag leaves SELECTED state. An attempt to read the password block will return zeroes. The authentication does not override permissions set by the lock bits. Authentication also does not restrict access over SPI / I²C in any way. Authentication can be configured using configuration bits in AUTH_CFG and AUTH_LIM bytes. ams Datasheet [v1-04] 2016-Feb-03 Page 35 Document Feedback AS3955 − Detailed Description Configuration Byte CHIP_KILL Figure 36: Configuration Byte CHIP_KILL Conf. Bit Name Default Function b7 chip_kill_2 0 1: Tunneling and Extended mode are disabled b6 chip_kill_1 0 1: RF communication part is disabled b5 rfu 0 b4 rfu 0 b3 rfu 0 b2 rfu 0 b1 rfu 0 b0 rfu 0 Note Note(s): 1. This byte can always be accessed for read and write via the SPI / I²C and can’t be accessed for read and write from the RF side. By setting CHIP_KILL byte the RF communication part of the chip or Tunneling and Extended mode will be disabled permanently. At its initial state, the CHIP_KILL byte is set to value 00h. The value of this byte can be changed via SPI / I²C. If bit b6 is set to value 1, the RF part of the chip shall be disabled and AS3955 will not respond to any command received from a NFC device. By setting bit b7 to 1, Tunneling and Extended mode will be disabled. Page 36 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Detailed Description Configuration Byte AUTH_CNT Figure 37: Configuration Byte AUTH_CNT Conf. Bit Name Default b7 rfu 0 b6 auth_cnt2 1 b5 auth_cnt2 1 b4 auth_cnt2 1 b3 rfu 0 b2 auth_cnt1 1 b1 auth_cnt1 1 b0 auth_cnt1 1 Function Note Authentication counter 2 Authentication counter 1 Note(s): 1. This byte can always be accessed for read and write via the SPI / I²C and can’t be accessed for read and write from the RF side. This byte indicates the number of allowed unsuccessful authentication attempts over RF available before disabling the chip. The byte consists of two separate counters where the second counter is a copy of the first counter. These counters are updated at each failed authentication. At each successful authentication, counters are reset to 7 and, at each unsuccessful authentication attempt, counters are decreased by one. If the value of the counters reaches 0, the chip will be permanently locked and cannot be authenticated any longer over the RF field. The chip will also be locked in case the two counter values don’t match. The lock can always be cleared via SPI / I²C interface. ams Datasheet [v1-04] 2016-Feb-03 Page 37 Document Feedback AS3955 − Detailed Description Configuration Byte AUTH_LIM Figure 38: Configuration Byte AUTH_LIM Conf. Bit Name Default b7 auth_lim 1 b6 auth_lim 1 b5 auth_lim 1 b4 auth_lim 1 b3 auth_lim 1 b2 auth_lim 1 b1 auth_lim 1 b0 auth_lim 1 Function Note AUTH_LIM defines the block address above which password verification is required. Note(s): 1. This byte can always be accessed for read and write via SPI / I²C and can be accessed for read and write from the RF side if chip is in AUTHENTICATED state and configuration bit auth_set is 1. AUTH_LIM defines the block address above which password verification is required. Valid address range for the AUTH_LIM byte is from 00h to FFh. If AUTH_LIM is set to a block address higher than the last block of the EEPROM address space, the password protection is effectively disabled. Addresses above the limit are protected for read / write depending on auth_r and auth_w values. If no bits are set, password protection is disabled. If the NFC device tries to access protected blocks without authenticating first, then: • If only protected blocks are accessed, AS3955 will not respond • If protected and unprotected blocks are accessed 1, AS3955 will return actual stored values only for the unprotected portion, and zeroes for the protected portion. 1. This can occur, for instance, with a READ command crossing the border between protected and unprotected memory. Page 38 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Detailed Description Configuration Byte AUTH_CFG Figure 39: Configuration Byte AUTH_CFG Conf. Bit Name Default Function b7 rfu 0 b6 rfu 0 b5 rfu 0 b4 rfu 0 b3 rfu 0 b2 rfu 0 b1 auth_w 0 Authentication is required for writing b0 auth_r 0 Authentication is required for reading Note Note(s): 1. This byte can always be accessed for read and write via SPI / I²C and can be accessed for read and write from the RF side if chip is in AUTHENTICATED state and configuration bit auth_set is 1. Bits auth_w and auth_r define for which operations the authentication is needed. If a lock bit is set for a certain block, then write cannot be performed even if IC is in AUTHENTICATED state. This means that lock bits overrule authentication. Configuration Byte SENSR1 Figure 40: Configuration Byte SENSR1 Conf. Bit Name Default b7 sens_res 0 b6 sens_res 0 b5 sens_res 0 b4 sens_res 0 b3 sens_res 0 b2 sens_res 0 b1 sens_res 0 b0 sens_res 0 Function Note SENS_RES response byte 2 on SENS_REQ Note(s): 1. This byte can always be accessed for read and write via SPI / I²C and can be accessed for read and write from the RF side if rfcfg_en is set to 1. ams Datasheet [v1-04] 2016-Feb-03 Page 39 Document Feedback AS3955 − Detailed Description Configuration Byte SENSR2 Figure 41: Configuration Byte SENSR2 Conf. Bit Name Default b7 sens_res 0 b6 sens_res 1 b5 sens_res 0 b4 sens_res 0 b3 sens_res 0 b2 sens_res 1 b1 sens_res 0 b0 sens_res 0 Function Note SENS_RES response byte 1 on SENS_REQ Note(s): 1. This byte can always be accessed for read and write via SPI / I²C and can be accessed for read and write from the RF side if rfcfg_en is set to 1. Configuration Byte SELR Figure 42: Configuration Byte SELR Conf. Bit Name Default b7 sel_res 0 b6 sel_res 0 b5 sel_res 0 b4 sel_res 0 b3 sel_res 0 b2 sel_res 0 b1 sel_res 0 b0 sel_res 0 Function Note SEL_RES response on Cascade Level 1/2 This bit is not used, as cascade bit 3 in SEL_RES CL1 is fixed to 1, and to 0 in SEL_RES CL2 Note(s): 1. This byte can always be accessed for read and write via SPI / I²C and can be accessed for read and write from the RF side if rfcfg_en is set to 1. Page 40 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Detailed Description Configuration Byte IC_CFG0 Figure 43: Configuration Byte IC_CFG0 Conf. Bit Name Default b7 slnt_mod 0 b6 slnt_vl 0 b5 slnt_vl 0 b4 slnt_vl 0 b3 arbit_mod 0 b2 i2c_addr3 0 b1 i2c_addr2 0 b0 i2c_addr1 0 Function Note 1: Enable silent mode Silent mode voltage level (see Silent Mode) 1: RF has priority access to EEPROM over SPI / I²C I²C slave address Note(s): 1. This byte can always be accessed for read and write via SPI / I²C and can be accessed for read and write from the RF side if rfcfg_en is set to 1. Bit arbit_mod can be modified after initialization over SPI / I²C. Bit slnt_mod enables Silent mode. In this mode, the supply pin VP_IO is being observed. If voltage is below the level defined in slnt_vl, then Silent mode is activated. This means that RF part of the IC is turned off and stops being responsive to incoming RF commands. Voltage threshold settings on VP_IO are shown in Figure 44. Figure 44: Silent Mode Threshold Voltage Levels ams Datasheet [v1-04] 2016-Feb-03 slnt_vl Voltage Threshold Abs. Accuracy 000b 1.42V ±15mV 001b 1.62V 010b 1.82V 011b 2.23V 100b 2.53V 101b 2.74V 110b 3.04V 111b 3.65V Linearly increasing over range ±25mV Page 41 Document Feedback AS3955 − Detailed Description The voltage level of the supply on VP_IO is measured when tag enters RF field. The selected voltage level threshold can be properly measured only if the RF field is strong enough to provide sufficient supply voltage level. When small antennas are used, it is advisable to set lower threshold. Bit arbit_mod defines arbitration mode during mutual EEPROM access via SPI / I²C and RF side. If arbit_mod is set to 0, then the EEPROM access follows the first-come-first-serve principle. If arbit_mod is set to 1, then the RF part will always have higher priority over SPI / I²C. For further details, please refer to section Interface Arbitration. The i2c_addr bits represent lower three bits of the I²C address. The upper four bits of the I²C address that represent a group shall be set to 1010b. Configuration Byte IC_CFG1 Figure 45: Configuration Byte IC_CFG1 Conf. Bit Name Default b7 en_rx_crc 0 b6 vreg 0 b5 vreg 0 b4 vreg 0 b3 vreg 0 b2 vreg 0 b1 rreg 0 b0 rreg 0 Function Note 1: CRC stored in the buffer in the tunneling mode Voltage level for voltage regulator VP_REG (see Figure 16) Output resistance value for voltage regulator VP_REG (see Figure 15) Note(s): 1. This byte can always be accessed for read and write via SPI / I²C and can be accessed for read and write from the RF side if rfcfg_en is set to 1. If bit en_rx_crc is set to 1 then the CRC shall be part of the message in the buffer. This implies that maximum message effective length is reduced to 30 bytes. CRC check is performed regardless of the value of the en_rx_crc bit. Page 42 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Detailed Description Configuration Byte IC_CFG2 Figure 46: Configuration Byte IC_CFG2 Conf. Bit Name Default Function b7 rfcfg_en 1 1: Enables personalization / configuration over RF b6 tun_mod 0 1: Enables Tunneling Mode b5 ext_mod 0 1: Enables Extended Mode b4 nak_on_crc_parity 0 1: Defines error handling and response b3 auth_set 0 1: Configuration of the authentication settings is enabled from RF side b2 selr_b6_inv 0 1: Inverts bit 6 in SEL_RES response on Cascade Level 2 b1 powm 0 b0 powm 0 00: Power Mode 0 01: Power Mode 1 Note 10: Power Mode 2 11: Power Mode 3 Note(s): 1. This byte can always be accessed for read and write via SPI / I²C and can be accessed for read and write from the RF side if rfcfg_en is set to 1. Bits tun_mod and ext_mod represents a default value stored in a volatile memory which can be modified after initialization over SPI / I²C. Bit rfcfg_en enables the personalization process during production at customer facilities. When this bit is set to 0, the modification of the last two blocks is not possible anymore over the RF field. If auth_set is set then changing of authenticated setting (authentication limits, read/write permission) is enabled over the RF after successful authentication. Password can always be changed via the RF side if tag is in authenticated state regardless of the value of read/write bits. Bit nak_on_crc_parity configures error handling mechanism as described in Error Handling. Bit selr_b6_inv configures SEL_RES response on Cascade Level 2. If selr_b6_inv is set to 1, bit b6 in SEL_RES response on Cascade Level 2 will be inverted, otherwise it will be set as configured in SELR byte. Bits powm are setting power modes as defined in Power Management. ams Datasheet [v1-04] 2016-Feb-03 Page 43 Document Feedback AS3955 − Detailed Description Configuration Bytes MIRQ_0 and MIRQ_1 These two bytes define the default value of the volatile memory for Mask Interrupt Register 0 and Mask Interrupt Register 1 registers. These bytes can always be accessed for read and write via the SPI / I²C and can be accessed for read and write from the RF side if rfcfg_en is set to 1. AS3955 Communication Modes AS3955 supports three different modes. The basic communication mode is a standalone mode where AS3955 can behave as a standalone NFC tag without MCU intervention. The other two modes (Tunneling and Extended mode) represent modification of the communication in SELECTED state. The anti-collision process is the same for all three modes. It is possible to change the mode of operation at any time. In case Tunneling and Extended mode are both enabled, Tunneling mode has priority over Extended mode. Standalone NFC Type 2 Tag Mode If neither of the two modes are enabled (Tunneling and Extended mode) in IC Configuration Register 2, the tag is in standalone mode. In this mode, all RF incoming commands address the internal EEPROM. In this mode, it is always possible to connect the MCU since all other functionalities of AS3955 are not limited by the communication modes. The main purpose of this mode is to use the AS3955 as a standalone chip or a chip in combination with MCU where the MCU is used for managing AS3955 configuration and memory content. Tunneling Mode Tunneling mode enables transparent data transfer between NFC device and MCU. In this mode, the internal EEPROM cannot be accessed via RF and any type of data received will be forwarded to MCU when the tag is in SELECTED state. An error during the reception will trigger a corresponding interrupt. In this mode the MCU shall take care for the correct response. For this purpose, the MCU may issue an ACK or a different type NAK response using implemented commands. By enabling this mode, the MCU can emulate NFC type 2 tags, NFC type 4 tags, ISO14443A Level 3 cards, ISO14443A Level 4 cards, and also implement higher level protocols such as [PHDC]. Tunneling mode can be configured by setting Configuration Byte IC_CFG2 in EEPROM or the corresponding register ( IC Configuration Register 2). This mode also allows access to the internal EEPROM via the SPI / I²C during RF communication. Page 44 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Detailed Description The basic assumption of Tunneling mode is that MCU is responsible for generating the response and that AS3955 takes care of the response synchronization over RF. For this reason, AS3955 has a possibility to transmit ACK and NACK by issuing a direct command (see section Direct Commands). The MCU can also transmit data by writing the data into the buffer and issuing a Transmit command. The implementation of Tunneling mode also requires the handling of the SLP_REQ command since all the received data in SELECTED state are stored in the buffer and will not be processed by AS3955. This also implies that MCU has to take care of correct transition of the tag into SLEEP or SENSE state by using one of the three available commands Go To Sleep, Go To Sense and Go To Sense / Sleep. Data Transaction in Tunneling Mode Figure 47 shows an example of how communication in Tunneling mode should be implemented. Figure 47: Read First, then Acknowledge PCD AS3955 MCU Rx start DAT A TX DAT AR X Rx end, crc or parity error, buffer error DAT AR DO ACK / N CK CMD A ACK UT / NACK Tx end ACK and NACK responses can be replaced by data, in case of an incoming READ command. Relevant Registers, Interrupts and Commands Registers: • Buffer Status Register 1 and Buffer Status Register 2 (data length and error type) ams Datasheet [v1-04] 2016-Feb-03 Page 45 Document Feedback AS3955 − Detailed Description Interrupts: • Rx start (I_rxs bit in Interrupt Register 1) • Rx end, Tx end (resp. I_rxe and I_txe bits in Interrupt Register 0) • CRC, parity and framing interrupt (resp. I_crc_err, I_par_ err and I_frm_err bits in Interrupt Register 1) • Buffer error (I_bf_err in Interrupt Register 1) • SPI / I²C buffer access error (I_acc_err in Interrupt Register 1) Commands: • Transmit ACK • Transmit NACK 0-5 • Transmit Buffer • Go To Sense • Go To Sleep • Go To Sense / Sleep Extended Mode Extended mode enables communication between the NFC device and MCU by employing standard NFC Tag 2 Type READ and WRITE commands. The purpose of this communication mode is to provide a simple data transfer mechanism between a NFC device and a MCU while guaranteeing correct timing and synchronization. This is achieved by implementing a robust handshake mechanism. This mode uses a part of the memory address space that is out of range of the internal physical memory. The communication between a NFC device and a MCU can be performed by using WRITE/READ commands on address FCh – FFh, independently of the EEPROM configuration size. Data with CRC or any other error will not be forwarded to the MCU. In case of successful reception of data, AS3955 will automatically reply with ACK. Error handling in Extended mode is defined in Error Handling. Data received from RF side are kept available until the MCU reads the data. The implemented asynchronous transmission protocol arbitrates on overlapping memory accesses (producer-consumer principle) and complies with timing constraints of both RF and SPI / I²C protocols regardless of the MCU performance. Extended mode can be configured by setting Configuration Byte IC_CFG2 in EEPROM or the corresponding register ( IC Configuration Register 2). Page 46 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Detailed Description Extended mode uses an address space above the address space of the internal EEPROM. It is then possible for a NFC device to perform accesses to AS3955 internal memory and data transfer to/from the MCU, without switching modes. This feature allows the NFC device e.g. to request to the MCU a switch to Tunneling mode with a simple WRITE command. The extended mode communication employs a built-in buffer for communication. Access to buffer from RF and SPI / I²C is mutually exclusive. AS3955 ensures that buffer content shall be kept as long as the AS3955 is powered (even in case RF field is not present) and as long the tag is in SELECTED state. In case the RF field is switched off and then on again, the buffer content will be reset. NFC Device to MCU Data Flow Protocol For the data transmission from NFC device to the MCU employing the Extended mode, a NFC WRITE shall be used. Each data transfer from NFC device is comprised of four WRITE commands starting from address FCh and ending at address FFh. The protocol implemented on a NFC device is expected to always start the data transmission at address FCh, which signals the beginning of the communication, and end at address FFh. Figure 48 depicts regular implementation of the Extended mode using the WRITE commands. Figure 48: Address Space Employed for Communication Address space used for communication in extended mode ... WRITE FCh,00112233h TIME WRITE FDh,44556677h WRITE FEh,8899AABBh WRITE hFF,CCDDEEFFh ams Datasheet [v1-04] 2016-Feb-03 ACK, rf_busy = 1, IRQ RX start = 1 ACK ACK ACK, rf_data_rdy = 1, IRQ RX end = 1 FCh 00h 11h 22h 33h FDh 44h 55h 66h 77h FEh 88h 99h AAh BBh FFh CCh DDh EEh FFh ... Page 47 Document Feedback AS3955 − Detailed Description Assuming that the internal buffer is empty, the NFC device may start with data transmission by sending a WRITE command on address FCh. When the first block is written, the rf_busy flag is set and Rx start interrupt is triggered. At this point, the buffer cannot be accessed over SPI / I²C until the entire write message is received which is assumed to be complete when NFC device sends a write command to block FFh. At this point, an Rx end interrupt is triggered. This implies that a minimum two messages must be received from a NFC device in order to successfully complete a message. If a WRITE command is received on address FFh before a WRITE command to address FCh, AS3955 will assume that an error has occurred and will respond as described in Error Handling in Extended Mode . When the reader writes into the last block FFh, rf_data_rdy flag is set and the reader cannot change the buffer content until the MCU reads the content of the block and clears the rf_data_rdy flag. Any additional reception of WRITE commands from NFC device, prior to MCU reading out the buffer content, shall result in a response as defined in Error Handling. The blocks from internal memory address space are directly mapped into buffer space as shown on Figure 49. Figure 49: Mapping of Data Received into Buffer Address space used for communication in extended mode Buffer address space ... FCh 00h 11h 22h 33h 00h 00h 11h 22h 33h FDh 44h 55h 66h 77h 04h 44h 55h 66h 77h FEh 88h 99h AAh BBh 08h 88h 99h AAh BBh FFh CCh DDh EEh FFh 0Ch CCh DDh EEh FFh ... When MCU reads out the data from the buffer, data will be sent to MCU in the same order as they were stored in the buffer starting from address 00h. When MCU has read all buffer content, it shall issue a Clear Buffer command to clear the flag rf_data_rdy. At this point, a new data message can be received. Page 48 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Detailed Description Figure 50: Data Reception in Extended Mode PCD AS3955 MCU Rx start Rx end MCU to NFC Device Data Flow Protocol NFC devices can receive data from a MCU through AS3955 by using standard READ commands. Prior to writing data into the buffer, the MCU shall issue a Clear Buffer command to AS3955 to ensure data are correctly mapped into the buffer. To start data transmission, the MCU shall issue then a Transmit Buffer command. In this way, the flag io_data_rdy is set and data can be transmitted to the reader. The transmission of the data from the tag to the NFC device is done by issuing a READ command on block FCh. The fourth block being read during the read command contains the status flags of the ongoing communication. NFC devices can receive data from a MCU through AS3955 by using standard READ commands. Prior to writing data into the buffer, it is advisable that to issue a Clear Buffer command to AS3955 to ensure data are correctly mapped into the buffer. MCU can trigger data transmission by writing three words of data into the buffer at addresses FCh-FEh, and issuing a Transmit Buffer command. This will also set io_data_rdy flag. The transmission of the data from the tag to the read is done by issuing a read command on word 0xFC. The NFC device can then retrieve the data from the buffer by sending a READ command to address FCh. The fourth word contains the status flags as shown in Figure 51. ams Datasheet [v1-04] 2016-Feb-03 Page 49 Document Feedback AS3955 − Detailed Description Figure 51: Data Transmission from MCU to NFC Device !!""#$%$!#$# &%#"! *+, 3 ./057$!./057 $!.%.05 3!#2  7 7 7  83+*7  ./057$!./057 $!.%.05 3!#2 9 / / / / 2   ''' ./057$!./057 $!.%.05 3!#2 7 7 7   3                       ''' / / / / ./0 .%.0 $!./0 $!.%.0 When the NFC device has successfully read all data from the buffer, it shall clear the buffer and prepare for further data transfer by issuing a WRITE command to address FFh. This will trigger a Tx end interrupt. If a READ command is received on address FCh prior to the Transmit Buffer command, AS3955 will return zero data, io_busy set to 1 and io_data_rdy set to 0. A NFC device can then poll AS3955 by continuously sending READ commands at address FCh and waiting until the last word equals 01h. A READ command can be issued only to address FCh. Issuing a READ command to any other address than FCh while in Extended mode shall be treated as an error. In Extended mode, it is assumed that AS3955 will always receive 16 bytes and transmit 12 bytes of data, 3 empty bytes and 1 byte for FLAGS. If the message size differs in any direction, then the MCU or NFC device are responsible for proper error management. Page 50 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Detailed Description Figure 52: Data Transmission in Extended Mode PCD AS3955 MCU IN WRITE READ @ Transmit FC h DATA WRITE @ FFh Tx end If MCU decides to update the buffer before the NFC device issues a WRITE command to address FFh, a I_acc_err interrupt will be triggered, signaling that buffer cannot be accessed (see Interrupt Register 1). Relevant Registers, Interrupts and Commands Relevant Registers: • Buffer Status Register 1 (status flags : rf_busy, rf_data_rdy, io_data_rdy) Relevant Interrupts: • Rx start (I_rxs bit in Interrupt Register 1) • Rx end, Tx end (resp. I_rxe and I_txe bits in Interrupt Register 0) Commands: • Transmit Buffer • Clear Buffer ams Datasheet [v1-04] 2016-Feb-03 Page 51 Document Feedback A S 3 9 5 5 − Detailed Description Extended Mode Timing Diagram Figure 53: RF to MCU Data Transfer in Extended Mode RFLINK RFfield NFCreader RFfieldON Tagstate Poweroff BUFFER SPI/I²CLINK INTERRUPTS SENSE 0xFC 0xFD 0xFE 0xFF 0x00000000 0x00000000 0x00000000 0x00000000 WRITE 0xFC, 0x001122 33 WRITE 0xFD, 0x445566 77 WRITE 0xFE, 0x8899AA BB WRITE 0xFF, 0xCCDDE EFF READ 0xFC RESOLUTI SELECTED ON AntiͲcollision sequence AS3955RF response Buffercontent AntiͲcollision sequence ACK 0x00112233 0x00000000 0x00000000 0x00000000 ACK 0x00112233 0x44556677 0x00000000 0x00000000 ACK 0x00112233 0x44556677 0x8899AABB 0x00000000 0x000000 0x000000 0x000000 0x000000 00 00 00 02 ACK 0x00112233 0x44556677 0x8899AABB 0xCCDDEEFF 0x00000000 0x00000000 0x00000000 0x00000000 AS3955 SPI/I²C 0x001122 0x445566 0x8899AA 0xCCDDE 33 77 BB EFF 0x10 MCU SPI/I²C ReadIRQ Read Buffer Length Buffer Read Clear Buffer RXstart Rxend Txend FLAGS rf_busy rf_data_rdy io_busy io_data_rdy TAGINITIALIZATION Page 52 Document Feedback RFTOBUFFERDATATRANSFER BUFFERTOMCUDATATRANSFER ams Datasheet [v1-04] 2016-Feb-03 A S 3 9 5 5 − Detailed Description Figure 54: MCU to RF Data Transfer in Extended Mode RFLINK RFfield NFCreader WRITE 0xFF, 0x000000 00 READ 0xFC READ0xFC Tagstate INTERRUPTS SPI/I²CLINK BUFFER AS3955RF response Buffercontent 0x00000000 0xFC 0xFD 0xFE 0xFF 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0xFFEECCAA 0x00000000 0x00000000 0x00000000 0x00000000 0xFFEECCAA 0x99887766 0x00000000 0x00000000 0x00000000 0x000000 02 0xFFEECC 0x998877 0x554433 0x000000 AA 66 22 09 0xFFEECCAA 0x99887766 0x55443322 0x00000000 ACK 0x00000000 0x00000000 0x00000000 0x00000000 AS3955 SPI/I²C MCU SPI/I²C BufferLoad 0xFFEECCAA 0x99887766 0x55443322 TransmitBuffer ReadIRQ RXstart Rxend Txend FLAGS rf_busy rf_data_rdy io_busy io_data_rdy MCUTOBUFFERDATATRANSFER ams Datasheet [v1-04] 2016-Feb-03 BUFFERTORFDATATRANSFER Page 53 Document Feedback AS3955 − Detailed Description Implementation Recommendations While in Extended mode, the NFC device shall not issue a WRITE command to the address space of the internal EEPROM until the buffer is empty. The NFC device can issue a READ command to check internal status flag (io_busy = 0), before writing to EEPROM. It is also not allowed to interleave data communication in Extended mode (e.g. writing to addresses FCh-FFh) and issue a WRITE command to internal EEPROM. If case this happens, writing to internal EEPROM would be successful, but the buffer content would be lost. Reading status flags is always allowed. Error Handling Figure 55 shows how different type of errors in Standalone and Extended communication modes are handled and what is the resulting state of the tag. Figure 55: Error Handling Command Condition AS3955 nak_on_crc_parity=0 AS3955 nak_on_crc_parity=1 (empty fields have same reply as nak_on_crc_parity=0) Any Bit Coding Error No Response, SLEEP Any Incomplete Frame No Response, SLEEP T2T Read Parity Error No Response, SLEEP NAK_1, SLEEP T2T Read CRC Error No Response, SLEEP NAK_1, SLEEP T2T Read 1 Byte Frame (no CRC) No Response, SLEEP T2T Read Empty frame (only CRC bytes) No Response, SLEEP T2T Read Missing address No Response, SLEEP T2T Read Too long frame No Response, SLEEP T2T Read Memory fully locked Send Block Content T2T Read Memory partially locked Send Block Content T2T Read Memory fully protected NAK_4, SLEEP T2T Read Memory partially protected Send unprotected memory as is, replace protected memory with zero bytes T2T Read Memory address range fully not existent NAK_0, SLEEP Page 54 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Detailed Description Command Condition AS3955 nak_on_crc_parity=0 AS3955 nak_on_crc_parity=1 (empty fields have same reply as nak_on_crc_parity=0) T2T Read Memory address range partially not existent Send existing memory appended with zero bytes T2T Read EEPROM access collision NAK_5, SLEEP T2T Read No Error Send Block Content T2T Write Parity Error No Response, SLEEP NAK_1, SLEEP T2T Write CRC Error No Response, SLEEP NAK_1, SLEEP T2T Write 1 Byte Frame (no CRC) No Response, SLEEP T2T Write 2 Byte Frame with correct CRC No Response, SLEEP T2T Write Missing address and data No Response, SLEEP T2T Write Missing data No Response, SLEEP T2T Write Incomplete data No Response, SLEEP T2T Write Too long frame No Response, SLEEP T2T Write Memory fully locked NAK_0, SLEEP T2T Write Memory partially locked cannot occur T2T Write Memory fully protected NAK_4, SLEEP T2T Write Memory partially protected cannot occur T2T Write Memory address range fully not existent NAK_0, SLEEP T2T Write Memory address range partially not existent cannot occur T2T Write EEPROM access collision NAK_5, SLEEP T2T Write No Error ACK, SELECTED T2T Sector Select 1 Parity Error No Response, SLEEP NAK_1, SLEEP T2T Sector Select 1 CRC Error No Response, SLEEP NAK_1, SLEEP T2T Sector Select 1 1 Byte Frame (no CRC) No Response, SLEEP T2T Sector Select 1 Empty frame (only CRC bytes) No Response, SLEEP ams Datasheet [v1-04] 2016-Feb-03 Page 55 Document Feedback AS3955 − Detailed Description Command Condition AS3955 nak_on_crc_parity=0 AS3955 nak_on_crc_parity=1 (empty fields have same reply as nak_on_crc_parity=0) T2T Sector Select 1 Missing second byte No Response, SLEEP T2T Sector Select 1 Incorrect second byte (not FFh) No Response, SLEEP T2T Sector Select 1 Too long frame No Response, SLEEP T2T Sector Select 1 Only 1 sector available NAK_0, SLEEP T2T Sector Select 2 Parity Error No Response, SLEEP NAK_1, SLEEP T2T Sector Select 2 CRC Error No Response, SLEEP NAK_1, SLEEP T2T Sector Select 2 1 Byte Frame No Response, SLEEP T2T Sector Select 2 Empty frame (only CRC bytes) No Response, SLEEP T2T Sector Select 2 Missing sector number No Response, SLEEP T2T Sector Select 2 Missing RFU bytes No Response, SLEEP T2T Sector Select 2 Too few RFU bytes No Response, SLEEP T2T Sector Select 2 Too long frame No Response, SLEEP T2T Sector Select 2 Selected sector not existent (cannot happen for AS3955) No Response, SLEEP T2T Sector Select 2 No Error (cannot occur for AS3955) No Response, SLEEP Unknown Command Code Parity Error No Response, SLEEP NAK_1, SLEEP Unknown Command Code CRC Error No Response, SLEEP NAK_1, SLEEP Page 56 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Detailed Description Command Unknown Command Code Condition No Error AS3955 nak_on_crc_parity=0 AS3955 nak_on_crc_parity=1 (empty fields have same reply as nak_on_crc_parity=0) No Response, SLEEP Figure 56: Error Handling in Extended Mode Command Condition Error Type Write buffer (T2T Write) Start with FD, FE or FF NAK0, SLEEP Write buffer (T2T Write) Write when io_data_rdy=1 or rf_data_rdy=1 NAK0, SLEEP Clear buffer (T2T Write on block FFh) Write none zero data NAK0, SLEEP Read buffer (T2T read on block FCh) Read on FD, FE, FF NAK0, SLEEP Read buffer (T2T read on block FCh) Buffer access collision NAK5, SLEEP Write buffer (T2T Write) Buffer access collision NAK5, SLEEP Clear buffer (T2T Write on block FFh) Buffer access collision NAK5, SLEEP ams Datasheet [v1-04] 2016-Feb-03 Page 57 Document Feedback AS3955 − Detailed Description Wired Interfaces AS3955 host interface can be configured to be either SPI or I²C at production (Fabrication Data FAB_CFG0). In both cases, the /SS signal is also used to control the IC power state. By pulling the /SS low, the chip interface or the chip itself is enabled / powered (see Power Management). Note that interrupting SPI / I²C operations or issuing incomplete command sequence from the MCU may result in corrupted data content. For more information on EEPROM and buffer data reading and writing see EEPROM Read and Write and Data Buffer sections. SPI / I²C Access Modes Figure 57: Access Modes MODE Byte (com. bits) Mode MODE Trailer MODE Related Data M2 M1 M0 C4 C3 C2 C1 C0 Register Write 0 0 0 A4 A3 A2 A1 A0 Data byte(s) Register Read 0 0 1 A4 A3 A2 A1 A0 Data byte(s) EEPROM Write 0 1 0 0 0 0 0 0 Block Address byte 4 bytes of block data EEPROM Read 0 1 1 1 1 1 1 1 Block Address byte N*4 bytes Buffer Load 1 0 0 x x x x x Data byte(s) Buffer Read 1 0 1 x x x x x Data byte(s) COMMAND Mode 1 1 C5 C4 C3 C2 C1 C0 Page 58 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Detailed Description SPI Interface Communication between AS3955 and microcontroller can be done via a four-wire Serial Peripheral Interface (SPI) and an additional interrupt signal. AS3955 acts an SPI slave device, and it can request MCU attention by sending an interrupt (pin IRQ). The SCLK frequency can be between 100 kHz and 5 MHz. Figure 58: SPI and Interrupt Signals Name /SS Signal Signal Level Description Digital Input with pull up CMOS SPI enable (active low) MOSI Digital Input CMOS Serial data input MISO Digital Output with tristate CMOS Serial data output SCLK Digital Input CMOS Clock for serial communication Digital Output CMOS Interrupt Output pin (active high) IRQ SPI interface is in reset mode when signal /SS is high, and it is enabled when /SS is low. It is recommended to keep signal /SS high whenever the SPI interface is not used. MOSI is sampled at the falling edge of SCLK. All communication is done in 8-bit blocks (bytes). First three bits of first byte transmitted after /SS high to low transition define SPI operation mode. MSB bit is always transmitted first (valid for address and data). Read and Write modes support address auto incrementing, which means that in case some additional data bytes may be sent (read), they are written to (read from) addresses incremented by 1 after the address and first data byte. SPI interface supports the following modes: • internal registers read and write • EEPROM read and write • buffer read and write • direct commands Note that in case when logic and EEPROM are supplied from the VP_IO, the only SPI operations permitted are reading and writing of EEPROM and registers (see also Power Management). MISO output is usually in tristate and it is only driven when output data is available. MOSI and MISO can then be externally shorted to create a bidirectional signal. When MISO output is in tristate, it is possible to switch on a 10 kΩ pull down by activating option bits miso_pd1 and miso_pd2 in IO Configuration Register. ams Datasheet [v1-04] 2016-Feb-03 Page 59 Document Feedback AS3955 − Detailed Description Figure 59: IO Signals to Controller MOSI MOSI MOSI μC AS3955 MISO AS3955 I/O μC MISO MISO Separate SPI Input and Output Signals to Controller Bidirectional Data IO Signal to Controller Writing Data to Addressable Registers (Register Write Mode) Following figures show waveforms of writing a single byte and writing multiple bytes with auto-incrementing address. After the SPI operation mode bits, the address of starting register to be written is provided. Then one or more data bytes are transferred from the SPI, always MSB first. The data byte is written in register on falling edge of its last clock. In case the communication is terminated by putting /SS high before a packet of 8 bits composing one byte is sent, writing of this register is not performed. In case the register on the defined address does not exist or it is a read-only register, no write is performed. Figure 60: SPI Communication: Writing a Single Register /SS SCLK MOSI X 0 0 Three leading bits indicate Mode Page 60 Document Feedback 0 A4 A3 SCLK raising edge Data is transfered from µC A2 A1 SCLK falling edge Data is sampled A0 D7 D6 D5 D4 D3 D2 D1 D0 Data is moved to Address A4-A0 X /SS rising edge signals end of WRITE Mode ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Detailed Description Figure 61: SPI Communication: Writing Register Data with Auto-Incrementing Address /SS SCLK MOSI X 0 0 0 A A A A A D D D D D D D D D D D D D D D D D D 4 3 2 1 0 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 7 6 Data is moved to Address Three leading bits indicate Mode Data is moved to Address + 1 D D D D D D D D D D 1 0 7 6 5 4 3 2 1 0 Data is moved to Address + (n-1) X Data is moved to Address + n /SS rising edge signals end of WRITE Mode Reading Data from Addressable Registers (Register Read Mode) After the SPI operation mode bits, the register address to be read shall be provided, MSB first. Then one or more data bytes are transferred to MISO output, always MSB first. As in case of the write mode, also the read mode supports auto-incrementing addressing. MOSI is sampled at the falling SCLK edge (as shown in the following diagrams); data to be read from AS3955 internal register is driven to MISO pin on rising edge of SCLK and is sampled by the master at the falling SCLK edge. In case the register on defined address does not exist, all 0 data is sent to MISO. In the following figure an example of reading of a single byte is given. Figure 62: SPI Communication: Reading a Single Register /SS SCLK MOSI X 0 0 MISO 1 A4 A3 A2 A1 X Three leading bits indicate The Mode ams Datasheet [v1-04] 2016-Feb-03 SCLK rising edge Data is transferred from µC X A0 D7 SCLK falling edge Data is sampled D6 SCLK rising edge Data is moved from Address D5 D4 D3 SCLK falling edge Data is transferred to µC D2 D1 D0 X /SS rising edge signals end of READ Mode Page 61 Document Feedback AS3955 − Detailed Description Writing and Reading of EEPROM Through SPI EEPROM data can be read and written also through SPI interface. Due to possible conflict with the RFID interface additional arbitration bit can be set (IC_CFG0) in order to set the priority access to the EEPROM access. If EEPROM write operation is terminated due to higher priority of the RF an I_ acc_err (Interrupt Register 1) IRQ is sent. The description is referring to following case when an EEPROM write operation is triggered via SPI / I²C and bit arbit_mod (EEPROM, IC_CFG0, bit3) is set to 1 which means that RF has priority over SPI when accessing EEPROM. In this case EEPROM via SPI / I²C write will be terminated and IRQ I_acc_err is triggered if tags enters RF field and EEPROM is needed for RF initialization, EPROM read or write is issued via RF. Word Address Byte Both EEPROM modes (Read and Write) use Word Address byte to define the address of the EEPROM word which is accessed. Seven MSB bits of the Address Byte are used to define the address; while the last bit is don’t care (it is used to synchronize EEPROM access). Figure 63: EEPROM Block Address Byte EEPROM Block Address B7 B6 B5 B4 B3 B2 B1 B0 WA6 WA5 WA4 WA3 WA2 WA1 WA0 x EEPROM Write In order to program an EEPROM block, six bytes shall be sent (mode byte, block address byte and 4 bytes of data, all of them MSB first). Actual EEPROM programming is started with rising /SS edge signal which terminates the EEPROM Write command. EEPROM Read In order to read data from EEPROM, first a mode byte is sent, followed by the block address byte (MSB first). Then one or more blocks of data with address auto-incrementing (packets of 4 bytes) are transferred to MISO output, also MSB first. MOSI is sampled at the SCLK falling edge; data to be read from AS3955 EEPROM is driven to MISO pin on SCLK rising edge and is sampled by the master at the SCLK falling edge. In case the block on the defined address does not exist, all 0 data is sent to MISO. Please note that SCLK frequency should not exceed 1MHz during EEPROM Read (limited by EEPROM read access time). Page 62 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Detailed Description Figure 64: Reading an EEPROM Block over SPI /SS SCLK W W W W W W W MOSI X X 0 1 1 1 1 1 1 1 A A A A A A A x 6 MISO 5 4 3 2 1 X 0 B B B B B B B B B B 3 3 2 2 2 2 2 2 2 2 1 0 9 8 7 6 5 4 3 2 X B B B B B B B B B B 9 8 7 6 5 4 3 2 1 0 LSB Byte from Address MSB Byte from Address 1µs min X Loading Transmission Data into Buffer Loading the transmitting data into the buffer is similar to writing data into an addressable registers. Difference is that in case of loading more bytes all bytes go to the buffer. The command mode code 100b indicates buffer write operation. A bit stream of 32 bytes of data can be transferred. The following figure shows how to load the transmission data into the buffer. Figure 65: Loading Data into Buffer over SPI /SS SCLK MOSI X 1 0 10 pattern indicates FIFO mode ams Datasheet [v1-04] 2016-Feb-03 0 x x SCLK rising edge Data is transfered from µC x x SCLK falling edge Data is sampled 1 to 32 bytes x Start of payload Data X /SS rising edge signals end of COMMAND Mode Page 63 Document Feedback AS3955 − Detailed Description Reading Received Data from Buffer Reading received data from the buffer is similar to reading data from an addressable registers. Difference is that, in case of reading more bytes, they all come from the buffer. The command mode code 101b indicates buffer operations. In case the command is terminated by putting /SS high before a packet of 8 bits composing one byte is read that particular byte is considered read. Direct Command Mode Direct Command Mode is comprised of one command byte followed by argument byte. SPI operation mode bits 11b indicate Direct Command Mode. The following six bits define command code, sent MSB first. Last two bits in argument byte indicate success of the direct command. Value 01h of the argument byte indicates that command was accepted, while value 02h indicates rejected due to internal access priorities. The argument byte does not provide information on timing of the command execution. Figure 66: Sending a Direct Command Over SPI /SS SCLK MOSI X 1 1 Two leading ONE indicate COMMAND Mode Page 64 Document Feedback C5 C4 C3 SCLK rising edge Data is transferred from µC C2 C1 C0 D7 D6 D5 D4 D3 D2 D1 D0 X SCLK falling edge Data is sampled ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Detailed Description SPI Timing Figure 67: SPI Timing Symbol Parameter Min Typ Max Unit Note General timing (VDD=VDD_IO=VDD_D= 3.3V, Temperature 25°C) TSCLK SCLK period 200 ns TSCLKL SCLK low 80 ns TSCLKH SCLK high 80 ns TSSH SPI reset (/SS high) 50 ns TNCSL /SS falling to SCLK rising 25 ns first SCLK pulse TNCSH SCLK falling to /SS rising 80 ns last SCLK pulse TDIS Data in setup time 10 ns TDIH Data in hold time 10 ns (1) Read timing (VDD=VDD_IO=VDD_D= 3.3V, Temperature 25°C, Cload ≤ 50pF) TDOD Data out delay 20 ns TDOHZ Data out to high impedance delay 20 ns Note(s): 1. TSCLK=TSCLKL+TSCLKH, during EEPROM read the SCLK period has to be increased to 1μs (this limitation is imposed by EEPROM read access time) Figure 68: SPI General Timing /SS ... t NCSL t SCLKH tSCLKL t NCSH SCLK ... t DIS MOSI MISO ams Datasheet [v1-04] 2016-Feb-03 tDIH DATAI DATAI ... DATAI ... Page 65 Document Feedback AS3955 − Detailed Description Figure 69: SPI Read Timing ... /SS SCLK MOSI ... ... DATAI DATAO MISO ... DATAO t DOHZ t DOD SPI Electrical Connection A pull-down resistor can be connected by setting miso_pd1 and miso_pd2 bits in IO Configuration Register . Figure 70: SPI Electrical Connection AS3955 VP_IO MISO RP=10kΩ Pull down settings VSS Page 66 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Detailed Description I²C Interface Communication between AS3955 and microcontroller can be done via a I²C interface and an additional interrupt signal. AS3955 acts an I²C slave device, and supports single master, multiple slave configurations. AS3955 I²C supports following modes: Standard-mode, Fast-mode, Fast-mode Plus. Figure 71: I²C and Interrupt Signals Name Signal Signal Level Description /SS Digital Input with pull up CMOS Should be set to high during I²C communication SDA Digital Output CMOS Serial Data output SCL Digital Input CMOS Clock for serial communication IRQ Digital Output CMOS Interrupt Output pin (active high) During I²C communication, the signal /SS should be set to low. By setting the /SS to low, I²C interface is enabled. It is recommended to keep signal /SS high whenever the I²C interface is not used. I²C interface supports the following modes: • Internal registers read and write • EEPROM read and write • Buffer read and write • Direct commands Please note that the only I²C operations allowed, when logic and EEPROM are supplied from VP_IO, are EEPROM and registers reading and writing (see also Power Management). I²C Slave Address The I²C slave address is composed of 7 bits where the first 4 MSBs are fixed and the last 3 LSBs are programmable. Figure 72: I²C Slave Address I²C Slave Address B6 B5 B4 B3 B2 B1 B0 1 0 1 0 A2 A1 A0 The value of bits A2:A0 can be set in the Configuration Byte IC_CFG0. ams Datasheet [v1-04] 2016-Feb-03 Page 67 Document Feedback AS3955 − Detailed Description Writing Data to Addressable Registers (Register Write Mode) Following figures show cases of writing a single byte and writing multiple bytes with auto-incrementing address. After the I²C slave address, the initial register address follows. Then one or more data bytes are transferred from the I²C, MSB first. The data byte is written in register on falling edge of its last clock. Figure 73: Writing a Single Register over I²C SCL SDA S A A A A A A A A A A 0 R R R R R D D D D D D D D C C 0 0 0 C 6 5 4 3 2 1 0 4 3 2 1 1 7 6 5 4 3 2 1 0 K K K Slave address Mode Byte P Data Figure 74: Writing Register Data with Auto-Incrementing Address over I²C SCL SDA S A A A A A A A A A A D D D D D D D D C R R R R R C 0 C 0 0 0 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 K 4 3 2 1 1 K K Slave address Page 68 Document Feedback Mode Byte Data is moved to Address + 0 A D D D D D D D D C 7 6 5 4 3 2 1 0 K P Data is moved to Address + n ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Detailed Description Reading Data from Addressable Registers (Register Read Mode) After the I²C slave address, the address of register to be read shall be provided, MSB first. Then one or more data bytes are transferred to SDA output, also MSB first. As in case of the write mode, also read mode supports auto-incrementing address. In case the register at the defined address does not exist, all 0 data is sent to SDA. In the following figure, an example for reading of single byte is given. Figure 75: Reading a Single Register over I²C SCL SDA S A A A A A A A A A R R R R R C S 0 C 0 0 1 6 5 4 3 2 1 0 4 3 2 1 0 K K Slave address Mode Byte A N D D D D D D D D A A A A A A A A 1 C 6 5 4 3 2 1 1 K 7 6 5 4 3 2 1 0 K Slave address P Data Writing and Reading EEPROM through I²C EEPROM data can be read and written through I²C interface. Due to possible conflict with RFID interface, additional arbitration bit can be set (IC_CFG0) in order to set the priority access to the EEPROM access. If EEPROM write operation is terminated due to higher priority of the RF an I_spi (Interrupt Register 1), an IRQ is sent. Block Address Byte Both EEPROM Read and Write use Block Address byte to define the EEPROM block address to be accessed. Seven MSB bits of the Address Byte are used to define the address; while the last bit is don’t-care (it is used to synchronize EEPROM access). Figure 76: EEPROM Block Address Byte over I²C EEPROM Block Address ams Datasheet [v1-04] 2016-Feb-03 B7 B6 B5 B4 B3 B2 B1 B0 WA6 WA5 WA4 WA3 WA2 WA1 WA0 x Page 69 Document Feedback AS3955 − Detailed Description EEPROM Write In order to program an EEPROM block, seven bytes shall be sent (slave address, mode byte, block address byte and 4 bytes of data, all of them MSB first). Actual EEPROM programming is started with rising edge of ACK of the last byte. Figure 77: Writing Register Data with Auto-Incrementing Address over I²C SCL SDA S A A A W W W W W W W A A A A A A A 0 C 0 1 0 0 0 0 0 0 C A A A A A A A x C 6 5 4 3 2 1 0 K K K 6 5 4 3 2 1 0 Mode Byte Slave address A D D D D D D D D C 7 6 5 4 3 2 1 0 K EEPROM page address P Data EEPROM Read In order to read data from EEPROM, first a slave address and mode byte is sent, followed by the block address byte (MSB first). Then one or more blocks of data with address auto-incrementing (packets of 4 bytes) are transferred via SDA line, also MSB first. SDA is sampled at the SCL falling edge. In case the block on defined address does not exist, all 0 data is sent via SDA line. Figure 78: Reading a EEPROM Block over I²C SCL SDA S A A W W W W W W W A A A A A A A A 0 C 0 1 1 1 1 1 1 1 C A A A A A A A x C 6 5 4 3 2 1 0 K K 6 5 4 3 2 1 0 K Slave address S EEPROM page address A N A A A A A A A D D D D D D D D 1 C A 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 K K Slave address Page 70 Document Feedback Mode Byte P Data ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Detailed Description Loading Transmission Data into Buffer Loading the transmitting data into the buffer is similar to writing data into an addressable register. Difference is that, in case of loading more bytes, all bytes go to the buffer. The command mode code 10b indicates buffer operations. The following figure shows how to load the transmitting data into the buffer. Figure 79: Loading Data into Buffer over I²C SCL SDA S A A A A A A A A A A D D D D D D D D C 0 C 1 0 0 0 0 0 0 0 C 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 K K K Mode Byte Slave address A D D D D D D D D C 7 6 5 4 3 2 1 0 K Data P Data Reading Received Data from Buffer Reading received data from the buffer is similar to reading data from an addressable register. Difference is that, in case of reading more bytes, they all come from the buffer. The command mode code 10b indicates buffer operations. In case of reading the received data from the buffer, all bits are set to 1. Figure 80: Reading Data from Buffer over I²C SCL SDA S A A A A A A A A A 0 C 1 0 1 1 1 1 1 1 C 6 5 4 3 2 1 0 K K Slave address S A N A A A A A A A D D D D D D D D 1 C A 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 K K Slave address ams Datasheet [v1-04] 2016-Feb-03 Mode Byte P Data Page 71 Document Feedback AS3955 − Detailed Description Direct Command Mode Direct Command Mode is comprised of one command byte and argument byte. The two msb’s of command code 11b indicate Direct Command Mode. The following six bits define command code, sent MSB first. Last two bits in argument byte indicate success of the direct command. Value 01h of the argument byte indicates that command was accepted, while 02h indicates it was rejected due to internal access priorities. The argument byte does not provide information on timing of the command execution. Figure 81: Sending a Direct Command over I²C SCL SDA S A A A A A A A 6 5 4 3 2 1 0 Slave address A A C C C C C C C C C C S 7 6 5 4 3 2 1 0 K K Mode Byte A A A A A A A A 1 C 0 0 0 0 0 0 x x 6 5 4 3 2 1 1 K Slave address N A K P Argument byte I²C Electrical Connection The AS3955 has two built-in 3kΩ pull-up resistors on SDA and SCL lines as shown on Figure 82 and used only in I²C mode. The SPI pull-down bits in IO Configuration Register must be set 00h. Figure 82: I²C Interface with Built-In Pull-Up Resistors AS3955 VP_IO RP=3kΩ RP=3kΩ SDA SCL VSS Page 72 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Detailed Description Interrupt Interface Description There are two interrupt registers implemented in AS3955 (Interrupt Register 0 and Interrupt Register 1). When an interrupt condition is met, the source of interrupt bit is set in the interrupt register and the IRQ pin goes to high. The microcontroller shall read the interrupt registers to distinguish between different interrupt sources. After an interrupt register is read, its content is reset to 0. IRQ pin goes to low after the interrupt bit(s), which caused its transition to high, has been read. Please note that there may be multiple interrupt register bits set in case the controller does not immediately read the Interrupt Registers after the IRQ signal was set and another event causing interrupt occurred. The process of reading interrupt registers is composed of two phases. In the first phase, interrupts are pushed into internal buffer just before reading the first bit of the register. In the second phase the bits stored in the buffer are read out. The interrupts stored in each internal register are cleared and considered being read out at the rising edge of SCLK of the first interrupt bit for each interrupt register. Buffer Interrupts and Buffer Status Register The AS3955 contains a 32 byte buffer. In case of transmission the Control logic shifts data which was previously loaded by the external controller to the Framing Block and further to the Transmitter. During reception, the demodulated data is stored in the buffer and the external controller can download received data. Transmit and receive capability of the AS3955 is limited by the buffer size. The maximum message size that can be received or transmitted is 32 bytes. The mutual access to the buffer from NFC block and SPI / I²C block is not allowed. At the beginning of each reception the buffer is cleared automatically. Before the data is loaded into the buffer via SPI / I²C for transmission the MCU must take care of clearing the buffer. Five interrupts that can be triggered during read or write of the buffer: • When buffer overflow or underflow is detected an I_bf_ err is triggered. The reason for the interrupt can be distinguished by reading the Buffer Status Register 1. • Buffer overflow IRQ is not blocked, in case if more than 32 bytes are received from reader or written via SPI / I²C into buffer the buffer underflow IRQ is produced. • When data is loaded via data RF an I_rxs and I_rxe are triggered • When all data is transmitted an I_txe is triggered • When buffer is already busy due to another operation in progress and MCU tries to access the internal buffer an interrupt I_acc_err shall be triggered. ams Datasheet [v1-04] 2016-Feb-03 Page 73 Document Feedback AS3955 − Detailed Description After data is received, the microcontroller shall check the amount of bytes actually received. This information is available in the Buffer Status Register 2, which displays number of bytes in the buffer not yet read out. Buffer Status Register 1 additionally contains a flag indicating buffer overflow. EEPROM Read and Write The EEPROM can be accessed from SPI / I²C interface or over RF field issuing NFC read and write commands. The EEPROM access is controlled by the internal EEPROM controller. Since the mutual access to the EEPROM is not possible AS3955 needs to arbitrate between MCU and NFC device in cases of mutual access. How this is handled it is defined according to arbit_mod bit. Typical EEPROM programing time is 8.3 ms and should not exceed 9.5 ms. Please note that word data is sent MSB first which is opposite to the RFID EEPROM programming where LSB is sent first. Three interrupts can be triggered during EEPROM read or write: • When EEPROM programing is executed successfully an I_ io_eewr interrupt is triggered. • When EEPROM programming is terminated due to higher priority of the RF part, writing to a non-existent address or writing is not allowed an I_eeac_err interrupt is triggered. • When EEPROM is busy and can’t be accessed an I_acc_err interrupt is triggered Note that EEPROM does not contain any kind on ant tearing mechanism that would allow detection of corrupted data The valid range for the Block Address byte depends on the EEPROM size. For 4kbit EEPROM, the valid range for the Block Address byte is from 000_0000b to 111_1111b (EEPROM blocks from 00h to 7Fh). Data Buffer Data in buffer is organized in bytes; each byte is terminated by a parity bit. Data bits in a byte are numbered from b1 to b8 where b1 is LSB bit, LSB is sent first. Data sent over SPI / I²C is also organized in bytes, bits in a byte are marked D0 to D7, where D0 is LSB bit, MSB is sent first. During reception, the framing engine checks the parity bit and removes it from data frame, and only data bytes are put into buffer. During transmission, the process is reversed, only data bytes are put into buffer, while the framing engine adds the parity bits. The data bits b1 to b8 are mapped to buffer data bits D0 to D7, which means that the order of receiving/transmitting bits in a byte is reversed (the bytes are sent LSB first while the SPI / I²C bytes are sent MSB first). Page 74 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Detailed Description Direct Commands Figure 83: List of Direct Commands Command Byte Value Command C2 Set Default Set AS3955 to default state C4 Clear Buffer Clears buffer and its error flags C6 Restart Transceiver C7 Disable/Enable Transceiver C8 Transmit Buffer C9 Transmit ACK CA Transmit NACK 0 Transmits NFC NAK reply with code 0h CB Transmit NACK 1 Transmits NFC NAK reply with code 1h CD Transmit NACK 4 Transmits NFC NAK reply with code 4h CC Transmit NACK 5 Transmits NFC NAK reply with code 5h D0 Go To Sleep Puts a tag in SLEEP state D1 Go To Sense Puts a tag in SENSE state D2 Go To Sense / Sleep Comments Restarts transceiver communication logics Toggles disable transceiver bit Starts a transmit sequence of the buffer content Transmits NFC ACK reply Puts a tag in SENSE or SLEEP state depending on the internal AS3955 state Set Default This direct command puts the AS3955 in the same state as power-up initialization except for I²C bit in register IC Status Display Register that defines the interface and IO Configuration Register, which are not cleared. Clear Buffer Clears buffer, buffer overflow and underflow bits. Restart Transceiver Resets protocol logic to its initial state except for the tag state. This interrupts all receptions and transmissions that are being processed at the time. ams Datasheet [v1-04] 2016-Feb-03 Page 75 Document Feedback AS3955 − Detailed Description Disable/Enable Transceiver This direct command toggles internal states which enables or disables the reception or transmission of the data. This command should be used when MCU wants to disable the interruption of EEPROM write/read over SPI / I²C by the received RF wire/read command. The RF part can also be enabled by issuing the Restart RX/TX. This command shall not change the tag state. Transmit Buffer This direct command trigger the transmission of data stored in the buffer over the RF link. Before issuing a Transmit command, the MCU shall send a Clear Buffer command, and write into the buffer the data to be transmitted by sending a Buffer Load command. Execution of this direct command is only enabled when the AS3955 antenna coil is in a PCD field (VP_INT is above HF_PON threshold) and AS3955 Extended or Tunneling modes are enabled. Transmit ACK Transmit 4-bit ACK response. Transmit NACK 0-5 Transmit 4-bit NACK response with different NACK codes. Go To Sleep Puts tag in SLEEP state. Execution of this direct command is only enabled when AS3955 antenna coil is in a NFC device field (VP_ INT is above HF_PON threshold). Go To Sense Puts tag in SENSE state. Execution of this direct command is only enabled when the AS3955 antenna coil is in a NFC device field (VP_INT is above HF_PON threshold). Go To Sense / Sleep Puts tag in SLEEP state depending on the internal state of the tag. Execution of this direct command is only enabled when AS3955 antenna coil is in a NFC device field (VP_INT is above HF_PON threshold). Page 76 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Register Description The 6-bit register addresses below are defined in hexadecimal notation. The possible address range is from 00h to 3Fh. Register Description There are two types of registers implemented in AS3955: configuration registers and display registers. The configuration registers are used to configure AS3955. They can be written and read through SPI / I²C (RW). The display registers are read-only (RO); they contain information about AS3955 internal state, which can be accessed through SPI / I²C. Registers Overview Figure 84: List of the SPI / I²C Internal Registers Address [hex] Content Comment Type 00 IO Configuration Register 01 IC Configuration Register 0 Default: IC_CFG0 RO/RW 02 IC Configuration Register 1 Default: IC_CFG1 RO 03 IC Configuration Register 2 Default: IC_CFG2+ battery supply enable 04 RFID Status Display Register RO 05 IC Status Display Register RO 08 Mask Interrupt Register 0 Default: MIRQ_0 RW 09 Mask Interrupt Register 1 Default: MIRQ_1 RW 0A Interrupt Register 0 RO 0B Interrupt Register 1 RO 0C Buffer Status Register 2 RO 0D Buffer Status Register 1 RO 0E Last NFC Address Access Register RO 1E Version Control – Major Revision RO 1F Version Control – Minor Revision RO ams Datasheet [v1-04] 2016-Feb-03 RW RO/RW Page 77 Document Feedback AS3955 − Register Description IO Configuration Register Figure 85: IO Configuration Register Address 00h: IO Configuration Type: RW Bit Name Default Function Comments 7 miso_pd2 0 1: pull down on MISO, when \SS is low and MISO is not driven by the AS3955 6 miso_pd1 0 1: pull down on MISO when \SS is high 5 rfu 0 4 rfu 0 3 rfu 0 2 rfu 0 1 rfu 0 0 rfu 0 Note(s): 1. Default value is loaded from EEPROM configuration block bits (IC_CFG2). IC Configuration Registers Figure 86: IC Configuration Register 0 Address 01h: IC Configuration 0 Bit Name 7 slnt_mod 6 slnt_vl 5 slnt_vl 4 slnt_vl 3 arbit_mod 2 i2c_addr3 1 i2c_addr2 0 i2c_addr1 Default Function Type 1: Enable silent mode RO Silent mode voltage level (see Silent Mode) RO 1: RF has priority access to EEPROM over SPI / I²C RW I²C slave address RO See note Note(s): 1. Default value is loaded from EEPROM configuration block bits (IC_CFG0). Page 78 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Register Description Figure 87: IC Configuration Register 1 Address 02h: IC Configuration 1 Bit Name 7 en_rx_crc 6 vreg 5 vreg 4 vreg Default See note 3 vreg 2 vreg 1 rreg 0 rreg Function Type 1: CRC stored in the buffer in the Tunneling mode RO Voltage level for voltage regulator VP_REG (see Energy Harvesting) RO Output resistance value for voltage regulator VP_REG (see Energy Harvesting) RO Note(s): 1. Default value is loaded from EEPROM configuration block bits (IC_CFG1). Figure 88: IC Configuration Register 2 Address 03h: IC Configuration 2 Bit Name Default 7 rfcfg_en 6 tun_mod 5 ext_mod 4 nak_on_crc_parity 0 3 auth_set See note 2 selr_b6_inv 0 1 powm Function Type RO See note RW RW See Configuration Byte IC_CFG2 for full description RO RO RO RW See note 0 powm RW Note(s): 1. Default value is loaded from EEPROM configuration block bits (IC_CFG2) ams Datasheet [v1-04] 2016-Feb-03 Page 79 Document Feedback AS3955 − Register Description Status Display Registers Figure 89: RFID Status Display Register Address 04h: RFID Status Display Bit Name Function 7 hf_pon 6 state 5 state 4 state 3 state 2 state_notvalid 1 rfu RO 0 rfu RO 1: PICC AFE is active 0000: POWER OFF 0001: SENSE 0011: RESOLUTION 0010: RESOLUTION_L2 0110: SELECTED 0111: SECTOR_2 Type RO 1111: SECTORX_2 1110: SELECTEDX 1010: SENSEX_L2 1011: SENSEX 1001: SLEEP 1: State update – indicates that the state is not valid RO RO Figure 90: IC Status Display Register Address 05h: IC Status Display Bit Name 7 ee2k Default Function Type RO See note (1) 6 i2c RO 5 chipkill_2 0 Signal depends on the CHIP_KILL value at initialization RO 4 chipkill_1 0 Signal depends on the CHIP_KILL value at initialization RO 3 auth_locked 0 Signal depends on the AUTH_CNT value RO 2 rfu 0 RO 1 rfu 0 RO 0 rfu 0 RO Note(s): 1. Default is set during production Page 80 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Register Description Interrupt Registers Figure 91: Mask Interrupt Register 0 Address 08h: Mask Interrupt 0 (1) Bit Name 7 Default Function Type M_pu Mask I_pu IRQ RW 6 M_wu_a Mask I_wu_a IRQ RW 5 M_slp Mask I_slp IRQ RW 4 M_eew_rf Mask I_eew_rf IRQ RW See note (2) 3 M_eer_rf Mask I_eer_rf IRQ RW 2 M_rxe Mask I_rxe IRQ RW 1 M_txe Mask I_txe IRQ RW 0 M_xrf Mask I_xrf IRQ RW Note(s): 1. The mask bits only mask the triggering of the physical interrupt line. The interrupt bits in the Interrupt register still get set when the interrupt is masked. 2. Default values are loaded from EEPROM configuration block bits (MIRQ_0). Figure 92: Mask Interrupt Register 1 Address 09h: Mask Interrupt 1 (1) Bit Name 7 Default Function Type M_rxs Mask I_rxs IRQ RW 6 M_frm_err Mask I_frm_err IRQ RW 5 M_par_err Mask I_par_err IRQ RW 4 M_crc_err Mask I_crc_err IRQ RW See note (2) 3 M_bf_err Mask I_bf_err IRQ RW 2 M_io_eewr Mask I_io_eewr IRQ RW 1 M_eeac_err Mask I_eeac_err IRQ RW 0 M_acc_err Mask I_acc_err IRQ RW Note(s): 1. The mask bits only mask the triggering of the physical interrupt line. The interrupt bits in the Interrupt register still get set when the interrupt is masked. 2. Default values are loaded from EEPROM configuration block bits (MIRQ_1). ams Datasheet [v1-04] 2016-Feb-03 Page 81 Document Feedback AS3955 − Register Description Figure 93: Interrupt Register 0 Address 0Ah: Interrupt Register 0 Bit Name Function Type 7 I_pu Power-up IRQ. Interrupt is triggered at each power up (RF or battery), when chip is already powered and RF field appears and after Go To Sleep, Go To Sense, Go To Sense / Sleep and Set Defaultcommand RO 6 I_wu_a Wake-up IRQ at entry in SELECTED state RO 5 I_slp IRQ due to reception of SLP_REQ command RO 4 I_eew_rf PCD has updated the content of the data area RO 3 I_eer_rf PCD has read the content of the data area RO 2 I_rxe IRQ due to End of Receive. Applicable when receive frame is put in buffer RO 1 I_txe IRQ due to End of Transmission. Applicable when data from buffer is sent RO 0 I_xrf Exit RF field IRQ RO Note(s): 1. Power-up and Set Default command set the content of this register to 0. After Interrupt Register has been read, its content is set again to 0. Figure 94: Interrupt Register 1 Address 0Bh: Interrupt Register 1 Bit Name 7 I_rxs 6 Function Type IRQ due to Start of Receive. Applicable when receive frame is put in buffer RO I_frm_err Lower layer error (broken byte, wrong bit coding sequence) / In case of error the receive data is still put in buffer, error IRQ is additionally sent RO 5 I_par_err Parity error / In case of error the receive data is still put in buffer, error IRQ is additionally sent RO 4 I_crc_err CRC error / In case of CRC error the receive data is still put in buffer, error IRQ is additionally sent RO 3 I_bf_err Buffer error (overflow/underflow). See Buffer Status Register 2 RO Page 82 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Register Description Address 0Bh: Interrupt Register 1 Bit Name Function Type 2 I_io_eewr IRQ due to successful termination of EEPROM programming. In case EEPROM write command was sent through SPI / I²C RO 1 I_eeac_err IRQ due to EEPROM write on write protected block or write to non-existing address RO 0 I_acc_err IRQ due to interruption of SPI / I²C operation on buffer, EEPROM or registers due to access control RO Note(s): 1. Power-up and Set Default command reset the content of this register to 0. After Interrupt Register has been read, its content is set again to 0. Buffer Registers Figure 95: Buffer Status Register 2 Address 0Ch: Buffer Status Register 2 Bit Name 7 buf_len_invalid 6 rfu 5 buf_len 4 buf_len 3 buf_len 2 buf_len 1 buf_len 0 buf_len Function Type Buffer content is being changed – data length not valid RO RO Number of data bytes (binary coded) in the buffer not yet read out. Valid range is from 000000b to 100000b – 000000b means that there are no data bytes to be read out RO Note(s): 1. Power-up and commands Set Default and Clear Buffer reset the content of this register to 0. ams Datasheet [v1-04] 2016-Feb-03 Page 83 Document Feedback AS3955 − Register Description Figure 96: Buffer Status Register 1 Address 0Dh: Buffer Status Register 1 Bit Name Function Type 7 rfu RO 6 rfu RO 5 rf_busy RO Extended mode buffer status flags (see Extended Mode); io_ busy flag is omitted since in this it is always zero when this byte is read out 4 rf_data_rdy RO 3 io_data_rdy RO 2 rfu RO 1 buf_unf Buffer underflow. Set when read more bytes then actual content of buffer RO 0 buf_ovr Buffer overflow. Set when written more bytes then actual content of buffer RO Note(s): 1. Power-up and commands Set Default and Clear Buffer reset the content of this register to 0. NFC Last Address Register Figure 97: Last NFC Address Access Register Address 0Eh: Last NFC Address Access Bit Name 7 last_addr 6 last_addr 5 last_addr 4 last_addr 3 last_addr 2 last_addr 1 last_addr 0 last_addr Function Type Contains last address accessed by reader. Updated on internal EEPROM access over RF. The address is 8 bit long and contains also access attempts that are higher than the EEPROM address space. Value FFh indicates that the value is being updated and is not valid. RO Note(s): 1. Power-up and commands Set Default and Clear Buffer reset the content of this register to 0. Page 84 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Register Description Version Control Register Figure 98: Version Control – Major Revision Address 1Eh: Version Control – Major Revision Bit Name Default 7 maj7 0 6 maj6 0 5 maj5 0 4 maj4 0 3 maj3 0 2 maj2 0 1 maj1 0 0 maj0 1 Function Type Major version revision RO Figure 99: Version Control – Minor Revision Address 1Fh: Version Control – Minor Revision Bit Name Default 7 min7 0 6 min6 0 5 min5 0 4 min4 0 3 min3 0 2 min2 0 1 min1 0 0 min0 0 Function Type Minor version revision RO Note(s): 1. Default values are loaded from EEPROM configuration block bits (Configuration Bytes MIRQ_0 and MIRQ_1) ams Datasheet [v1-04] 2016-Feb-03 Page 85 Document Feedback AS3955 − Application Information Application Information This section describes some general use cases of AS3955 in combination with a microcontroller. The examples are shown for explanatory purposes of specific AS3955 features. Detailed descriptions of specific implementations are subject of dedicated Application Notes. Writing a NDEF Message into AS3955 Memory AS3955 is an NFC Forum Type 2 Tag Platform and as such its memory has to have the layout defined in NFC Forum Type 2 Tag Operation Specification. In a Type 2 Tag platform data is stored in memory in the form of TLV blocks. A TLV block has three fields: T field – tag field, L field – length field and V field – value field. • T field – indicates the type of the TLV block and is one byte long. • L field – gives the size in bytes of the value field. It’s 1 or 3 bytes long depending on the size of the value filed. When the size of the value field is between 0 and 254 bytes, the L field is one byte long and has a value between 00h and FEh. For sizes of the value field between 255 and 65535 bytes, the L field is 3 bytes long. First byte is FFh indicating that the size will be provided by the following two bytes that can have values between 00FFh and FFFEh. • V field – holds the bytes of the data carried by the TLV block. When the L field is zero or not present, the V field is omitted. For NDEF messages the TLV block has a T field value of 03h and the message is stored inside the V field. The NDEF Message TLV should always be present in a T2T platform and at a minimum it is an empty NDEF Message TLV, which is defined as an NDEF Message TLV with L field equal 00h and no V field. For the NDEF message format refer to NFC Data Exchange Format Technical Specification. Two more TLV types can exist in the memory, these are Lock Control TLV and Memory Control TLV. When they are present inside the memory, the NDEF Message TLV should be placed after them. Another structure that has to be present in the memory of T2T platform is the Capability Container (CC). CC contains NFC Forum management data. It is comprised of 4 bytes and always resides at block number 03h of the memory. The AS3955 comes with programmed CC (refer to Capability Container in the section Memory Organization of this datasheet), no Lock Control TLV and no Memory Control TLV. The NDEF Message TLV then can be placed already at the beginning of the data area of the memory - block 04h. Page 86 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Application Information Following is an example of an NDEF message with one Well Known URL record, which carries the http://www.ams.com URL: • In the NDEF message format, the URL above will be represented by the bytes: [D1 01 08 55 01 61 6D 73 2E 63 6F 6D]h • The NDEF Message TLV will have the content: [03 0C D1 01 08 55 01 61 6D 73 2E 63 6F 6D]h; first byte is 03h – T field value, indicating this is an NDEF Message TLV, second byte is 0Ch saying the V field is 12 bytes long, the following 12 bytes are the V field holding the NDEF message. The NDEF message TLV given above will fully occupy the first 3 blocks of the data area and the first two bytes of the 4th block of the data area (each memory block is 4 bytes long). Reading/Writing Through NFC Device NFC devices use the T2T WRITE command to write data into a T2T platform. The T2T WRITE command consists of 6 bytes, 1st byte is the command code – A2h, 2nd byte is the block number where data is to be written and the remaining 4 bytes are the data content. When the execution of the command is successful, the tag will return an ACK response – A0h. In case of failure, a NACK code will be returned (see Error Handling section of this datasheet for NACK codes). The T2T READ command consists of 2 bytes, first byte is the command code and is equal to 30h, second byte is the first block number from which data will be returned. The response, when successful, will return 4 blocks of data, each block is 4 bytes long, so 16 bytes of data. In case of error, one byte NACK response will be returned (see error handling section of AS3955 datasheet for NACK codes). AS3955 has to be configured in Extended or Normal mode in order for an NFC device to write/read NDEF data from the EEPROM of the tag. An NFC device has to send 4 write commands to the tag to write the NDEF Message TLV bytes [03 0C D1 01 08 55 01 61 6D 73 2E 63 6F 6D]hex defined in the section above into blocks 04h-07h: 1. [A2 04 03 0C D1 01]hex 2. [A2 05 08 55 01 61]hex 3. [A2 06 6D 73 2E 63]hex 4. [A2 07 6F 6D 00 00]hex The same NDEF Message TLV bytes can be obtained with a single READ command, as the TLV occupies only 4 blocks and the READ command returns 16 bytes. In case of longer NDEF messages of course several READs are necessary until the complete message has been read out. ams Datasheet [v1-04] 2016-Feb-03 Page 87 Document Feedback AS3955 − Application Information Reading/Writing Through SPI / I²C An MCU can write the NDEF Message TLV bytes [03 0C D1 01 08 55 01 61 6D 73 2E 63 6F 6D]hex into blocks 04h-07h by sending the following 4 bytes sequences through SPI or I²C (as described in the Wired Interfaces section of this datasheet): Writing: 1. [40 08 03 0C D1 01]hex 2. [40 0A 08 55 01 61]hex 3. [40 0C 6D 73 2E 63]hex 4. [40 0E 6F 6D 00 00]hex To read the same data bytes written in blocks 04h – 07h, the MCU should send the bytes sequences below (2 clock cycles for MODE and address and 4 additional clock cycles to read the data sent from AS3955, refer to the Wired Interfaces section of this datasheet): 1. [7F 08 00 00 00 00]hex 2. [7F 0A 00 00 00 00]hex 3. [7F 0C 00 00 00 00]hex 4. [7F 0E 00 00 00 00]hex Using Extended Mode to Switch AS3955 into Tunneling Mode An NFC device can force the AS3955 in Tunneling mode by sending a command via Extended to the MCU to switch the AS3955 operating mode from Extended to Tunneling (refer to Extended mode section of this datasheet for implementation details). If the MCU should emulate a T4T after the switch, AS3955 should be sent to SENSE state by the MCU with the direct command “Go To Sense” (command code D1h) and the NFC device should do a new anti-collision round for proper T4T activation. Using Tunneling Mode to Emulate a NFC Type 4 Tag For T4T emulation the Tunneling mode has to be enabled by setting the tun_mod bit of IC_CFG2 to 1 and the SELR to 0x20. With this configuration, once AS3955 has passed anti-collision and entered SELCTED state, all frames coming from the NFC interface will be pushed to the BUFFER. That means also the SENS_REQ, ALL_REQ, SSD_REQ, SEL_REQ and SLP_REQ will not be executed by the AS3955, so MCU must send the tag to SLEEP state on SLP_REQ (with direct command “Go To Sleep”) and to SENSE state (with direct command “Go To Sense”) on any of the other commands listed above. Page 88 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Application Information The ISO14443A-4 command RATS should also be handled by the MCU. RATS is sent by an NFC device to activate ISO14443A-4, on top of which is T4T platform is implemented. Please refer to the application note Emulation of an NFC Type 4Tag in Tunneling Mode for detailed information and software code examples. References • [EMVCO-1] EMVCo Type Approval Contactless Terminal Level 1 – PCD Digital Test Bench & Test Cases, version 2.3.1a, January 2013 • [ISO14443-3] ISO/IEC 14443-3:2011(E), Identification cards — Contactless integrated circuit cards — Proximity cards — Part 3: Initialization and anticollision • [ISO14443-4] ISO/IEC 14443-4:2008(E), Identification cards — Contactless integrated circuit(s) cards — Proximity cards — Part 4: Transmission protocol • [ISO18092] ISO/IEC 18092:2013 — Information technology — Telecommunications and information exchange between systems — Near Field Communication — Interface and Protocol (NFCIP-1) • [ISO7816-3] ISO/IEC 7816-3:2006, Identification cards — Integrated circuit cards — Part 3: Cards with contacts — Electrical interface and transmission protocols • [ISO7816-4] ISO/IEC 7816-4:2005, Identification cards — Integrated circuit cards — Part 4: Organization, security and commands for interchange • [ISO7816-6] ISO/IEC 7816-6:2004, Identification cards — Integrated circuit cards — Part 6: Interindustry data elements for interchange • [NFC Analog] NFC Analog Specification — NFC Forum, 11.07.2011, Version 1.0 • [NFC Digital] NFC Digital Protocol — NFC Forum, 17.11.2010, Version 1.0 • [NDEF] NFC Data Exchange Format (NDEF), Technical Specification — NFC Forum, 24.07.2006, Version 1.0 • [PHDC] Personal Health Device Communication), Technical Specification — NFC Forum, 27.02.2013, Version 1.0 • [T2T] Tag 2 Type Operation, Technical Specification — NFC Forum, 31.05.2011, Version 1.1 • [T4T] Tag 4 Type Operation, Technical Specification — NFC Forum, 28.06.2011, Version 2.0 ams Datasheet [v1-04] 2016-Feb-03 Page 89 Document Feedback AS3955 − Package Drawings & Mark ings Package Drawings & Markings Figure 100: Package Outline Drawings MLPD RoHS Green Symbol Min Nom Max A A1 A3 L b D E e D2 E2 aaa bbb ccc ddd eee N 0.80 0 0.90 0.02 0.20 REF 0.40 0.25 3.00 BSC 3.00 BSC 0.50 BSC 2.38 1.64 0.15 0.10 0.10 0.05 0.08 10 1.00 0.05 0.30 0.18 2.23 1.49 - 0.50 0.30 2.48 1.74 - Note(s): 1. Dimensioning and tolerancing conform to ASME Y14.5M-1994. 2. All dimensions are in millimeters. Angles are in degrees. 3. Coplanarity applies to the exposed heat slug as well as the terminal. 4. Radius on terminal is optional. 5. N is the total number of terminals. Page 90 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Package Drawings & Markings Figure 101: Package Marking MLPD (I²C) AS39 55I4 XXXX Figure 102: Package Marking MLPD (SPI) AS39 55S4 XXXX Figure 103: Package Code MLPD XXXX Tracecode ams Datasheet [v1-04] 2016-Feb-03 Page 91 Document Feedback AS3955 − Package Drawings & Mark ings Figure 104: Package Outline Drawings WL-CSP RoHS Green Note(s): 1. Pin 1=A1. 2. ccc Coplanarity. 3. All dimensions are in μm. 4. This applies to AWLT ordering codes. Page 92 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Package Drawings & Markings Figure 105: Package Outline Drawings Thin WL-CSP RoHS Green Note(s): 1. Pin1 = A1. 2. ccc coplanarity. 3. All dimensions are in μm. 4. This applies to ATWT ordering codes. ams Datasheet [v1-04] 2016-Feb-03 Page 93 Document Feedback AS3955 − Package Drawings & Mark ings Figure 106: Package Marking WL-CSP 3955_S4 XXXX Figure 107: Package Code WL-CSP XXXX Tracecode Page 94 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Ordering & Contact Information Ordering & Contact Information Figure 108: Ordering Information Ordering Code Package Marking Delivery Form Configuration AS3955-ATDM-S4 MLPD AS3955S4 Mini Reel SPI - EEPROM 4kbit AS3955-ATDT-S4 MLPD AS3955S4 Tape & Reel SPI - EEPROM 4kbit AS3955-ATDM-I4 MLPD AS3955I4 Mini Reel I²C - EEPROM 4kbit AS3955-ATDT-I4 MLPD AS3955I4 Tape & Reel I²C - EEPROM 4kbit AS3955-AWLT-S4 WL-CSP 3955_S4 Tape & Reel SPI - EEPROM 4kbit AS3955-AWLT-I4 WL-CSP 3955_I4 Tape & Reel I²C - EEPROM 4kbit AS3955-ASWF-S4 Sorted wafer NA Wafer Box SPI - EEPROM 4kbit AS3955-ASWF-I4 Sorted wafer NA Wafer Box I²C - EEPROM 4kbit AS3955-ATWT-S4 Thin WL-CSP 3955_S4 Tape & Reel SPI - EEPROM 4kbit AS3955-ATWT-I4 Thin WL-CSP 3955_I4 Tape & Reel I²C - EEPROM 4kbit AS3955-ATDM-S2 (1) MLPD AS3955S2 Mini Reel SPI - EEPROM 2kbit AS3955-ATDT-S2 (1) MLPD AS3955S2 Tape & Reel SPI - EEPROM 2kbit AS3955-ATDM-I2 (1) MLPD AS3955I2 Mini Reel I²C - EEPROM 2kbit AS3955-ATDT-I2 (1) MLPD AS3955I2 Tape & Reel I²C - EEPROM 2kbit AS3955-AWLT-S2 (1) WL-CSP 3955_S2 Tape & Reel SPI - EEPROM 2kbit AS3955-AWLT-I2 (1) WL-CSP 3955_I2 Tape & Reel I²C - EEPROM 2kbit AS3955-ASWF-S2 (1) Sorted wafer NA Wafer Box SPI - EEPROM 2kbit AS3955-ASWF-I2 (1) Sorted wafer NA Wafer Box I²C - EEPROM 2kbit Note(s): 1. Will be available on request. ams Datasheet [v1-04] 2016-Feb-03 Page 95 Document Feedback AS3955 − Ordering & Contact Information Buy our products or get free samples online at: www.ams.com/ICdirect Technical Support is available at: www.ams.com/Technical-Support Provide feedback about this document at: www.ams.com/Document-Feedback For further information and requests, e-mail us at: ams_sales@ams.com For sales offices, distributors and representatives, please visit: www.ams.com/contact Headquarters ams AG Tobelbaderstrasse 30 8141 Premstaetten Austria, Europe Tel: +43 (0) 3136 500 0 Website: www.ams.com Page 96 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − RoHS Compliant & ams Green Statement RoHS Compliant & ams Green Statement RoHS: The term RoHS compliant means that ams AG products fully comply with current RoHS directives. Our semiconductor products do not contain any chemicals for all 6 substance categories, including the requirement that lead not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, RoHS compliant products are suitable for use in specified lead-free processes. ams Green (RoHS compliant and no Sb/Br): ams Green defines that in addition to RoHS compliance, our products are free of Bromine (Br) and Antimony (Sb) based flame retardants (Br or Sb do not exceed 0.1% by weight in homogeneous material). Important Information: The information provided in this statement represents ams AG knowledge and belief as of the date that it is provided. ams AG bases its knowledge and belief on information provided by third parties, and makes no representation or warranty as to the accuracy of such information. Efforts are underway to better integrate information from third parties. ams AG has taken and continues to take reasonable steps to provide representative and accurate information but may not have conducted destructive testing or chemical analysis on incoming materials and chemicals. ams AG and ams AG suppliers consider certain information to be proprietary, and thus CAS numbers and other limited information may not be available for release. ams Datasheet [v1-04] 2016-Feb-03 Page 97 Document Feedback AS3955 − Copyrights & Disclaimer Copyrights & Disclaimer Copyright ams AG, Tobelbader Strasse 30, 8141 Premstaetten, Austria-Europe. Trademarks Registered. All rights reserved. The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the copyright owner. Devices sold by ams AG are covered by the warranty and patent indemnification provisions appearing in its General Terms of Trade. ams AG makes no warranty, express, statutory, implied, or by description regarding the information set forth herein. ams AG reserves the right to change specifications and prices at any time and without notice. Therefore, prior to designing this product into a system, it is necessary to check with ams AG for current information. This product is intended for use in commercial applications. Applications requiring extended temperature range, unusual environmental requirements, or high reliability applications, such as military, medical life-support or life-sustaining equipment are specifically not recommended without additional processing by ams AG for each application. This product is provided by ams AG “AS IS” and any express or implied warranties, including, but not limited to the implied warranties of merchantability and fitness for a particular purpose are disclaimed. ams AG shall not be liable to recipient or any third party for any damages, including but not limited to personal injury, property damage, loss of profits, loss of use, interruption of business or indirect, special, incidental or consequential damages, of any kind, in connection with or arising out of the furnishing, performance or use of the technical data herein. No obligation or liability to recipient or any third party shall arise or flow out of ams AG rendering of technical or other services. Page 98 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Document Status Document Status Document Status Product Preview Preliminary Datasheet Datasheet Datasheet (discontinued) ams Datasheet [v1-04] 2016-Feb-03 Product Status Definition Pre-Development Information in this datasheet is based on product ideas in the planning phase of development. All specifications are design goals without any warranty and are subject to change without notice Pre-Production Information in this datasheet is based on products in the design, validation or qualification phase of development. The performance and parameters shown in this document are preliminary without any warranty and are subject to change without notice Production Information in this datasheet is based on products in ramp-up to full production or full production which conform to specifications in accordance with the terms of ams AG standard warranty as given in the General Terms of Trade Discontinued Information in this datasheet is based on products which conform to specifications in accordance with the terms of ams AG standard warranty as given in the General Terms of Trade, but these products have been superseded and should not be used for new designs Page 99 Document Feedback AS3955 − Revision Information Revision Information Changes from 1-01 (2015-Apr-29) to current revision 1-04 (2016-Feb-03) Page 1-01 (2015-Apr-29) to 1-02 (2015-Dec-30) Updated Figure 10 10 Updated text under Energy Harvesting 17 Updated text under NFC Device to MCU Data Flow Protocol 46 Updated Figure 50 48 Updated Figure 51 49 Added Figure 56 56 Added I²C Slave Address section 66 Updated Figure 104 103 Updated Figure 107 105 1-02 (2015-Dec-30) to 1-03 (2016-Jan-28) Updated Figure 50 49 Updated Figure 51 50 Updated Application Information section 86 Updated Figure 105 93 Updated Figure 108 95 1-03 (2016-Jan-28) to 1-04 (2016-Feb-03) Updated text under Using Tunneling Mode to Emulate a NFC Type 4 Tag 88 Note(s): 1. Page and figure numbers for the previous version may differ from page and figure numbers in the current revision. 2. Correction of typographical errors is not explicitly mentioned. Page 100 Document Feedback ams Datasheet [v1-04] 2016-Feb-03 AS3955 − Content Guide Content Guide 1 2 3 4 General Description Key Benefits & Features Applications Block Diagram 6 7 Pin Assignment Pin Description 8 Absolute Maximum Ratings 9 9 9 10 Electrical Characteristics Operating Conditions DC/AC Characteristics for Digital Inputs and Outputs Electrical Specifications 13 13 14 14 16 16 16 17 17 17 18 19 19 19 20 20 20 23 24 25 25 25 26 26 26 Detailed Description Analog Frontend (AFE) Power Management Power Mode 0 Power Mode 1 Power Mode 2 Power Mode 3 Interface Arbitration Arbitration Mode 0 Arbitration Mode 1 Energy Harvesting Silent Mode Memory Protection Passive Wake-Up Chip Kill NFC Tag Functionality Communication Principle NFC Forum Type 2 Tag Support UID Coding Coding of SENS_RES, SEL_REQ, ACK and NACK SENS_RES Response SEL_RES Response, Cascade Level 1 and 2 ACK Response NACK Response Access to UID, SENS_RES and SEL_REQ During AntiCollision Get Version Command Memory Organization 4kbit EEPROM Organization 2kbit EEPROM Organization UID Bytes Fabrication Data Capability Container Configuration Bytes AS3955 Communication Modes Standalone NFC Type 2 Tag Mode Tunneling Mode Extended Mode Error Handling 26 28 28 30 31 31 34 35 44 44 44 46 54 ams Datasheet [v1-04] 2016-Feb-03 Page 101 Document Feedback AS3955 − Content Guide Page 102 Document Feedback 58 58 59 67 73 73 74 74 75 Wired Interfaces SPI / I²C Access Modes SPI Interface I²C Interface Interrupt Interface Description Buffer Interrupts and Buffer Status Register EEPROM Read and Write Data Buffer Direct Commands 77 77 78 78 80 81 83 84 85 Register Description Registers Overview IO Configuration Register IC Configuration Registers Status Display Registers Interrupt Registers Buffer Registers NFC Last Address Register Version Control Register 86 86 87 88 88 88 89 Application Information Writing a NDEF Message into AS3955 Memory Reading/Writing Through NFC Device Reading/Writing Through SPI / I²C Using Extended Mode to Switch AS3955 into Tunneling Mode Using Tunneling Mode to Emulate a NFC Type 4 Tag References 90 95 97 98 99 100 Package Drawings & Markings Ordering & Contact Information RoHS Compliant & ams Green Statement Copyrights & Disclaimer Document Status Revision Information ams Datasheet [v1-04] 2016-Feb-03
AS3955-ATDM-S4 价格&库存
很抱歉,暂时无法提供与“AS3955-ATDM-S4”相匹配的价格&库存,您可以联系我们找货
