32403
32403
    PARALLAXINC.
    SHEET FERRITE 210X297MM
32403 数据手册
Web Site: www.parallax.com Forums: forums.parallax.com Sales: sales@parallax.com Technical: support@parallax.com Office: (916) 624-8333 Fax: (916) 624-8003 Sales: (888) 512-1024 Tech Support: (888) 997-8267 XBee Adapter Board (#32403) This low cost XBee Adapter Board comes in a kit form and provides a cost-effective solution to interfacing to any XBee or XBee Pro module. By using this adapter board you can provide an easy interface to the XBee or XBee Pro modules by converting the 2mm pin spacing to breadboard friendly 0.100” spacing. The adapter boards also provide a means to connect pluggable wires or solder connections and also provide mounting holes. Features      Converts XBee 2mm pin spacing to 0.100” pin spacing Provides easy pluggable wire or solder connections Includes mounting holes Pin-out compatible with our other XBee Adapter boards Kit form for flexible configuration Key Specifications     Power requirements: 3.3V pass-through to XBee module Communication: Serial pass-through to XBee module Operating temperature: -40 to +185°F (-40 to +85°C) Dimensions: 1.16” L x 1.00” W x 0.58” H* (29.4 mm x 25.6 mm x 14.8 mm*) * when headers are attached Application Ideas   Easy connection of XBee modules to breadboard or proto board Convenient way to mount the XBee module away from the microcontroller Packing List    (1) XBee Adapter Board PCB (2) 10-pin 2mm sockets (1) 40-pin SIP header Tools Required     Soldering Iron (always wear safety glasses when soldering) Solder (some soldering experience required) Flux (if not using rosin/flux-core solder) Diagonal cutters or Exacto knife (optional) Copyright © Parallax Inc. XBee Adapter Board (#32403) v1.1 3/4/2010 Page 1 of 4 Assembly Instructions Step 1: Check to ensure your kit contains the following parts as shown in the photo. Step 2: Install the 2mm sockets on top of the PCB as shown and solder them in place from the bottom side of the board. Copyright © Parallax Inc. XBee Adapter Board (#32403) v1.1 3/4/2010 Page 2 of 4 Step 3: Using an Exacto knife, hobby knife or a pair of diagonal cutters, cut two 11pin headers from the 40-pin header. Extra header material was included in case of a mistake or damaged header. Step 4 (optional): Insert the two 11-pin SIP headers into the bottom of the adapter board as shown and solder them in place from the top. This step is optional in that you could leave the headers out and solder wires into the pads instead if you wish. Copyright © Parallax Inc. XBee Adapter Board (#32403) v1.1 3/4/2010 Page 3 of 4 Adapter Board Dimensions Adapter Board Schematic The schematic below shows the relationship between the connections on the XBee module (outer sockets) and the headers from the Adapter Board. Please note that the lower-right pin (labeled VDD) is not used on this adapter but is shown for compatibility with our other XBee Adapter boards. Copyright © Parallax Inc. XBee Adapter Board (#32403) v1.1 3/4/2010 Page 4 of 4
32403
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出等。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件支持多种信号路径配置,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制、医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为4x4mm,共有24个引脚。
32403 价格&库存
很抱歉,暂时无法提供与“32403”相匹配的价格&库存,您可以联系我们找货
