B4505CSRO
B4505CSRO
    LAIRD(莱尔德)
    ACCY MOBILE LOAD COIL B4505CS
B4505CSRO 数据手册
Laird Technologies Web site: www.LairdTech.com Mobile Load Coil Antennas      •  Low loss coil form adds dimensional and frequency stability  •  ABS material is injection molded around solid brass inserts to create a virtually indestructible housing that is virtually leak proof  •  All silver soldered joints ensure electrically and mechanically secure connections   Results 1 - 41 of 41 Item # Model Description Frequency Range Center Frequency Gain Whip Style C27 Lowband DC Ground Base Models 1/4 Wave 26.75-31 MHz Tunable Unity 49” Tapered C30 Lowband DC Ground Base Models 1/4 Wave 30 - 35 MHz Tunable Unity 49” Tapered C34 Lowband DC Ground Base Models 1/4 Wave 34 - 37 MHz Tunable Unity 49” Tapered C37 Lowband DC Ground Base Models 1/4 Wave 37 - 40 MHz Tunable Unity 49” Tapered C40S Lowband DC Ground Base Models 1/4 Wave w/Spring 40 - 47 MHz Tunable Unity 49” Tapered C40 Lowband DC Ground Base Models 1/4 Wave 40 - 47 MHz Tunable Unity 49” Tapered C47 Lowband DC Ground Base Models 1/4 Wave 47 - 50 MHz Tunable Unity 49” Tapered B66 VHF Models 1/4 Wave Broadband 66 - 174 MHz Tunable Unity 49” Tapered B132 VHF Models 1/4 Wave Broadband 132 - 928 MHz Tunable Unity 21” Straight B132S VHF Models 1/4 Wave Broadband 132 - 525 MHz Tunable Unity 21” Straight B1323S VHF Models 5/8 Wave w/Spring 132 - 174 MHz Tunable 3 dB 55” Tapered B1323 VHF Models 5/8 Wave 132 - 174 MHz Tunable 3 dB 55” Tapered B1443 VHF Models 5/8 Wave 144 - 174 MHz Tunable 3 dB 49” Tapered B1443S VHF Models 5/8 Wave w/Spring 144 - 174 MHz Tunable 3 dB 49” Tapered B2003 VHF Models 5/8 Wave 200 - 225 MHz Tunable 3 dB 33” Straight B2503 VHF Models 5/8 Wave 250 - 280 MHz Tunable 3 dB 24 1/2” Straight B1322N VHF Models NGP Base Loaded 1/2 Wave 132 - 174 MHz Tunable 2.4 dB 55” Tapered B1442NS VHF Models NGP Base Loaded 1/2 Wave w/Spring 144 - 174 MHz Tunable 2.4 dB 49” Tapered B1442N VHF Models NGP Base Loaded 1/2 Wave 144 - 174 MHz Tunable 2.4 dB 49” Tapered B2002N VHF Models NGP Base Loaded 1/2 Wave 200 - 225 MHz Tunable 2.4 dB 29 1/2" Straight B4063 UHF Models 5/8 Wave 406 - 430 MHz Tunable 3 dB 13” Straight B4303 UHF Models 5/8 Wave 430 - 450 MHz Tunable 3 dB 11 13/16” Straight B4503 UHF Models 5/8 Wave 450 - 470 MHz Tunable 3 dB 11” Straight B4703 UHF Models 5/8 Wave 470 - 490 MHz Tunable 3 dB 10 11/16” Straight B4903 UHF Models 5/8 Wave 490 - 512 MHz Tunable 3 dB 10 1/2" Straight B4065C UHF Models Closed Coil Collinear 406 - 430 MHz Tunable 5 dB 37 3/8” Collinear B4305C UHF Models Closed Coil Collinear 430 - 450 MHz Tunable 5 dB 34 1/8” Collinear B4505CS UHF Models Closed Coil Collinear w/Spring 450 - 470 MHz Tunable 5 dB 32 3/4” Collinear B4505C UHF Models Closed Coil Collinear 450 - 470 MHz Tunable 5 dB 32 3/4” Collinear 8/15/2012 | Page 1 of 2 B4705C UHF Models Closed Coil Collinear 470 - 490 MHz Tunable 5 dB B4905C UHF Models Closed Coil Collinear 490 - 512 MHz Tunable 5 dB 31 1/4” Collinear 29 1/8” Collinear B4062N UHF Models NGP 1/2 Wave 406 - 430 MHz Tunable 2.4 dB 11 9/16” Straight B4302N UHF Models NGP 1/2 Wave 430 - 450 MHz Tunable 2.4 dB 10 5/8” Straight B4502N UHF Models NGP 1/2 Wave 450 - 470 MHz Tunable 2.4 dB 10 5/16” Straight B4065CN UHF Models NGP Closed Coil Collinear 406 - 430 MHz Tunable 5 dB 34 1/8” Collinear B4305CN UHF Models NGP Closed Coil Collinear 430 - 450 MHz Tunable 5 dB 32 7/8” Collinear B4505CN UHF Models NGP Closed Coil Collinear 450 - 470 MHz Tunable 5 dB 30 1/2” Collinear B4705CN UHF Models NGP Closed Coil Collinear 470 - 490 MHz Tunable 5 dB 28 7/16” Collinear B4905CN UHF Models NGP Closed Coil Collinear 490 - 512 MHz Tunable 5 dB 27 1/8” Collinear B1322W VHF Models 1/2 Wave 132 - 174 MHz Tuneable 2.4 dB N/A B1360W VHF Models 1/4 Wave 136 - 174 MHz 155 MHz 0 dB N/A   Results 1 - 41 of 41 8/15/2012 | Page 2 of 2
B4505CSRO 价格&库存
很抱歉,暂时无法提供与“B4505CSRO”相匹配的价格&库存,您可以联系我们找货
