SP6-230-BFF
SP6-230-BFF
    LAIRD(莱尔德)
    SURGE PROT 230V 6GHZ N FEM-N FEM
SP6-230-BFF 数据手册
Client Side Antennas Pacific Wireless offers client antennas for 900MHz, 2.4, 3.5 and 5GHz applications. Antennas are compatible with 802.11a/b/g, WiMax, ETSI and various other international standards. 900—928MHz Part # Type Gain (dBi) BW (deg) Front to Back Polarity Weight (lbs) Dimensions (in.) R2T9R2T9 -12 RooTenna® 12 45 >21dB Hor / Ver 9 16.5 x 15 x 1 Dual Band Yagi 9 55/90/75 >23dB Hor/Ver 1.5 15.5 x 10.5 x 2.75 Yagi 9 53 >14dB Hor / Ver 1.9Lbs 20 YA9WYA9W-11 Wide Band Yagi 11 50 >15dB Hor / Ver 2.4Lbs 35 YA9WYA9W-13 Wide Band Yagi 13 30 >18dB Hor / Ver 3.3Lbs 57 HDGD9HDGD9-15 HD Series Grid 15 19 >19dB Hor / Ver 11 34 x 28 Grid 15 19 >19dB Hor / Ver 11 34 x 28 HD Series Die Cast Grid 15 19 >19dB Hor / Ver 8.2 42 x 24 Die Cast Grid 15 19 >19dB Hor / Ver 8.2 42 x 24 LP800LP800 -25002500- 9-NF YA9YA9-9 GD9GD9 -15 HDGD9HDGD9-DC15 GD9GD9 -DC15 2400—2485MHz Part # Type Gain (dBi) BW (deg) Front to Back Polarity Weight (lbs) Dimensions (in.) R 2T 24-15 RooTenna® 15 35 >18dB Hor / Ver 1.8 9x9x2 R T 24-18 RooTenna® 19 20 >30dB Hor / Ver 9 16.5x15x1 R2T 2458 Dual Band RooTenna® 12 15 43 22 >25dB Hor/Ver 1.8 9x9x2 DCEDCE-ANT2412ANT2412-7x6x2 Die Cast Enclosure Antenna 12 35 >18dB Ver 2.5 10 x 7.1 x 2.25 DCEDCE-ANT2458ANT2458-7x6x2 Dual Band Die Cast Enclosure Antenna 12 15 43 22 >30dB Ver 2.5 10 x 7.1 x 2.25 Dual Band Yagi 9 55/90/ 75 >23dB Hor/Ver 1.5 15.5 x 10.5 x 2.75 Vagi 16 25 >19dB Hor / Ver 1.5 22 x 3 Mini-Directional 12 34 >25dB Hor / Ver 1 4x4x4 LP800LP800 -25002500- 9-NF VA24VA24 -16 MD 24-12 2 Client Side Antennas RooTenna ® Part No. R2T9 / R2T24 / R2T58 Flat Panel Antenna Part No. PA24 / PA35 Circular Polarized Antenna Part No. CP24-12 Wide Band Yagi Echo SeriesTM Part No. YA9W-11, YA9W-13 Part No. ES24-14 Mini Directional Antenna Part No. MD24-12 Die Cast Enclosure Antenna Part No. DCE2412-ANT / DCE2458ANT / DCE5819-ANT Vagi TM Log Periodic Antenna Part No. VA24-16 Part No. LP800-2500-9-NF Part # Type Gain (dBi) BW (deg) Front to Back Polarity Weight (lbs) CP24CP24-12 Circular 12 37 ES24ES24-14 Echo Series 14 26 PA 24-13 Flat Panel 13 PA 24-16 Flat Panel Dimensions (in.) >20dB Circular 1.1 8.5 x 8 >30dB Hor / Ver 3 10.24 dia 35 >20dB Hor / Ver 1.5 7.5 x 7.5 x .8 16 26 >27dB Hor / Ver 2 11 x 11 x .8 Flat Panel 19 17.5 >30dB Hor / Ver 3.75 16 x 14 x .8 HDGD24HDGD24- 24 HD Series Grid 24 8 >24dB Hor/Ver 11 34 x 28 HDDC24HDDC24-24 HD Series Die Cast Grid 24 8 >24dB Hor/Ver 8.2 42 x 24 GD24GD24 -15 Grid 15 19 >19dB Hor / Ver 4 14 x 12 GD24GD24 -19 Grid 19 17 >22dB Hor / Ver 6 24 x 17 PA 24-19 Grid 24 8 >24dB Hor / Ver 11 34 x 28 Die Cast Grid 24 8 >24dB Hor / Ver 8.2 42 x 24 GD22GD22 -MT 2.4GHz MotorolaTM Gain Booster 14 21 (v) 17(h) >17dB Hor / Ver 4 14 x 12 GD26GD26 -MT 2.4GHz MotorolaTM Gain Booster 18 17(v) 11(h) >22dB Hor / Ver 6 24 x 17 GD29GD29 -MT 2.4GHz MotorolaTM Gain Booster 22 8, 5 >25dB Hor / Ver 11 34 x 28 GD24GD24 -24 DC24 3 Client Side Antennas Die Cast Parabolic Grid Dish Part No. DC24 MotorolaTM Gain Booster 5.8GHz Echo SeriesTM Antenna Part No. GDx-MT Part No. ES58-17 2500—2700MHz Part # Type Gain (dBi) BW (deg) Front to Back Polarity Weight (lbs) Dimensions (in.) VA25VA25 -16 Vagi 16 25 >19dB Hor/Ver 1.5 22 x 3 x 4 GD25GD25 -15 Grid 15 17 / 21 >17dB Hor/Ver 4 12 x 16 GD25GD25 -19 Grid 19 11 /17 >17dB Hor/Ver 6 16.5 x 24 GD25GD25 -24 Grid 24 8 / 10 >25dB Hor/Ver 11 28.5 x 36 DC25DC25 -24 Die Cast Grid 24 8 >24dB Hor/Ver 8.2 42 x 24 3400—3600MHz Part # Type Gain (dBi) BW (deg) IN35IN35-8DE Indoor Directional 8 65 PA35PA35 -13 Flat Panel 13 35 GD35GD35 -17 Grid 17 GD35GD35 -20 Grid GD35GD35 -25 Grid 4 Front to Back Polarity Weight (lbs) Dimensions (in.) Hor / Ver .5 4.25 x 3.5 x 1” >20dB Hor / Ver 1.5 7.5 x 7.5 x .8 17 >14dB Hor / Ver 4 14 x 12 20 11 >20dB Hor / Ver 6 24 x 17 25 8 >20dB Hor / Ver 11 34 x 28 Client Side Antennas 4900—5850MHz Part # Type Gain (dBi) BW (h/v) Front to Back Polarity Weight Dimensions (in.) R2T2458 Dual Band RooTenna® 15 22 >25dB Hor/Ver 1.8 9x9x2 R2T58R2T58 -19 RooTenna® 19 16 >30dB Hor/Ver 1.8 9 x9 x 2 R2T58R2T58 -24 RooTenna® 24 9 >30dB Hor/Ver 6 16.25x14.75x1 Enclosure Antenna 19 22 >20dB Ver. 2.5 10 x 7.1 x 2.25 Grid 21 11/10 >18dB Hor/Ver 3 11.8 x 15.7 GD5WGD5W- 25P Grid 5150—5825MHz 25 6/6 >20dB Hor/Ver 6 16.8 x 24 GD5WGD5W- 28P 28 5/4 >25dB Hor/Ver 11 28.5 x 36 DCEDCE-ANT5819 GD5WGD5W- 21P Grid 5150—5850MHz Part # Type Gain (dBi) BW Front to Back (deg) Polarity Weight (lbs) Dimensions (in.) ES58ES58-17 Echo Series 17 25 >30dB Hor/Ver 1.3 10 x 2.5 PA 58-19 Flat Panel 19 16 >30dB Hor/Ver 1.5 7.5 x 7.5 x.8 PA 58-24 Flat Panel 24 8 >40dB Hor/Ver 3.75 16 x 11 x 8.8 GD22GD22 -MT 5.8GHz MotorolaTM Gain Booster 19 12 / 8 >18dB Hor/Ver 4 14 x 12 GD26GD26 -MT 5.8GHz MotorolaTM Gain Booster 24 8/6 >22dB Hor/Ver 6 24 x 17 GD29GD29 -MT 5.8GHz MotorolaTM Gain Booster 27 5/4 >22dB Hor/Ver 11 34 x 28 GD22GD22 -TR 2.4/5.8GHZ Trango TM Gain Booster 14, 19 12 / 8 >30dB Hor/Ver 4 14 x 12 GD26GD26 -TR 2.4/5.8GHZ Trango TM Gain Booster 18, 24 8/6 >22dB Hor/Ver 6 24 x 17 GD29GD29 -TR 2.4/5.8GHZ Trango TM Gain Booster 22, 27 5/4 >22dB Hor/Ver 11 34 x 28 GD5xGD5x-22 Grid 22 11 >25dB Hor/Ver 4 14 x 12 GD5xGD5x-26 Grid 26 6 >30dB Hor/Ver 6 24 x 17 GD5xGD5x-29 Grid 29 4 >25dB Hor/Ver 11 34 x 28 HDGD5x Grid 29 4 >25dB Hor/Ver 11 34 x 28 5 Base Station Antennas Base station antennas are designed for connection to a wireless access point to serve a large area with wireless access. 2.4GHz HPOL Omnidirectional Antenna Part No: ODH24 2.4GHz VPOL 9dBI Sector Part No: SA24-90-9/SA24-120-9 900MHz VPOL Sector Part No: SA9-120-13 900MHz VPOL Omnidirectional Antenna Part No: OD9 Omnidirectional Antennas Omnidirectional antennas communicate in 360 degrees while the sector antennas cover slices of 90 degrees, 120 degrees or 180 degrees. Generally Omni's are used in less densely populated areas and sectors are used in more heavily populated areas. Tech Note: Horizontally Polarized (HPOL) antennas are useful in areas where there is a lot of interference. The HPOL technology offers very good interference rejection of VPOL signals. Part # Frequency Gain (dB) BW (deg) Polarity Downtilt Dimensions Weight (lbs) OD9OD9 -5 900 5 36 Vert. 0 2’ 1.3 OD9OD9 -6 900 6 16 Vert. 0 5.6’ 5.4 OD9OD9 -8 900 8 10 Vert. 0 8.5’ 6.7 OD9OD9 -11D1 900 11 7 Vert. 1 11’ 9.4 ODH9ODH9-9 900 9 18 Horiz. 0 62” 22 FlagTenna 900 2400-2485 11 12 7 Vert. 1 Vary Vary OD24OD24 -7D5 2400-2485 7 18 Vert. 5 21” 1.1 OD24OD24 -9 2400-2485 9 14 Vert. 0 28” 1.1 OD24OD24 -9D7 2400-2485 9 14 Vert. 7 28” 1.1 OD24OD24 -12 2400-2485 12 7 Vert. 3 48” 1.9 ODH24ODH24- 9 2400-2485 9 20 Horiz. 0 27” 6 ODH24ODH24- 13 2400-2485 13 7 Horiz. 0 49” 9 OD24M 2400-2485 5,7,9,12 45,35,18,14 Vert. 0 Vary Vary OD49 4940-4990 6, 11 5 Vert. Vary Vary Vary OD58M 5470-5850 12 7 Vert. 0 21.25” 1.1 OD58OD58 -12 5470-5850 12 7 Vert. 0 21.25” 1.1 6 Base Station Antennas Sector Antennas Freq.(MHz) Gain BW Front/Back Polarity Downtilt Weight/ Dims SAH9SAH9-120120-12 902-928 12 120 >14dB Horiz. 5-10deg 22Lb 62x 8x 2 SA9SA9- 120120 -13 902-928 13 120 >21dB Vert. 10deg 31Lb 53x11x5 SA24SA24 -9090 -9 2400-2485 9 90 (H) 40 (V) >25dB Vert. 45deg 1.6Lb 10x6x2.5 SA24SA24 -120120 -9 2400-2485 9 120(H) 40(V) >25dB Vert. 45deg 1.6Lb. 10x6x2.5 SA24SA24 -180180 -12 2400-2485 12 180(H) 10(V) >15dB Vert. 10deg 3Lb. 40x3x3 SA24SA24 -180180 -14 2400-2485 14 180(H) 10(V) >25dB Vert. 10deg 11Lb. 40x10.25x7 SA24SA24 -4545 -2020 -WB 2300-2700 20 45 >25dB Vert. 30deg. 8.4Lb 34x7x3.5 SA24SA24 -6060 -1717 -WB 2300-2700 17 60 >25dB Vert. 30deg. 6.6Lb 33.5x6.5 x2.5 SA24SA24 -120120 -1616 -WB 2300-2700 16 120(H) 7(V) >25dB Vert. 10deg 9.9Lb. 38x6.5x2.5 SA24SA24 -9090 -1717 -WB 2300-2700 17 90(H) 7(V) >25dB Vert. 10deg 9.9Lb. 38x6.5x2.5 SAH24SAH24-12 2400-2485 12 95(H) 18(V) >14dB Horiz. 10deg 6Lb. 23x4x1 SAH24SAH24-16 2400-2485 16 95(H) 7(V) >14dB Horiz. 10deg 9Lb. 50x4x1 SO24SO24-120x3120x3-15 2400-2485 15 360(H) 6.5(V) >15dB Vert. 2deg 14Lb. 40x6.5 SAH35SAH35-9090-16 3300-3600 17 90 (H) 6.5 (V) >16dB Horiz. 30deg SA49SA49 -9090 -16 4900-4990 16 90 (H) 9 (V) >25dB Vert. 10deg 5.7Lb. 20x6x2.4 SA58SA58 -9090 -1717 -WB 5470-5850 17 90(H) 7 (V) >23dB Vert. 15deg 2.6Lb SA58SA58 -120120 -1616 -WB 5470-5850 16 120(H) 7 (V) >21dB Vert. 15deg 2.6Lb SAH58SAH58-9090-1717-WB 5470-5850 17 90(H) 8(V) >25dB Horiz. 30deg 10Lb. 28.6.5x2.5 SAH58SAH58-120120- 1616-WB 5470-5850 16 120(H) 8(V) >25dB Horiz. 30deg 10Lb. 28.6.5x2.5 Part # 10Lb 35.5x4.7x2.4 7 Point-to-Point Backhaul Antennas The Pacific Wireless Point-to-Point Backhaul antennas are specifically designed for high performance long distance applications. Backhaul antennas are offered in the 900MHz, 2.4, 3.5 and 5GHz frequencies. The grid dish backhaul systems are lightweight and offer excellent windloading performance. The solid parabolic dishes are constructed to withstand the harshest of environments. An optional radome cover is available. 3.5GHz Solid Parabolic Dish Part No: DA35-25, DA35-28 900MHz Parabolic Grid Dish Part No: GD9-18 5GHz Solid Parabolic Dish Point-to-Point Backhaul Antennas Part No: HDDA5W Part # Frequency (MHz) Gain (dBi) BW (deg) Front to Back Polarity Weight (lbs) Dimensions (in) GD9GD9 -18 900-928 19 16.5 >30dB Hor/Ver 27 4’ dia HDGD24HDGD24- 24 1700-2700 24 8 >24dB Hor/Ver 5.5 42 x 24 HDDC24HDDC24-24 1700-2700 24 8 >24dB Hor/Ver 8.2 28.5 x 36 GD35GD35 -25 3400-3600 25 13 >20dB Hor / Ver 8.2 28.5 x 36 DA35DA35- 25 3400-3600 25 10 >32dB Hor / Ver 11 26 dia DA35DA35- 28 3400-3600 28 7.5 >35dB Hor / Ver 22 35.4 dia HDDA5WHDDA5W-29 5150-5825 29 6 >30dB Hor/Ver 11 26 dia HDDA5WHDDA5W-32 5150-5825 32 4 >38dB Hor/Ver 12 35.4 dia HDDA5WHDDA5W-2929-DP 5150-5825 29 4 >30dB Dual Polarity 11 26 dia HDDA5WHDDA5W-3232-DP 5150-5825 32 4 >35dB Dual Polarity 22 35.4 dia GD5xGD5x-29 5150-5825 29 4 >25dB Hor/Ver 11 28.5 x 36 8 Indoor Antennas Wall Mounted Indoor Sector Antenna Part No: IN24-65-8, IN24-90-7 3dBi Ceiling Mount Omnidirectional TriTri - Band Ceiling Mount Omnidirectional Part No: IN24-3 (a or b) Part No: IN800/2500 Rubber Duck APXtender Part No: IN24-5RD Rover Laptop Mount Antenna Part No: RV24-5RD (laptop not included) Shown window mounted 9dBi Directional Antenna Part No: IN24-9DE Indoor Antennas Part # Freq. (GHz) Gain (dBi) BW (Deg) Type Connectors Dimensions (inches) Weight (lbs) IN800/2500 800MHz-2.5 2.2-5 90 Ceiling Mount N Female 7x4 0.8 IN24IN24-3 2.4–2.5 3 90 Ceiling Mount N Female 7x4 1 I N24-90-7 2.4-2.5 7 90 Wall Mount N Female 4x4 0.4 I N24-65-8 2.4-2.5 8 65 Wall Mount N Female 4x4 0.4 TR24TR24 -3- 6 2.4-2.5 3/6 120 Transformer RPSMA, RPTNC 5x1 1.4 MM24MM24 -5RD 2.4-2.5 5.5 45 Mag Mount RPSMA, RPTNC, MC-Card, MMCX, RPMMCX, U.FL 8 .9 8 .15 8 .06 6.1 .8 4.25 x 3.5 x 1” .4 RV24RV24 -5RD 2.4-2.5 5.5 45 Laptop Mount IN24IN24-5RD 2.4-2.5 5.5 45 Rubber Duck RD2458RD2458-5 2.4-5.8 3-5 45 Rubber Duck IN24IN24-9DE 2.4-2.5 9 70 Directional RPSMA, RPTNC, MC-Card, MMCX, RPMMCX, U.FL SMA, RPSMA, RPTNC, N Male SMA, RPSMA, RPTNC, N Male RPSMA, RPTNC, MC-Card, MMCX, RPMMCX, U.FL 9 Mobile Antennas / Accessories Mobile Antennas Part # Frequency (GHz) Gain (dBi) Dimensions (inch) Weight (Lbs) MA9MA9 -5N 900MHz 5 16 0.24 MA9MA9 -7N 900MHz 7 20 0.36 MA24MA24-7N 2.4–2.5 7 12 0.4 2.4GHz 7dB Mobile 900MHz 5dB Mobile Part No. MA9-5N 900MHz 7dB Mobile Part No.MA9-7N Part No. MA24-7N (shown w/MM-110N mag mount) Mobile Mounting Options Magnetic, Trunk Lid & Surface Mounting Part No. MM-90N, MM-110N, MM-TMN, MM-SMN, MM-SM-LPN 10’ LMR195 cable terminated with N Female Wireless Accessories Description Dimensions POE -48i5s48i5s-afi Power Over Ethernet 90-264VAC Input, 5VDC 2.4A Output Two units (each) 3.25x3x1.5 POE -48i1248i12-afi Power Over Ethernet 90-264VAC Input, 12VDC 1A Output Two units (each) 3.25x3x1.5 POE Inserter, 48VDC output, 16.8W 3.25x3x1.5 POE -48i48i-CI POE Inserter, 48VDC output, 16.8W, Current Detection Indicator 3.25x3x1.5 POE -48iD Power Over Ethernet Midspan Power Supply / Splitter 3.25x3x1.5 POE -24i POE Power Supply/Inserter, 24VDC output, 1A(24W) 3.25x3x1.5 POE -24iR POE Power Supply/Inserter, 24VDC output, .8A(19W) 3.25x3x1.5 POE -24iR24iR-CI POE Power Supply/Inserter, 24VDC output, .8A(19W), Current Detection Indicator 3.25x3x1.5 POE -18i POE Power Supply/Inserter, 18VDC output 3.25x3x1.5 POE -12i POE Power Supply/Inserter, 12VDC output, 12W 3.25x3x1.5 POE -5s5s-afi POE Active Splitter With Isolation, 5VDC 2.4A , 12" Ethernet and DC Power cable. 3.25x3x1.5 POE -9s9s-afi POE Active Splitter With Isolation, 9VDC 1A , 12" Ethernet and DC Power cable. 3.25x3x1.5 POE -12s12s-afi POE Active Splitter With Isolation, 12VDC .67A , 12" Ethernet and DC Power cable. 3.25x3x1.5 POE -24s24s-afi POE Active Splitter With Isolation, 24VDC .5A , 12" Ethernet and DC Power cable. 3.25x3x1.5 Connector Adapters Various connector adapters are available to adapt between different connector types. Please contact us for more information. Vary Part # POE -48i 10 Accessories Universal Wall Mount Bracket Part No. WMB8 Power Over Ethernet Injectors & Splitters Adapter Connectors Part No. POE-Xxi . POE-XXs-afi Cable Assemblies Lightning Arrestors Contact us for more info! Part No. SP3 / SP6 RJ45 Ethernet Connector System Part No. RJ45-ECS Universal Mounts Part No. UM / UML Die Cast Aluminum Enclosure Part No. DCE-7x6x2 Part # Description Dimensions Weight (lbs) RJ45RJ45 -FT RJ45 Feed-Thru Cable Gland 3.75 x 1.18 2oz. RJ45RJ45 -ECS RJ45 Ethernet Connector System w/12” RJ45 pigtail 15.75 x 1.18 5oz. DCEDCE-7x6x2 Die Cast Aluminum Nema 6 Rated Weatherproof Enclosure with 7”x6”x2” usable space 10 x 7.1 x 2.75 2.5 DCEDCE-H -7x6x2 Die Cast Aluminum Nema 6 Rated Weatherproof Enclosure w/Hinged Cover—7”x6”x3” usable space 10 x 7.1 x 3.75 3 SP3SP3-9090-6 -BFF Bulkhead Surge Protector, Bulkhead N Fem to N Female, 6KA Discharge, .4dB IL, 3GHz 2.75 x 1.25 x 1.75 4.5oz SP3SP3-9090-6 -BFM Bulkhead Surge Protector, Bulkhead N Fem to N Male, 6KA Discharge, .4dB IL, 3GHz 2.75 x 1.25 x 1.75 4.5oz SP6SP6-230230-BFF DC-6GHz Bulkhead Surge Protector, Bulkhead N Fem to N Fem 2.4 x 1.2 x 0.9 4.5oz SP6SP6-230230-BFM DC-6GHz Bulkhead Surge Protector, Bulkhead N Fem to N Male 2.4x1.2x0.9 4.5oz Wall Mount Bracket, Welded Plated Steel, 8" standoff, 1.25" diameter mount 8x6 3 Universal Mount, 1.5" Pipe, regular and long lengths 7.5x10x15 (UM) 7.5x14x23 (UML) 5 (UM) 7(UML) Vary Vary WMB8 UM / UML Cable Assemblies Various cable assemblies are available or can be custom made. Contact us for more information. 11 About Pacific Wireless Pacific Wireless— a unit of Laird Technologies designs and manufactures state of the art wireless communications solutions targeted at the 900 MHz to 5.8 GHz markets for both fixed and mobile applications. In addition to our line of standard products, we also specialize in custom antenna products for OEM customers. We ship antennas internationally from single unit quantities up to container quantities. New products are always in development! Watch www.pacwireless.com for updates to our product line. For more information about Laird Technologies, please visit www.lairdtech.com. www.lairdtech.com 14557 South 790 West Unit B Bluffdale, UT 84065 Phone: 801-572-3024 Fax: 801-572-3025 sales@pacwireless.com www.pacwireless.com Wirfra-bro-pac-english-2007
SP6-230-BFF 价格&库存
很抱歉,暂时无法提供与“SP6-230-BFF”相匹配的价格&库存,您可以联系我们找货
