Approval sheet
RFBLN Series – 1608(0603)- RoHS Compliance
MULTILAYER CERAMIC BALUN TRANSFORMER
Halogens Free Product
2.4 GHz ISM Band Working Frequency
P/N: RFBLN1608060AF6T50
*Contents in this sheet are subject to change without prior notice.
Page 1 of 7
ASC_RFBLN1608060AF6T50_V02
May. 2015
Approval sheet
FEATURES
3
1.
Miniature footprint: 1.6 X 0.8X 0.6 mm
2.
Low insertion loss
3.
Low in-band amplitude and phase imbalance enhances system performance
4.
LTCC process
APPLICATIONS
1.
2.4GHz ISM Band RF Application
2.
Bluetooth, Wireless LAN, HomeR
CONSTRUCTION
Top view
P6
P1
P5
P2
P4
PIN
Definition
PIN
Definition
P1
Unbalance Port
P4
Balance Port
P2
GND
P5
GND
P3
Balance Port
P6
GND
P3
DIMENSIONS
Figure
Top view
Page 2 of 7
Bottom view
Side view
Symbol
Dimension (mm)
L
1.60 ± 0.15
W
0.80 ± 0.15
T
0.60 ± 0.10
A
0.175 ± 0.15
B
0.25 ± 0.15
C
0.25 ± 0.15
D
0.50 ± 0.15
E
0.20 ± 0.15
May. 2015
Approval sheet
ELECTRICAL CHARACTERISTICS
RFBLN1608060AF6T50
Specification
Frequency range
2400 - 2500 MHz
Insertion Loss
1.0 dB max.
Attenuation (dB min )
15 dB @ 4800 - 5000 MHz
20 dB @ 7200 - 7500 MHz
Phase Difference
180∘± 10∘
Amplitude Difference
2.0 dB Max.
VSWR
2.0 max.
Impedance (Unbalanced)
50 Ω
Impedance (Balanced)
Conjugate match to TI CC26XX Chipset
Operating temperature Range
-40℃ ~ +85℃
Moisture sensitivity levels
MSL is LEVEL 1 (Refer to : IPC/JEDEC J-STD-020)
Typical Electrical Chart
SOLDER LAND PATTERN
Figure
Unit : mm
Line width to be designed to match 50 Ω characteristic impedance, depending on PCB material and thickness.
Page 3 of 7
May. 2015
Approval sheet
RELIABILITY TEST
Test condition / Test method
Test item
Solderability
*Solder bath temperature:235 ± 5°C
Specification
At least 95% of a surface of each terminal
JIS C 0050-4.6
*Immersion time:2 ± 0.5 sec
electrode must be covered by fresh solder.
JESD22-B102D
Solder:Sn3Ag0.5Cu for lead-free
Leaching
*Solder bath temperature:260 ± 5°C
(Resistance to
*Leaching immersion time:30 ± 0.5 sec
dissolution of
Loss of metallization on the edges of each
electrode shall not exceed 25%.
Solder : SN63A
metallization)
IEC 60068-2-58
Resistance to soldering
*Preheating temperature:120~150℃,
No mechanical damage.
1 minute.
Electrical specification shall satisfy the
*Solder temperature:270±5°C
descriptions in electrical characteristics under
heat
JIS C 0050-5.4
*Immersion time:10±1 sec
the operational temperature range within -40
~ 85°C.
Measurement to be made after keeping at
room temperature for 24±2 hrs
Drop Test
JIS C 0044
Customer’s specification.
*Height:75 cm
*Test Surface:Rigid surface of concrete or
steel.
*Times:6 surfaces for each units;2 times
for each side.
Vibration
JIS C 0040
~ 85°C.
*Frequency:10Hz~55Hz~10Hz(1min)
*Total amplitude:1.5mm
*Test times:6hrs.(Two hrs each in three
mutually perpendicular directions)
~ 85°C.
Adhesive Strength
of Termination
JIS C 0051- 7.4.3
Bending test
JIS C 0051- 7.4.1
*Pressurizing force:
5N(≦0603);10N(>0603)
No remarkable damage or removal of the
termination.
*Test time:10±1 sec
The middle part of substrate shall be
pressurized by means of the pressurizing rod Electrical specification shall satisfy the
at a rate of about 1 mm/s per second until the descriptions in electrical characteristics under
deflection becomes 1mm/s and then pressure the operational temperature range within -40
shall be maintained for 5±1 sec.
~ 85°C.
room temperature for 24±2 hours
Page 4 of 7
May. 2015
Approval sheet
Temperature cycle
JIS C 0025
1.
30±3 minutes at -40°C±3°C,
2.
10~15 minutes at room temperature,
3.
30±3 minutes at +85°C±3°C,
4.
Total 100 continuous cycles
under the operational temperature range
within -40 ~ 85°C.
High temperature
JIS C 0021
*Temperature:85°C±2°C
*Test duration:1000+24/-0 hours
~ 85°C.
Humidity
(steady conditions)
*Humidity:90% to 95% R.H.
*Temperature:40±2°C
JIS C 0022
*Time:1000+24/-0 hrs.
~ 85°C.
※ 500hrs measuring the first data then
1000hrs data
Low temperature
JIS C 0020
*Temperature:-40°C±2°C
~ 85°C.
Page 5 of 7
May. 2015
Approval sheet
SOLDERING CONDITION
Typical examples of soldering processes that provide reliable joints without any damage are given in Fig 2,
Fig 2. Infrared soldering profile
ORDERING CODE
RF
BLN
160806
A
Walsin
Product Code
Dimension code
RF device
BLN : BALUN
Per 2 digits of
Length, Width,
Thickness :
Unit of
dimension
0 : 0.1 mm
F6T50
Application
Specification
A : 2.4GHz ISM
Band
Design Code
1 : 1.0 mm
e.g. :
160806=
Length 16,
Width 08,
Thickness 06
Minimum Ordering Quantity: 4000 pcs per reel.
PACKAGING
Paper Tape specifications (unit :mm)
Index
Dimension (mm)
Index
Dimension (mm)
Page 6 of 7
Ao
Bo
ΦD
T
W
1.09± 0.05
1.83 ±0.05
1.55 + 0.05
0.75 ± 0.10
8.00 ± 0.10
E
F
Po
P1
P2
1.750 ± 0.100
3.50 ± 0.050
4.00 ± 0.100
4.00 ± 0.100
2.000 ± 0.050
May. 2015
Approval sheet
Reel dimensions
C
Index
A
Φ178.0
Dimension (mm)
B
Φ60.0
A
B
C
Φ13.0
Taping Quantity: 4000 pieces per 7” reel
CAUTION OF HANDLING
Limitation of Applications
Please contact us before using our products for the applications listed below which require especially high reliability for
the prevention of defects, which might directly cause damage to the third party’s life, body or property.
(1)
(2)
(3)
(4)
(5)
(6)
(7)
(8)
Aircraft equipment
Aerospace equipment
Undersea equipment
Medical equipment
Disaster prevention / crime prevention equipment
Traffic signal equipment
Transportation equipment (vehicles, trains, ships, etc.)
Applications of similar complexity and /or reliability requirements to the applications listed in the above.
Storage condition
(1)
Products should be used in 6 months from the day of WALSIN outgoing inspection, which can be
confirmed.
(2)
Storage environment condition.
Products should be storage in the warehouse on the following conditions.
Temperature
: -10 to +40℃
Humidity
: 30 to 70% relative humidity
Don’t keep products in corrosive gases such as sulfur. Chlorine gas or acid or it may cause oxidization of
electrode, resulting in poor solderability.
Products should be storage on the palette for the prevention of the influence from humidity, dust and son on.
Products should be storage in the warehouse without heat shock, vibration, direct sunlight and so on.
Products should be storage under the airtight packaged condition.
Page 7 of 7
May. 2015
很抱歉,暂时无法提供与“RFBLN1608060AF6T50”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.84386
- 200+1.13476
- 500+1.09685
- 1000+1.07806
