SN111F5-NR
SN111F5-NR
    SYNAPSE
    SNAP NODE END DEVICE W/NO RADIO
SN111F5-NR 数据手册
Wireless Technology to Control and Monitor Anything from Anywhere™ SNAP Node End Device (SN111) Demonstration Board SN111 - End Device The SNAP End Device has the onboard peripherals to demonstrate powerfulmonitoring and control capabilities right out of the box. You can control external electrical devices withthe power-relay, display link-quality or other parameters on the 7-segment LEDs, wake up with a button-press, and more. Several of Portal’s sample scripts make specific use of these boards. Modify one of the sample scripts to make your own application – demonstrate for yourself the power of SNAP! SNAP Node End Device™ (SN111) The SN111 End Device provides a latching relay for controlling external devices, and a sensor input with jumper-selectable pullup resistors which allows the connection of a number of off-the-shelf resistive sensor types such as photocells and thermistors. Compatible with all Synapse RF Engines RS-232 port with full hardware flow control(UART1) 2-Digit 7-segment LED, softwarecontrollable Status LED and select switch, also under users oftwarecontrol Battery or external power option USB port (UART0) which can also provide power 10A latching relay Analog input terminals (ADC-CH0) 10-bit A/D with selectable pullup 430-0112.01C Wireless Technology to Control and Monitor Anything from Anywhere™ SNAP Node End Device (SN111) Demonstration Board Product Features Feature Part Selection Part No. Description RS-232 Port..........................................Full RS-232 support with HW flow control (RTS/CTS) Display ................................................2-digit seven-segment green LED Display Input Power ..........................................4 - 9 VDC wall transformer, USB 5V (SN163 - Bridge only), 2x AA battery Select Button........................................User function definable Status LED............................................User function definable (yellow) External Power LED ..............................On when external power from wall transformer or USB is supplied (green) Power Switch ......................................On/Off switch for all power modes Reset....................................................Reboot RF Engine Relay ....................................................Contacts rated 10A at 250 VAC or 30 VDC. Replaceable fuse protection for relay circuit Analog Input ........................................10-bit A/D input, 0-3.2V range. Jumper selectable pullup resistors: 10k, 100k, 1M SN111F5-NR............End Device RF Engine Socket Allocationon Demonstration Board Pin No. Name Direction Description Demonstration Board Connection 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 GND GPIO0_TPM1CH2 GPIO1_KBI10 GPIO2_KBI11 GPIO3_RX_UART0 GPIO4_TX_UART0 GPIO5_KBI4_CTS0 GPIO6_KBI5_RTS0 GPIO7_RX_UART1 GPIO8_TX_UART1 GPIO9_KBI6_CTS1 GPIO10_KBI7_RTS1 GPIO11_AD7 GPIO12_AD6 GPIO13_AD5 GPIO14_AD4 GPIO15_AD3 GPIO16_AD2 GPIO17_AD1 GPIO18_AD0 VCC PTG0/BKDG RESET_L GND Bidirectional Bidirectional Bidirectional Input Output Bidirectional Bidirectional Input Output Bidirectional Bidirectional Bidirectional Bidirectional Bidirectional Bidirectional Bidirectional Bidirectional Bidirectional Bidirectional Bidirectional Bidirectional - Power Supply/Return GPI/O, or Timer1 Channel 2 GPI/O, Keyboard In GPI/O, Keyboard In UART0 Data In UART0 Data Out GPI/O, Keyboard In, or UART0 CTS GPI/O, Keyboard In, or UART0 RTS UART1 Data In UART1 Data Out GPI/O, Keyboard In, or UART1_CTS GPI/O, Keyboard In, or UART1_RTS GPI/O, or Analog In GPI/O, or Analog In GPI/O, or Analog In GPI/O, or Analog In GPI/O, or Analog In GPI/O, or Analog In GPI/O, or Analog In GPI/O, or Analog In Power Supply Background Debug Communication Module Reset, Active Low Power Supply/Return GND Status LED Select Switch ADC - 24-bit CS SYNAPSE Wireless, Inc. ® All specifications are subject to change without notice. © 2012 SYNAPSE All Rights reserved. Patents pending. MAX232 MAX232 MAX232 MAX232 ADC-24-bit DATA ADC-24-bit CLK LED - 7 seg CLK LED - 7 seg DATA Battery level (analog) Relay RESET Relay SET Sensor Input VCC PTG0/BKDG RESET GND 500 Discovery Drive, Huntsville, Alabama 35806 877 982-7888 · synapse-wireless.com
SN111F5-NR 价格&库存
很抱歉,暂时无法提供与“SN111F5-NR”相匹配的价格&库存,您可以联系我们找货
