Page 1 of 1
SparkFun XBee Explorer Regulated
W R L- 113 73 R OH S
images are CC BY-NC-SA 3.0
Description: The SparkFun XBee Explorer Regulated takes care of the 3.3V
regulation, signal conditioning, and basic activity indicators (Power, RSSI and
DIN/DOUT activity LEDs). It translates the 5V serial signals to 3.3V so that you can
connect a 5V (down to 3.3V) system to any XBee module. The board was
conveniently designed to mate directly with Arduino Pro boards for wireless
bootloading and USB based configuration.
This unit works with all XBee modules including the Series 1 and 2, standard and Pro
versions. Plug an XBee into this breakout and you will have direct access to the serial
and programming pins on the XBee unit and will be able to power the XBee with 5V.
This board comes fully populated with 3.3V regulator (5V max input), XBee socket,
four status LEDs, and level shifting. In the latest revision the diode level shifter is
replaced with a more robust MOSFET level shifter. This board does not include and
XBee module.
https://www.sparkfun.com/products/11373
4/16/2015
很抱歉,暂时无法提供与“WRL-11373”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+225.51480
- 200+89.98560
