Verizon SIM Card
Datasheet
NimbeLink Corp
Updated: February 2021
PN 30147 Rev 3
© NimbeLink Corp. 2021. All rights reserved.
1
Table of Contents
Table of Contents
2
Introduction
Orderable Part Numbers
Additional Resources
Product Images
NL-SIM-VER-TRI
NL-SIM-IND
NL-SIM-COM
Product Overview
Compatible Products
Mechanical Diagram
3
3
3
3
3
3
3
4
4
4
Technical Specifications
Electrical Specifications
Absolute Maximum Ratings
Recommended Ratings for Contacts C1-C7
Other Specifications
5
5
5
5
5
Compliance Requirements
UICC Standards
USIM Standards
ISIM Standards
CSIM Standards
RoHS Compliance
6
6
6
6
6
7
Regulatory Information
7
Version Information
8
PN 30147 Rev 3
2
1. Introduction
This document serves as the datasheet for NimbeLink Verizon SIM cards.
1.1 Orderable Part Numbers
Orderable Device
NL-SIM-VER-TRI
NL-SIM-COM
NL-SIM-IND
Operating Temp
-40˚C to +85˚C
-40C to +85˚C
-40˚C to +105˚C
Description
Mini/Micro/Nano (2FF/3FF/4FF), Commercial Temp Sim Card
Micro-Sim, 3FF size, Commercial Temp Sim Card
Micro-Sim, 3FF size, Industrial Temp Sim Card
Network
Verizon
Verizon
Verizon
1.2 Additional Resources
The following documents or documentation resources are referenced within this
document.
● ETSI TS 102 221 Technical Specification
1.3 Product Images
Below are product images for the SIM cards documented in this datasheet. The
SIM's branding may change over time.
NL-SIM-VER-TRI
NL-SIM-IND
NL-SIM-COM
PN 30147 Rev 3
3
1.4 Product Overview
4G LTE connected devices require a SIM card in order to connect to the network. The
NL-SIM-COM and the NL-SIM-IND from NimbeLink are Verizon approved SIM cards.
1.5 Compatible Products
The NL-SIM-COM, NL-SIM-IND and NL-SIM-VER-TRI from NimbeLink are compatible with all
devices designed to work on the Verizon network, including non-NimbeLink modems. These
SIMs are meant for use with LTE CAT1 or greater devices.
1.6 Mechanical Diagram
PN 30147 Rev 3
4
2. Technical Specifications
2.1 Electrical Specifications
2.1.1 Absolute Maximum Ratings
Parameter
Signal
Maximum Rating
Main Power Supply
I/O Voltage Reference
VCC
VREF
5.5V
5.5V
2.1.2 Recommended Ratings for Contacts C1-C7
Name
Direction
Description
Contact
Min
Max
VCC
Input
Supply voltage
C1
1.8V
5.5V
RST
Input
Reset (RST), VIH
Reset (RST), VIL
C2
C2
VCC - 0.7V
0V
VCC
0.6V
CLK
Input
Clock (CLK), VIH
C3
0.7V x VCC
VCC
Clock (CLK), VIL
C3
0V
0.5V
Input for logic high
Input for logic low
Output for logic high
Output for logic low
C7
C7
C7
C7
0.7V x VCC
-0.3V
3.8V
0V
VCC + 0.3V
0.15V x VCC
VCC
0.4V
IO
I/O
2.2 Other Specifications
Orderable Device
Parameter
Typical
Min Temp
Max Temp
Unit
Dimensions
15 x 12 x 0.76
mm
Weight
> 0.20
Grams
NL-SIM-COM
Operating Temperature
-35
+85
˚C
NL-SIM-COM
Storage Temperature
-35
+85
˚C
Storage Temperature
Storage Temperature
-40
-40
-35
-35
+105
+105
+85
+85
˚C
˚C
˚C
˚C
NL-SIM-IND
NL-SIM-IND
NL-SIM-VER-TRI
NL-SIM-VER-TRI
PN 30147 Rev 3
5
3. Compliance Requirements
3.1 UICC Standards
The UICC is compliant to ETSI TS 102 2211 Rel 8 and 3GPP 31.101 Rel 8
Except the following:
No environmental condition TLV response to select
4 logical channel only supported
No Inter-Chip USB
No Terminal capability
No secure channel
3.2 USIM Standards
The USIM is compliant to 3GPP 31.102 Rel 8.
Except the following commands:
Key Establishment mechanism
OMA BCAST
MBMS security
Authentication of GBA
Addition of I-WLAN related files and procedures
HPLMN Direct Access Indicator for I-WLAN
I-WLAN Steering of Roaming Refresh Command
Geographical Location
Introduction of AES and automatic detection of application data format
Introduction of AES and deprecation of DES
USSD
3.3 ISIM Standards
The ISIM is compliant to 3GPP 31.103 R8.0.1
Except for the following commands:
● Key establishment mechanism
● Authentication of GBA
3.4 CSIM Standards
The CSIM is compliant to 3GPP2 specifications as specified in C.S0065-A v1.0
OTAF command support only the following commands:
● OTAPA request
● Commit and Validate
● Generic Configuration
PN 30147 Rev 3
6
○ Configuration Request and Response Management
○ SSPR Download Request and Response Message
Generic Download Request
○ Download Request and Response Message
OTAPA request
Commit
○ SSPR Configuration Request
BCMCS-related commands are not supported
AKA-related commands are not supported
LCS-related commands are not supported
IP-based Location Service Procedures are not supported
3.5 RoHS Compliance
This product complies with the requirements of 2012/19/EC of the European
Parliament by satisfying the stipulated limits on restricted substances.
4. Regulatory Information
4.1 Export Control Classification Number (ECCN)
ECCNs are five character alphanumeric designations used on the Commerce
ControlList (CCL) to identify dual-use items for export control purposes. An ECCN
categorizes items based on the nature of the product, i.e. type of commodity,
software,or technology and its respective technical parameters.
NL-SIM-IND, NL-SIM-COM, NL-SIM-VER-TRI ECCN: 5A992.c
PN 30147 Rev 3
7
5. Version Information
Revision
Notes
Date
1
Initial Release
2016/07/01
2
Added ECCN information
2021/02/01
3
Added NL-SIM-VER-TRI
2021/02/02
PN 30147 Rev 3
8
很抱歉,暂时无法提供与“NL-SIM-COM”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+52.917661+6.84490
