AS3931-ZTSM
AS3931-ZTSM
    AMSOSRAM(艾迈斯半导体)
    TSSOP16
    RFID Reader IC 19kHz ~ 150kHz SPI 2.4 V ~ 5.5 V 16-TSSOP (0.173", 4.40mm Width)
AS3931-ZTSM 数据手册
austriamicrosystems AG is now ams AG The technical content of this austriamicrosystems datasheet is still valid. Contact information: Headquarters: ams AG Tobelbaderstrasse 30 8141 Unterpremstaetten, Austria Tel: +43 (0) 3136 500 0 e-Mail: ams_sales@ams.com Please visit our website at www.ams.com Datasheet AS3931 3 D L o w P o w e r Wa k e u p R e c e i v e r Error tolerant digital pattern correlator that detects a given code sequences in the received data signal and generates a wakeup signal. 1 General Description 2 Key Features Programmable Serial Data Interface Flexible carrier frequencies The product is available in 16-pin TSSOP package. The AS3931 contains: Antenna rotation switch Three axis wakeup pattern detection Three axis LF field strength measurement Antenna rotation for easy calibration Three independent LF receiver chains High sensitivity and high dynamic range Wakeup output combining the three receiver chains Wide operating frequency range Low power 32.768kHz crystal oscillator circuit Reliable, interference resistant wakeup decoding Serial programming interface Highly protected differential inputs Voltage regulator with 2.4V output, on/off switchable Ultra low power consumption Each independent LF receiver chain contains: Automotive qualified Input overload protection Input attenuator al id Sophisticated power management logic that powers down the correlator if no data is received. am lc s on A te G nt st ill v The AS3931 is an ultra low power, three channel LF ASK receiver designed to operate in various applications such as LF identifications systems and LF tag receivers. AS3931 detects a low frequency ASK-modulated signal by looking for a digital wakeup pattern and generates a WAKE signal after successful pattern detection. The device incorporates an intelligent pattern detection algorithm that provides reliable operation in presence of strong interference. An RSSI signal can be generated at the RSSI pin for each receiver channel. 16-pin TSSOP package Ultra low power LF amplifier with logarithmic envelope output Robust data detector with adaptive slicing threshold that translates the logarithmic envelope into a digital data signal. 3 Applications The device is ideal for LF identification systems, LF tag receivers, three dimensional LF field strength measurement systems, and Ultra low power wake up systems. Receiving Antennas Te Transmitting Antenna VCC CBAT RP CREG VCC VREG LF1N RSSI RSSI LF1P SDA DATA SCL CLOCK LF2N LF2P AS3931 ch ni ca Figure 1. Typical Application Diagram CHIP SEL CS LF3N WAKE LF3P XOUT GND XIN WAKE XTAL CA www.austriamicrosystems.com/AS3931 Revision 6.2 CB 1 - 30 AS3931 Datasheet - C o n t e n t s Contents 1 General Description .................................................................................................................................................................. 1 2 Key Features ............................................................................................................................................................................ 1 3 Applications .............................................................................................................................................................................. 1 ....................................................................................................................................................................... 4 4.1 Pin Descriptions ................................................................................................................................................................................... 4 5 Absolute Maximum Ratings 6 Electrical Characteristics ...................................................................................................................................................... 5 .......................................................................................................................................................... 6 7 Typical Operating Characteristics 7.1 RSSI Characteristic al id 4 Pin Assignments ............................................................................................................................................. 9 .............................................................................................................................................................................. 9 7.2 Temperature Dependence of RSSI am lc s on A te G nt st ill v .................................................................................................................................................... 10 7.3 Supply Voltage Dependence of RSSI 7.4 Frequency Dependence of RSSI ................................................................................................................................................ 11 ....................................................................................................................................................... 12 8 Detailed Description ............................................................................................................................................................... 13 8.1 Block Diagram .................................................................................................................................................................................... 13 8.2 Block Description ............................................................................................................................................................................... 13 8.2.1 Antenna Rotator ......................................................................................................................................................................... 13 8.2.2 Input Attenuator ......................................................................................................................................................................... 13 8.2.3 Input Shortcutting ....................................................................................................................................................................... 13 8.2.4 Input Protection Circuit .............................................................................................................................................................. 13 8.2.5 Logarithmic Envelope Amplifiers ............................................................................................................................................... 14 8.2.6 Detectors ................................................................................................................................................................................... 14 8.2.7 Digital Correlators ...................................................................................................................................................................... 14 8.2.8 Wake Generator ........................................................................................................................................................................ 14 8.2.9 Crystal Oscillator ........................................................................................................................................................................ 14 8.2.10 Regulator ................................................................................................................................................................................. 14 8.2.11 Power On Reset (POR) ........................................................................................................................................................... 14 8.3 Basic Operation .................................................................................................................................................................................. 15 LF Transmission Protocol .......................................................................................................................................................... 15 Wake Up Detection .................................................................................................................................................................... 16 WAKE Signal Clearing ............................................................................................................................................................... 16 WAKE Signal After POR ............................................................................................................................................................ 16 RSSI Operation .......................................................................................................................................................................... 16 ca 8.3.1 8.3.2 8.3.3 8.3.4 8.3.5 ni 8.4 Serial Programming Interface Timing 8.5 Input Signal Waveform Definition 9 Configuring the Product ....................................................................................................................................................... 17 .......................................................................................................................................................... 18 ch 9.1 Serial Programming Interface 9.2 Power On Register ................................................................................................................................................. 16 ............................................................................................................................................................ 18 ............................................................................................................................................................................. 18 Te 9.2.1 P0, P1, P2 (Channel Enable) ..................................................................................................................................................... 19 9.2.2 P3 (Regulator Enable) ............................................................................................................................................................... 19 9.2.3 P4, P5 (Antenna Rotator/Input Shortcut) ................................................................................................................................... 19 9.3 RSSI Channel Select Register 9.3.1 9.3.2 9.3.3 9.3.4 ........................................................................................................................................................... 19 C0, C1 (RSSI Channel Select) .................................................................................................................................................. 20 C2, C3 (RSSI Output Mode) ...................................................................................................................................................... 20 C4 (Channel Attenuator) ............................................................................................................................................................ 20 C5 (WAKE Clear) ....................................................................................................................................................................... 21 www.austriamicrosystems.com/AS3931 Revision 6.2 2 - 30 AS3931 Datasheet - C o n t e n t s 9.4 Test Mode Register 9.4.1 9.4.2 9.4.3 9.4.4 9.4.5 ............................................................................................................................................................................ 21 T0 (Test Mode Enable) .............................................................................................................................................................. 21 T1, T2 (Test Mode Select) ......................................................................................................................................................... 21 T3 ............................................................................................................................................................................................... 22 T4 (RSSI Step Select) ............................................................................................................................................................... 22 T5 (Wake Generator On/Off) ..................................................................................................................................................... 22 9.5 Correlator Mode Register ................................................................................................................................................................... 22 al id M0 (Correlator Off) ..................................................................................................................................................................... 23 M1 (Single/Double Wake Pattern) ............................................................................................................................................. 23 M2, M3 (Zero-Half-Bit Detection Mode) ..................................................................................................................................... 23 M4 (Detector Time Constant) .................................................................................................................................................... 23 M5 .............................................................................................................................................................................................. 23 10 Extended Operation .............................................................................................................................................................. 24 am lc s on A te G nt st ill v 9.5.1 9.5.2 9.5.3 9.5.4 9.5.5 10.1 Power Management 10.1.1 10.1.2 10.1.3 10.1.4 10.1.5 10.1.6 10.1.7 ......................................................................................................................................................................... 24 Sleep Mode .............................................................................................................................................................................. 24 Standby Mode .......................................................................................................................................................................... 24 Receive Mode .......................................................................................................................................................................... 24 Regulator On/Off ...................................................................................................................................................................... 24 Typical Current Consumption in Different Modes .................................................................................................................... 24 RSSI Step ................................................................................................................................................................................ 24 Antenna Rotation ..................................................................................................................................................................... 24 10.2 Input Attenuation and Input Shortcutting 10.3 WAKE Signal at the RSSI Pin 10.4 Single WAKE Operation .......................................................................................................................................... 24 .......................................................................................................................................................... 25 ................................................................................................................................................................... 25 10.5 Using the Wake Generator ............................................................................................................................................................... 25 10.6 Direct DATA Mode ............................................................................................................................................................................ 26 10.7 Correlator Modes ............................................................................................................................................................................. 26 10.8 Threshold Adaptation Filter Time Constant 10.9 RSSI and WAKE Pin Modes 11 Package Drawings and Markings ......................................................................................................................................... 27 ............................................................................................................................................................. 29 Te ch ni ca 12 Ordering Information ...................................................................................................................................... 26 ............................................................................................................................................................ 26 www.austriamicrosystems.com/AS3931 Revision 6.2 3 - 30 AS3931 Datasheet - P i n A s s i g n m e n t s 4 Pin Assignments VCC 1 16 VREG LF1N 2 15 RSSI LF1P 3 14 SDA LF2N 4 13 SCL LF2P 5 12 CS LF3N 6 11 WAKE LF3P 7 10 XOUT GND 8 9 XIN am lc s on A te G nt st ill v AS3931 al id Figure 2. Pin Assignments 16-pin TSSOP Package 4.1 Pin Descriptions Pin Name VCC LF1N LF1P LF2N LF2P LF3N LF3P GND XIN XOUT WAKE CS Pin Number 1 2 3 4 5 6 7 8 9 10 11 12 13 ni SCL Pin Type Supply Input Analog Input Analog Input Analog Input Analog Input Analog Input Analog Input Ground Analog Input Analog Output Open Drain Digital Input with Pulldown Digital Input with Pulldown Digital Input with Pulldown Analog/Digital output Analog Output Description Positive Supply Voltage Channel 1 negative input Channel 1 positive input Channel 2 negative input Channel 2 positive input Channel 3 negative input Channel 3 positive input Negative Supply Voltage Crystal Oscillator Pin 1 Crystal Oscillator Pin 2 Wake Up Detect output/Reset output ca Table 1. Pin Descriptions 14 RSSI 15 VREG 16 Serial Clock Serial Data Received Signal Strength Indicator signal/ Digital Test mode signal output Regulator Output Voltage Te ch SDA Chip Select www.austriamicrosystems.com/AS3931 Revision 6.2 4 - 30 AS3931 Datasheet - A b s o l u t e M a x i m u m R a t i n g s 5 Absolute Maximum Ratings Stresses beyond those listed in Table 2 may cause permanent damage to the device. These are stress ratings only. Functional operation of the device at these or any other conditions beyond those indicated in Section 6 Electrical Characteristics on page 6 is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Table 2. Absolute Maximum Ratings Max Units Positive supply voltage (VCC) -0.5 5.5 V Analog ground (GND) 0 0 V Voltage at any pin except pin 2 to pin 7 (VIN) GND-0.5 VCC+0.5 V Notes al id Min am lc s on A te G nt st ill v Parameter Voltage at Pin 2 to Pin 7 (VIN) GND-0.5 GND+0.5 V Input current (Latchup Immunity) (Iin) -100 +100 mA JEDEC 78 Electrostatic discharge (VESD) 1000 V Norm: MIL 883 E method 3015 HBM: R=1.5 kΩ, C=100 pF Total power dissipation (Ptot) 300 mW 125 ºC Storage temperature (Tstg) -55 Package body temperature (Tbody) Humidity non-condensing 5 Moisture Sensitive Level Operating Ambient Temperature Range (TAMB) +260 ºC 85 % 3 -20 The reflow peak soldering temperature (body temperature) specified is in accordance with IPC/ JEDEC J-STD-020 “Moisture/Reflow Sensitivity Classification for Non-Hermetic Solid State Surface Mount Devices”. The lead finish for Pb-free leaded packages is matte tin (100% Sn). Represents a maximum floor life time of 168h +65 ºC ca Recommended Operating Conditions 2.6 5.5 V Regulator used Positive supply voltage (VCC) 2.4 3.5 V Regulator not used Analog Ground (GND) 0 0 V Te ch ni Positive supply voltage (VCC) www.austriamicrosystems.com/AS3931 Revision 6.2 5 - 30 AS3931 Datasheet - E l e c t r i c a l C h a r a c t e r i s t i c s 6 Electrical Characteristics TAMB = -20° to +65° C, VCC = 3.0 V, fIN = 20 kHz, register settings as after POR, CS = low, transmission protocol according to Figure 15, Figure 16 and application circuit according to Figure 1 unless otherwise specified. Table 3. Electrical Characteristics Parameter Conditions Min Typ General fIN LF input carrier frequency range BR Half-bit rate BM Manchester Bit Rate W Manchester Code Word NPRE Preamble half-bits VREG Regulator Voltage TPOR Power On Reset time 19 1 4 kHz 2.758 kB/s 1.379 kB/s 6 VCC = 2.6 V to 5.5 V 2.30 VCC = 2.4 V to 5.5 V 5 regulator off, VCC = 2.4V to 3.5V; TAMB = 27° C operating current ca regulator on, RSSI-step = low; TAMB = 27° C RSSI buffer operating IBUF 7 ni current 8 ch VCC transient compliance Te Differential small sig. input impedance crystal oscillator frequency www.austriamicrosystems.com/AS3931 hex 8 regulator on, TAMB = 27° C fXTAL 1.365 150 96 5 ICC ZIN 1.352 3 regulator off, VCC = 2.4 V; TAMB = 27° C ΔVCC 2.731 Units am lc s on A te G nt st ill v 2 2.704 Max al id Symbol 2.4 2.60 V ms sleep mode 0.3 µA standby mode 6.5 µA receive mode 6.7 µA sleep mode 0.5 standby mode 6.8 sleep mode 0.8 1.5 µA standby mode 7.0 8.8 µA receive mode 7.2 9 µA standby mode 6.6 No load at RSSI-Pin 2 8 recovery time = 10 ms; regulator on , 2.6 V < VCC < 5.5 V for VCC after step 8 recovery time = 10 ms; regulator off ; 2.4 V < VCC < 5.5 V for VCC before step µA 2 V 0.3 V normal operation; TAMB = 27º 2 MΩ input attenuator active; TAMB = 27º 1.5 kΩ input shortcutting active; TAMB = 27º 0.5 kΩ 32.768 kHz Crystal type: CC4 from MicroCrystal Revision 6.2 9 6 - 30 AS3931 Datasheet - E l e c t r i c a l C h a r a c t e r i s t i c s Table 3. Electrical Characteristics Symbol Parameter Conditions Min Typ Max Units WAKEUP Vin,max maximum differential input voltage for wake up 10 detection IWAKE WAKE pin current VRSSI RSSI output voltage range VRSSI0 RSSI output voltage (RSSI offset) 350 NPRE = 8 trise,tfall < 150 µs; 10 detection VREG = 2.4 V to 3.5 V µVpp 11 al id minimum differential input voltage for wake up Vin,min Voltage at WAKE pin: VOL < 0.4 V; 11 Vpp 0.33 mA am lc s on A te G nt st ill v VREG = 2.4 V to 3.5 V 1 RSSI 0.5 12 VIN = 0; 0.5 0.76 VIN = 1 mVpp; 100 290 0.3 VSTEP RSSI output voltage step VLOG logarithmic input voltage range VIN = 1 mVpp, RSSI step = high SRSSI RSSI slope in log. range RSSI step = high CRSSI cap. loading of RSSI pin IRSSI RSSI buffer output current Tstep RSSI voltage step time 13 ca RSSI Ripple Voltage 1.2 V mV 12 Input signal amplitude 100 mVpp; CS from low to high (Buffer activation in presence of a strong input signal); mV mV/dB 10 pF 5 µA 350 µs 350 µs channel switching from ChA(100 mVpp) to 14 VRIP V 300 RSSI buffer active CL = 10 pF, RL = 1 MΩ; 1.7 ChB (0 mVpp) , with CS deactivation of 10 µs RSSI buffer active, CL = 10 pF, RL = 1 MΩ; VIN = 1 mVpp ; 70 mV Digital input L level ch VIL ni Serial Programming Interface Te VIH IIH Digital input H level Digital Input current Pins SCL, SDA, CS; 11 VREG = 2.4 V to 3.5 V Pins SCL, SDA, CS 11 VREG 0.7 * VREG = 2.4 V to 3.5 V VREG Pins SCL, SDA, CS VIH = 2.4 V; 30 11 VREG = 2.4 V to 3.5 V V 11 60 100 µA 2 µs 11 500 ns 11 500 ns Clock period VREG = 2.4 V to 3.5 V TCH Clock high duration VREG = 2.4 V to 3.5 V TCL Clock low duration VREG = 2.4 V to 3.5 V Revision 6.2 V 11 TCLK www.austriamicrosystems.com 0.3 * 11 7 - 30 AS3931 Datasheet - E l e c t r i c a l C h a r a c t e r i s t i c s Table 3. Electrical Characteristics Parameter Conditions Min TDVCH Data valid to pos. Clock edge VREG = 2.4 V to 3.5 V TCHDI pos. Clock edge to Data invalid VREG = 2.4 V to 3.5 V TSHCH Select active to pos. Clock edge VREG = 2.4 V to 3.5 V TCHSL pos. Clock to Select inactive VREG = 2.4 V to 3.5 V TSL Select low time VREG = 2.4 V to 3.5 V 11 Max 100 11 100 11 100 11 500 Units ns 100 11 ns ns ns ns am lc s on A te G nt st ill v 1. The half-bit rate correlates with the crystal oscillator clock frequency fclk as follows: BR = fCLK/12 Typ al id Symbol 2. The Manchester bit rate correlates with the Half-Bit Rate as follows: BM = BR/2 3. 4. 5. 6. Code word can be changed by metal option 8 preamble half-bits are equivalent to 4 manchester bits VREG output may not be used as a supply for other circuits This is the internal Power on Reset time generated by the chip. To ensure proper start-up conditions, the supply voltage VCC must be ramped up to its final value during TPOR 7. This is the additional operating current when the RSSI buffer is activated without load 8. ΔVCC means a hard step of the supply voltage down to a lower value by an amount of ΔVCC; after such a step, the analog circuits in the chip take some time to recover for working properly again. The maximum step value is listed. 9. Crystal tolerance: 100ppm 10.Values refer to production test 11.If regulator is on, then VREG = 2.4 V; If regulator is off, then VREG = VCC, where VCC = 2.4 V to 3.5 V Te ch ni ca 12.The RSSI step is the change of the RSSI output voltage when the input signal amplitude changes from 0 to specified value 13.Time to step from initial RSSI value to 95% of the final value 14.ChA may be any channel 1 – 3, whereas ChB may be any other remaining channel. www.austriamicrosystems.com Revision 6.2 8 - 30 AS3931 Datasheet - Ty p i c a l O p e r a t i n g C h a r a c t e r i s t i c s 7 Typical Operating Characteristics All graphs refer to Tab = 27°C and VREG = 2.4 V, unless otherwise stated. 7.1 RSSI Characteristic Figure 3. RSSI-Characteristic VRSSI [V] vs Vin [Vpp] al id 1.70 1.60 am lc s on A te G nt st ill v 1.50 1.40 1.30 1.20 1.10 1.00 900m 800m 100µ 10m 100m 1 Te ch ni ca 1m www.austriamicrosystems.com/AS3931 Revision 6.2 9 - 30 AS3931 Datasheet - Ty p i c a l O p e r a t i n g C h a r a c t e r i s t i c s 7.2 Temperature Dependence of RSSI Figure 4. RSSI-step [V] @ Vin = 1 mVpp and 2 mV vs temp [deg C] Figure 5. RSSI-step [V] @ Vin = 300 µVpp and offset vs. temp [deg C] 410m 920m 390m 900m 880m 370m al id 860m 350m 840m 330m 820m 800m 310m 70.0m 290m am lc s on A te G nt st ill v 69.0m 270m 68.0m 250m 67.0m 230m 210m 66.0m -20 -10 0.0 10 20 30 temp 40 50 60 70 -20 Figure 6. RSSI-step [V] @ Vin = 1 mV and 2 mV vs. temp [deg C], reduced step 290m 65.0m -10 0.0 10 20 30 40 50 60 70 Figure 7. RSSI-step [V] @ Vin=300µ Vpp and offset vs. temp [deg C], reduced step 1.020 1.010 1.000 270m VIN = 0 (offset) 990.0m 980.0m 250m 970.0m 960.0m 230m 950.0m 45.0m 210m 44.0m 190m 170m VIN = 300µ VPP 43.0m -10 0.0 10 20 30 temp 40 50 60 70 42.0m -20 -10 0.0 10 20 30 40 50 60 70 Te ch ni -20 ca 150m www.austriamicrosystems.com/AS3931 Revision 6.2 10 - 30 AS3931 Datasheet - Ty p i c a l O p e r a t i n g C h a r a c t e r i s t i c s 7.3 Supply Voltage Dependence of RSSI Figure 8. RSSI-step [V] @ Vin = 1 mVpp and 2 mV vs. VCC [V] 410m Figure 9. RSSI-step [V] @ Vin = 300 µVpp and offset vs. VCC [V] 87.0m 83.0m 390m 79.0m 370m al id 75.0m 71.0m 350m 67.0m 330m 2.00m 1.80m 310m am lc s on A te G nt st ill v 1.60m 290m 1.40m 1.20m 270m 1.00m 250m 800m 2.40 2.60 2.80 3.00 3.20 3.40 3.60 Figure 10. RSSI-step [V] @ Vin = 1 mVpp and 2 mV vs VCC [V], reduced stepvs. VCC [V], reduced step 280m 2.40 2.60 2.80 3.00 3.20 3.40 3.60 Figure 11. RSSI-step [V] @ Vin =300 µVpp and offset 57.0m 55.0m 53.0m 260m 51.0m 49.0m 240m 47.0m 45.0m 43.0m 220m 2.10 1.90 200m 1.70 1.50 180m 1.30 2.80 3.00 3.20 3.40 3.60 900m 2.40 2.60 2.80 3.00 3.20 3.40 3.60 Te ch ni 2.60 ca 1.10 160m 2.40 www.austriamicrosystems.com/AS3931 Revision 6.2 11 - 30 AS3931 Datasheet - Ty p i c a l O p e r a t i n g C h a r a c t e r i s t i c s 7.4 Frequency Dependence of RSSI Figure 12. RSSI-step [V] @ Vin = 1 mVpp vs. fin [Hz], RSSI high step and low step 280m 260m al id 240m 220m 200m 180m am lc s on A te G nt st ill v 160m 140m 120m 100m 80.0m 10.k 1M Te ch ni ca 100.k www.austriamicrosystems.com/AS3931 Revision 6.2 12 - 30 AS3931 Datasheet - D e t a i l e d D e s c r i p t i o n 8 Detailed Description 8.1 Block Diagram LF3N Log. Env. Amp 3 Detector3 Correlator3 Wake WAKE Multiplexer Input Attenuator3 LF3P Correlator2 Wake3 Input Protection3 Detector2 RSSI3 LF2N Log. Env. Amp 2 am lc s on A te G nt st ill v LF2P AS3931 al id Input Attenuator2 RSSI2 Input Protection2 Wake1 Detector1 LF1N Correlator1 Wake2 Log. Env. Amp 1 Data1 LF1P Input Attenuator1 Data2 Antenna Rotator Data3 Input Protection1 RSSI1 Figure 13. Block Diagram Control Logic Data Multiplexer RSSI Buffer POR XOUT Regulator VREG GND Regulator XIN VCC RSSI RSSI Multiplexer CS SCL SDA Multiplexer Wake Generator 8.2 Block Description 8.2.1 Antenna Rotator Input Attenuator ni 8.2.2 ca In order to achieve an optimum assignment of the antennas to the receiving channels, the connection of the antennas to the channels can be changed cyclically with a multiplexed (antenna rotator), which is controlled by an internal register. The register setting can be changed by the serial interface. ch Input signal attenuation is provided for each channel by means of connecting a 1.5 kΩ resistor across the differential inputs. An internal register controls attenuation. 8.2.3 Input Shortcutting Te The differential inputs can be shortened by register settings to measure the RSSI offset. In this case, the resistance between the differential inputs is reduced to approximately 500 Ω. 8.2.4 Input Protection Circuit Each signal input has a powerful input overload protection circuit consisting of two anti-parallel protection diodes connected to ground (see Figure 14). This connection ensures that the differential input voltage can never exceed the supply voltage of the chip. To obtain proper operation, the differential input receiving circuits (resonant RLC-circuits) must be floating and shall be grounded nowhere (see Figure 1) www.austriamicrosystems.com/AS3931 Revision 6.2 13 - 30 AS3931 Datasheet - D e t a i l e d D e s c r i p t i o n Figure 14. Input Protection Circuit LFN al id LFP GND 8.2.5 Logarithmic Envelope Amplifiers 8.2.6 Detectors am lc s on A te G nt st ill v The logarithmic envelope amplifiers amplify the ASK coded LF input signals. They generate Received Signal Strength Indicator (RSSI) signals, which are proportional to the logarithm of the received field strengths within the specified dynamic range. These signals are used for data detection and distance measurements. The RSSI signals are bandwidth limited to reduce noise influence. The slope of the amplifiers in the low signal range can be controlled by register settings: a high slope for increased sensitivity but also increased current consumption and a weak slope with reduced current consumption are possible. The detectors convert the logarithmic envelope signal containing ASK coded data into digital signals. Each detector consists of a lowpass filter for generation of an adaptive threshold and a slicing comparator. A preamble is required for a proper adaptation of the threshold prior to the decision of the first valid data bit. A constant positive threshold offset is included in the comparator to ensure no data output in case of no input signal. This increases the overall system noise immunity. 8.2.7 Digital Correlators The AS3931 uses a 16-bit digital wakeup pattern. Digital correlators perform the identification of this pattern. They use a sophisticated detection algorithm that provides high immunity against noise injection as a result of stochastic and periodic interference’s. The AS3931 provides the possibility to double the length of the wake pattern to 32 bit. This is useful in environments with high noise levels to reduce the possibility of spurious (parasitic) wakeups. In this case the usual wake pattern must be sent twice before a wake up is recognized and a WAKE signal is generated. This active low WAKE signal is generated after successful pattern identification. Otherwise WAKE is high. Setting a register bit via the serial-programming interface resets the correlators. In order to save power the correlators are stopped when no data has been received for a specified amount of time. The correlators can be configured regarding their error tolerance by register settings. 8.2.8 Wake Generator Crystal Oscillator ni 8.2.9 ca A counter, clocked by the 32 kHz crystal oscillator, generates an artificial wake up app. every 2 hours. This wake up can be used to manage the quiescent current consumption of the AS3931. The idea behind is, to switch off one or more of the receiving channels in case of no true wake up detection for long times; that is when only parasitic wakeups or no wakeup at all is detected. An external controlling unit (µC) can identify this case by counting the parasitic wake ups and powering down one or more of the receiver channels to save current. When no wake ups are detected at all, e.g. if the application device is stored in a stock, then the wake generator’s artificial parasitic wakeups (every 2 hours) can be used to identify the situation. ch The crystal oscillator generates the clock signal for the digital correlators. It has been optimized for a 32.768 kHz quartz crystal connected to pins XIN and XOUT. The oscillator provides extremely low current consumption, so it can be operated permanently by a battery. 8.2.10 Regulator Te A regulator is implemented to provide the amplifiers and digital circuits with a stable and clean supply. The regulator can be switched off; in this case the external supply voltage is bypassed to the amplifiers and digital circuits. The regulator shall always be used for external supply voltages higher then 3.3V, otherwise the current consumption is significantly increased. The regulated voltage can be seen at the VREG pin, but may not be used to supply any other external circuits. 8.2.11 Power On Reset (POR) A power on reset circuit guarantees proper circuit operation after power supply starts up. All internal registers are reset to their default states after power on. After the Power On Reset time, the active low WAKE output is activated and set to low (Power On Wake Up). During the Power On Reset time, the WAKE output pin is set to high. By this, it is ensured that this triggers the Power On Wake Up triggered only when the internal registers are reset and ready to be programmed. www.austriamicrosystems.com/AS3931 Revision 6.2 14 - 30 AS3931 Datasheet - D e t a i l e d D e s c r i p t i o n 8.3 Basic Operation 8.3.1 8.3.1.1 LF Transmission Protocol Data Pattern 8.3.1.2 al id The AS3931 identifies a 16 half-bit binary coded data pattern, which is ASK-modulated on a LF carrier. The pattern must contain 8 LOGIC 0 halfbits and 8 LOGIC 1 half-bits in order to be DC free. Furthermore, for a proper detector threshold adaptation it has to be ensured that there are no long groups of LOGIC 0 and LOGIC 1 half-bits. Therefore coding of the 16 half-bit binary data to 8 Manchester bits is common. This means that 8 consecutive half-bit pairs are grouped to Manchester bits whereas a Manchester bit 1 is a HIGH to LOW transition and a Manchester bit 0 is a LOW to HIGH transition. The AS3931 supports the Manchester bit pattern 96 [hex] which in binary code is: 10 01 01 10 01 10 10 01. MSB is transmitted first. The Manchester bit pattern i.e. the binary DATA pattern can be changed on demand by a metal mask modification. Double Data Pattern 8.3.1.3 Wake Up Frame am lc s on A te G nt st ill v To increase the immunity against parasitic wakeups, the data pattern necessary for a successful wakeup can be doubled by programming the AS3931: if the double data pattern is used, the pattern 96 has to be sent twice; after recognition of the first data pattern, the second data pattern has to be sent immediately after the first one, otherwise no WAKE signal is generated. For the timing see Wake Up Frame on page 15. Setting the bit M1 to 1 can program the double data pattern feature. The Wake Up Frame of AS3931 consists of a preamble used for detector threshold adaptation followed by the DATA pattern once (normal or single Wake Up) or twice (double Wake Up) to be identified. We recommend a transmission protocol as shown on Figure 15 and Figure 16. The preamble consists of a half-bit pattern 1010... with a specified number NPRE of half-bits (NPRE must be an even number in order to get complete 1/0 pairs). NPRE depends on the application and has influence on the wakeup and overload sensitivity. We recommend a minimum of NPRE = 8 half-bits (according to 4 manchester bits “1”). Figure 15. Wake Up Frame of AS3931 with Single WAKE Data Pattern LF Carrier Amplitude Preamble NPRE half- bits ca WAKE Data 96 5.86 ms (16 half-bits) ni Figure 16. Wake Up Frame of AS3931 with Double WAKE Data Pattern Te ch LF Carrier Amplitude Preamble NPRE half-bits Data 96 5.86 ms (16 half-bits) Data 96 5.86 ms (16 half-bits) WAKE www.austriamicrosystems.com/AS3931 Revision 6.2 15 - 30 AS3931 Datasheet - D e t a i l e d D e s c r i p t i o n 8.3.2 Wake Up Detection A WAKE signal is generated if and only if all 8 LOGIC 1 half-bits and a predefined number of LOGIC 0 half-bits have been identified as correct. The wakeup detection criteria can be changed: the number of invalid zero half-bits can be programmed from 0 to 3. A valid Wake Up Frame can be detected at only one of the 3 channels or at more then one channel simultaneously. The single WAKE signals of each channel are ored together to a common WAKE signal Figure 13. WAKE Signal Clearing am lc s on A te G nt st ill v 8.3.3 al id In case of using the double wake up feature, the settings of the allowed zero half-bit errors apply for each of the sent data pattern individually. E.g. if you configure the AS3931 to allow 2 zero half-bit errors, the first data pattern can contain up to two invalid zero half-bits as well as the second data pattern, but it is not possible that the first pattern contains 3 and the second data pattern contains one zero half-bit error (what in total would give the same number of allowed zero half-bit errors as before). Note that a Double-Wake-Pattern detection is possible also if the two consecutive Single-Wake-Patterns are assigned to different channels: e.g. if the first pattern is recognized at channel 2 and the second pattern is recognized at channel 3, then a Double-Wake-Pattern is recognized and the WAKE Pin is activated. All channel combinations are possible. In case of different channels, it is not possible to decide which channel received the first and which channel received the second data pattern. After a Wake Up detection, the WAKE output signal must be reset via the Serial Programming Interface. This is done by toggling the bit C5 in the Channel Select register from low to high and vice versa. This is valid for both cases the Single Wake pattern and the Double Wake pattern detection. Furthermore, it is also valid for an internal generated Artificial Wakeup (see Extended Operation on page 24). 8.3.4 WAKE Signal After POR After a power on reset (POR), the WAKE signal is activated (LOW). Therefore, after startup the WAKE signal must be cleared as if a valid Wake Up would have been detected. 8.3.5 RSSI Operation The RSSI signal of a selected channel can be measured at the RSSI pin. Each channel can be selected by register settings. To calibrate the RSSI measurement, the LF inputs can be shortcutted with approximately 500 Ω by internal register settings. Doing so, the RSSI voltage offset can be measured. The RSSI – signal is buffered at the RSSI pin. The buffer can be deactivated by register settings; in this case the RSSI pin is tristated (high impedance). However, if the CS signal is not activated, the RSSI pin is tristated. This has to be kept in mind when programming the AS3931 via the Serial Programming Interface (the CS signal is used to latch the serial data into the selected register at the falling edge of CS). 8.4 Serial Programming Interface Timing Figure 17. SPI Timing Waveforms TSHCH TCLK SCL ca TDVCH TCL ni TCH TCHSL ch TCHDI A0 A1 D4 Te SDA D5 TSL CS www.austriamicrosystems.com/AS3931 Revision 6.2 16 - 30 AS3931 Datasheet - D e t a i l e d D e s c r i p t i o n 8.5 Input Signal Waveform Definition Figure 18. Input Signal Waveform Vin tfall 0.9*Vin Te ch ni ca am lc s on A te G nt st ill v 0.1*Vin al id trise www.austriamicrosystems.com/AS3931 Revision 6.2 17 - 30 AS3931 Datasheet - C o n f i g u r i n g t h e P r o d u c t 9 Configuring the Product 9.1 Serial Programming Interface The AS3931 is programmed via an unidirectional three wire Serial Programming Interface.The 3 lines are: CS: Chip Select, used for selecting AS3931 and for data latching SCL: Serial Clock al id SDA: Serial Data A block of 8 bit data starting with the LSB is sent according to the diagram shown in Figure 19. The received block of 8 bit data is shifted into an 8 bit latch. The two LSBs are register address bits and the remaining 6 bits are data bits. The register address bits A1 and A0 are decoded and the 6 data bits are stored into one of three 6 bit registers with the falling edge of CS. CS am lc s on A te G nt st ill v Figure 19. Protocol of 8 Bit Data Serial Transmission ADDRESS SDA SCL A0 DATA A1 D0 D1 D2 D3 D4 D5 D = P : POWER ON REGISTER D = C : CHANNEL SELECT REGISTER D = T : TEST MODE REGISTER D = M: CORRELATOR MODE REGISTER 9.2 Power On Register Bit P0 P1 P2 P3 Description 1 Enable Channel 1 1 Enable Channel 2 ni P4 POR state ca Table 4. Register Data P5 1 Enable Channel 3 1 Enable Regulator 0 Antenna Rotator Bit 1 0 Antenna Rotator Bit 2 Te ch Table 5. Register Address Bit Value A0 0 A1 0 www.austriamicrosystems.com/AS3931 Revision 6.2 18 - 30 AS3931 Datasheet - C o n f i g u r i n g t h e P r o d u c t 9.2.1 P0, P1, P2 (Channel Enable) If the bit P0, P1 or P2 is set to 1, the related channel is enabled. That means, the logarithmic envelope amplifier and the correlator are enabled and ready to receive a Wake Up Frame. When disabled, the channel is off, taking no current except for the bias cell to the amplifier. After a power on, all channels are enabled. Note: Shaded cells show POR-states 9.2.2 P0, P1, P2 Mode 0 Channel Disabled 1 Channel Enabled al id Table 6. P0, P1, P2 Bit Mode P3 (Regulator Enable) Table 7. P3 Bit Mode 9.2.3 am lc s on A te G nt st ill v Bit P3 enables the regulator (VREG 2.4 V) or switches off the regulator (VREG = VCC). If the regulator is switched off, then the voltage at Pin VCC is bypassed unregulated to the internal circuits. After a power on, the regulator is on. P3 Mode 0 Regulator Disabled 1 Regulator Enabled P4, P5 (Antenna Rotator/Input Shortcut) Bits P4 and P5 are used to set the Antenna Connection Mode or to shortcut the differential inputs of each amplifier. See Table 28 for the description of the rotator modes. Table 8. P4, P5 Bit Mode P4 P5 Mode 0 Connection Mode1 0 Connection Mode2 1 Connection Mode3 1 Amplifier Inputs Shorted Connection Mode1 Connection Mode2 Connection Mode3 Antenna 1 → Channel 1 Antenna 2 → Channel 1 Antenna 3 → Channel 1 Antenna 2 → Channel 2 Antenna 3 → Channel 2 Antenna 1 → Channel 2 Antenna 3 → Channel 3 Antenna 1 → Channel 3 Antenna 2 → Channel 3 Bit POR state Description C0 0 RSSI select Bit 1 C1 0 RSSI select Bit 2 C2 0 RSSI output mode Bit 1 C3 0 RSSI output mode Bit 2 C4 0 Channel attenuator C5 0 WAKE clear 0 1 0 1 ni ca Table 9. Antenna Rotation Modes ch 9.3 RSSI Channel Select Register Te Table 10. Register Data www.austriamicrosystems.com/AS3931 Revision 6.2 19 - 30 AS3931 Datasheet - C o n f i g u r i n g t h e P r o d u c t Table 11. Register Address 9.3.1 Bit Value A0 1 A1 0 C0, C1 (RSSI Channel Select) Table 12. C0, C1 Bit Mode C1 Mode 0 0 Channel 1 0 1 am lc s on A te G nt st ill v C0 1 9.3.2 al id Bits C0 and C1 are used to select the channel whose RSSI signal is multiplexed to the RSSI pin. In case of both bits C0 and C1 set to 1, a bandgap voltage VBG (1.25 V) appears at the RSSI pin. After power on, channel 1 is selected. 0 Channel 2 1 Channel 3 1 VBG (T0=0), WAKE (T0=1) C3 RSSI Pin Function 0 high Z 0 Analog output: RSSI of selected channel or VBG 1 Digital output: WAKE, single WAKE or DATA 1 not used C2, C3 (RSSI Output Mode) Bits C2 and C3 define the RSSI pin function. Table 13. C2, C3 Bit Mode C2 0 1 0 1 Note: The RSSI pin function also depends on the signal CS. If CS = 0, the RSSI pin is always in the high impedance state. This is also the case after power on. 9.3.3 ca The WAKE or single WAKE function is selected together with bits T0 – T2 and C0 – C1. For more information see Extended Operation on page 24 C4 (Channel Attenuator) ni When bit C4 is set, a resistor (app. 1.5 kΩ) is connected across the differential inputs of each channel. This resistor reduces the Q-factor of the antenna resonant circuit; therefore the received signal is reduced too. The amount of damping depends on the Q-factor of the antenna circuit. C4 Mode 0 Input attenuators disabled 1 Input attenuators enabled Te ch Table 14. C4 Bit Mode www.austriamicrosystems.com/AS3931 Revision 6.2 20 - 30 AS3931 Datasheet - C o n f i g u r i n g t h e P r o d u c t 9.3.4 C5 (WAKE Clear) Bit C5 is used to reset the active low WAKE pin after the pin has been set as a result of receiving a valid code word (single or double wake pattern) by one of the 3 channels, a POR or an internally generated Wakeup. Setting Bit C5 to 1, the WAKE pin is reset to high and held in high state, to enable the channels for the next wake up signal, the bit C5 must be toggled to 0 afterwards. After power on, the WAKE-pin is activated and the bit C5 has to be toggled high and low after a power on. C5 Mode 0 no effect 1 WAKE=H al id Table 15. C5 Bit Mode Table 16. Register Data Bit T0 T1 T2 T3 T4 T5 Table 17. Register Address 9.4.1 am lc s on A te G nt st ill v 9.4 Test Mode Register POR state Description 0 Test mode enable 0 Test mode select Bit 1 0 Test mode select Bit 2 0 not used 1 RSSI step 0 WAKE Generator on/off Bit Value A0 0 A1 1 T0 (Test Mode Enable) Bit T0 is used to define the pin function of the WAKE pin. When bit T0 is reset to 0, the WAKE pin is used for normal Wake Up detection (Single or Double Wakeup from the receiver channels or internally generated wakeup). When bit T0 is set to 1, testmode signals are multiplexed to the WAKE pin according to the selected test mode (T1, T2). After power on, the normal wake up detection mode is selected. ca Table 18. T0 Bit Mode WAKE Pin function 0 WAKE 1 Test Mode Signals ni 9.4.2 T0 T1, T2 (Test Mode Select) ch When bit T0 is set to 1, the following signals can be mapped to the WAKE pin. For signal description (see Figure 13). DATA: received bit stream of the selected channel WAKE: detected wake up of the selected channel Te For the DATA and WAKE signal select the desired channel by setting Bits C0 and C1. Table 19. T1, T2 Bit Mode T1 T2 WAKE Pin Function 0 0 DATA of selected channel 1 0 WAKE of selected channel www.austriamicrosystems.com/AS3931 Revision 6.2 21 - 30 AS3931 Datasheet - C o n f i g u r i n g t h e P r o d u c t Table 19. T1, T2 Bit Mode 9.4.3 T1 T2 WAKE Pin Function 0 1 not used 1 1 not used T3 9.4.4 al id Not used; must always be programmed to 0 by the user! T4 (RSSI Step Select) Bit T4 is used to switch between a high and a low RSSI step. For more information on RSSI steps see Extended Operation on page 24. Table 20. T4 Bit Mode Mode 0 Low RSSI step 1 High RSSI step am lc s on A te G nt st ill v 9.4.5 T4 T5 (Wake Generator On/Off) Bit T5 is used to activate the Wake Generator. If activated, an artificial parasitic wakeup is generated every 2 hours. Table 21. T5 Bit Mode T5 Mode 0 Wake Generator off 1 Wake Generator on 9.5 Correlator Mode Register Table 22. Register Data Bit M0 M1 M2 M4 M5 ca M3 POR state Description 0 Correlator Off 0 single/double wake pattern 0 Zero-Bit Detection Mode bit1 1 Zero-Bit Detection Mode bit2 1 detector threshold τ select 0 not used Bit Value A0 1 A1 1 Te ch ni Table 23. Register Address www.austriamicrosystems.com/AS3931 Revision 6.2 22 - 30 AS3931 Datasheet - C o n f i g u r i n g t h e P r o d u c t 9.5.1 M0 (Correlator Off) Bit M0 is used to simultaneously turn off all 3 correlators. This is done by turning off the correlator clocks. This can be used to reduce power consumption when the Direct Data Mode is used. 9.5.2 M0 Mode 0 Low RSSI step 1 High RSSI step M1 (Single/Double Wake Pattern) Bit M1 selects the number of data patterns that are necessary for wakeup detection. 9.5.3 am lc s on A te G nt st ill v Table 25. M1 Bit Mode al id Table 24. M0 Bit Mode M1 Mode 0 Single Data pattern 1 Double Data pattern M2, M3 (Zero-Half-Bit Detection Mode) Bits M2 and M3 select the number of Zero-Half-bits that are allowed to be invalid. A high level of allowed invalid Zero-Half-bits increases the error tolerance related to noise or interference’s, that means that the probability for the detection of a valid WAKE pattern increases. Note that in turn the immunity against parasitic wakeups (WAKE detection when no data has been sent, due to noise or interference’s) is reduced. Table 26. M2, M3 Bit Mode M2 0 1 0 1 9.5.4 M3 WAKE Pin Function 0 3 invalid Zero-bits allowed 0 2 invalid Zero-bits allowed 1 1 invalid Zero-bits allowed 1 0 invalid Zero-bits allowed M4 (Detector Time Constant) Bit M4 is used to switch between a large and a small τ of the detector threshold adoption filter. A large τ is recommended, because it increases the noise margin. A small τ can be used to improve the wake sensitivity when non-specified wake-patterns are used. ca Table 27. M4 Bit Mode M5 Mode 0 small τ 1 large τ ni 9.5.5 M4 Te ch Not used; must always be programmed to 0 by the user! www.austriamicrosystems.com/AS3931 Revision 6.2 23 - 30 AS3931 Datasheet - E x t e n d e d O p e r a t i o n 10 Extended Operation 10.1 Power Management 10.1.1 Sleep Mode al id In sleep mode, all channels are switched off, taking no current except for the bias cells of the amplifiers. Sleep mode is entered by register setting, bits P0, P1, P2 set to 0. The remaining elements that take current are the oscillator and the regulator (if used). The Serial Programming Interface remains active also in the sleep mode. 10.1.2 Standby Mode 10.1.3 Receive Mode am lc s on A te G nt st ill v In standby mode, selected channels are switched on, ready to receive data. The amplifier of the selected channel is on, whereas the correlator is powered down as long as no input signal is detected at the input. Enabling the related channel when setting bits P0, P1 or P3 enters the standby mode. In the standby mode, the current consumption increases by the amplifier currents compared to the sleep mode. An enabled channel automatically changes from the standby mode to the receive mode as soon as an input signal is detected. The channel stays in receive mode as long as an input signal is detected. In receive mode, the correlator of the channel is active, scanning the input signal waveform for a valid wake up pattern. The channel goes back to standby mode if no input signal is detected for more then a fixed timeout period. The timeout period is approximately 3.3 ms. by this operating principle it is guaranteed, that the correlators are only active and taking current as long as it is really necessary. 10.1.4 Regulator On/Off The regulator can be switched off to reduce the current consumption. When switching off, the supply voltage is bypassed unregulated to the internal circuits, so VREG = VCC. Otherwise, the internal voltage is regulated to 2.4 V. Switching off the regulator saves about 1 µA of current. The regulator should only be switched off, when VCC is not higher then 3.3 V, otherwise the current consumption is increased because the internal circuits will then take more current. 10.1.5 Typical Current Consumption in Different Modes The Table 28 gives an overview of the typical current consumptions in the different modes. All three channels are used in this case. Power consumption of course can be further reduced when not all three channels are enabled. Table 28. Typical Current Consumption Operating Mode Regulator on, VCC = 3 V Regulator off, VCC = 2.4 V Sleep 0.8 µA 0.3 µA 7.0 µA 6.5 µA 7.2 µA 6.8 µA 6.6 µA 6.1 µA Standby ca Receive Standby & RSSI low step 10.1.6 RSSI Step ch ni The RSSI step is defined as the change in the RSSI signal voltage if the input amplitude steps from zero to a defined (small) value. For example when changing the input signal amplitude from zero to 1 mVpp, the RSSI signal makes a step of app. 175 mV if the bit T4 is set to 1 (compare to Figure 8 on page 21). If not needed, this step can be reduced to a lower value (T4 = 0), which decreases the current consumption of each channel by app. 120 nA. 10.1.7 Antenna Rotation Te The 3 possible input signals can be distributed to the 3 channels in 3 different connection modes. Using this feature, the differences between the individual antenna voltages and also the differences of the individual RSSI-voltages of the channels can be handled. For example to eliminate the differences of the RSSI-voltages it is possible to use only one channel and to multiplex it to each antenna. The Bits P4 and P5 select the Antenna Rotation Modes. 10.2 Input Attenuation and Input Shortcutting All differential LF-inputs are each shorted by approximately 500 Ω when setting Bits P4 and P5 both to 1. This can be used to measure the RSSI-voltage with no input signal present; therefore the RSSI offset can be calibrated. It should be taken into account that the shortcut resistance can not be made zero due to design restrictions, so the input signal cancellation is not 100% (depending on the antenna circuit). www.austriamicrosystems.com/AS3931 Revision 6.2 24 - 30 AS3931 Datasheet - E x t e n d e d O p e r a t i o n Similar to the input shortcutting option, a 1.5 kΩ resistor can be connected across the differential inputs when setting bit C4 to 1. This input attenuation allows handling of very strong input signals by damping the antenna circuit. The damping depends on the Q-factor of the receiver circuits. 10.3 WAKE Signal at the RSSI Pin C3 = 1 and C2 = 0 in the Channel Select Register (RSSI output mode digital) C0 = 1 and C1 = 1 in the Channel Select Register Note: The RSSI pin is only active if the CS signal is active (CS = 1), otherwise RSSI is high Z. 10.4 Single WAKE Operation al id The WAKE signal, which is normally available at the WAKE pin, can be mapped to the RSSI pin additionally, which then becomes a digital output. To do this, set the following bits: am lc s on A te G nt st ill v The single WAKE signals of each channel can be mapped to the WAKE pin. Normally, the 3 WAKE signals are “ored” together and mapped to the WAKE pin, so the channel with the strongest input signal will generate a WAKE signal. To map a single WAKE signal to the WAKE pin, follow the steps: 1. Enable Test Mode: set T0 = 1 in Test Mode Register 2. Select Test Mode: set T1 = 1 and T2 = 0 in Test Mode Register 3. Select Channel: set C0 and C1 in the Channel Select Register The single WAKE signals can also be mapped to the RSSI pin, which then becomes a digital output pin. To do this, make this step: Select RSSI output mode digital:set C2 = 0 and C3 = 1 in the Channel Select Register The RSSI pin is only active if the CS signal is active (CS = 1), otherwise RSSI is high Z. It is possible to operate the WAKE pin in the normal mode first (that is all three single WAKE signals ored together) and after a wake up detection, to use the Single WAKE mode to check which channel received the wake pattern. This must be done before clearing the WAKE pin. It is also possible to operate the WAKE pin in normal WAKE mode and simultaneously to operate the RSSI-pin in single WAKE mode. 10.5 Using the Wake Generator The wake generator generates artificial parasitic wakeup’s every 2 hours as a time base for an external-controlling unit to identify situations where no true wakeup’s can be detected for a long time. For this purpose the external controlling unit must be able to distinguish between a true wakeup (generated by one of the receiving channels) or an Artificial Wakeup. This is done by checking the receiving channels using the single WAKE operation (see Single WAKE Operation on page 25). If a wakeup has occurred and no one of the receiving channels can be identified as the trigger for the wake up, then the Wake Generator has triggered the wakeup. In this case, the WAKE signal has to be cleared as if a receiving channel would have triggered the Wake Up. ca Note: The internal counter, that generates the internal wakeup by an overflow, can not be reset by clearing the wake pin or other actions. The time between two artificial wakeups is approximately 2 hours (2h 16min 32sec); however, the first artificial wakeup generated by the Wake Generator after activation of the feature (by setting bit T5 = 1) may come earlier then in 2:16:32 hours. This time is not defined. After the first artificial wakeup, the time between two wake ups is then 2 hours. Te ch ni The Wake Generator must be activated by programming the bit T5 = 1 in the Test Mode Register. www.austriamicrosystems.com/AS3931 Revision 6.2 25 - 30 AS3931 Datasheet - E x t e n d e d O p e r a t i o n 10.6 Direct DATA Mode In Direct Data Mode, the received DATA of a selected channel can be mapped to the WAKE pin. The DATA signal is the digital output of the detector and is normally fed to the correlator, where it is scanned for the WAKE pattern (see Figure 13). To get the DATA signal at the WAKE pin, follow the steps: al id 1. Enable Test Mode: set T0 = 1 in Test Mode Register 2. Select Test Mode: set T1 = 0 and T2 = 0 in Test Mode Register 3. Select Channel: set C0 and C1 in the Channel Select Register The Direct DATA signals can also be mapped to the RSSI pin, which then becomes a digital output pin. To do this, make this step: Select RSSI output mode digital:set C2 = 0 and C3 = 1 in the Channel Select Register Note: The RSSI pin is only active if the CS signal is active (CS = 1), otherwise RSSI is high Z. am lc s on A te G nt st ill v 10.7 Correlator Modes Operation of the correlators can be modified regarding the error tolerances for the Zero-Half-Bits. In this case, the number of Zero-Half-Bits that is allowed to be invalid can be set from 0 to 2. Please take into account that an increased error tolerance also reduces the immunity against parasitic wakeups (WAKE detection when no data has been sent, due to noise or interferences). 10.8 Threshold Adaptation Filter Time Constant Bit M4 is used to switch between a large and a small τ of the detector threshold adaptation filter. A large τ is recommended, because it increases the noise margin. A small τ can be used to improve the wake sensitivity when non-specified Wake-Patterns are used. 10.9 RSSI and WAKE Pin Modes This table gives an overview of the different signals that can be mapped to the RSSI and WAKE pin and how to program it. RSSI Output Mode 2 RSSI Output Mode 1 Channel Select 2 Channel Select 1 WAKE Test Mode Enable Test Mode Select 2 Test Mode Select 1 CS C3 C2 C1 C0 T0 T2 T1 WAKE-Pin: WAKE X X X X X 0 X X WAKE-Pin: DATA1 X X X 0 0 1 0 0 WAKE-Pin: DATA2 X X X 0 1 1 0 0 WAKE-Pin: DATA3 X X X 1 0 1 0 0 Bit/Pin Chip Select Pin Table 29. RSSI/WAKE-Pin Modes ni ca Mode X X X 0 0 1 0 1 WAKE-Pin: WAKE2 X X X 0 1 1 0 1 WAKE-Pin: WAKE3 X X X 1 0 1 0 1 RSSI-Pin: WAKE 1 1 0 1 1 X X X RSSI-Pin: DATA1 1 1 0 0 0 X 0 0 RSSI-Pin: DATA2 1 1 0 0 1 X 0 0 RSSI-Pin: DATA3 1 1 0 1 0 X 0 0 RSSI-Pin: WAKE1 1 1 0 0 0 X 0 1 RSSI-Pin: WAKE2 1 1 0 0 1 X 0 1 RSSI-Pin: WAKE3 1 1 0 1 0 X 0 1 Te ch WAKE-Pin: WAKE1 www.austriamicrosystems.com/AS3931 Revision 6.2 26 - 30 AS3931 Datasheet - P a c k a g e D r a w i n g s a n d M a r k i n g s 11 Package Drawings and Markings The product is available in 16-pin TSSOP package. al id Figure 20. 16-pin TSSOP Package am lc s on A te G nt st ill v AS3931 YYWWMZZ Max 1.20 0.15 1.05 0.30 0.20 5.10 4.50 0.75 - Te Symbol R R1 S Θ1 Θ2 Θ3 aaa bbb ccc ddd N ca Nom 1.00 5.00 6.40 BSC 4.40 0.65 BSC 0.60 1.00 REF ni Min 0.05 0.80 0.19 0.09 4.90 4.30 0.45 - ch Symbol A A1 A2 b c D E E1 e L L1 Min 0.09 0.09 0.20 0º - Nom - 12 REF 12 REF 0.10 0.10 0.05 0.20 16 Max 8º - Notes: 1. Dimensioning & tolerancing conform to ASME Y14.5M-1994. 2. All dimensions are in millimeters. Angles are in degrees. Marking: YYWWMZZ. YY WW M ZZ Year (i.e. 10 for 2010) Manufacturing Week Assembly plant identifier Assembly traceability code www.austriamicrosystems.com/AS3931 Revision 6.2 27 - 30 AS3931 Datasheet - R e v i s i o n H i s t o r y Revision History Table 30. Revision History Owner 6.1 Apr 22, 2010 6.2 Apr 14, 2011 Description Changed to new template dhe Updated the Ordering table Table 31 Updated Absolute Maximum Ratings, Package Drawings and Markings. al id Date Te ch ni ca am lc s on A te G nt st ill v Revision www.austriamicrosystems.com/AS3931 Revision 6.2 28 - 30 AS3931 Datasheet - O r d e r i n g I n f o r m a t i o n 12 Ordering Information Table 31. Ordering Device ID Information Part Number AS3931-TPD Description AS3931-ZTST AS3931-ZTSM 1 Delivery Form Tape and Reel Tape and Reel Package 16-pin TSSOP 16-pin TSSOP lid 1. Dry pack sensitivity level = 3, according to IPC/JEDEC J-STD-033A Where: T = Temperature range va P = Package Type D = Delivery Form Z = Others TS = TSSOP am lc s on A te G nt st ill M = Tape & Reel (500 pcs / reel) T = Tape & Reel (4500 pcs / reel) Note: All products are RoHS compliant and Pb-free. Buy our products or get free samples online at ICdirect: http://www.austriamicrosystems.com/ICdirect Te ch ni ca For further information and requests, please contact us mailto:sales@austriamicrosystems.com or find your local distributor at http://www.austriamicrosystems.com/distributor www.austriamicrosystems.com/AS3931 Revision 6.2 29 - 30 AS3931 Datasheet - C o p y r i g h t s Copyrights Copyright © 1997-2011, austriamicrosystems AG, Tobelbaderstrasse 30, 8141 Unterpremstaetten, Austria-Europe. Trademarks Registered ®. All rights reserved. The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the copyright owner. All products and companies mentioned are trademarks or registered trademarks of their respective companies. al id Disclaimer am lc s on A te G nt st ill v Devices sold by austriamicrosystems AG are covered by the warranty and patent indemnification provisions appearing in its Term of Sale. austriamicrosystems AG makes no warranty, express, statutory, implied, or by description regarding the information set forth herein or regarding the freedom of the described devices from patent infringement. austriamicrosystems AG reserves the right to change specifications and prices at any time and without notice. Therefore, prior to designing this product into a system, it is necessary to check with austriamicrosystems AG for current information. This product is intended for use in normal commercial applications. Applications requiring extended temperature range, unusual environmental requirements, or high reliability applications, such as military, medical life-support or life-sustaining equipment are specifically not recommended without additional processing by austriamicrosystems AG for each application. For shipments of less than 100 parts the manufacturing flow might show deviations from the standard production flow, such as test flow or test location. The information furnished here by austriamicrosystems AG is believed to be correct and accurate. However, austriamicrosystems AG shall not be liable to recipient or any third party for any damages, including but not limited to personal injury, property damage, loss of profits, loss of use, interruption of business or indirect, special, incidental or consequential damages, of any kind, in connection with or arising out of the furnishing, performance or use of the technical data herein. No obligation or liability to recipient or any third party shall arise or flow out of austriamicrosystems AG rendering of technical or other services. Contact Information ca Headquarters ni austriamicrosystems AG Tobelbaderstrasse 30 A-8141 Unterpremstaetten, Austria Tel: +43 (0) 3136 500 0 Fax: +43 (0) 3136 525 01 ch For Sales Offices, Distributors and Representatives, please visit: Te http://www.austriamicrosystems.com/contact www.austriamicrosystems.com/AS3931 Revision 6.2 30 - 30
AS3931-ZTSM 价格&库存
很抱歉,暂时无法提供与“AS3931-ZTSM”相匹配的价格&库存,您可以联系我们找货
