WRL-11697
WRL-11697
    SPARKFUNELECTRONICS
    XBEE EXPLORER DONGLE
WRL-11697 数据手册
Page 1 of 2  Export Restrictions This product has some level of export control/restriction, so may be delayed by 2-3 business days when shipping outside the United States. Contact us with questions, or we will contact you after you place your order. SparkFun XBee Explorer Dongle W R L- 116 97 R OH S        2  images are CC BY-NC-SA 3.0 Description: This is the SparkFun XBee Explorer Dongle unit for the Digi XBee module line. With the XBee Explorer Dongle you can plug the unit directly into your USB port and have it act as a gateway between your computer and the XBee. No cables needed! This unit works with all XBee modules including the Series 1 and Series 2.5, standard and Pro version. The on-board voltage regulator is good up to 500mA. The highlight of this board is an FT231X USB-to-Serial converter. That’s what translates data between your computer and the XBee. There’s also a reset button, and a voltage regulator to supply the XBee with plenty of power. In addition, there are four LEDs that’ll help if you ever need to debug your XBee: RX, TX, RSSI (signalstrength indicator), and power indicator. This board also breaks out each of the XBee’s I/O pins to a pair of breadboardcompatible headers. So if you want to make use of the XBee’s extended functionality, you can solder some header pins into those, or even just solder some wire. Not sure which XBee module or accessory is right for you? Check out our XBee Buying Guide! Page 2 of 2 Note: There is no XBee included with this Explorer Dongle. Check the Recommended Products section below for different options. https://www.sparkfun.com/products/11697 6/24/2015
WRL-11697 价格&库存
很抱歉,暂时无法提供与“WRL-11697”相匹配的价格&库存,您可以联系我们找货
WRL-11697
    库存:213
    WRL-11697
      库存:500
