Approval sheet
RFBLN Series – 1608(0603)- RoHS Compliance
MULTILAYER CERAMIC BALUN TRANSFORMER
2.4 GHz ISM Band RF Application
P/N: RGBLN1608070A5T
*Contents in this sheet are subject to change without prior notice.
Page 1 of 7
ASC_RGBLN1608070A5T_V04
Dec.2015
Approval sheet
FEATURES
1.
Multilayer LTCC ( Low Temperature Cofired Ceramics ) Technology
2.
Miniatured Size 1.6 x 0.8 x 0.7 mm
3.
Low Insertion Loss reduces power consumption
4.
Low inband Amplitude and Phase imbalance enable high performance wireless system operation.
5.
Enable for DC Biasing of PA or Mixer
6.
Suitable for 2.45 GHz Working Frequency Operation
7.
Special Balance/ Unbalance impedance is upon requested.
3
APPLICATIONS
1.
2.4GHz ISM Band RF Application
2.
Bluetooth, Wireless LAN, HomeRF
CONSTRUCTION
Figure
P3
P4
P2
P5
P1
P6
PIN
Connection
1
Unbalanced port
2
DC or GND
3
Balanced port
4
Balanced port
5
GND
6
NC
DIMENSIONS
Figure
Top view
Page 2 of 7
Bottom view
Symbol
Dimension (mm)
L
1.60 ± 0.15
W
0.80 ± 0.15
T
0.70 ± 0.10
A
0.175 ± 0.15
B
0.25 ± 0.15
C
0.25 ± 0.15
D
0.50 ± 0.15
E
0.20 ± 0.15
Side view
Dec.2015
Approval sheet
ELECTRICAL CHARACTERISTICS
RGBLN1608070A5T
Specification
Frequency range
2400 ~ 2500 MHz
Insertion Loss
1.2 dB max.
Phase Difference
180∘± 10∘
Amplitude Difference
2.0 dB max.
VSWR
2.0 max.
Impedance (Unbalanced)
50 Ω
Impedance (Balanced)
100 Ω
Operating temperature Range
Moisture sensitivity levels
-40℃~85℃
LEVEL 1 (Refer to : IPC/JEDEC J-STD-020)
Typical Electrical Chart
SOLDER LAND PATTERN
Figure
Unit: mil
Line width to be designed to match 50 Ω characteristic impedance, depending on PCB material and thickness.
Page 3 of 7
Dec.2015
Approval sheet
RELIABILITY TEST
Test item
Test condition / Test method
Solderability
JIS C 0050-4.6
*Solder bath temperature:235 5C
JESD22-B102D
*Immersion time:2 0.5 sec
Specification
At least 95% of a surface of each terminal
electrode must be covered by fresh solder.
Solder:Sn3Ag0.5Cu for lead-free
Leaching
*Solder bath temperature:260 5C
Loss of metallization on the edges of each
of metallization)
*Leaching immersion time:30 0.5 sec
electrode shall not exceed 25%.
IEC 60068-2-58
Solder : SN63A
(Resistance to dissolution
Resistance to soldering heat
*Preheating temperature:120~150℃,
No mechanical damage.
JIS C 0050-5.4
1 minute.
Electrical specification shall satisfy the
*Solder temperature:2705C
descriptions in electrical characteristics under
*Immersion time:101 sec
the operational temperature range within -40
~ 85°C.
Measurement to be made after keeping at
room temperature for 242 hrs
Drop Test
JIS C 0044
*Height:75 cm
Customer’s specification.
*Test Surface:Rigid surface of concrete
or steel.
*Times:6 surfaces for each units;2
times for each side.
Adhesive Strength
of Termination
JIS C 0051- 7.4.3
*Pressurizing force:
5N(≦0603);10N(>0603)
*Test time:10±1 sec
~ 85°C.
~ 85°C.
Bending test
JIS C 0051- 7.4.1
The middle part of substrate shall be
No remarkable damage or removal of the
pressurized by means of the pressurizing
termination.
rod at a rate of about 1 mm/s per second
until the deflection becomes 1mm/s and
then pressure shall be maintained for 51
sec.
room temperature for 242 hours
Page 4 of 7
Dec.2015
Approval sheet
Temperature cycle
JIS C 0025
1.
303 minutes at -40C3C,
2.
10~15 minutes at room temperature,
3.
303 minutes at +85C3C,
4.
Total 100 continuous cycles
~ 85°C.
Vibration
JIS C 0040
*Frequency:10Hz~55Hz~10Hz(1min)
*Total amplitude:1.5mm
*Test times:6hrs.(Two hrs each in three
mutually perpendicular directions)
under the operational temperature range
within -40 ~ 85°C.
High temperature
JIS C 0021
*Temperature:85C2C
*Test duration:1000+24/-0 hours
~ 85°C.
Humidity
(steady conditions)
*Humidity:90% to 95% R.H.
*Temperature:402C
JIS C 0022
*Time:1000+24/-0 hrs.
~ 85°C.
※ 500hrs measuring the first data then
1000hrs data
Low temperature
JIS C 0020
*Temperature:-40C2C
~ 85°C.
Page 5 of 7
Dec.2015
Approval sheet
SOLDERING CONDITION
Typical examples of soldering processes that provide reliable joints without any damage are given in Fig 2,
Fig 2. Infrared soldering profile
ORDERING CODE
RG
Walsin
RG: RF
/Pb free
device
BLN
160807
Product
Code
Dimension
code
Unit of
dimension
BLN :
BALUN
Per 2 digits of
Length, Width,
Thickness :
0 : 0.1 mm
A
5
T
Application
Specification
Packing
A : 2.4GHz ISM
Band
Design Code
T : Reeled
1 : 1.0 mm
e.g. :
160807 = Length
16, Width 08,
Thickness 07
PACKAGING
Paper Tape specifications (unit :mm)
Index
Dimension (mm)
Index
Dimension (mm)
Page 6 of 7
Ao
Bo
D
T
W
0.975 0.05
1.76 0.05
1.55 + 0.05
0.75 0.03
8.0 0.10
E
F
Po
P1
P2
1.75 0.10
3.50 0.05
4.00 0.10
4.00 0.10
2.00 0.05
Dec.2015
Approval sheet
Reel dimensions
C
Index
A
Φ178.0
Dimension (mm)
B
Φ60.0
A
B
C
Φ13.0
Taping Quantity: 4000 pieces per 7” reel
CAUTION OF HANDLING
Limitation of Applications
Please contact us before using our products for the applications listed below which require especially high reliability for
the prevention of defects, which might directly cause damage to the third party’s life, body or property.
(1)
(2)
(3)
(4)
(5)
(6)
(7)
(8)
Aircraft equipment
Aerospace equipment
Undersea equipment
Medical equipment
Disaster prevention / crime prevention equipment
Traffic signal equipment
Transportation equipment (vehicles, trains, ships, etc.)
Applications of similar complexity and /or reliability requirements to the applications listed in the above.
Storage condition
(1)
Products should be used in 6 months from the day of WALSIN outgoing inspection, which can be
confirmed.
(2)
Storage environment condition.
Page 7 of 7
Products should be storage in the warehouse on the following conditions.
Temperature
: -10 to +40℃
Humidity
: 30 to 70% relative humidity
Don’t keep products in corrosive gases such as sulfur. Chlorine gas or acid or it may cause oxidization of
electrode, resulting in poor solderability.
Products should be storage on the palette for the prevention of the influence from humidity, dust and son on.
Products should be storage in the warehouse without heat shock, vibration, direct sunlight and so on.
Products should be storage under the airtight packaged condition.
Dec.2015
很抱歉,暂时无法提供与“RGBLN1608070A5T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.39936
- 200+0.55836
- 500+0.53968
- 1000+0.53050
