ANT-SKN-V1-3.15
ANT-SKN-V1-3.15
    LINXTECHNOLOGIES(灵思)
    3.15" ANTENNA COVER
ANT-SKN-V1-3.15 数据手册
ANT-SKN-V1-x.xx DATA SHEET Product Dimensions Description These low-cost sleeves provide your customer with the ruggedness and cosmetic appeal of expensive whip antennas, but are hollow to cover the low-cost internal element of a user's choosing, such as a wire, rod, or flexible shaft. The sleeve is designed to allow a wide range of mounting options in metal or plastic housings of various thicknesses. Ant-Skins can also reduce your parts inventory since a wide range of frequency lengths can be accommodated by a single sleeve. Ø0.245” (6.2) Ø0.200” (5.1) 0.090” (2.3) Ø0.110” (2.8) Features • Recesses provided to accommodate six different enclosure thicknesses by simply pulling the Ant-Skin through the case until it is in the correct position • Generous cavity to accommodate many different elements, including flexible cable, wire, or rod • Squared base for permanent spin-proof mounting option • Cost-effective • Gives cosmetically attractive, professional appearance 1.50” (38.0) Ordering Information 3.15” (80.0) • ANT-SKN-V1-1.50 (1.5” antenna cover) • ANT-SKN-V1-3.15 (3.15” antenna cover) • ANT-SKN-V1-4.25 (4.25” antenna cover) 4.25” (108.0) Ø0.265” (6.7) Ø0.375” (9.5) 0.400” (10.2) Ø0.060” (1.5) 0.028” (0.7) 0.350” (8.9) 0.038” (1.0) Ø0.400” (8.9) 0.058” (1.5) Hole 0.063” (1.6) Ø0.325” (8.3) 0.079” (2.0) Ø0.275” (7.0) 0.115” (2.9) 0.060” (1.5) Ø0.325” (8.3) Ø0.275” (7.0) 0.100” (2.5) Ø0.400” (10.2) Clamp Antenna Factor 159 Ort Lane Merlin, OR 97532 www.antennafactor.com 541-956-0931 (phone) 541-471-6251 (fax) Molded Slot Rev 08-24-09
ANT-SKN-V1-3.15 价格&库存
很抱歉,暂时无法提供与“ANT-SKN-V1-3.15”相匹配的价格&库存,您可以联系我们找货
