SL900A-ASWB
SL900A-ASWB
    AMSOSRAM(艾迈斯半导体)
    VQFN16_EP
    RFID Transponder IC 860MHz ~ 960MHz ISO 15693 SPI 1.2 V ~ 3.6 V 16-VQFN Exposed Pad
SL900A-ASWB 数据手册
SL900A EPC Class 3 Sensory Tag Chip - For Automatic Data Logging General Description The SL900A is an EPC global Class 3 sensory tag chip optimized for single-cell and dual-cell, battery-assisted smart labels with sensor functionality. The chip is ideal for applications using thin and flexible batteries but can also be powered from the RF field (electromagnetic waves from an RFID reader). The chip has a fully integrated temperature sensor with a typical nonlinearity of ±0.5ºC over the specified temperature range. The external sensor interface provides a flexible way of adding additional sensors to the system and supports up to 2 external sensors. Ordering Information and Content Guide appear at end of datasheet. Key Benefits & Features The benefits and features of SL900A, EPC Class 3 Sensory Tag Chip - For Automatic Data Logging are listed below: Figure 1: Added Value of using SL900A Benefits Features Versatile temperature and data logging High Temperature Range: -40°C to +125°C Worldwide EPC compliant Frequency: 860 to 960 MHz Works fully passive or in BAP mode Battery supply: 1.5V or 3V Programmable logging modes with various sensors Data logging from: • On-chip temperature sensor • 2 external sensors Works with EPC readers EPC Class 1 and Class 3 Compliant Provides supply for external sensors Energy harvesting from reader field Autonomous data logging with timestamp Real-time clock for data logging Sensor alert function External sensor interrupt capability Supports fast communication via SPI Serial peripheral interface Storage for up to 841 events with timestamps On-chip 9k bit EEPROM Alert for shelf life expiration Integrated dynamic shelf life calculation Programmable sensor limits Advanced logging with 4 user-selectable limits ams Datasheet: 2014-May-06 [v1-01] SL900A – 1 Package Options The available SL900A package options are: • 16-pin QFN (5 x 5 mm) • Tested wafer (8”) Applications The SL900A device is ideal suited for: • Monitoring and tracking of temperature-sensitive products • Temperature monitoring of medical products • Pharmaceutical logistics • Monitoring of fragile goods transportation • Dynamic Shelf Life applications • RFID to SPI interface Block Diagram The functional blocks of this device for reference are shown below: Figure 2: SL900A Block Diagram VBAT 1.5V or 3V VSS Power Management EXT1 Temperature Sensor VDD VPOS Battery Voltage External Sensor Front-End VSSA ANT SCLK SPI Port (Slave) Processing Digital Control EPC Gen2 Class 3 (cool-Log™) FIFO SEN MEAS ANA TEST DIGI TEST EXC VREF 860 - 960 MHz AFE DIN DOUT EXT2 1152 x 8 Bit EEPROM MUX 10-Bit A/D Converter Oscillator with RTC SL900A SL900A Block Diagram: Basic block diagram of SL900A SL900A – 2 ams Datasheet: 2014-May-06 [v1-01] Pi n A s s i g n m e n t The SL900A pin assignments are described below. Pin Assignment ANA_TEST EXC MEAS VBAT Figure 3: Pin Layout 16 15 14 13 VPOS 1 12 DOUT VSSA 2 11 DIN 10 SCLK 9 SEN DIGI_TEST 4 VREF 5 6 7 8 VSS 3 EXT2 ANT EXT1 SL900A Figure 4: Pin Description Pin Number Pin Name 1 VPOS RF rectifier output 2 VSSA Chip substrate ground – connect to antenna ground 3 ANT Antenna coil 4 DIGI_TEST 5 VREF Reference voltage output (Vo2) 6 EXT1 Analog input for external sensor 7 EXT2 Analog input for external sensor 8 VSS Chip substrate ground – connect to negative battery terminal. Recommended to connect to VSSA! 9 SEN Enable input for the SPI interface 10 SCLK SPI clock 11 DIN 12 DOUT ams Datasheet: 2014-May-06 [v1-01] Description Test input – must be left open SPI data input SPI data output SL900A – 3 Bare Die Pad Layout Pin Number Pin Name Description 13 VBAT Positive supply input 14 MEAS Test pin for use during test – must be left open 15 EXC 16 ANA-TEST Supply voltage for the external sensors or a AC signal source for external sensors Analog test pin – must be left open Pin Description: This table shows a detailed pin description of the SL900A. Bare Die Pad Layout Figure 5: Pad Location Diagram SL900A – 4 ams Datasheet: 2014-May-06 [v1-01] B a r e D i e Pa d L a y o u t Figure 6: Pad Parameters Pad name X position (μm) Y position (μm) Pad window (μm) Type VREF 77.5 2040.5 85 x 85 Analog Output EXT1 77.5 1787.5 85 x 85 EXT2 77.5 1098.5 85 x 85 VSS 77.5 223.5 85 x 85 SEN 1822.5 77.5 85 x 85 SCLK 2005.5 77.5 85 x 85 SDATAI 2271.5 77.5 85 x 85 SDATAO 2454.5 77.5 85 x 85 Digital Output E_SDATAO 2653.5 82.5 85 x 85 Test Pad VBAT 2657.5 275.5 85 x 85 Supply MEAS 2648.3 509.15 85 x 85 Test Pad EXC 2657.5 2144.5 85 x 85 Analog Output ANA_TEST 2657.5 2327.5 85 x 85 Test Pad VPOS 2657.5 2510.5 85 x 85 Analog Output VSSA 2292 2689.5 85 x 85 Supply ANT2 1396 2696 See RF pad drawing ANT1 1177 2694 See RF pad drawing DIGI_TEST 955 2707.5 85 x 85 Analog Input/Output Supply Digital Input Radio-frequency Pad, Test Pad Pad locations: Pad locations are measured from lower left chip edge to pad centre. ams Datasheet: 2014-May-06 [v1-01] SL900A – 5 Absolute Maximum Ratings Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only. Functional operation of the device at these or any other conditions beyond those indicated under “Operating Conditions” is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Absolute Maximum Ratings Figure 7: Absolute Maximum Ratings (Operating free-air temperature range, unless otherwise noted) Parameter Min Max Units Comments -0.3 3.7 V All voltage values are with respect to substrate ground terminal VSS 100 mA 2 kV ESD Rating, HBM (RF input pin ANT) 500 V Maximum Operating Virtual Junction Temperature, TJ +150 °C +150 °C +260 °C Input Voltage Range Maximum Current VPOS, ANT ESD Rating, HBM (all pins except ANT) Storage Temperature Range, Tstg -65 Lead Temperature (soldering, 10 sec.) Absolute Maximum Ratings: This figure shows the absolute maximum ratings of the SL900A. Electrical Discharge Sensitivity This integrated circuit can be damaged by ESD. We recommend that all integrated circuits are handled with appropriate precautions. Failure to observe proper handling and installation procedures can cause damage. ESD damage can range from subtle performance degradation to complete device failure. Precision integrated circuits may be more susceptible to damage because very small parametric changes could cause the device not to meet the published specifications. RF integrated circuits are also more susceptible to damage due to use of smaller protection devices on the RF pins, which are needed for low capacitive load on these pins. Operating Conditions Figure 8: Operating Conditions Symbol VBAT TA SL900A – 6 Parameter Min Typ Max Units Input Supply Voltage 1.2 1.5 3.6 V Operating ambient temperature range -40 +125 °C ams Datasheet: 2014-May-06 [v1-01] Electrical Characteristics Electrical Characteristics All limits are guaranteed. The parameters with min and max values are guaranteed with production tests or SQC (Statistical Quality Control) methods. TA = -40°C to +125°C, VBAT = 1.5V, unless otherwise noted. Typical values are at TA = 25°C (1). Figure 9: Electrical Characteristics Symbol Parameter Conditions Min Typ Max Units 3.6 V Operating Input Voltage TA = 25°C VBAT(SU) Minimum Start-Up Input Voltage TA = 25°C 1.3 IBAT-OP15 Operating Current into VBAT Temperature conversion, VBAT=1.5V 200 250 μA IBAT-OP30 Operating Current into VBAT Temperature conversion, VBAT=3V 290 350 μA IBAT-Q Quiescent Current into VBAT VBAT = 1.5V; timer running 1.6 μA IBAT-SD Shutdown Current into VBAT VBAT = 1.5V 0.5 μA Maximum Current from VPOS pin In electromagnetic field 200 μA VPOS limiter point In electromagnetic field 3.4 V ANTI-QFN Antenna pad impedance Measured at 900MHz, QFN package for PCB assembly 31-j3 20 Ω ANTI-DIE Antenna pad impedance Measured at 900MHz, bare die for inlay assembly 9-j33 0 Ω ANTS Antenna pad sensitivity Measured at 900MHz, battery assisted mode -15 dBm VBAT = 1.5V 0.4 V VBAT = 3V 1 V VBAT = 1.5V 1 V 2.1 V VBAT IEXT VPOS-l VIL VIH Voltage Input Threshold, Low (SEN, SCLK, DIN) Voltage Input Threshold, High (SEN, SCLK, DIN) ams Datasheet: 2014-May-06 [v1-01] VBAT = 3V 1.2 V SL900A – 7 Electrical Characteristics Symbol VOL VOH fSCLK fc TS-R TS-R EXT Parameter Voltage Output Threshold, Low DOUT pin Voltage Output Threshold, High DOUT pin Conditions Min Typ Units VBAT = 1.5V, IDOUT = 1mA VSS 450m V VBAT = 3V, IDOUT = 1mA VSS 300m V 1 VBAT V 2.7 VBAT V VBAT = 1.5V 1 MHz VBAT = 3V 5 MHz VBAT = 1.5V, IDOUT = -1mA VBAT = 3V, IDOUT = -1mA SCLK serial data clock Carrier Frequency 860 960 MHz Temperature Sensor Range -20 60 ºC Extended temperature sensor range with reduced accuracy -40 +125 ºC TS-NL Temperature sensor nonlinearity Inside TS-R ±0.5 TS-A Temperature Sensor Accuracy Inside TS-R ±1 tsens Measurement interval Programmable tRTC-I Real-Time Clock, Interval tRTC-A Real-Time Clock, Accuracy Over specified TS-R temperature range tRTC-CA Real-Time Clock, Calibration Accuracy TA = 35°C SL900A – 8 Max 1 ºC 32,768 1 Sec Sec -3 +3 % -0.2 +0.2 % ams Datasheet: 2014-May-06 [v1-01] Short Description Symbol Parameter Conditions Min Typ Max Units tRTC-B Real-time Clock, Accuracy VBAT=1.3V ~ 3V tRTC-C Real time clock, Accuracy VBAT= 1.2V~1.3V; 3V~3.6V EWCYC EEPROM Erase/Write Cycles TA = 25°C 100,000 Cycles tDR EEPROM Data Retention Time TA = 125°C 20 Years tE/W EEPROM Erase/Write Speed rEXC EXC pin output resistance rEXT External sensor interface pads resistance (EXT1, EXT2, VREF) ±3 -7 +5 7 EXC internally connected to VBAT for ext. sensor supply % % 7.5 ms 400 Ω 200 Ω Note(s) and/or Footnote(s): 1. Limits are 100% production tested at TA = 35°C. Limits over the operating temperature range are guaranteed by design. Short Description The SL900A is designed for use in smart active labels (SAL), semi-passive labels and passive labels. Smart active labels are defined as thin and flexible labels that contain an integrated circuit and a power source. SAL includes in its definition both “fully active” smart labels, and semi-active smart labels, also known as battery-assisted back-scattered passive labels, both of which enable enhanced functionality and performance over passive labels. The IC includes sensor functionality and logging of sensor data (see Figure 10 below). The SL900A is operating at 860 to 960 MHz and is fully EPC global Class 1 compliant. The chip is supplied from a single-cell battery of typically 1.5V, or from a dual cell battery (3V). The on-chip temperature sensor and real-time clock (RTC) accommodate temperature data logging. ams Datasheet: 2014-May-06 [v1-01] SL900A – 9 Short Description Supply Arrangement The SL900A is supplied from either the battery or through the electromagnetic waves from a reader. The device is normally supplied from the battery unless there is no battery attached (passive label), or when the battery is drained. Figure 10: Block Diagram VBAT 1.5V or 3V VSS Power Management EXT1 Temperature Sensor VDD VPOS Battery Voltage External Sensor Front-End VSSA ANT SCLK 860 - 960 MHz AFE SPI Port (Slave) Processing Digital Control EPC Gen2 Class 3 (cool-Log™) FIFO SEN MEAS ANA TEST EXC VREF DIN DOUT EXT2 1152 x 8 Bit EEPROM MUX 10-Bit A/D Converter Oscillator with RTC SL900A DIGI TEST Analog Front End (AFE) The analog front end is designed according to EPC Gen 2. The forward link (reader to tag) is amplitude modulated and the backward link (tag to reader) is amplitude modulated (load modulation is used). Processing and Digital Control The SL900A is fully EPC Class 1 compliant, with additional custom commands for extended functions. The maximum transponder to interrogator data rate according to Class 1/Gen.2 is 640 kbit/s. The maximum interrogator to transponder data rate is 160 kbit/s. Figure 11: Supported Data Rates Data Rate Min Max Interrogator to transponder 40 kbit/s 160 kbit/s Transponder to interrogator 5 kbit/s 640 kbit/s SL900A – 10 ams Datasheet: 2014-May-06 [v1-01] Short Description Serial Interface (SPI) The integrated serial interface (SPI) can be used to initialize the chip and to set the parameters. The logging procedure can be started and stopped with the SPI. The SPI bus can also be used for the communication between a microcontroller that is attached to the SL900A and the RFID reader. Real-Time Clock (RTC) The on-chip real-time clock (RTC) is started through the START LOG command in which the start time is programmed in UTC format. The interval for sensing and data logging can be programmed in the range from 1 second up to 9 hours. The accuracy of the timer is ±3%. The timer oscillator is calibrated at 35 ºC within ±0.2%. Temperature Sensor The on-chip temperature sensor can measure the temperature in the range from -20ºC to 60ºC with a typical accuracy of ±1ºC. The full temperature range of -40ºC to +125ºC has a reduced accuracy. External Sensors The on-chip external sensor front end provides a flexible interface for analog external sensors. It has an auto-range and interrupt function. It supports various types of analog sensors from pressure, humidity, temperature, light … Analog to Digital Converter The chip has an integrated 10-bit analog to digital converter with selectable voltage references. It is used for conversion of temperature, external sensors and battery voltage. External Sensor Interrupt The external sensor inputs EXT1 and EXT2 can be used for event-triggered logging. In this mode, the logging is not triggered in predefined time intervals from the internal timer, but can be triggered externally, either with a sensor, switch or a microcontroller. The interrupt source can be the EXT1, EXT2 input or both, were the EXT1 input has the higher priority. The user application can select which measurements are triggered by the interrupt event. In the interrupt mode, the sensor value is stored together with the 32-bit real time clock value. For a correct real-time clock value, the correct Start time has to be supplied. The interrupt mode is started with the START LOG command and the correct setting in the registers (SET LOG MODE command). ams Datasheet: 2014-May-06 [v1-01] SL900A – 11 Short Description Data Protection Additional to the Gen2 lock protection, the SL900A offers read/write protection using 3 password sets for 3 memory areas. Each 32-bit password is divided into 2 16-bit passwords, where the lower 16 bits are reserved for the Write protection and the higher 16 bits are reserved for the Read/Write protection. Shelf Life The SL900A device has an integrated shelf life algorithm that can dynamically calculate the remaining shelf life of the product. It has an automatic alarm function for the shelf life expiration. This can be used to directly drive a LED or as an interrupt for an external microcontroller. Memory arrangement The SL900A device has an integrated 9kbit EEPROM. It is organized into 5 memory banks shown below. Figure 12: Memory Arrangement Memory Bank Bank Size (bits) SYSTEM 512 System parameters like calibration data and log parameters RESERVED 64 Access and Kill password EPC 144 PC and EPC value TID 80 Unique identifier – programmed and locked during production USER 8416 SL900A – 12 Comments User and measurement data ams Datasheet: 2014-May-06 [v1-01] System Description System Description Figure 14 shows the different states and their interactions. Figure 22 shows the command overview. Initializing the Chip A virgin chip (not initialized) can be initialized either through the SPI port or through the electromagnetic field from a reader in the standby mode. The power source is either from a battery (VBAT ) or extracted from the RF field via the AFE circuit. After the initializing procedure, the chip will enter the ready mode. Power Modes Ready Mode In the ready mode, all parameters can be set, read and changed through a reader with the appropriate passwords. Active Mode In active mode, the real-time clock (RTC) is running, the desired parameters are set, and the on-chip temperature sensor is in standby. Logging Mode A log flag from the timer will enable the logging mode in which the sensor and the A/D converter will be activated, and the measured value will be stored in the EEPROM together with the time of the event. If the external sensor flag is set, the external sensors will also be activated and the measured data stored. The A/D converter can be multiplexed between internal temperature sensor, external sensors or battery voltage. After the event, the chip will return to the active mode. Interrupt Mode In the interrupt mode, the external sensor interrupt block is running with minimal power consumption. When the external sensor value exceeds a specified threshold, the chip goes into the logging mode where the selected sensor values and real time of the event are stored to the EEPROM. Stand-by Mode In passive mode, all blocks in the chip are turned off and only the leakage current is flowing. When the label enters an RF field, it will go from Stand-by mode to Ready mode. If the SEN pin rises high, the chip will go from the Stand by mode to the serial mode ams Datasheet: 2014-May-06 [v1-01] SL900A – 13 System Description Figure 13: Modes of Operation Mode IBAT (Typ.) Power from AFE In passive mode the chip is turned off and only the leakage current is flowing 0.1 μA No Serial Enables initializing and executing of all commands via the SPI bus 50 μA No Ready Chip is initialized and all commands can be executed via the reader 50 μA Yes 2 μA No Stand-by Description Active • RTC running • Sensor standby Interrupt • RTC running • External sensor minimum supply 2.5 μA No Logging • Sensor reading (on-chip temperature sensor, battery voltage level and/or external sensor through the MMI pin) • Measured data stored in EEPROM • RTC time stored in EEPROM 180 μA No State Diagram Figure 14: State Transition Diagram SPI REQUEST: ALL SEN=0 SPI Stop logging Serial SPI Start Logging SEN=1 Stand-by LOG-TIMER or IRQ SEN=1 SEN=0 Active or Interrupt Logging START-LOG RF on LOG-FINISHED Ready END-LOG RF off READER REQUEST: ALL COMMANDS SL900A – 14 READER REQUEST: ALL EPC standard COMMANDS SET PASSWORD GET MEASUREMENT SETUP SET PASSIVE GET LOG STATE GET CALIBRATION DATA GET BATTERY LEVEL OPEN AREA GET SENSOR VALUE Temperature measurement. Battery measurement. Limits comparison. Shelf life. External sensor measurement. Log to EEPROM. ams Datasheet: 2014-May-06 [v1-01] System Description Data Protection Additional to the Gen2 lock protection, the SL900A offers read/write protection using 3 password sets for 3 memory areas. The System area is protected by the System password, the Application area is protected by the Application password, and the Measurement area is protected by the Measurement password. Each 32-bit password is divided into 2 16-bit passwords, where the lower 16 bits are reserved for the Write protection and the higher 16 bits are reserved for the Read/Write protection. The password can be set either with the custom RFID command SET PASSWORD, or through the SPI, by writing the password to the password locations. The password protection is activated immediately after the SET PASSWORD command. In case the passwords are written with the SPI interface, the protection is activated when the transponder re-enters an RF field. Password protection does not block any read/write operation on the SPI interface; it is active only for the RFID interface. Figure 15: Password Storage in System Memory Address Data 0x000 System Password [31:24] 0x001 System Password [23:16] 0x002 System Password [15:8] 0x003 System Password [7:0] 0x004 Application Password [31:24] 0x005 Application Password [23:16] 0x006 Application Password [15:8] 0x007 Application Password [7:0] 0x008 Measurement Password [31:24] 0x009 Measurement Password [23:16] 0x00A Measurement Password [15:8] 0x00B Measurement Password [7:0] Function System Password – read/write protect System Password - write protect Application Password – read/write protect Application Password - write protect Measurement Password – read/write protect Measurement Password - write protest ams Datasheet: 2014-May-06 [v1-01] SL900A – 15 System Description Data Log Functions The SL900A device supports various flexible data log formats. The data log format depends on the Logging form. The data log formats are defined in Figure 23. The Logging form is set with the SET LOG MODE command and is stored in “Logging form [2:0]” (SPI address 0x026) bits in the EEPROM. Figure 16: Supported Logging Formats Bit 2 Bit 1 Bit 0 0 0 0 Dense All values are stored to the measurement area. No additional time information is stored to the measurement area. 1 All values out of limits All values that are out of the specified limits are stored to the measurement area. Additional to the sensor value, also the measurement number is stored, so the application can reconstruct the time-sensor points. Limits crossing Only the crossing point of each limit boundary is stored. Additional to the sensor value, also the measurement number is stored, so the application can reconstruct the time-sensor points. IRQ, EXT1 Interrupt triggered on the EXT1 external sensor input. At each trigger event the selected sensor values are stored. Additional to the sensor values, also the real-time clock offset is stored. IRQ, EXT2 Interrupt triggered on the EXT2 external sensor input. At each trigger event the selected sensor values are stored. Additional to the sensor values, also the real-time clock offset is stored. IRQ, EXT1, EXT2 Interrupt triggered on the EXT1 and EXT2 external sensor input. At each trigger event the selected sensor values are stored. Additional to the sensor values, also the real-time clock offset is stored. 0 0 1 1 1 0 1 0 1 1 1 1 0 1 Logging From Description When the “IRQ + timer enable” bit (Initialize command, SPI address 0x02A) is set to 1, the logging will be triggered on the selected time interval (timer) and also on an interrupt from external sensor1, sensor 2 or both – depending on the selected logging mode. The Storage rule bit defines what happens when the logging area in the EEPROM is full. SL900A – 16 ams Datasheet: 2014-May-06 [v1-01] System Description Figure 17: Storage Rule Bit Storage Rule Description 0 Normal When the logging area in the EEPROM is full, the chip does not store any new sensor data to the EEPROM, but it will still increment the measurement counter and RTC. Rolling When the logging area is full, the chip continues with writing new sensor data to the EEPROM form the beginning of the logging area. Thus the chip overwrites the old stored data and increments the “Number of memory replacements [5:0]” field in the System status group. 1 Limits Counter The Limits counter can be used as an advanced alarm mechanism. It is enabled in all log formats and it will display the cumulative number of measurements that are outside limits. The application does not have to read the whole EEPROM content in order to determine if the temperature limits have been exceeded, just the Limits counter block. The Limits counter block can be read out with the GET LOG STATE command. The system uses 4 limits that can be set by the user: • Extreme upper limit • Upper limit • Lower limit • Extreme lower limit There is a dedicated 8-bit counter for each of the 4 limits in the Limits counter block. The appropriate counter will increment each time a sensor value is outside a limit. The user can select which sensor will be used in the limits comparison. The internal temperature sensor is selected by default. Other sensors can be selected with the SET SFE PARAMETERS command with the “Verify sensor ID[1:0]” field (SPI address 0x018): Figure 18: Modes of Operation Verify Sensor ID Bit 1 Verify Sensor ID Bit 0 0 0 Internal temperature sensor - DEFAULT 0 1 External sensor 1 1 0 External sensor 2 1 1 Battery voltage ams Datasheet: 2014-May-06 [v1-01] Sensor Selected for Limits Comparison SL900A – 17 System Description Logging Timer The SL900A device has an integrated RC oscillator that is calibrated to 1024Hz. This oscillator drives the logging timer. The logging timer resolution is 1 second. The maximum period is 9.1 hours (32768 seconds). The logging interval is programmed with the SET LOG MODE command. The measurement real time is derived from 4 parameters - the Start time (ST), the Delay time (DT), the log interval (LT), and the # of the measurement (NM). This value has to be calculated in the reader by the equation: Real time = ST+DT+LT*NM Delay Time The SL900A supports delayed start of the logging procedure. The Delay time has a resolution of 8 minutes - 32 seconds (512 seconds) and a maximum value of 582 hours (12 bits). The delay time value is set with the Initialize command, while the Delay time counter starts counting when the device receives the START LOG command. The delay time can also be disabled and an external push button can be used for starting the logging procedure. Analog to Digital Conversion The chip has an integrated analog to digital converter with 10-bit resolution and selectable voltage references. By default, the references are selected as: Vo1 = 0V and Vo2 = 310mV. This results in a voltage input range of 310mV ~ 620mV, for the temperature conversion this is -89.3ºC ~ +94.6ºC. The voltage references are individually selectable in 50mV steps with a fine adjustment for offset calibration. Additionally, the Vo1 reference voltage can be tied directly to ground if the bit “gnd_switch” in the SET CALIBRATION DATA command is set to 1 (SPI address 0x012). SL900A – 18 ams Datasheet: 2014-May-06 [v1-01] System Description Figure 19: AD Reference Voltages Calib. Code Vo1 Vo2 0b000 160mV 260mV 0b001 210mV 310mV 0b010 260mV 360mV 0b011 310mV 410mV 0b100 360mV 460mV 0b101 410mV 510mV 0b110 460mV 560mV 0b111 510mV 610mV The Vo2 voltage defines the lower temperature limit for the temperature conversion – note that normal operation is not guaranteed below -40 ºC. Figure 20: Theoretical Lower Temperature Limit Vo2 Low. Temp. Lim. 260mV -118.9 ºC 310mV -89.3 ºC 360mV -59.6 ºC 410mV -29.0 ºC 460mV 0.3 ºC 510mV 29.3 ºC 560mV 59.0 ºC 610mV 88.7 ºC The voltage difference between the Vo2 and Vo1 references define the resolution and temperature range. ams Datasheet: 2014-May-06 [v1-01] SL900A – 19 System Description Figure 21: Temperature Conversion Resolution and Range Vo2 - Vo1 Resolution Range 310mV (default) 0.18 ºC 183.9 ºC 50mV 0.029 ºC 29.7 ºC 100mV 0.058 ºC 59.3 ºC 150mV 0.086 ºC 88.0 ºC 200mV 0.116 ºC 118.6 ºC 250mV 0.145 ºC 148.3 ºC 260mV 0.151 ºC 154.2 ºC 300mV 0.174 ºC 177.9 ºC 350mV 0.203 ºC 207.6 ºC 360mV 0.209 ºC 213.5 ºC 400mV 0.232 ºC 237.2 ºC Example: Vo1 = 310mV, Vo2 = 410mV -> A/D conversion temperature range = -29.3ºC ~ 30.0 ºC. Temperature resolution = 0.058 ºC. The converted voltage can be calculated from the following equation: Vo2 – Vo1 V SENS = code ⋅ ---------------------------- + Vo2 1024 SL900A – 20 ams Datasheet: 2014-May-06 [v1-01] System Description Temperature Conversion The calibration data does not have to be included in the temperature conversion equation. The temperature value calculation is dependent on the selected voltage references (See “Analog to Digital Conversion” on page 18.): T ⋅ ( °C ) = code∗ Resolution – Low ⋅ temp ⋅ limit By default (factory setting), the voltage references are set: Vo1 = 0V, Vo2 = 310mV. This yields a theoretical temperature conversion range of -89.3ºC ~ +94.6ºC. The temperature conversion equation for this setting is: T ⋅ ( °C ) = code∗ 0.18°C – 89.3°C LSB = 0.18°C Offset = ( – 89.3 )°C When the reference voltages are set to some other value, the following equation needs to be used for temperature conversion: Vo2 [ mV ] ⋅ ( code + 1024 ) – code ⋅ Vo1 [ mV ] T ⋅ ( °C ) = ------------------------------------------------------------------------------------------------------------------ – 273.15 1024 ⋅ 1.686 The Vo1 and Vo2 in the above equation have to be in mV. Battery Voltage Conversion The battery voltage conversion is dependent on the initial battery voltage (1.5V or 3V) and on the selected voltage references (See “Analog to Digital Conversion” on page 18.). The conversion equations with factory selected voltage references (Vo1 = 0V, Vo2 = 310mV) are: For 1.5V battery, the equation is: • V = code*0.85mV + 873mV • LSB = 0.85mV • Offset = 873mV For 3V battery: • V = code*1.65mV + 1.69V • LSB = 1.65mV • Offset = 1.69V ams Datasheet: 2014-May-06 [v1-01] SL900A – 21 Commands Some commands can be password protected by 3 different passwords: System password (S), Application password (A) or Measurement password (M). Commands Figure 22: EPC Gen2 and Cool-Log™ Command Overview SERIAL READY 01 QueryRep 0b00 - √ √ 02 ACK 0b01 - √ √ 03 Query 0b1000 - √ 04 QuaryAdjust 0b1001 - 05 Select 0b1010 06 NAK 07 Req_RN 09 Read Write 10 SL900A – 22 Kill STAND-BY Command 08 ACTIVE # LOGGING Allowed in Modes Command Code Mode Change Security Level √ - No / EPC Gen2 anticollision round command √ - Yes / EPC Gen2 anticollision round command √ √ - No / EPC Gen2 anticollision round command √ √ √ - No / EPC Gen2 anticollision round command - √ √ √ - No / EPC Gen2 anticollision round command 0xC0 - √ √ √ - No / EPC Gen2 anticollision round command 0xC1 - √ √ √ - No / Request for a new 16-bit random number A or M Reads the selected block in the specified memory bank A or M Writes the selected block in the specified memory bank / Kills the transponder – no RFID access is possible after this command (SPI remains active) 0xC2 0xC3 0xC4 - - - √ √ √ √ √ √ √ √ √ - - - No No No Definition ams Datasheet: 2014-May-06 [v1-01] Commands Command Code SERIAL READY 11 Lock 0xC5 - √ √ 12 Access 0xC6 - √ √ √ 14 BlockWrite BlockErase 0xC7 0xC8 - - √ √ √ √ STAND-BY Command 13 ACTIVE # LOGGING Allowed in Modes Mode Change Security Level √ - No / Locks the selected memory banks - No / Puts the transponder to the secured state A or M Writes the selected block in the specified memory bank A or M Erases the selected block in the specified memory bank √ √ - - No No Definition Note: The cool-Log commands are defined as EPC custom commands. All custom commands have a 16-bit command code, where the 1st command code is defined as 0xE0, the second command code is in the table below. 15 Set Password 0xA0 - √ √ √ - No S, M or A Sets the passwords to EEPROM 16 Set Log Mode 0xA1 - √ √ - - No S Sets logging mode 17 Set Log Limits S Sets the measurement limits for limits logging mode 0xA2 - √ √ - - No 18 Get measurement setup 0xA3 - √ √ √ - No S Reads 4 system blocks - Start time, Log limits, Log mode, and Delay time + application area size 19 Set SFE parameters 0xA4 - √ √ - - No S Sets parameter for the External sensor front end 20 Set Calibration Data S Sets the calibration data for the temperature sensor and timer S Stops the log procedure and returns the chip to Standby mode 21 End Log 0xA5 0xA6 ams Datasheet: 2014-May-06 [v1-01] - - √ √ √ - - √ - - No Yes SL900A – 23 Commands Command Code SERIAL READY 22 Start Log 0xA7 - √ √ 23 Get Log State 0xA8 - √ √ 24 Get calibration data 0xA9 - √ 25 Get Battery level 0xAA - 26 Set Shelf Life 0xAB - Initialize 0xAC - STAND-BY Command 27 ACTIVE # LOGGING Allowed in Modes Mode Change Security Level Definition - - Yes S Starts the timer and the selected log procedure √ - No S Gets the log state of the chip √ √ - No S Reads the internal and external calibration data √ √ √ - No / Measures the battery voltage √ √ - - No / Set the shelf life parameters S Initializes the chip and sets the aapplication area size and the logging delay √ √ - - No 28 Get Sensor Value 0xAD - √ √ √ - No / Measures the specified sensor – temperature, ext. sensor1 or ext. sensor 2 29 Open Area 0xAE - √ √ √ - No / Opens access to the specified EEPROM area / Reads or writes the 8-byte FIFO register (for fast SPI to RFID data transfer) 30 Access FIFO SL900A – 24 0xAF - √ √ √ - No ams Datasheet: 2014-May-06 [v1-01] Commands Supported EPC Gen2 Commands QuerryREP - #01 The QUERRY_REP command instructs tags to decrement their slot counter and is specified for one out of 4 sessions. If the slot counter becomes 0 after decrementing, the tag will backscatter its RN16. ACK - #02 When a tag receives the ACK command in the Reply state, it will transition to the Acknowledged state and backscatter the EPC. The EPC can be truncated if this has been requested by the reader in the SELECT command. The ACK command can also be processed in the Open or Secured states, but in this case no state transition will occur. Query - #03 The QUERY command initiates and specifies an inventory round. It sets the TX and RX data rates. It also defines the number of slots used for the inventory round. When the tag receives the QUERY command, it will calculate a random RN16 if it has a matching Sel and Target. The tag will backscatter the RN16 value in case the slot counter is loaded with 0. QueryAdjust - #04 The QUERY_ADJUST command increments or decrements the Q number (number of slots) for the current inventory round. Select - #05 The SELECT command selects a tag population that will participate in the inventory round, based on user-defined criteria. The tag can receive any number of successive SELECT commands. NAK - #06 When a tag receives the NAK command, it will transition to the Arbitrate state, unless it is in the Kill or Ready states. The tag will not send any reply to the NAK command. Req_RN - #07 The REQ_RN command will instruct the tag to backscatter a new RN16. When a tag in the Acknowledged state receives a correct REQ_RN command, it will transition to the Open or Secured state. When the tag is in the Open or Secured state, it will backscatter a new RN16 and no state transition will occur. Read - #08 The Read command instructs the tag to read and backscatter a part or all of the Reserved, EPC, TID or User memory. ams Datasheet: 2014-May-06 [v1-01] SL900A – 25 Commands Write - #09 The WRITE command allows the interrogator to write a word (16 bits) in the tags Reserved, EPC, TID or User memory. Prior to sending the Write command, the interrogator has to send the REQ_RN command in order to receive a new RN16 that will be used for cover-coding the data by EXOR-ing it with the RN16. In case the data writing has been successful, the tag will backscatter the response within 20ms after receiving the command. Kill - #10 The KILL command is used to permanently disable a tag. When the tag receives the correct multi-step Kill procedure, it will transition to the Killed state and will not send any response thereafter. Lock - #11 The LOCK command instructs the tag to lock the specified block of the EEPROM memory. The Kill and Access passwords can be Read/Write locked, while the EPC, TID and User block can only be Write locked. The command will only be executed in the Secured state. Access - #12 The ACCESS command with a correct password and correct multi-step procedure instructs the tag to transition from the Open to the Secured state. When the tag has successfully received the multi-step access procedure, it will backscatter its handle. BlockWrite - #13 The BLOCK_WRITE command writes a single word of data (16 bits) to the specified memory address. It provides faster data writing than the WRITE command as it does not need a new RN16 for every word of data that has to be written. In case the data writing has been successful, the tag will backscatter the response within 20ms after receiving the command. BlockErase - #14 The BLOCK_ERASE command erases a single word in the specified memory bank. In case the erase has been successful, the tag will backscatter the response within 20ms after receiving the command. SL900A – 26 ams Datasheet: 2014-May-06 [v1-01] Commands Cool-Log Custom Commands Set Password - #15 The SET PASSWORD command sets the password for the specified memory area. This is the System area, Application area and Measurement area. The System area is in the Reserved memory bank. The Application and Measurement areas are in the User memory bank. In case the command has executed successfully, the tag will backscatter the response within 20ms after receiving the command. Set Log Mode - #16 The SET LOG MODE command sets various parameters for the logging procedure. In case the command has executed successfully, the tag will backscatter the response within 20ms after receiving the command. Set Log Limits - #17 The SET LOG LIMITS command write the 4 limits that are going to be used for logging measurement data. The limits are: Extreme upper limit, Upper limit, Lower limit and Extreme lower limit. In case the command has executed successfully, the tag will backscatter the response within 20ms after receiving the command. Get Measurement Setup - #18 The GET MEASUREMENT SETUP command reads 4 system blocks - Start time, Log limits, Log mode and Delay time. Set SFE Parameters - #19 The SET SFE PARAMETERS command sets the parameters for the External sensor front end. Set Calibration Data - #20 The SET CALIBRATION DATA command sets the calibration values for the internal temperature sensor. WARNING – the factory preset calibration data can be overwritten. It is advised to read the calibration data, change only the required bits and write back with the SET CALIBRATION DATA command. End Log - #21 The END LOG command stops the logging procedure and returns the chip to passive mode. It also stops the timer. ams Datasheet: 2014-May-06 [v1-01] SL900A – 27 Commands Start Log - #22 The START LOG command starts the logging procedure and sets the Start time in UTC format. In logging state the chips automatically performs the measurements and data logging in the specified time intervals. Supported is also a delayed start, which means that the chip will start with the logging procedure with a specified delay after it receives the START LOG command. This command also starts the Interrupt mode of operation where the measurements and data-logging are driven from external events. Get Log State - #23 The GET LOG STATE command gets the log state of following parameters: measurement status and out of limits counter. This gives the ability to quickly check the state of the package without the need to read the whole temperature data log. Get Calibration Data - #24 The GET CALIBRATION DATA command reads the calibration data for the internal and external sensors. Get Battery Level - #25 The GET BATTERY LEVEL command measures and reads the voltage level of the battery. Set Shelf Life - #26 The SET SHELF LIFE command writes the shelf life algorithm parameters and enables the dynamic shelf life calaculation. Initialize - #27 The INITIALIZE command sets the size of the application data area and sets the delay time. The command clears the measurement status and limits counter blocks. Get Sensor Value - #28 The GET SENSOR VALUE command measures and backscatters the value of the specified sensor – internal, external 1 or external 2. Open Area - #29 The OPEN AREA command opens the specified area of the memory (System, Application, and Measurement). The password is stored in a RAM location and compared with the password in EEPROM. When the tag leaves the RF field, this RAM location is cleared. Access FIFO - #30 The ACCESS FIFO command can read or write the 8-byte FIFO. The FIFO can also be accessed from the SPI so this command can be used for fast data transfer between a microcontroller connected to the SPI and an RFID reader. SL900A – 28 ams Datasheet: 2014-May-06 [v1-01] Custom Command Description Custom Command Description Upon receiving a valid command, the tag always transmits a reply. If the command can not be executed, the tag replies with the following error message: Reply Structure (error): SOF Header Error code Handle CRC EOF Pilot tone + preamble 1 bit [1] 8 bits 16 bits 16 bits Dummy bit [1] The error codes are defined as: Error Code Error Name Error Description Condition Other error For error s that are not covered by the other specified error codes 00000011 Memory overrun The specified memory location does not exist or the EPC length field is not supported by the tag The EBV address is outside the physical address of the EEPROM or outside the specified memory bank. 00000100 Memory locked The specified memory location is locked and/or permalocked and can not be read or written. The lock bit for the specified memory bank or password is set. 00001011 Insufficient power The tag has insufficient power to perform the memory write operation. This error code can only be set in fully passive mode when the supply voltage is to low. 10100000 Incorrect password The password is incorrect – tag is not open. The IDS custom password protection is active. 10100010 Battery measurement error The battery measurement can not be started. The tag is fully passive and there is no battery attached. 00000000 10100011 Command not allowed Command is not allowed in active state. Custom commands that can modify logging and calibration parameters are not allowed when the tag is in active state (RTC running). 10100110 EEPROM busy error The memory can not be accessed as the measurement unit or SPI is accessing the EEPROM. This error is reported when the EEPROM is used by the SPI or measurement unit. ams Datasheet: 2014-May-06 [v1-01] SL900A – 29 Custom Command Description Set Password The SET PASSWORD command writes a 32 - bit password to the EEPROM. The password protection for the specified area is automatically enabled if the password is any other value except 0. Command Structure: SOF Custom Command Code Password Level Password Handle CRC Frame-sync 0xE0 0xA0 8 bits 32 bits 16 bits 16 bits Successful Reply Structure: SOF Header Handle CRC EOF Pilot tone + preamble 1 bit [0] 16 bits 16 bits Dummy bit [1] The “Password Level” bits are: Password Level Bits b1 b0 Passw. level 0 0 Not allowed 0 1 System 1 0 Application 1 1 Measurement Bits b7 - b2 are X When the System area is open for writing, the Set password can change the passwords for all 3 password levels. When the System area is write-protected, the Set password command can not change the System password, but it can change the Application password, if the Application area is open, and the Measurement password when the Measurement area is open. Set Log Mode The SET LOG MODE command sets the logging form, storage rule, enables sensors that are used in the logging process and sets the logging interval (in 1 second steps). Command Structure: SOF Custom Command Code Log Mode Handle CRC Frame - sync 0xE0 0xA1 24 bits 16 bits 16 bits SL900A – 30 ams Datasheet: 2014-May-06 [v1-01] Custom Command Description In case the operation is successful, the following reply will be sent: Successful Reply Structure: SOF Header Handle CRC EOF Pilot tone + preamble 1 bit [0] 16 bits 16 bits Dummy bit [1] The “Log mode” field is composed as: Bit Number 23 … 21 20 19 18 17 16 15 … 1 0 Function Logging form [2:0] Storage rule Ext.1 sensor enable Ext.2 sensor enable Temp. sensor enable Battery check enable Log interval [14:0] RFU Set Log Limits The SET LOG LIMITS command writes the 4 limits that are used in the logging process. All 4 limits are 10 bits long. Command Structure: SOF Custom Command Code Log Limits Handle CRC Frame - sync 0xE0 0xA2 40 bits 16 bits 16 bits Successful Reply Structure: SOF Header Handle CRC EOF Pilot tone + preamble 1 bit [0] 16 bits 16 bits Dummy bit [1] The “Log Limits” field is composed as: Bit Number 39 … 30 29 ... 20 19 … 10 9…0 Function Extreme lower limit Lower limit Upper limit Extreme upper limit Get Measurement Setup The GET MEASUREMENT SETUP command will read the current system setup of the chip. Command Structure: SOF Custom Command Code Handle CRC Frame - sync 0xE0 0xA3 16 bits 16 bits ams Datasheet: 2014-May-06 [v1-01] SL900A – 31 Custom Command Description Successful Reply Structure: SOF Hea der Start Time Log Limits Log Mode Log Interval Delay Time Applic ation Data Han dle CRC EOF Pilot tone + preamble 1 bit [0] 32 bits 40 bits 8 bits 16 bits 16 bits 16 bits 16 bits 16 bits Dum my bit [1] The “Log Limits” field is composed as: Bit Number 39 … 30 29 ... 20 19 … 10 9…0 Function Extreme lower limit Lower limit Upper limit Extreme upper limit The “Log Mode” field is composed as: Bit Number 7 ... 5 4 3 2 Function Logging form [2:0] Storage rule Ext.1 sensor enable Ext.2 sensor enable The “Log Interval” field is composed as: Bit Number 15 … 1 0 Function Log interval [14:0] RFU The “Delay Time” field is composed as: Bit Number 15 … 4 3…2 1 0 Function Delay time [11:0] RFU [1:0] Delay mode [0 – timer, 1 – external switch] IRQ+timer enable The “Application Data” field is composed as: Bit Number 15 … 7 6…3 2…0 Function Number of words for application data [8:0] RFU [3:0] Broken word pointer [2:0] SL900A – 32 ams Datasheet: 2014-May-06 [v1-01] Custom Command Description Set SFE Parameters The SET SFE PARAMETERS command writes the Sensor Front End parameters to the memory. Those parameters include the range preset values for the external sensor inputs, external sensor types and the also the sensor that will be used for limits comparison. Command Structure: SOF Custom Command Code SFE Parameters Handle CRC Frame - sync 0xE0 0xA4 16 bits 16 bits 16 bits Successful Reply Structure: SOF Header Handle CRC EOF Pilot tone + preamble 1 bit [0] 16 bits 16 bits Dummy bit [1] The “SFE Parameters” field is composed as: Bit Number 15 … 11 10 … 6 5…4 3 2 1…0 Function Rang [4:0] Seti [4:0] EXT1 [1:0] EXT2 Autorange disable Verify sensor ID [1:0] Set Calibration Data The SET CALIBRATION DATA write to the calibration block in the EEPROM memory. The calibration data is preset during manufacturing, but can also be changed in the application if needed. The SET CALIBRATION DATA will write only to the EEPROM, but it will not update the calibration values in the calibration registers. The calibration registers are automatically updated with each START LOG command. Command Structure: SOF Custom Command Code Calibration Data Handle CRC Frame - sync 0xE0 0xA5 56 bits 16 bits 16 bits Successful Reply Structure: SOF Header Handle CRC EOF Pilot tone + preamble 1 bit [0] 16 bits 16 bits Dummy bit [1] Note: The “Calibration data” field is composed of 7 bytes (See “Calibration Bits” on page 63.). ams Datasheet: 2014-May-06 [v1-01] SL900A – 33 Custom Command Description End Log The END LOG command stops the logging procedure and turns off the real time clock. It also clears the Active flag that is store in the “System status” field in the EEPROM. Command Structure: SOF Custom Command Code Handle CRC Frame - sync 0xE0 0xA6 16 bits 16 bits Successful Reply Structure: SOF Header Handle CRC EOF Pilot tone + preamble 1 bit [0] 16 bits 16 bits Dummy bit [1] Start Log The START LOG command starts the logging process. It refreshes the data in the calibration registers, enables the RTC, writes the Start time and sets the Active bit in the “System status” field in the EEPROM. Command Structure: SOF Custom Command Code Start Time Handle CRC Frame - sync 0xE0 0xA7 32 bits 16 bits 16 bits Successful Reply Structure: SOF Header Handle CRC EOF Pilot tone + preamble 1 bit [0] 16 bits 16 bits Dummy bit [1] The “Start Time” field is composed as: Bit Number 31 … 26 25 … 22 21 … 17 16 … 12 11 … 6 5…0 Function Year [5:0] Month [3:0] Day [4:0] Hour [4:0] Minute [5:0] Second [5:0] SL900A – 34 ams Datasheet: 2014-May-06 [v1-01] Custom Command Description Get Log State The GET LOG STATE command reads the status of the logging process. The command can be used to quickly determine the current state of the product, together with the Shelf life and the Limit counter. Command Structure: SOF Custom Command Code Handle CRC Frame - sync 0xE0 0xA8 16 bits 16 bits Successful Reply Structure: SOF Hea der Limit Counter System Status SL-bloc k 0&1 Current Shelf Life Status Flags Han dle CRC EOF Pilot tone + preamble 1 bit [0] 32 bits 32 bits 64 bits (see Note) 24 bits (see Note) 8 bits 16 bits 16 bits Dum my bit [1] OPTIONAL - only when Shelf Life flag is set in the EEPROM. The “Limit Counter” field is composed as: Bit Number 31 … 24 23 … 16 15 … 8 7…0 Function Extreme lower [7:0] Lower [7:0] Upper [7:0] Extreme upper [7:0] The “System Status” field is composed as: Bit Number 31 … 22 21 … 16 15 … 1 0 Function Measurement address pointer [9:0] Number of memory replacements [5:0] Number of measurements [14:0] Active The “Status Flags” field is composed as: Bit Number 7 6 5 4 3 2 1 0 Function Active (logging process) Measure ment area full Measurement overwritten AD error Low battery Shelf life low error Shelf life high error Shelf Life expired ams Datasheet: 2014-May-06 [v1-01] SL900A – 35 Custom Command Description Get Calibration Data The GET CALIBRATION DATA command reads the calibration data field and the SFE parameters field. Command Structure: SOF Custom Command Code Handle CRC Frame - sync 0xE0 0xA9 16 bits 16 bits Successful Reply Structure: SOF Header Calibration Data & SFE Parameters Handle CRC EOF Pilot tone + preamble 1 bit [0] 72 bits 16 bits 16 bits Dummy bit [1] The content of the Calibration data field and the SFE parameters field is displayed in the Memory map in “SPI Interface” on page 45. Get Battery Level The GET BATTERY LEVel command starts the AD conversion on the battery voltage and returns the voltage level with the battery type (1.5V or 3V). Command Structure: SOF Custom Command Code Battery retrigger Handle CRC Frame - sync 0xE0 0xAA 8 bits 16 bits 16 bits Successful Reply Structure: SOF Header A/D Error Battery Type Zeros Battery Level Handle CRC EOF Pilot tone + preamble 1 bit [0] 1 bit error [1] 1 bit - [0 = 1.5V, 1 = 3V] 4 bits [0000] 10 bits 16 bits 16 bits Dummy bit [1] The application can also request the battery type re-check if the Battery retrigger field has the value “00000001”, otherwise the Battery retrigger field needs to have the value “00000000”. SL900A – 36 ams Datasheet: 2014-May-06 [v1-01] Custom Command Description Set Shelf Life The SET SHELF LIFE command programs parameters for the dynamic shelf life algorithm. Command Structure: SOF Custom Command Code SL Block 0 SL Block 1 Handle CRC Frame - sync 0xE0 0xAB 32 bits 32 bits 16 bits 16 bits Successful Reply Structure: SOF Header Handle CRC EOF Pilot tone + preamble 1 bit [0] 16 bits 16 bits Dummy bit [1] The “SL Block 0” field is composed as: Bit Number 31 … 24 23 … 16 15 … 8 7…0 Function Tmax [7:0] Tmin [7:0] Tstd [7:0] Ea [7:0] The “SL Block 1” field is composed as: Bit Number 31 … 16 15 … 6 5…4 3 2 1…0 Function SLinit [15:0] Tinit [9:0] Shelf life sensor ID [1:0] Enable negative shelf life Shelf life algorithm enable RFU [1:0] Initialize The INITIALIZE command clears the System status field, the Limit counters and sets the Delay time field and the Application data field. The Initialize command is needed before the START LOG command as it will clear the pointers and counters. If the application needs to run the logging process from the previous point on, the Initialize command ca be left out. Command Structure: SOF Custom Command Code Delay Time Application time Handle CRC Frame - sync 0xE0 0xAC 16 bits 16 bits 16 bits 16 bits ams Datasheet: 2014-May-06 [v1-01] SL900A – 37 Custom Command Description Successful Reply Structure: SOF Header Handle CRC EOF Pilot tone + preamble 1 bit [0] 16 bits 16 bits Dummy bit [1] The “Delay Time” field is composed as: Bit Number 15 … 4 3…2 1 0 Function Delay time [11:0] RFU [1:0] Delay mode [0 – timer, 1 – external switch] IRQ+timer enable The “Application Data” field is composed as: Bit Number 15 … 7 6…3 2…0 Function Number of words for application data [8:0] RFU [3:0] Broken word pointer [2:0] Get Sensor Value The GET SENSOR VALUE command starts the AD conversion on the specified sensor and returns the value. Command Structure: SOF Custom Command Code Sensor Type Handle CRC Frame - sync 0xE0 0xAD 8 bits 16 bits 16 bits Successful Reply Structure: SOF Header A/D Error Range/Limit Sensor Value Handle CRC EOF Pilot tone + preamble 1 bit [0] 1 bit - error [1] 5 bits (1), (2) 10 bits 16 bits 16 bits Dummy bit [1] Note(s) and/or Footnote(s): 1. RANGE - for external sensors 2. LIMIT CURRENT - for self heating compensation. The “Sensor Type” field is composed as: Bit Number Function SL900A – 38 7…2 RFU [5:0] – all 0’s 1…0 Sensor type: • 00 – Temperature sensor • 01 – External sensor 1 • 10 – External sensor 2 • 11 – Battery voltage ams Datasheet: 2014-May-06 [v1-01] Custom Command Description Open Area The OPEN AREA command opens the specified area (System, Application, and Measurement) that is protected by a password. Command Structure: SOF Custom Command Code Password Level Password Handle CRC Frame - sync 0xE0 0xAE 8 bits 32 bits 16 bits 16 bits SOF Header Handle CRC EOF Pilot tone + preamble 1 bit [0] 16 bits 16 bits Dummy bit [1] Successful Reply Structure: The “Password Level” field is composed as: Password Level Bits b1 b0 Passw. level 0 0 Not allowed 0 1 System 1 0 Application 1 1 Measurement Bits b7 - b2 are X Access FIFO The ACCESS FIFO command can read and write data from the FIFO and can also read the FIFO status register. Command Structure: SOF Custom Command Code Sub-command Payload Handle CRC Frame - sync 0xE0 0xAF 8 bits 0 ~ 8 bytes 16 bits 16 bits Successful Reply Structure: SOF Header Payload Handle CRC EOF Pilot tone + preamble 1 bit [0] 0 ~ 8 bytes (data from FIFO or FIFO status register) 16 bits 16 bits Dummy bit [1] ams Datasheet: 2014-May-06 [v1-01] SL900A – 39 Custom Command Description Possible Subcommand codes are defined as: Subcommand bits Function Comment 7 6 5 1 0 0 Read data from FIFO The bits 3-0 specify the number of bytes that will be read from FIFO 1 0 1 Write data to FIFO The bits 3-0 specify the number of bytes that will be written to FIFO 1 1 0 Read status register The FIFO status register is defined as: Bit # Function 7 FIFO busy 6 Data ready 5 No data 4 0 – data from SPI, 1 – data from RFID 3 2 1 Number of valid bytes in FIFO register (0000 – FIFO empty, 0001 – 1 byte, 1000 – 8 bytes) 0 Access FIFO command example: • Frame sync + E0 AF A5 11 22 33 44 55 + Handle + CRC • This example command will write 5 bytes to the FIFO. SL900A – 40 ams Datasheet: 2014-May-06 [v1-01] L o g g i n g Fo r m a t s The logging format is selected with the SET LOG MODE command in the “Logging Mode[2:0]” field. Logging Formats Figure 23: Supported Logging Formats Logging Mode [2:0] Logging Form Description Bit 2 Bit 1 Bit 0 0 0 0 Dense All values are stored to the measurement area. No additional time information is stored to the measurement area. All values that are out of the specified limits are stored to the measurement area. Limits comparison is done on the selected sensor (“Verify sensor ID [1:0]”). The measurement number is stored, additional to the sensor value. 0 0 1 All values out of limits 0 1 0 RFU Reserved for future use – this setting is not allowed 0 1 1 Limits crossing Only the crossing point of each limit boundary is stored. Limits comparison is done on the selected sensor (“Verify sensor ID [1:0]”). The measurement number is stored, additional to the sensor value. 1 0 0 RFU Reserved for future use – this setting is not allowed 1 0 1 IRQ, EXT1 Interrupt triggered on the EXT1 external sensor input 1 1 0 IRQ, EXT2 Interrupt triggered on the EXT2 external sensor input 1 1 1 IRQ, EXT1, EXT2 Interrupt triggered on the EXT1 and EXT2 external sensor input Dense Logging Form The dense logging form provides maximum usage of the non-volatile memory space. 8 sensor values are stored into 5 words of memory when only the internal temperature sensor is used: Figure 24: Dense Form - Only Internal Temperature Sensor Bits Block # 15 14 13 12 0x00 0x01 0x04 10 9 8 7 6 5 4 Temp. 1 Temp. 3 Temp. 4 Temp. 5 Temp. 7 2 1 0 Temp. 4 Temp. 5 Temp. 6 ams Datasheet: 2014-May-06 [v1-01] 3 Temp. 2 Temp. 2 0x02 0x03 11 Temp. 7 Temp. 8 SL900A – 41 Lo g gi ng For m ats In case external sensors are used for logging, the chip will use the following storage format: Figure 25: Dense Form with External Sensors Bits Block # 15 0x00 1 Range 5 bits External sensor 1 - 10 bits 0x01 1 Range 5 bits External sensor 2 - 10 bits 0x02 14 13 12 11 10 9 8 7 Bat. meas. 6 bits 6 5 4 3 2 1 0 Temperature meas. - 10 bits In the dense logging form, no time information is stored in the measurement area of the EEPROM in order to maximize the number of stored sensor values. The real time of a particular measurement can be calculated by using the Start time and Log interval. Out-of-Limits Logging Form This logging form uses the limits that are set by the user. The limits can be set with the SET LOG LIMITS command. The storage data format is the same for the “All values out-of-limits” form and the “Limits crossing” form. Figure 26: Limits Mode with Internal Sensor Only Bits Block # 15 14 0x00 13 12 11 10 9 8 7 6 Battery voltage 5 4 3 2 1 0 3 2 1 0 Temperature 0x01 Measurement # Figure 27: Limits Mode with External Sensors Bits Block # 15 0x00 1 Range 5 bits External sensor 1 - 10 bits 0x01 1 Range 5 bits External sensor 2 - 10 bits 0x02 0x03 SL900A – 42 14 13 12 11 Bat. meas. 6 bits 10 9 8 7 6 5 4 Temperature meas. - 10 bits Measurement # ams Datasheet: 2014-May-06 [v1-01] L o g g i n g Fo r m a t s Interrupt Logging Form This logging form is used when the interrupts from external sensors are enabled. In this case, the real time clock is stored together with the sensor values. Figure 28: Interrupt Mode Bits Block # 15 14 0x00 1 Range 5 bits External sensor 1 - 10 bits 0x01 1 Range 5 bits External sensor 2 - 10 bits 0x02 13 12 11 10 Bat. meas. 6 bits 9 8 7 6 5 4 3 2 1 0 Temperature meas. - 10 bits 0x03 Real time clock - Higher 16 bits 0x04 Real time clock - Lower 16 bits Note(s) and/or Footnote(s): 1. The interrupt source can either be the external sensor 1, external sensor 2 or both external sensors. The limits are ignored in the interrupt mode. Storage Capacity The storage capacity is the number of measurement points that can be stored to the EEPROM. It is dependent on the selected logging form. Figure 29: Storage Capacity: Selected Sensors Dense Limits (both modes) Event Triggered Only temperature 841 263 175 Temperature + battery 526 263 175 1 External 526 263 175 Temperature + External 263 175 131 Temperature + External + Battery 263 175 131 2 External 263 175 131 Temperature + 2 external 175 131 105 All 4 sensors 175 131 105 ams Datasheet: 2014-May-06 [v1-01] SL900A – 43 Storage Rule Storage Rule The Storage rule defines how the device handles a completely full Measurement area. The device has 2 storage rules – normal or rolling. Normal storage rule In this storage rule, the logging of new data is stopped when the memory is completely full. When this happens, the bit 6 in the Status Flags (Measurement area full) is set to 1 and no new data is stored to the EEPROM. However, the timer is still active and the Number of measurements counter will still be incremented. Rolling storage rule In this mode, the device will overwrite the old data with new data once the measurement area is completely full. When this happens, the bit 6 (Measurement area full) and bit 5 (Measurement overwritten) in the Status Flags are set to 1 and the Number of memory replacements counter is incremented. The new measurement is stored to the beginning of the Measurement area. When the dense logging mode with temperature sensor is used with the rolling storage mode and the memory is overwritten, the new data is stored from the beginning of the Measurement area starting with a fresh 5-block 8-measurements super-block. It does not matter if the last super-block at the end of the memory was not completed due to the end of the memory. When more sensors are enabled or the limits mode is used, it can happen that the last measurement at the end of the memory can not be written, because there is not enough space. An example for this is if all 4 sensors are enabled in dense logging mode. In this case, 1 measurement is 3 blocks long. If it happens that there are only 2 blocks free in the memory, the measurement will be written to the beginning of the Measurement area, so the last 2 blocks are not used. When the Number of memory replacement counter reaches its maximum value, the logging is stopped and no new data is written to the EEPROM. However, the timer will still be active and the Number of measurements counter will still be incremented. SL900A – 44 ams Datasheet: 2014-May-06 [v1-01] SPI Inter face Full and unlimited EEPROM access is possible through the SPI interface. The primary function of the SPI interface is production calibration and UID programming, but it can also be used in application, for the data transmission between the interrogator and a microcontroller attached to the SPI interface. The chip has a basic arbitration implemented that controls the EEPROM access from the RFID interface, the automatic data logger and the SPI interface. The RFID interface has the highest priority, second is the automatic data logger, and last is the SPI interface. SPI Interface The first 2 bits in the frame are the MODE bits, which define the SPI operation (00 – Write memory, 01 – Read memory, 10 – Test, 11 – Direct command). The EEPROM address is an 11-bit address that point to the physical locations in the EEPROM. The write command can be executed on a single byte, or any number of successive bytes on a single page (up to 16 bytes). The minimum number of bytes in the Page write operation is 2. The Read operation is a continuous operation, so any number of bytes can be read with a single frame. The address is the starting address and is automatically incremented in the chip. The Test MODE is reserved for production testing and cannot be used in application. The maximum SCLK frequency is 10MHz at 3V battery supply (dual cell). With a 1.5V battery supply the maximum frequency is 2MHz. Figure 30: SPI Communication Modes MODE EEPROM Address / Command Code Data Byte A15 A14 A13 A12 A11 A10...A0 D7...D0 Write Mode 0 0 0 0 0 Physical EEPROM address DI7 … DI0 Page Write Mode 0 0 0 0 1 Physical EEPROM address DI7 … DI0 ...16 data bytes Read Mode 0 1 0 0 0 Physical EEPROM address DO7...DO0 ...Continuous read (n*8 bits) Test Mode Command Mode RESERVED for PRODUCTION 1 1 ams Datasheet: 2014-May-06 [v1-01] C5...C0 SL900A – 45 SPI Inter face Figure 31: SPI Timings t sc t ch t cl t ds t dh Figure 32: SPI Timing for 3V Supply Voltage Symbol Min Max Description tsc 150us - SEN to first SCLK rising edge setup time tch 100ns - SCLK high period tcl 100ns - SCLK low period tds 50ns - Data setup time tdh 50ns - Data hold time Figure 33: SPI Timing for 1.5V Supply Voltage Symbol Min Max tsc 150us - SEN to first SCLK rising edge setup time tch 500ns - SCLK high period tcl 500ns - SCLK low period tds 50ns - Data setup time tdh 50ns - Data hold time SL900A – 46 Description ams Datasheet: 2014-May-06 [v1-01] SPI Inter face Figure 34: SPI Write Mode A10 A9 A8 A7 A6 A5 A4 A3 A2 A1 A0 D7 D6 D5 D4 D3 D2 D1 D0 Figure 35: SPI Read Mode A10 A9 A8 A7 A6 A5 A4 A3 A2 A1 A0 D7 D6 D5 D4 D3 D2 D1 D0 Figure 36: SPI Command Mode - Start Log and Stop Log, Reset command C5 C4 C3 C2 C1 C0 ams Datasheet: 2014-May-06 [v1-01] SL900A – 47 SPI Inter face Figure 37: SPI Command Mode – Get Temperature, Get Ext. Sensor, Get Battery, Read Fifo, Read Remaining Shelf Life C5 C4 C3 C2 C1 C0 D7 D6 D5 D4 D3 D2 D1 D0 D7 D6 D5 D4 D3 D2 D1 D0 Figure 38: SPI Write FIFO Command Figure 39: SPI Read FIFO Status Command SL900A – 48 ams Datasheet: 2014-May-06 [v1-01] SPI Direct Commands SPI Direct Commands Figure 40: SPI Direct Commands Command Code Command Comment 0x00 Reset command - same effect as POR All calibration registers are refreshed from the EEPROM 0x01 Get temperature After SDATAO signal goes high send additional 16 clock pulses for conversion data read-out 0x02 Get battery After SDATAO signal goes high send additional 16 clock pulses for conversion data read-out 0x03 Get Ext. sensor 1 After SDATAO signal goes high send additional 16 clock pulses for conversion data read-out 0x04 Get Ext. sensor 2 After SDATAO signal goes high send additional 16 clock pulses for conversion data read-out 0x05 Start Logging Starts the timer or IRQ mode - generates the sta_log pulse signal - the start time has to be written before with the SPI Write mode 0x06 Stop Logging Stops the timer or IRQ mode - generates the end_log pulse signal 0x07 Read FIFO status Read the FIFO status byte (8-bit) 0x08 Read Remaining shelf life Reads the remaining shelf life (24-bit) 0x20 Read FIFO Reads up to 8 bytes from the FIFO 0x21 Write FIFO Writes up to 8 bytes to the FIFO ams Datasheet: 2014-May-06 [v1-01] SL900A – 49 SPI Direct Commands FIFO The SL900A device has an integrated 8-byte FIFO register that can be used for fast data transmission between the RFID reader and the microcontroller that is connected to the SPI port. The FIFO status can be determined by reading the FIFO status register: Bit # Function 7 FIFO busy 6 Data ready 5 No data 4 0 – data from SPI, 1 – data from RFID 3 2 1 Number of valid bytes in FIFO register (0000 – FIFO empty, 0001 – 1 byte, 1000 – 8 bytes) 0 The FIFO can be read and written from the SPI and the RFID interface. From the RFID interface, the ACCESS FIFO command is used to access the FIFO register and the FIFO status. From the SPI interface, 3 commands are used – 0x07, 0x20 and 0x21. The 0x07 commands reads the FIFO status byte. Up to 8 bytes can be read from the FIFO with the 0x20 command and up to 8 bytes written with the 0x21 command. SL900A – 50 ams Datasheet: 2014-May-06 [v1-01] A l t e r n a t e Pa d Fu n c t i o n s Alternate Pad Functions Some functions are multiplexed on same pads, so some functions of the device can not be used in parallel. Manual Log Start with Button The SL900A device supports 2 delayed start possibilities for the logging. Delayed start means that the logging is not started immediately when the device receives the Start Log command, but some time after the reception of this command. The application can set a fixed delay for the logging, or the logging can be started manually (without a RFID reader). Figure 41 shows the external push button connection for the manual delayed start function. The DIN pin has an integrated pull-down resistor, so the only required external component is the button. When the DIN pin is connected to V BAT, the logging will be started. Figure 41: Push Button Connection VBAT DIN R= 100k In order to enable this function, the application needs to set the “Delay mode” bit to 1. This is done with the “Initialize” command on page 37 External Shelf Life Alarm Function The SL900A device can generate an alarm when the Shelf Life algorithm is used and the shelf life expires. The EXC pin is used for this function. This signal can be used as an interrupt on a microcontroller, or can be directly used to drive a LED diode. The EXC driver resistance is 400Ω. Figure 42 shows how to connect an LED diode to the EXC pin. This is possible only when the transponder uses a 3V battery supply as most of the LED diodes have a threshold above 1.5V. Depending on the type of the LED diode, also an external current-limiting resistor needs to be used. ams Datasheet: 2014-May-06 [v1-01] SL900A – 51 Alternate Pa d Func ti ons Figure 42: LED Connection for Shelf Life Alarm VBAT EXC 400 Ohm VSS Gnd The external alarm function is activated automatically when the Shelf Life algorithm is used. The “sw_ext_en” bit in Calibration data has to be 0. If the “sw_ext_en” bit is set to 1, the EXC pin is used for external sensor supply. SL900A – 52 ams Datasheet: 2014-May-06 [v1-01] E x t e r n a l S e n s o r Fr o n t - E n d ( S F E ) External Sensor Front-End (SFE) The SL900A device can process the internal temperature sensor, the battery voltage and up to 2 external sensors. The result of the A/D conversion can be logged to the EEPROM or sent directly back to the interrogator (if the GET SENSOR VALUE command is used). The external sensors and the integrated temperature sensor can only be processed in serial manner. This is done through a multiplex amplifier, as the SL900A device has only one A/D converter integrated. Figure 43: External Sensor Front End ext_sw Vbat 2 Predrive current 1 4 IRQ 5 REFERENCES SFE CONTROLS 6 9 EXT2 A-D CONVERTER V-AGC 7 EXT1 11 VREF I-AGC S/H EXC 3 8 Programmable Current Sources ARC TIMING, IRQ REFERENCE 10 MEMORY Vbat shelf_life SFE Interface The external sensor interface consists of 4 pads: • EXT1 – connection for external sensor 1 that can be a linear-resistive sensor, a DC voltage source (sensor with external analog processing), capacitive and resistive sensors with AC driving, • EXT2 – connection for external sensor 2 that can be a linear-conductive sensor, a reverse-polarized diode, DC voltage source with serial resistance or a DC current source to V SS, • EXC – supply voltage for the external sensors or a AC signal source for external sensors that do not allow a DC voltage. • V REF – reference voltage (Vo2) pin used for capacitive and resistive sensors with AC excitation. ams Datasheet: 2014-May-06 [v1-01] SL900A – 53 External Sensor Front-End (SFE) The SFE can be used for measurements with resistive sensors with linear resistance or conductance. It can be used for capacitive sensors and optical sensors (diode). It can also be used for connecting integrated sensors with voltage output (high impedance input). The SFE allows a connection of a resistor bridge sensor arrangement, where the bridge is supplied by the EXC pad (battery voltage) and the 2 sensing points are attached to the EXT1 and EXT2 inputs. The 4th point of the resistive bridge has to be attached to the V SS point. The AD conversion for the 2 sensing points is done with 2 successive measurements. First the EXT1 point and next the EXT2 point. The final calculation has to be done in the application software. Also a capacitive or resistive sensor that does not allow a DC voltage can be attached to the SFE. In this case, the sensing point is the EXT1 input, the AC stimulus signal is provided by the EXC pin and the V REF pad outputs an adjustable DC reference voltage. SFE Interface Figure 44: Sensor Front End Setting Bits SFE Group Bits Function Description rang[4:0] External sensor 2 range Resistor feedback ladder – see application note for SFE seti[4:0] External sensor 1 range Current source value – see application note for SFE 00 – linear resistive sensor 01 – high impedance input (voltage follower), bridge EXT1[1:0] external sensor 1 type 10 – reserved 11 – capacitive or resistive sensor without DC (AC signal on EXC pin) EXT2 external sensor 2 type 0 – linear conductive sensor, opto sensor, current source sensor 1 - high impedance input (voltage follower), bridge Range preset Use preset range Autorange function is turned off 00 – first selected sensor Verify sensor ID[1:0] Sensor used in limit check (sensor enable bits in log mode group) 01 – second selected sensor 10 – third selected sensor 11 – fourth selected sensor SL900A – 54 ams Datasheet: 2014-May-06 [v1-01] E x t e r n a l S e n s o r Fr o n t - E n d ( S F E ) The external sensor interface has an auxiliary output pin (EXC) that can be used for supplying the external sensor either with a constant voltage or with an AC voltage signal (for capacitive sensor). Figure 45: EXC Output Pin Operation EXC Pin Controls EXT1 [1:0] sw_ext_en stand-by mode 00 0 0 HI-Z The output drivers are disconnected 00 0 1 HI-Z The output drivers are disconnected 11 X X AC signal during external sensor conversion Is to be used only with capacitive sensors 00 1 0 VBAT The output is connected to the battery voltage for the duration of the conversion 00 1 1 HI-Z The output drivers are disconnected 00 1 0 VBAT The output is connected to the battery voltage for the duration of the conversion 00 1 1 HI-Z The output drivers are disconnected ams Datasheet: 2014-May-06 [v1-01] EXC Signal Output Comment SL900A – 55 External Sensor Front-End (SFE) External Sensor 1 Interface The external sensor 1 interface (EXT1 pin) can be used for measurements with linear resistive sensors and capacitive sensors with AC excitation. It can also be used to measure 1 point of a resistive bridge (with the second point connected to the EXT2 pad). The processing of an external capacitive sensor without DC voltage is possible in case an external reference capacitor is used. The external sensor in this case is excitated with an AC signal from the EXC pin. The connection for this kind of sensors is shown on Figure 46. Figure 46: External Capacitive Sensor with AC Excitation (EXT1[1:0] = 11) EXC SENS VREF REF. CAP. EXT1 EXT2 VSS Cap. No_DC sensor SL900A – 56 SL900A ams Datasheet: 2014-May-06 [v1-01] E x t e r n a l S e n s o r Fr o n t - E n d ( S F E ) The external capacitive sensor in Figure 46 is excitated with a square wave signal around the reference voltage V REF. The amplitude of the AC signal is equal to the V REF voltage. Input AC amplitude: C REF ⋅ CAP V EXT1 = V EXC ⋅ -----------------------------------------------------( C REF ⋅ CAP + C SENS ) The selection of the reference capacitor depends on the AD converter input voltage range. The input AC amplitude V EXT1 at minimum capacitance C_SENS must be at a maximum AD level: V AD – max = 2 ⋅ V vo2 – V vo1 The input AC amplitude V EXT1 at minimum capacitance C_SENS must be close to minimum AD level: V AD – min = V vo2 The external sensor interface can also be used for resistive sensor with linear resistance and with resistive sensor that do not allow any DC voltage (AC excitation). The connection diagrams are on Figure 47 and Figure 48. For a resistive sensor with AC excitation The following relation is valid: V VREF V VREF < V VREF + --------------------------------------------------------- ⋅ R REF ⋅ RES ≤ V VREF + vo1 R R – SENS + R REF ⋅ RES The proper ratio between sensor and reference resistor can be chosen to fulfill the upper relation and the range of sensor’s resistivity. Figure 47: External Linear Resistive Sensor (EXT1[1:0] = 00) EXC VREF EXT1 EXT2 VSS Resistive type sensor - linear SL900A resistance ams Datasheet: 2014-May-06 [v1-01] SL900A – 57 External Sensor Front-End (SFE) An additional external reference resistor has to be used for processing external resistive sensor with AC excitating. Figure 48: External Resistive Sensor with AC Signal (EXT1[1:0] = 11) EXC R_SENS VREF REF. RES. EXT1 EXT2 VSS Res. No_DC sensor SL900A A resistive bridge has to be connected to both sensor inputs (Figure 49). The 2 input voltages are converted one after the other. In automatic logging, both external sensors have to be enabled. If the resistor bridge is also used with the GET SENSOR VALUE RFID command, this command has to be sent twice – first for external sensor 1, second for external sensor 2. Figure 49: Resistor Bridge Sensor (EXT1[1:0] = 01, EXT2 = 1) EXC VREF EXT1 EXT2 VSS External bridge SL900A sensor SL900A – 58 ams Datasheet: 2014-May-06 [v1-01] E x t e r n a l S e n s o r Fr o n t - E n d ( S F E ) External Sensor 2 Interface The external sensor 2 interface (EXT2 pin) can be used for measurements with linear conductive sensors, optical sensors (diode) and to measure the second point of a resistive bridge (with the first point connected to the EXT1 pad) (see Figure 49). The Figure 50 shows the connection diagram for a resistive sensor with linear conductance (like a pressure sensor). Figure 50: External Resistive Sensor - Linear Conductance (EXT2 = 0) EXC VREF EXT1 EXT2 VSS Resistive type sensor - linear conductance SL900A The EXT2 pad can also be used for measurements with an optical sensor based on reverse polarized diode current (Figure 51). Figure 51: External Optical Sensor (EXT2 = 0) EXC VREF EXT1 EXT2 VSS Opto sensor SL900A A voltage source output sensor can be connected to the EXT2 pin. This can be used for integrated sensors with an analog output signal. ams Datasheet: 2014-May-06 [v1-01] SL900A – 59 External Sensor Front-End (SFE) Figure 52: External Voltage Source Sensor (EXT2 = 1) EXC VREF EXT1 EXT2 VSS Sensor -voltage source SL900A The EXT1 interface can also be used for external current source output sensors (Figure 53). Figure 53: External Current Source Sensor (EXT2 = 0) EXC VREF EXT1 EXT2 VSS Sensor - current source SL900A External Sensor Interface Settings The external sensor interface is set up either with the SPI interface or with RFID custom commands. The commands required for external sensor operation are: SET LOG MODE, SET SFE PARAMETERS, SET CALIBRATION DATA and INITIALIZE. The SET LOG MODE command is used to setup various parameters required for the automatic logging process. The command is described in “Set Log Mode” on page 30. If external sensors are used in the logging process, they have to be enabled with this command. The SET SFE PARAMETERS command (“Set SFE Parameters” on page 33) is used to set up the SFE functionality. The SFE can be used as an automatic range selection block, for sensors with a SL900A – 60 ams Datasheet: 2014-May-06 [v1-01] E x t e r n a l S e n s o r Fr o n t - E n d ( S F E ) wide output range. It can also be used as a fixed gain preamplifier for sensors with a low output range. In this case, the user application has to preset the range and enable the preset values. The preset range has to be selected in case the internal limits are used with an external sensor. The EXT1 interface gain is preset with the “seti [4:0]” field. The EXT2 gain is preset with the “rang [4:0]” field. The preset values are enabled with the “Autorange Preset” flag. The external sensor type “EXT1[1:0]” and “EXT2” can be set with the SET SFE PARAMETERS command. This command is also used for selecting the sensor (“Verify Sensor ID”) that will be used with the limits in out of limits logging mode. The SET CALIBRATION DATA command is used to set up the supply switch for external sensors (“sw_ext_en”) and to setup the interrupt voltage level for external sensors (“irlev[1:0]”). The external sensors can be supplied with the battery voltage from the EXC pin only during the conversion time. This will save power compared to a system where the sensor is supplied directly from the battery. This is especially useful for a resistive bridge sensor. The INITIALIZE command is used to setup interrupt and timer logging modes in parallel (“IRQ + timer enable” flag). This special logging mode can be used for regular interval-based sensor sampling combined with the interrupt capability of the SFE. External Sensor Interrupt The external sensor interface can be used for sampling short events on the EXT1 and EXT2 pins. This can be used for shock sensors, acceleration sensors and other pulse response sensors. It is also useful for counting events on the external sensor pins. The sensors are pre-driven with a small current of 125nA and are constantly observed with a very low consumption comparator. The overall current consumption of the interrupt block is 0.5μA at room temperature. In case the sensor voltage exceeds the specified threshold (“irlev[1:0]”), the SFE will generate and IRQ request. This will wake up the whole system and the sensor data, together with the real time information, will be logged to the memory. ams Datasheet: 2014-May-06 [v1-01] SL900A – 61 External Sensor Front-End (SFE) The interrupt mode is selected with the SET LOG MODE command with the “Logging Mode[2:0]” field (“Logging Formats” on page 41). The implemented IRQ modes are: Figure 54: IRQ Logging Modes Bit 2 Bit 1 Bit 0 Logging Form Description 1 0 1 IRQ, EXT1 Interrupt triggered on the EXT1 external sensor input 1 1 0 IRQ, EXT2 Interrupt triggered on the EXT2 external sensor input 1 1 1 IRQ, EXT1, EXT2 Interrupt triggered on the EXT1 and EXT2 external sensor input Either of the 2 external sensor pads, or both of them, can be used for generating an interrupt. This function can also be used for button-triggered measurements, as the user can select which sensor will be logged during an interrupt event. The interrupt level can be selected by the application with the SET CALIBRATION DATA command (“irlev[1:0]”). The setting is valid for EXT1 and EXT2. Figure 55: Sensor Front End Setting Bits Irlev [1:0] EXT1 resistive – [MΩ] EXT2 resistive - [MΩ] IRQ level - % of supply voltage Bit 1 Bit 0 0 0 > 2)} } SL900A – 68 ams Datasheet: 2014-May-06 [v1-01] Memory Map Overview Memory Map Overview Figure 62: Memory Map Overview Loc. # Physical Address 1 0x000 Bank Bank Name Logical Address Content System Password [31:24] 2 0x001 System Password [23:16] 3 0x002 System Password [15:8] 4 0x003 System Password [7:0] 5 0x004 User Password [31:24] 6 0x005 User Password [23:16] 7 0x006 User Password [15:8] 8 0x007 User Password [7:0] 9 0x008 Measurement Password [31:24] 10 0x009 X 11 0x00A 12 0x00B 13 0x00C SYSTEM Measurement Password [23:16] Measurement Password [15:8] Measurement Password [7:0] Group System Password - read protect System Password write protect User Password - read protect User Password - write protect Measurement Password - read protect Measurement Password - write protest Year [5:0] Month [3:2] Month [1:0] 14 0x00D Day [4:0] Hour [4] Start time Hour [3:0] 15 0x00E Minute [5:2] Minute [1:0] 16 0x00F Second [5:0] ams Datasheet: 2014-May-06 [v1-01] SL900A – 69 Memory Map Overview Loc. # Physical Address Bank Bank Name Logical Address Content Group ad1[4:0] - reference voltage 1 fine cal. 17 0x010 coars1[2:0] - reference voltage 1 coarse cal. ad2[4:0] - reference voltage 2 fine cal. 18 0x011 coars2[2:0] - reference voltage 2 coarse cal. gnd_switch 19 selp12[1:0] - 1.5V battery POR level 0x012 adf[4:0] - 635mV reference voltage cal. 20 df[7:0] - timer oscillator cal. 0x013 sw_ext_en - switched battery supply for ext. sensor 21 0x014 X SYSTEM selp22[1:0] - 3V battery POR level Calibration irlev[1:0] ring_cal[4:2] - 1.92MHz oscillator cal. ring_cal[1:0] 22 0x015 off_int[6:1] temperature offset calibration off_int[0] reftc[3] - band gap temperature coefficient cal. 23 0x016 reftc[2:0] - band gap temperature coefficient cal. exc_res - excitate for resistive sensors without DC RFU[1:0] SL900A – 70 ams Datasheet: 2014-May-06 [v1-01] Memory Map Overview Loc. # 24 Physical Address Bank Bank Name Logical Address Content Group rang[4:0] - ext. sensor 2 range (feedback resistor) 0x017 seti[4:2] - ext. sensor 1 range (current source) seti[1:0] - ext. sensor 1 range SFE parameters sext1[1:0] - external sensor 1 type 25 0x018 sext2 - external sensor 2 type Auto range preset Verify sensor ID[1:0] 26 27 Extreme lower limit [9:2] 0x019 0x01A Extreme lower limit [1:0] X SYSTEM Lower limit [9:4] Lower limit [3:0] 28 0x01B Limits Upper limit [9:6] Upper limit [5:0] 29 0x01C 30 0x01D Extreme upper limit [7:0] 31 0x01E Ext. lower limits counter [7:0] 32 0x01F Lower limits counter [7:0] 33 0x020 Higher limits counter [7:0] 34 0x021 Ext. higher limits counter [7:0] Extreme upper limit [9:8] Limits counter ams Datasheet: 2014-May-06 [v1-01] SL900A – 71 Memory Map Overview Loc. # Physical Address 35 0x022 Bank Bank Name Logical Address Content Group Measurement address pointer [9:2] Measurement address pointer [1:0] 36 0x023 Number of memory replacements [5:0] 37 38 System status Number of measurements [14:7] 0x024 Number of measurements [6:0] 0x025 Active Logging form [2:0] Storage rule (0 normal, 1 - rolling) 39 0x026 Ext.1 sensor enable X SYSTEM Log mode Ext.2 sensor enable Temp. sensor enable Battery check enable 40 0x027 41 0x028 Log interval [14:7] Log interval [6:0] Log interval RFU 42 0x029 Delay time [11:4] Delay time [3:0] Single use flag 43 0x02A Delay time RFU Delay mode (0 - timer or 1 - switch) IRQ+timer enable SL900A – 72 ams Datasheet: 2014-May-06 [v1-01] Memory Map Overview Loc. # Physical Address 44 0x02B Bank Bank Name Logical Address Content Number of blocks for user data [8:1] Number of blocks for user data [0] 45 Group User data RFU [3:0] 0x02C Broken word pointer [2:0] 46 0x02D RFU[7:0] RFU Kill lock [1:0] Access lock [1:0] 47 0x02E EPC [1:0] TID lock [1:0] Lock bits, write ONLY with the 'Lock' command USER lock [1:0] 48 0x02F RFU [5:0] 49 0x030 50 0x031 Tmin[7:0] 51 0x032 Tstd[7:0] 52 0x033 Ea[7:0] 53 0x034 SLinit[15:8] 54 0x035 Slinit[7:0] 55 0x036 Tinit[9:2] X SYSTEM Tmax[7:0] Shelf Life block 0 Tinit[1:0] ShelfLife Sensor ID [1:0] 56 0x037 Shelf Life block 1 Enable Negative ShelfLife Shelf life algorithm enable Skip log [1:0] ams Datasheet: 2014-May-06 [v1-01] SL900A – 73 Memory Map Overview Loc. # 57 58 Physical Address Bank Bank Name Logical Address Content Group T1_delay [3:0] Adjust bits for the T1 timer (default value is “0111” FIRO_enable Enable FIRO RNG cl_sh_diss Disables the clock shop T2_diss Disables the T2 timing RFU Reserved for future use RFU[6:0] Reserved for future use KILL KILL flag 0x038 0x039 X SYSTEM 59 0x03A RFU[7:0] 60 0x03B RFU[7:0] 61 0x03C RFU[7:0] 62 0x03D RFU[7:0] 63 0x03E RFU[7:0] 64 0x03F RFU[7:0] 65 0x040 RFU Kill Password [31:24] 0x00 66 0x041 Kill Password [23:16] 67 0x042 Kill Password [15:8] 68 0x043 69 0x044 Kill Password 0x01 Kill Password [7:0] 0 Access Password [31:24] RESERVED 0x02 70 0x045 71 0x046 Access Password [23:16] Access Password Access Password [15:8] 0x03 72 0x047 Access Password [7:0] RAM - 1 RAM 0x00 CRC-16 [15:8] RAM - 2 RAM 0x01 73 0x048 0x00 1 CRC-16 [7:0] EPC PC [15:8] 0x01 74 SL900A – 74 0x049 CRC-16 is stored in the RAM portion and is mapped to the EPC memory block PC PC [7:0] ams Datasheet: 2014-May-06 [v1-01] Memory Map Overview Loc. # Physical Address 75 0x04A Bank Bank Name Logical Address Content Group EPC [127:120] 0x02 76 0x04B 77 0x04C EPC [119:112] EPC [111:104] 0x03 78 0x04D 79 0x04E EPC [103:96] EPC [95:88] 0x04 80 0x04F 81 0x050 EPC [87:80] EPC [79:72] 0x05 82 0x051 EPC [71:64] 1 83 0x052 84 0x053 85 0x054 EPC EPC EPC [63:56] 0x06 EPC [55:48] EPC [47:40] 0x07 86 0x055 87 0x056 EPC [39:32] EPC [31:24] 0x08 88 0x057 89 0x058 EPC [23:16] EPC [15:8] 0x09 90 0x059 91 0x05A EPC [7:0] TID [7:0] – 0xE0 0x00 92 0x05B 93 0x05C TID [15:8] – 0x36 TID [23:16] 0x01 94 0x05D 95 0x05E TID [31:24] TID [39:32] 2 96 0x05F 97 0x060 TID TID (same format as UID in ISO 15693), READ ONLY 0x02 TID [47:40] TID [55:48] 0x03 98 0x061 99 0x062 TID [63:56] Chip version [7:0] 0x04 100 0x063 ams Datasheet: 2014-May-06 [v1-01] RFU [7:0] Version, etc... READ ONLY SL900A – 75 Memory Map Overview Loc. # Physical Address 101 0x064 Bank Bank Name Logical Address 0x000 102 0x065 ~ ~ ~ ~ 1151 0x47E 1152 0x47F 3 USER Content Group USER memory start UMI USER / MEASUREMENT memory – 1052 bytes ~ ~ 0x20D SL900A – 76 USER memory end ams Datasheet: 2014-May-06 [v1-01] Applications Applications Battery-Assisted Transponder – Temperature Data Logger In the battery-assisted transponder application, only 4 pads are used – the antenna pads and the battery pads. This kind of circuit is suitable for a temperature data logger application. Dipole Antenna 16 15 14 13 ANA_TEST EXC MEAS VBAT Figure 63: Battery-Assisted Transponder – Temperature Data Logger 1 VPOS 2 VSSA 3 ANT 4 DIGI_TEST DOUT 12 DIN 11 SCLK 10 SEN 9 Battery 1.5V or 3V VREF EXT1 EXT2 VSS SL900A 5 6 7 8 Passive Transponder – Passive Temperature Sensor In the passive transponder, 2 pads are required for the antenna (ANT, V SSA). For extended read range an external capacitor connected between the V POS and VSS pads is recommended. ams Datasheet: 2014-May-06 [v1-01] VBAT VSSA 13 MEAS 2 14 EXC VPOS 15 DOUT 12 DIN 11 SCLK 10 SEN 9 SL900A DIGI_TEST VSS 4 EXT2 ANT EXT1 3 VREF Dipole Antenna 1 16 ANA_TEST Figure 64: Passive Transponder – Passive Temperature Sensor 5 6 7 8 Optional External Capacitor SL900A – 77 Applications Battery-Assisted Transponder with External Microcontroller An external microcontroller can be connected to the SL900A device using the SPI interface. The microcontroller can read and write the EEPROM, start and stop logging, perform an AD conversion and data can be transmitted to the RFID reader. The microcontroller can be used to perform additional tasks to extend the functionality of the system. Figure 65: Battery-Assisted Transponder with External Microcontroller VDD VBAT VSSA 13 MEAS 2 14 EXC VPOS 15 DOUT 12 DIN DIN 11 DOUT SCLK 10 SCLK SEN 9 SEN SL900A VSS DIGI_TEST EXT2 4 EXT1 ANT VREF 3 5 6 7 8 μC VSS Dipole Antenna 1 16 ANA_TEST Battery 1.5V or 3V Battery-Assisted Transponder with Pushbutton for Manual Delayed Log Start In the battery-assisted transponder application, 5 pads are used – the antenna pads, the battery pads and DIN for push button input. This kind of circuit is suitable for a temperature data logger application with manual logging start. SL900A – 78 VBAT VSSA 13 MEAS 2 14 EXC VPOS 15 DOUT 12 DIN 11 SCLK 10 SEN 9 SL900A DIGI_TEST VSS 4 EXT2 ANT EXT1 3 VREF Dipole Antenna 1 16 ANA_TEST Figure 66: Battery-Assisted Transponder with Pushbutton for Manual Delayed Log Start 5 6 7 8 Battery 1.5V or 3V ams Datasheet: 2014-May-06 [v1-01] Applications Dense Mode Logging – First 8 Measurements This is a short representation of the Measurement memory, the address pointer and the measurement counter for dense logging mode with the integrated temperature sensor. Shown are only the first 8 measurements – all other measurements are stored in same manner. Temperature data is: 0x2AA, 0x3FF, 0x2AA, 0x3FF, … Figure 67: Dense Mode Logging – First 8 Measurements: No Measurement: 0 00000000 00000000 Address pointer 0 1 00000000 00000000 Measurement counter 0 2 00000000 00000000 Broken Word Pointer 0 3 00000000 00000000 4 00000000 00000000 5 00000000 00000000 Measurement 1: 0 10101010 10000000 Address pointer 0 1 00000000 00000000 Measurement counter 1 2 00000000 00000000 Broken Word Pointer 5 3 00000000 00000000 4 00000000 00000000 5 00000000 00000000 Measurement 2: 0 10101010 10111111 Address pointer 1 1 11110000 00000000 Measurement counter 2 2 00000000 00000000 Broken Word Pointer 2 3 00000000 00000000 4 00000000 00000000 5 00000000 00000000 ams Datasheet: 2014-May-06 [v1-01] SL900A – 79 Applications Measurement 3: 0 10101010 10111111 Address pointer 1 1 11111010 10101000 Measurement counter 3 2 00000000 00000000 Broken Word Pointer 7 3 00000000 00000000 4 00000000 00000000 5 00000000 00000000 Measurement 4: 0 10101010 10111111 Address pointer 2 1 11111010 10101011 Measurement counter 4 2 11111111 00000000 Broken Word Pointer 4 3 00000000 00000000 4 00000000 00000000 5 00000000 00000000 Measurement 5: 0 10101010 10111111 Address pointer 3 1 11111010 10101011 Measurement counter 5 2 11111111 10101010 Broken Word Pointer 1 3 10000000 00000000 4 00000000 00000000 5 00000000 00000000 Measurement 6: 0 10101010 10111111 Address pointer 3 1 11111010 10101011 Measurement counter 6 2 11111111 10101010 Broken Word Pointer 6 3 10111111 11110000 4 00000000 00000000 5 00000000 00000000 SL900A – 80 ams Datasheet: 2014-May-06 [v1-01] Applications Measurement 7: 0 10101010 10111111 Address pointer 4 1 11111010 10101011 Measurement counter 7 2 11111111 10101010 Broken Word Pointer 3 3 10111111 11111010 4 10101000 00000000 5 00000000 00000000 Measurement 8: 0 10101010 10111111 Address pointer 5 1 11111010 10101011 Measurement counter 8 2 11111111 10101010 Broken Word Pointer 0 3 10111111 11111010 4 10101011 11111111 5 00000000 00000000 ams Datasheet: 2014-May-06 [v1-01] SL900A – 81 Pack age Drawings & Mark ings Package Drawings & Markings Figure 68: Package Drawings SL900A Symbol Min Nom Max A 0.80 0.90 1.00 A1 b 0.203 REF 0.33 0.40 D 5.00 BSC E 5.00 BSC 0.47 D1 3.15 3.25 3.35 E1 3.15 3.25 3.35 e - 0.80 BSC - L 0.255 0.355 0.455 L1 0.10 P 45º BSC aaa 0.10 ccc 0.10 SL900A Package Drawings: The reflow peak soldering temperature (body temperature) is specified according IPC/JEDEC J-STD-020C “Moisture/Reflow Sensitivity Classification for Nonhermetic Solid State Surface Mount Devices”. Note(s) and/or Footnote(s): 1. Dimensioning and tolerances conform to ASME Y14.5M-1994. 2. All dimensions are in millimeters. Angles are in degrees. 3. Dimension b applies to metalized terminal and is measured between 0.25mm and 0.30mm from terminal tip. Dimension L1 represents terminal full back from package edge up to 0.1mm is acceptable. 4. Co-planarity applies to the exposed heat slug as well as the terminal. 5. Radius on terminal is optional. 6. This drawing is subject to change without notice. SL900A – 82 ams Datasheet: 2014-May-06 [v1-01] RoHS Compliant & ams Green Statement RoHS Compliant & ams Green Statement RoHS: The term RoHS compliant means that ams products fully comply with current RoHS directives. Our semiconductor products do not contain any chemicals for all 6 substance categories, including the requirement that lead not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, RoHS compliant products are suitable for use in specified lead-free processes. ams Green (RoHS compliant and no Sb/Br): ams Green defines that in addition to RoHS compliance, our products are free of Bromine (Br) and Antimony (Sb) based flame retardants (Br or Sb do not exceed 0.1% by weight in homogeneous material). Important Information: The information provided in this statement represents ams knowledge and belief as of the date that it is provided. ams bases its knowledge and belief on information provided by third parties, and makes no representation or warranty as to the accuracy of such information. Efforts are underway to better integrate information from third parties. ams has taken and continues to take reasonable steps to provide representative and accurate information but may not have conducted destructive testing or chemical analysis on incoming materials and chemicals. ams and ams suppliers consider certain information to be proprietary, and thus CAS numbers and other limited information may not be available for release. ams Datasheet: 2014-May-06 [v1-01] SL900A – 83 Ordering & Contact Information Ordering & Contact Information Figure 69: Ordering Information Ordering Code SL900A-AQFT SL900A-ASWB Description Smart active label IC with on-chip temperature sensor and 9k EEPROM Operating Temperature Range Package Type Device Marking -40°C to 125°C QFN 16 (5 x 5 mm) SL900A -40ºC to 125ºC - Shipping Form Tape & reel (1,000/reel) Tested wafers Ordering Information: Order quantities should be a multiple of shipping form. Buy our products or get free samples online at: www.ams.com/ICdirect Technical Support is available at: www.ams.com/Technical-Support For further information and requests, e-mail us at: ams_sales@ams.com For sales offices, distributors and representatives, please visit: www.ams.com/contact Headquarters ams AG Tobelbaderstrasse 30 8141 Unterpremstaetten Austria, Europe Tel: +43 (0) 3136 500 0 Website: www.ams.com SL900A – 84 ams Datasheet: 2014-May-06 [v1-01] Copyrights & Disclaimer Copyrights & Disclaimer Copyright ams AG, Tobelbader Strasse 30, 8141 Unterpremstaetten, Austria-Europe. Trademarks Registered. All rights reserved. The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the copyright owner. Devices sold by ams AG are covered by the warranty and patent indemnification provisions appearing in its Terms of Sale. ams AG makes no warranty, express, statutory, implied, or by description regarding the information set forth herein. ams AG reserves the right to change specifications and prices at any time and without notice. Therefore, prior to designing this product into a system, it is necessary to check with ams AG for current information. This product is intended for use in commercial applications. Applications requiring extended temperature range, unusual environmental requirements, or high reliability applications, such as military, medical life-support or life-sustaining equipment are specifically not recommended without additional processing by ams AG for each application. This Product is provided by ams “AS IS” and any express or implied warranties, including, but not limited to the implied warranties of merchantability and fitness for a particular purpose are disclaimed. ams AG shall not be liable to recipient or any third party for any damages, including but not limited to personal injury, property damage, loss of profits, loss of use, interruption of business or indirect, special, incidental or consequential damages, of any kind, in connection with or arising out of the furnishing, performance or use of the technical data herein. No obligation or liability to recipient or any third party shall arise or flow out of ams AG rendering of technical or other services. ams Datasheet: 2014-May-06 [v1-01] SL900A – 85 Document Status Document Status Document Status Product Preview Preliminary Datasheet Datasheet Datasheet (discontinued) SL900A – 86 Product Status Definition Pre-Development Information in this datasheet is based on product ideas in the planning phase of development. All specifications are design goals without any warranty and are subject to change without notice Pre-Production Information in this datasheet is based on products in the design, validation or qualification phase of development. The performance and parameters shown in this document are preliminary without any warranty and are subject to change without notice Production Information in this datasheet is based on products in ramp-up to full production or full production which conform to specifications in accordance with the terms of ams AG standard warranty as given in the General Terms of Trade Discontinued Information in this datasheet is based on products which conform to specifications in accordance with the terms of ams AG standard warranty as given in the General Terms of Trade, but these products have been superseded and should not be used for new designs ams Datasheet: 2014-May-06 [v1-01] Revision Information Revision Information Changes from 1-00 (2013-Aug) to current revision 1-01 (2014-May-06) Page Removed “Confidential” from footer ams Datasheet: 2014-May-06 [v1-01] SL900A – 87 Content Guide Content Guide SL900A – 88 1 1 2 2 2 General Description Key Benefits & Features Package Options Applications Block Diagram 3 4 6 6 6 7 Pin Assignment Bare Die Pad Layout Absolute Maximum Ratings Electrical Discharge Sensitivity Operating Conditions Electrical Characteristics 9 10 10 10 11 11 11 11 11 11 12 12 12 Short Description Supply Arrangement Analog Front End (AFE) Processing and Digital Control Serial Interface (SPI) Real-Time Clock (RTC) Temperature Sensor External Sensors Analog to Digital Converter External Sensor Interrupt Data Protection Shelf Life Memory arrangement 13 13 13 13 13 13 13 13 14 15 16 17 18 18 18 21 21 System Description Initializing the Chip Power Modes Ready Mode Active Mode Logging Mode Interrupt Mode Stand-by Mode State Diagram Data Protection Data Log Functions Limits Counter Logging Timer Delay Time Analog to Digital Conversion Temperature Conversion Battery Voltage Conversion 22 25 25 25 25 25 25 25 25 Commands Supported EPC Gen2 Commands QuerryREP - #01 ACK - #02 Query - #03 QueryAdjust - #04 Select - #05 NAK - #06 Req_RN - #07 ams Datasheet: 2014-May-06 [v1-01] Content Guide ams Datasheet: 2014-May-06 [v1-01] 25 26 26 26 26 26 26 27 27 27 27 27 27 27 27 28 28 28 28 28 28 28 28 28 Read - #08 Write - #09 Kill - #10 Lock - #11 Access - #12 BlockWrite - #13 BlockErase - #14 Cool-Log Custom Commands Set Password - #15 Set Log Mode - #16 Set Log Limits - #17 Get Measurement Setup - #18 Set SFE Parameters - #19 Set Calibration Data - #20 End Log - #21 Start Log - #22 Get Log State - #23 Get Calibration Data - #24 Get Battery Level - #25 Set Shelf Life - #26 Initialize - #27 Get Sensor Value - #28 Open Area - #29 Access FIFO - #30 29 30 30 31 31 33 33 34 34 35 36 36 37 37 38 39 39 Custom Command Description Set Password Set Log Mode Set Log Limits Get Measurement Setup Set SFE Parameters Set Calibration Data End Log Start Log Get Log State Get Calibration Data Get Battery Level Set Shelf Life Initialize Get Sensor Value Open Area Access FIFO 41 41 42 43 43 Logging Formats Dense Logging Form Out-of-Limits Logging Form Interrupt Logging Form Storage Capacity 44 44 44 Storage Rule Normal storage rule Rolling storage rule 45 SPI Interface SL900A – 89 Content Guide 49 50 SPI Direct Commands FIFO 51 51 51 Alternate Pad Functions Manual Log Start with Button External Shelf Life Alarm Function 53 53 54 56 59 60 61 External Sensor Front-End (SFE) SFE Interface SFE Interface External Sensor 1 Interface External Sensor 2 Interface External Sensor Interface Settings External Sensor Interrupt 63 Calibration Bits 64 65 Shelf Life Calculation Shelf Life Sensor ID [1:0] 69 Memory Map Overview 77 77 79 Applications Battery-Assisted Transponder – Temperature Data Logger Passive Transponder – Passive Temperature Sensor Battery-Assisted Transponder with External Microcontroller Battery-Assisted Transponder with Pushbutton for Manual Delayed Log Start Dense Mode Logging – First 8 Measurements 82 83 84 85 Package Drawings and Markings RoHS Compliant & ams Green Statement Ordering & Contact Information Copyrights & Disclaimer 77 78 78 SL900A – 90 ams Datasheet: 2014-May-06 [v1-01]
SL900A-ASWB 价格&库存
很抱歉,暂时无法提供与“SL900A-ASWB”相匹配的价格&库存,您可以联系我们找货
