XBIB-U-SS
XBIB-U-SS
    DIGIINTERNATIONAL
    SMD
    BOARD XBEE/XBEE PRO USB SMD SKT
XBIB-U-SS 数据手册
XBIB-U-SS Reference Guide SMT XBee Socket XBee Extraction Hole Push up through hole to remove XBee from socket Test Points Programming Header Header used to program XBee Programmable modules Indicator LEDs DS5: ON/ SLEEP DS2: DIO12 DS3: DIO11 DS4: DIO4 SPI Self Power Module Advanced users only – will void warranty. R31 must be depopulated to power module using V+ and GND from J2 and J5. Sense lines can be connected to S+ and S- for sensing power supplies. CAUTION: Voltage not regulated. Applying incorrect voltage can cause fire and serious injury. See Note 1. SPI Power Connect to power board from 3.3V Current Testing Depopulating R31 allows a current probe to be inserted across P6 terminals. The current though P6/R31 powers the module only. Other supporting circuitry is powered by a different trace. Reset button Loopback Jumper Populating P8 with a loopback jumper causes transmissions both from the module and from the USB to loopback. DC barrel plug: 6-20V Module can be powered by the USB or DC supply. When plugged in simultaneously the DC supply powers the board. User Buttons Connected to DIO lines for user implementation LED Indicator Yellow: UART Tx, RF Rx Green: UART Rx, RF Tx Red: Associate RSSI Indicator USB NOTE 1: Powering board with J2 and J5 without R31 removed can cause shorts if USB or barrel plug power is connected. Applying too high of a voltage will destroy electronic circuitry in the module and other board components and/or cause injury.
XBIB-U-SS 价格&库存
很抱歉,暂时无法提供与“XBIB-U-SS”相匹配的价格&库存,您可以联系我们找货
