RJ45-ECS-4
RJ45-ECS-4
    LAIRD(莱尔德)
    ETH CONN SYSTEM RJ45 IP68 4"
RJ45-ECS-4 数据手册
RJ45-ECS Ethernet Connector System Innovative Technology for a Connected World ETHERNET CONNECTOR SYSTEM The patented RJ45-ECS Ethernet connector system, available exclusively from Laird Technologies, is a field replaceable outdoor rated and shielded Ethernet connection system for high speed 10BaseT, 100BaseT and 1000BaseT networks. The system features a shielded RJ45 receptacle mounted in a UV protected housing and a mating cable gland which passes an RJ45 connector and seals the cable to IP67 requirements. The system provides for quick and easy disconnect and reconnect of equipment. Because of its many unique design features and low cost, the RJ45-ECS is a universal solution for many industries where a sealed and waterproof, yet removable, Ethernet connection is required. These include outdoor applications such as wireless equipment or video surveillance equipment, and indoor applications such as equipment used in factory automation or harsh industrial processes. RJ45 connectors are not designed for high reliability in the presence of moisture, dust, or corrosive elements. For this reason, the IP67 sealing ability of the RJ45-ECS provides a reliable connection, even in very harsh environments, for many years of trouble free service. The shielded nature of the Cat5e cable and connectors provide maximum shielding against external EMI for consistent data communications. For modern wireless systems, the quick disconnect feature allows for ready replacement of rooftop equipment, to minimize field time spent servicing customer’s equipment, and minimizing downtime for the customer. This helps to increase operator profitability and customer satisfaction. * No Relief Version Shown Here FEATURES MARKETS • Patented low cost design • Wireless base stations • Field replaceable waterproof connector system for RJ45 shielded or unshielded connectors • Telecom equipment • Constructed of UV protective materials for long life in harsh outdoor environments • 802.11 a/b/g wireless systems • Seal meets IP67 criteria • Shock and vibration resistant • Positive locking RJ45 connector • 12 in Cat5E strain relieved cable global solutions: local support Americas: +1.847 839.6907 IAS-AmericasEastSales@lairdtech.com Europe: +1.32.80.7866.12 IAS-EUSales@lairdtech.com Asia: +1.65.6.243.8022 IAS-AsiaSales@lairdtech.com www.lairdtech.com TM • Wireless client radios • Direct burial equipment • 10BaseT, 100BaseT or 1000BaseT networks • Industrial process control • Factory automation • WiMAX RJ45-ECS Ethernet Connector System Innovative Technology for a Connected World Specifications Data Mechanical Material Sealing Salt Spray Flammability Thermal Shock Temperature Range Installation Hole Dia Overall Size (L x Dia) Weight 10BaseT, 100BaseT and 1000BaseT Networks CAT5e per TIA/EIA 568B ClassD per ISO/IEC 11801 Mating Cycles >500 Positive RJ45 bayonet coupling Cat5 Cable Strain Relief UV Resistant Nylon 66 IP67 >1000 h UL94VO 10 cycles -40 to +100°C -40°C to +85°C 0.787 in (20 mm) 3.75 in x 1.18 in (95 x 30 mm) 2 oz (57 gm) SYSTEM ORDERING INFORMATION RJ45-ECS RJ45-ECS-NR RJ45-ECS-4 RJ45-ECS-4-NR RJ45-ECS-6 RJ45-ECS-6-NR 12 in RJ45 Waterproof Outdoor Ethernet Connector System 12 in RJ45 Waterproof Outdoor Ethernet Connector System with no relief 4 in RJ45 Waterproof Outdoor Ethernet Connector System 4 in RJ45 Waterproof Outdoor Ethernet Connector System with no relief 6 in RJ45 Waterproof Outdoor Ethernet Connector System 6 in RJ45 Waterproof Outdoor Ethernet Connector System with no relief NOTES • All shipments F.O.B. Schaumburg, IL 60173 ANT-DS-RJ45-ECS 0611 Any information furnished by Laird Technologies, Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird Technologies materials rests with the end user, since Laird Technologies and its agents cannot be aware of all potential uses. Laird Technologies makes no warranties as to the fitness, merchantability or suitability of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2011 Laird Technologies, Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Technologies Logo, and other marks are trade marks or registered trade marks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird Technologies or any third party intellectual property rights.
RJ45-ECS-4 价格&库存
很抱歉,暂时无法提供与“RJ45-ECS-4”相匹配的价格&库存,您可以联系我们找货
