WA04P009XCTL
WA04P009XCTL
    WALSIN(华新科)
    0402封装π型RF衰减器
WA04P009XCTL 数据手册
www.passivecomponent.com Chip Resistors Ϯ WT04X Chip Resistor Network 10P8R Ϯ Description The resistor array is constructed in a high grade ceramic body (aluminum oxide). Internal metal electrodes are added at each end and connected by a resistive paste that is applied to the top surface of the substrate. The composition of the paste is adjusted to give the approximate resistance required and the value is trimmed to within tolerance by laser cutting of this resistive layer. The resistive layer is covered with a protective coat. Finally, the two external end terminations are added. For ease of soldering the outer layer of these end termination is Tin (Pb free) solder alloy. Ϯ Quick Reference Data Item General Specification Series No. WT04X Size 0402x8 (1005x8) Termination construction Convex type Resistance Tolerance ±5% (E24 series) Resistance Range 10ȍ ~ 100Kȍ TCR (ppm/к) ± 200 Max. dissipation @ Tamb=70к 1/16 W Max. Operation Voltage (DC or RMS) 25V Max. Overload Voltage (DC or RMS) 50V Climatic category (IEC 60068) 55/155/56 Circuit Mode: Resistor elements on pin1 ~ pin4, pin6 ~ pin9; R1=R2=R3=R4=R6=R7=R8=R9 Note : 1. Power derating curve and detail specification please refer to specific data sheets. Ϯ Physical Dimensions: 11 ppm/к Unit: mm Symbol ʳ L 3.30±0.20 W 1.60±0.15 T 0.55±0.10 P 0.64±0.05 A 0.50±0.05 B 0.40±0.15 C 0.40±0.15 G 0.40±0.15 Chip Resistors www.passivecomponent.com Ϯ WA04P Chip Attenuator Ϯ Typical Application of Chip Attenuator WA04 P 001 X B T L Size code Type code Characteristic Impedance Attenuation Tolerance Termination Packaging WA04: 0402 per element P: convex, S type attenuator Attenuation Range 000 = 0dB R05 = 0.5dB 001 = 1dB R15 = 1,5dB 002 = 2dB 003 = 3dB 004 = 4dB 005 = 5dB 006 = 6dB 007 = 7dB 008 = 8dB 009 = 9dB 010 =10dB 011 = 11dB 012 = 12dB 013 = 13dB 014 = 14dB 015 = 15dB 016 = 16dB 017 = 17dB 018 = 18dB 019 = 19dB 020 = 20dB T=7'' reel taped L=Sn base (lead free) X:50ȍ A: B: C: D: E: F: G: H: P: Γ̈́ Γ̈́ Γ̈́ Γ̈́ Γ̈́ Γ̈́ Γ̈́ Γ̈́ 0.1dB 0.3dB 0.4dB 0.8dB 1.0dB 1.5dB 2.0dB 2.5dB - S type Attenuator (-6dB, 50W) for VSWR improvement and output frequency level matching on VCO application. Ϯ Quick Reference Data Item Series No. Size General Specification WA04P 0402×2 (1005×2) Termination construction Convex type Attenuation Range Attenuation Tolerance 0dB 0.5dB 1dB~ 5dB 6dB~ 10dB 11dB~ 13dB 14dB 15dB~ 16dB 17dB~ 19dB 20dB Characteristic impedance 0dB, 0.5dB ~ 20dB Rated power at Tamb=70ɗ ± ± ± ± ± ± ± ± 0.1dB 0.3dB 0.4dB 0.8dB 1.0dB 1.5dB 2.0dB 2.5dB 50Ÿ 0.1 W / package Limiting Voltage (DC) 50V Frequency range (DC) MAX. 3 GHz VSWR (Voltage Standing Wave Ratio) MAX. 1.2 Number of Resistors 3 resistors Number of Terminals 4 terminals Climatic category (IEC 60068) -40 ~ 125’C Ϯʳ Physical Dimensions: Unit: mmʳ WA04P L 1.00±0.10 W 1.00+0.10/-0 T 0.35±0.10 P 0.65±0.20 A 0.33±0.10 Ta 0.15±0.10 Tb 0.25±0.10 12 2
WA04P009XCTL 价格&库存
很抱歉,暂时无法提供与“WA04P009XCTL”相匹配的价格&库存,您可以联系我们找货
WA04P009XCTL
    • 10000+0.3387710000+0.04382
    • 20000+0.3246420000+0.04200
    • 30000+0.3167530000+0.04097
    • 50000+0.3071750000+0.03974
    • 70000+0.3010970000+0.03895
    • 100000+0.29483100000+0.03814
    库存:9332
    WA04P009XCTL
    • 1+0.886851+0.11472
    • 10+0.5299710+0.06856
    • 25+0.5017725+0.06491
    • 100+0.45593100+0.05898
    • 250+0.42911250+0.05551
    • 500+0.41000500+0.05304
    • 1000+0.391891000+0.05069
    • 5000+0.353735000+0.04576
    库存:9332
