MB8M
MB8M
    LAIRD(莱尔德)
    ACCY MOUNT BMM 3/4 58A
MB8M 数据手册
Vehicular Mobile Radio Mounts NMO Thru Hole Mounts LAIRD VEHICULAR MOUNTS ARE THE INDUSTRY STANDARD FOR PERFORMANCE AND DURABILITY FEATURES AND BENFITS • All brass construction and gold plated contact design ensure the most corrosion resistance and best power transfer available • 78 Rockwell Hardness brass material resists corrosion • Silver soldered ground lug and contact virtually eliminates RF noise or static • Multiple cable options are available Model Connector Type Model Connector Type 3/4” or 3/8” Hole Alternative Mounts (Cable Not Included) 3/4” Hole Brass Mounts* MO 3/4 Steel Mount Models with 17’ of RG58A/U Stranded Center Conductor Cable MBO 3/4 Brass Mount for use with RG58 size Cable MB8 No Connector MBOX 3/4 Brass Mount for RG8X size Cable MB8B BNC Crimp MBOF 3/4 Brass Mount for Teflon Cable MB8M Mini UHF Crimp MABO 3/8 Brass Mount for use with RG58 size Cable MB8N N Crimp MABTO 3/4 or 3/8 Brass Thick Plate Mount for 3/16”to 1/4” thick surfaces MB8NS N Solder MB8P UHF (PL259) Crimp MABVTO 3/4 or 3/8 Hole 1/2” Thick Plane Adjustable Mount Only MB8PS UHF (PL259) Solder MB8PST UHF (PL259) Teflon® Solder MXGPO 3/8” snap-in Ground Plane Mount MB8T TNC Crimp MXO Snap-in Mount Models with 17’ of RG58U Solid Center Conductor Cable ® 5/8” Hole Alternative Mounts VTPM VTPM800 MB8U No Connector 1” Extra Thick Plate Mount (UHF Barrel - 1-3/8” total stud length) MB8UB BNC Crimp MB8UM Mini UHF Crimp 800 MHz - 1/2” Thick Plate Mount (N Barrel - 1-3/16” total stud length) MB8UN N Crimp MB8UNS N Solder MB8UP UHF (PL259) Crimp MB8UPST UHF (PL259) Teflon® Solder MB8UT TNC Crimp *All connectors are shipped loose. Choose “I” option for installed connectors Models with 17’ of RG8X Low Loss Solid Center Conductor Cable Americas: +1.847 839.6925 IAS-AmericasEastSales@lairdtech.com Europe: +44.1628.858941 IAS-EUSales@lairdtech.com Asia: ++86.21.5855.0827.127 IAS-AsiaSales@lairdtech.com www.lairdtech.com MB8X No Connector MB8XB BNC Crimp MB8XM Mini UHF Crimp MB8XN N Crimp MB8XNS N Solder MB8XP UHF (PL259) Crimp MB8XPST UHF (PL259) Teflon® Solder MB8XT TNC Crimp Vehicular Mobile Radio Mounts Model Connector Type Model Connector Type 3/4” Hole Brass Mounts* (continued) 3/8” Hole Brass Mounts* (continued) Models with 17’ of Teflex™ Cable Models with 17’ of RG8X Low Loss Solid Center Conductor Cable MBD No Connector MAB8X No Connector MBDB BNC Crimp MAB8XB BNC Crimp MBDM Mini UHF Crimp MAB8XM Mini UHF Crimp MBDN N Crimp MAB8XN N Crimp MBDNS N Solder MAB8XNS N Solder MBDP UHF (PL259) Crimp MAB8XP UHF (PL259) Crimp MBDPST UHF (PL259) Teflon Solder MAB8XPST UHF (PL259) Teflon® Solder MBDT TNC Crimp MAB8XT TNC Crimp ® Models with 17’ of Teflon Cable Models with 17’ of Teflex™ Coax MBF No Connector MABD No Connector MBFB BNC Crimp MABDB BNC Crimp MBFM Mini UHF Crimp MABDM Mini UHF Crimp MBFN N Crimp ® MABDN N Crimp Models with 17’ of ATX195 Cable MABDNS N Solder Ordering Guide MB195 MABDP UHF (PL259) Crimp MB8PSI14 = 3/4” Brass Mount, PL259 Solder Installed, 14’ of RG58A/U Installation Accessories MABDPST UHF (PL259) Teflon® Solder P34 N/A Package of 6 - 3/4” Hole Plugs MABDT TNC Crimp MOGSK N/A Package of 6 - 3/4” Mount Gaskets Thick Plane Models* - up to 1/4” MORNG N/A Package of O-rings for ”M” Mounts Models with 17’ of RG58A/U Stranded Center Conductor Cable MB 8 PS I 14 Mount Style & Hole Style M= 3/4” Steel Hole Mounts MAB = 3/8” Brass Hole Mounts MABT = 3/8” or 3/4” Brass Mounts for Thick Plate up to 1/4” MABVT = 3/8” or 3/4” Brass Hole Mounts Adjustable up to 1/2” MB = 3/4” Brass Hole Mounts MX = 3/8” Brass Snap-in Hole Mount Cable Style 8 = RG58A/U 8U = RG58U 8X = RG8X “low loss” D = Teflex™ F = Teflon® Coax Cable O = Only (Mount Only-No Cable) 195=ATX195 Connector Style Blank = No connector B = BNC crimp M = Mini UHF crimp N = N crimp NS = N solder P = PL259 crimp PS = PL259 solder PST = PL259 solder Teflon® SM = SMA Crimp T = TNC crimp Installation Option Blank = Loose connector I = Installed connector (Add $1.00 for crimp, $1.50 for solder.) Cable Length Blank = Standard 17 ft. cable length 14 = Optional 14 ft. cable length Other lengths available upon request No Connector (Good for higher frequency) 3/8” Hole Brass Mounts* MABT8 No Connector Models with 17’ of RG58A/U Stranded Center Conductor Cable MABT8B BNC Crimp MAB8 No Connector MABT8M Mini UHF Crimp MAB8B BNC Crimp MABT8N N Crimp MAB8M Mini UHF Crimp MABT8P UHF (PL259) Crimp MAB8N N Crimp MABT8PS UHF (PL259) Solder MAB8NS N Solder Models with 17’ of RG58U Solid Center Conductor Cable MAB8P UHF (PL259) Crimp MABT8U No Connector MAB8PS UHF (PL259) Solder MABT8UB BNC Crimp MAB8PST UHF (PL259) Teflon Solder MABT8UM Mini UHF Crimp MAB8T TNC Crimp MABT8UN N Crimp Models with 17’ of RG58U Solid Center Conductor Cable MABT8UP UHF (PL259) Crimp MAB8U No Connector Thick Plane Models* - up to 1/2” MAB8UB BNC Crimp Models with 17’ of RG58A/U Stranded Center Conductor Cable MAB8UM Mini UHF Crimp MABVT8 No Connector MAB8UN N Crimp MABVT8M Mini UHF Crimp MAB8UNS N Solder MABVT8B BNC Crimp MAB8UP UHF (PL259) Crimp MABVT8UP UHF (PL259) Crimp MAB8UPST UHF (PL259) Teflon® Solder Model with 17’ of RG58U Solid Center Conductor Cable MAB8UT TNC Crimp MABVT8U ® *All connectors are shipped loose. Choose “I” option for installed connectors Vehicular Mobile Radio Mounts Magnetic NMO Mounts FEATURES AND BENFITS • • • • • • Corrosion resistant materials used throughout for high durability and weather resistance Neoprene seal for moisture protection High 80-lb pull strength will allow antenna to stay put Optional rubber boot provides additional protection to mounting surface Triple reinforced coax strain relief eliminates cable pull out 3-1/4” diameter Model Connector Type Model Connector Type 3/4” Style Magnetic Mounts* 3/4” Style Magnetic Mounts* (continued) Chrome Models with 12’ of RG58A/U Stranded Center Cable G8UM Mini UHF Crimp G8 No Connector G8UN N Crimp G8B BNC Crimp G8UNS N Solder G8BI BNC Crimp, Installed G8UP UHF (PL259) Crimp G8MI Mini UHF Crimp, Installed G8UPST UHF (PL259) Teflon® Solder G8N N Crimp G8UT TNC Crimp G8NS N Solder Chrome Models with 12’ of RG8X Low Loss Cable G8P UHF (PL259) Crimp G8X No Connector G8PI UHF (PL259) Crimp, Installed G8XBI BNC Crimp, Installed GR8PI UHF (PL259) Crimp, Installed G8XM Mini UHF Crimp G8PS UHF (PL259) Solder G8XNI N Crimp, Installed G8PST UHF (PL259) Teflon® Solder G8XNS N Solder G8TI TNC Crimp, Installed G8XP UHF (PL259) Solder Chrome Models with 12’ of RG58U Solid Center Conductor Cable G8XPST UHF (PL259) Teflon® Solder G8U No Connector Chrome Models with 12’ of Teflex™ Cable G8UB BNC Crimp GD No Connector GDBI BNC Crimp, Installed GDM Mini UHF Crimp MOBILE-TO-BASE-CONVERTERS GDNI N Crimp, Installed FEATURES AND BENFITS GDNS N Solder • Value conscious option for VHF, UHF, 800 MHz and up applications GDPI UHF (PL259) Crimp, Installed GDPST UHF (PL259) Teflon® Solder GDT TNC Crimp Model Connector Type Mobile-to-Base Converter Black Models with 12’ of RG58A/U Stranded Center Cable MBC Mobile-to-base Converter for VHF and UHF, S0239 Terminated GB8 RG58A/U MBCN Mobile-to-base Converter for VHF and UHF, N Terminated GBR8PI Rubber Boot Option - RG58A/U with PL259 Installed MBC800 Mobile-to-base Converter for 800 and 900 MHz, N Terminated MBC800LBT Mobile-to-base Converter for 800 and up, wall mount, N Terminated *All connectors are shipped loose. Choose “I” option for installed connectors Vehicular Mobile Radio Mounts Mini Magnetic NMO Mounts FEATURES AND BENFITS Model • Ideal for small antennas - 2-3/8” diameter • 50-lb pull strength • Brass, ceramic magnet, and chrome plated steel materials are very durable and resist corrosion • Gold plated contact Chrome Models with 12’ of RG58U Solid Center Conductor Cable Connector Type GM8U No Connector GM8UB BNC Crimp GM8UM Mini UHF Crimp GM8UN N Crimp GM8UNS N Solder 3/4” Style Mini-Magnetic Mounts* GM8UP UHF (PL259) Crimp Chrome Models with 12’ of RG58A/U Stranded Center Cable GM8UPST UHF (PL259) Teflon® Solder GM8 No Connector GM8UT TNC Crimp GM8B BNC Crimp Chrome Models with 12’ of Teflex™ Cable GM8M Mini UHF crimp GMD No Connector GM8N N Crimp GMDB BNC Crimp GM8NS N Solder GMDM Mini UHF Crimp GM8P UHF (PL259) Crimp GMDN N Crimp GM8PI UHF (PL259) Crimp, Installed GMDNS N Solder GM8PS UHF (PL259) Solder GMDPI UHF (PL259) Crimp, Installed GM8PST UHF (PL259) Teflon Solder GMDPST UHF (PL259) Teflon® Solder GM8T TNC Crimp GMDT TNC Crimp Model Connector Type ® Black Models with 12’ of RG58A/U Stranded Center Cable MINI-TRUNK LID MOUNTS GM88 No Connector FEATURES AND BENFITS • Stainless steel brackets and hardware are the ultimate in corrosion resistance • Elegant design enables proper fit on high tolerance trunk lid seams Model Connector Type TM8N N Crimp • Non staining rubber cushion minimizes scratches and stains TM8NS N Solder • Gold plated contact TM8P UHF (PL259) Crimp TM8PS UHF (PL259) Solder TM8PST UHF (PL259) Teflon® Solder Mini-trunk Lid Mounts* TM8T TNC Connector Models with 17’ RG58A/U Stranded Center Conductor Cable Models with 17’ of RG58U Solid Center Conductor Cable TM8 No Connector TM8U No Connector TMB8 No Connector TMB8U No Connector TM8B BNC Crimp TM8UB BNC Crimp TM8M Mini UHF Crimp TM8UM Mini UHF Crimp TM8UN N Crimp TM8UNS N Solder TM8UP UHF (PL259) Crimp TM8UPST UHF (PL259) Teflon® Solder TM8UT TNC Crimp Model Connector Type *All connectors are shipped loose. Choose “I” option for installed connectors ANT-DS-MOUNTS_1215 Any information furnished by Laird and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability or suitability of any Laird materials or products for any specific or general uses. Laird, Laird Technologies, Inc or any of its affiliates or agents shall not be liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2014 Laird Technologies, Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Technologies Logo, and other marks are trademarks or registered trademarks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights. Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: TE Connectivity: MB8MI3 MB8BI5 MB8PI MB8B25 MB8P40 MB8BI3 MB8NI20 MB8B14 MB8PS14 MB8P25 MB8B1 MB8NI15 MB8P20 MB8MI MB8PS40 MB8B20 MB8BI25 MB8B10 MB8BI2.25 MB8BI2 MB8BI9 MB8M30 MB8PS25 MB8M20 MB8P30 MB8BI MB8SM MAB8M G8B G8N GBR8PI GB8 MBO16394 G8 G8BI G8PI MABNUT MABT195 MABT19530 MABT195N15 MABT195SM MABT195SM4I MABT3160.5MCXI MABT8SMI2 MABT8SMRAI1 MABT8T MABT8TI12 MABT8TI4 MABT8X MABT8XM MABT8XM29 MABT8XN MABT8XNS MABT8XNSI MABT8XNSI4 MABT8XP MABT8XPST40 MABTD MABTD21 MABTDPS30 MABTDT MABTF30 MABTFM MABVT195 MABVT19510 MABVT195SMI MABVT195TI3 MABVT195TI6 MABVT195TNRA30 MABVT8FMEFI MABVT8NI MABVT8PI MABVT8PS30 MABVT8SM22 MABVT8SMBI20 MABVT8SMI12 MABVT8TI14 MABVT8X20 MABVT8X25 MABVT8XPS30 MABVTD MABVTD30 MABVTD40 MB8SMI MB8SMI10 MB8SMI15 MB8SMI3 MB8SMI6 MB8T14 MB8T30 MB8TI15 MB8TI3 MB8U14 MB8U20 MB8U21 MB8U25 MB8U40 MB8UBI MB8UBI2 MB8UM20
很抱歉,暂时无法提供与“MB8M”相匹配的价格&库存,您可以联系我们找货
