MMB.A.EXTMA.16
MMB.A.EXTMA.16
    TAOGLASLIMITED
    ANTROOFBRACKET16MMOLYMPIAN
MMB.A.EXTMA.16 数据手册
SPECIFICATION Part No. : MMB.A.EXTMA Product Name : Torus Magnetic Mount Base For Taoglas External Antennas Features : Super Strong Magnets Integrated In The Base for Reliable Installation Customizable For Different External Antenna Thread Diameters From Ø16mm to Ø31mm No Drilling Required MMB.A.EXTMA.16-- Ø16mm, For Taoglas Olympian Series Application MMB.A.EXTMA.19-- Ø19mm, For Taoglas Hercules Series Application MMB.A.EXTMA.21-- Ø21mm, For Taoglas Spartan ST version & Pantheon ST version Series Application MMB.A.EXTMA.31-- Ø31mm, For Taoglas Ultima, Spartan, & Pantheon Series Application RoHS Compliant Photo: Side View Top View SPE-15-8-016/A/WY Page 1 of 30 MMB.A.EXTMA.16-- Ø16mm, For Taoglas Olympian Series Application MMB.A.EXTMA.19-- Ø19mm, For Taoglas Hercules Series Application MMB.A.EXTMA.21-- Ø21mm, For Taoglas Spartan ST version SPE-15-8-016/A/WY Page 2 of 30 MMB.A.EXTMA.21-- Ø21mm, Pantheon ST version MMB.A.EXTMA.31-- Ø31mm, For Taoglas Ultima Series Application MMB.A.EXTMA.31 - Ø31mm, For Taoglas Spartan Series Application SPE-15-8-016/A/WY Page 3 of 30 MMB.A.EXTMA.31 - Ø31mm, For Taoglas Pantheon Series Application SPE-15-8-016/A/WY Page 4 of 30 1. Introduction The Taoglas MMB series is a robust magnetic mount base solution for external Taoglas antennas that would typically require drilling a hole for installation. There are times when drilling a hole for installation is not feasible either due to cost or aesthetics. The Taoglas MMB magnetic mount base removes the need to drill by providing an adapter with the proper hole size for the antenna you are using. The MMB series can support various Taoglas external antennas including the Olympian, Hercules, Ultima, Spartan, Spartan ST, Pantheon, and Pantheon ST series. The MMB can be mounted on iron/steel metal surfaces such as tops of vehicles, containers, etc. Due to six strong magnets, the magnetic force can resist wind speeds over 100KM/H (road test). Under the MMB, there is a soft cushion of foam which can protect the mounting surface during the mounting/removing processes. There are four standard mounting bases which have different aligning hole diameters from 16mm to 31mm, see table below for model numbers. Torus Magnetic Base for Screw Mount Antennas Part # MMB.A.EXTMA.16 Description Ø16mm, For Taoglas Olympian Model Model Numbers Thread Ø 12mm G30, MA140 A.01, A.03, A.40, A.41, G21, IS.01, IS.02, IS.04, MMB.A.EXTMA.19 Ø19mm, For Taoglas Hercules 18mm IS.05,WS.01, WS.02, MA104, MA106, MA120, MA501, MA510, MA515, MA520 Ø21mm, For Taoglas Spartan ST MMB.A.EXTMA.21 MA600.ST, MA612.ST, MA650.ST 20mm Ø21mm, For Taoglas Pantheon ST Ø31mm, For Taoglas Ultima MMB.A.EXTMA.31 MA700.ST, MA710.ST, MA750.ST, MA760.ST 24mm MA600, MA602, MA603, MA650, MA660, MA671, Ø31mm, For Taoglas Spartan 30mm Ø31mm, For Taoglas Pantheon A.30, G24, MA111, MA530, WS.24 MA672, MA673 MA700, MA710, MA741, MA750, MA760, MA761, MA770 SPE-15-8-016/A/WY Page 5 of 30 Each part comes ready assembled – ready for Installation. This magnetic base can be easily adapted to suit customer requirements – customization may be subject to an NRE and a MOQ, please contact your regional Taoglas Sales Office. 2. Specification MECHANICAL Dimension (mm) Diameter : 178.7, Height : 56 Magnets 6 Magnets integrated in base Material ABS Adapter Ø16mm, Ø19mm, Ø21mm, Ø31mm, Fully Customizable Magnetic Pull Force 20 kgF Weight 560g ENVIRONMENTAL RATINGS Storage Temperature Range -40°C to +85°C Operation Temperature Range -40°C to +85°C Humidity Non-condensing 65°C 95% RH SPE-15-8-016/A/WY Page 6 of 30 3. Torus MMB.A.EXTMA.16-- Ø16mm Olympian Series Application SPE-15-8-016/A/WY Page 7 of 30 3.1 Drawing MMB.A.EXTMA.16 Main Base Adapter SPE-15-8-016/A/WY Page 8 of 30 3.2 Installation MMB.A.EXTMA.16 3.3 Installation Maximum Torque Recommendation MMB.A.EXTMA.16 – For Olympian Series SPE-15-8-016/A/WY Page 9 of 30 SPE-15-8-016/A/WY Page 10 of 30 3.4 Packaging MMB.A.EXTMA.16 SPE-15-8-016/A/WY Page 11 of 30 4. Torus MMB.A.EXTMA.19-- Ø19mm Hercules Series Application SPE-15-8-016/A/WY Page 12 of 30 4.1 Drawing MMB.A.EXTMA.19 Main Base Adapter SPE-15-8-016/A/WY Page 13 of 30 4.2 Installation MMB.A.EXTMA.19 4.3 Installation Maximum Torque Recommendation MMB.A.EXTMA.19 – For Hercules Series SPE-15-8-016/A/WY Page 14 of 30 SPE-15-8-016/A/WY Page 15 of 30 4.4 Packaging MMB.A.EXTMA.19 SPE-15-8-016/A/WY Page 16 of 30 5. Torus MMB.A.EXTMA.21—Ø21mm 5.1 Spartan ST Series Application 5.2 Pantheon ST Series Application SPE-15-8-016/A/WY Page 17 of 30 5.3 Drawing MMB.A.EXTMA.21 Main Base Adapter SPE-15-8-016/A/WY Page 18 of 30 5.4 Installation Spartan ST series 5.5 Installation Pantheon ST series SPE-15-8-016/A/WY Page 19 of 30 5.6 MMB.A.EXTMA.21 – For Spartan ST Version & Pantheon ST Version Series 5.6.1 Spartan ST SPE-15-8-016/A/WY Page 20 of 30 5.6.2 Pantheon ST SPE-15-8-016/A/WY Page 21 of 30 5.7 Packaging MMB.A.EXTMA.21 SPE-15-8-016/A/WY Page 22 of 30 6. Torus MMB.A.EXTMA.31—Ø31mm 6.1 Ultima Series Application 6.2 Spartan Series Application SPE-15-8-016/A/WY Page 23 of 30 6.3 Pantheon Series Application SPE-15-8-016/A/WY Page 24 of 30 6.4 Drawing MMB.A.EXTMA.31 Main Base Adapter SPE-15-8-016/A/WY Page 25 of 30 6.5 Installation Ultima Series 6.6 Spartan Series 6.7 Pantheon Series SPE-15-8-016/A/WY Page 26 of 30 6.8 MMB.A.EXTMA.31 – For Ultima, Spartan, & Pantheon Series 6.8.1 Ultima SPE-15-8-016/A/WY Page 27 of 30 6.8.2 Spartan SPE-15-8-016/A/WY Page 28 of 30 6.8.3 Pantheon SPE-15-8-016/A/WY Page 29 of 30 6.9 Packaging MMB.A.EXTMA.31 SPE-15-8-016/A/WY Page 30 of 30
MMB.A.EXTMA.16 价格&库存
很抱歉,暂时无法提供与“MMB.A.EXTMA.16”相匹配的价格&库存,您可以联系我们找货
MMB.A.EXTMA.16
    • 50+723.9237250+93.83430
