SparkFun XBee Explorer USB
W R L- 118 12 R OH S
22
images are CC BY-NC-SA 3.0
3D Download: Sketchup, STL, Blender
Description: This is a simple to use, USB to serial base unit for the Digi XBee line.
This unit works with all XBee modules including the Series 1 and Series 2.5, standard
and Pro version. Plug the unit into the XBee Explorer, attach a mini USB cable, and
you will have direct access to the serial and programming pins on the XBee unit.
The highlight of this board is an FT231X USB-to-Serial converter. That’s what
translates data between your computer and the XBee. There’s also a reset button,
and a voltage regulator to supply the XBee with plenty of power. In addition, there are
four LEDs that’ll help if you ever need to debug your XBee: RX, TX, RSSI (signalstrength indicator), and power indicator.
This board also breaks out each of the XBee’s I/O pins to a pair of breadboardcompatible headers. So if you want to make use of the XBee’s extended functionality,
you can solder some header pins into those, or even just solder some wire.
Not sure which XBee module or accessory is right for you? Check out our XBee
Buying Guide!
Note: There is no XBee included with this Explorer USB. Check the Recommended
Products section below for different options.
https://www.sparkfun.com/products/11812
11/17/2015
很抱歉,暂时无法提供与“WRL-11812”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+527.43960
- 200+210.45960
