WA04P010XCTL
WA04P010XCTL
    WALSIN(华新科)
    1.0 X 1.0 MM 封装的不平衡π型芯片衰减器
WA04P010XCTL 数据手册
Approval sheet WA04P π type chip attenuator 50Ω, 0dB, 0.5dB to 20dB Size 1.0 x 1.0 mm Page 1 of 6 ASC_WA04P_V14 Feb. 2012 Approval sheet FEATURE 1. Unbalanced π type attenuator circuit in one chip (1.0mm x 1.0mm) 2. Mounting occupation area reduction 3. Mounting assembly cost saving APPLICATION • Attenuation, level control, impedance matching of high frequency signals of communication equipment; • Mobile phone (GSM, CDMA, PDC, etc,…) • Telecom DESCRIPTION The attenuator is constructed in a high grade ceramic body (aluminum oxide). Internal circuit is applied to the top surface of the substrate, and its design determines the required attenuation value. The attenuation layer is covered with a protective coating and a rectangular marker indicates input pin1 as shown in circuit configuration. Fig 1. Outline of WA04P Chip attenuator CIRCUIT CONFIGURATION Page 2 of 6 ASC_WA04P_V14 Feb. 2012 Approval sheet QUICK REFERENCE DATA Item General Specification Series No. WA04P(Convex type) Size 1.0 x 1.0 mm Attenuation Range 0dB, 0.5 dB ~ 20dB Attenuation Tolerance - 0dB ±0.1dB 0.5 dB 1dB ~ 5dB ±0.3dB 6dB ~ 10dB ±0.4dB 11dB ~ 13dB ±0.8dB 14dB ±1.0dB 15 ~ 16dB ±1.5dB 17 ~ 19dB ±2.0dB 20dB ±2.5dB Characteristic impedance 50Ω Rated power at Tamb=70°C 0.1 W / package Limiting voltage (DC) 50V Frequency range (DC) Max. 3GHz VSWR (Voltage Standing Wave Ratio) Max. 1.2 Number of Resistors 3 resistors Number of Terminals 4 terminals category temperature range -40 ~ +125 DIMENSIONS(mm) WA04P L 1.00 ± 0.10 W 1.00 +0.10 / -0 T 0.35 ± 0.10 P 0.65 ± 0.10 A 0.33 ± 0.10 Ta 0.15 ± 0.10 Tb 0.25 ± 0.10 MARKING Page 3 of 6 ASC_WA04P_V14 Feb. 2012 Approval sheet code 0 X 1 Y 2 3 4 5 6 7 8 9 A B C D E F G H J K L dB 0 0 . 5 1 1 . 5 2 3 4 5 6 7 8 9 1 0 1 1 1 2 1 3 1 4 1 5 1 6 1 7 1 8 1 9 2 0 FUNCTIONAL DESCRIPTION Product characterization Standard attenuation values include 0, 0.5dB to 20dB with a tolerance as defined in quick reference data. CATALOGUE NUMBERS AND PACKAGING The attenuators have a catalogue number starting with . WA04 P Size code Type code WA04 : P : convex, π type attenuator 0402 per element 001 X Attenuation code Impedance 000 = 0dB B Tolerance X : 50Ω A : ±0.1dB 001 = 1dB B : ±0.3dB 005 = 5dB C : ±0.4dB 010 = 10dB D : ±0.8dB 020 = 20dB E : ±1.0dB R05 = 0.5dB F : ±1.5dB R15 = 1.5dB T L Packaging code Termination code T : 7” reel taped L = Sn base (lead free) G : ±2.0dB H : ±2.5dB P :- Packaging : 8mm width paper taping 10,000pcs per reel. SOLDERING CONDITION The robust construction of chip resistors allows them to be completely immersed in a solder bath of 260°C for 10 seconds. Therefore, it is possible to mount Surface Mount Resistors on one side of a PCB and other discrete components on the reverse (mixed PCBs). Surface Mount Resistors are tested for solderability at 235°C during 2 seconds. The test condition for no leaching is 260°C for 30 seconds. Typical examples of soldering processes that provide reliable joints without any damage are given in Fig 3. Fig 3. Infrared soldering profile Page 4 of 6 ASC_WA04P_V14 Feb. 2012 Approval sheet TEST AND REQUIREMENTS (JIS C 5201-1 : 1998) TEST PROCEDURE REQUIREMENT Characteristic Impedance Measuring circuit 50Ω Insulation resistance Apply the 50VDC for 1minute At least 100MΩ Clause 4.6 Clause 4.17 Solderability Un-mounted chips completely immersed for 2±0.5 second in a SAC good tinning (>95% covered) solder bath at 235℃±5℃ no visible damage Resistance to soldering heat(R.S.H) Clause 4.18 Un-mounted chips completely immersed for 10±1 second in a SAC no visible damage solder bath at 260℃±5ºC Attenuation 0.5~ 2dB : within ±0.1dB Attenuation 3~ 5dB : within ±0.2dB Attenuation 6~ 20dB : within ±0.3dB Temperature cycling Clause 4.19 30 minutes at -55°C±3°C, 2~3 minutes at 20°C+5°C-1°C, 30 minutes at +125°C±3°C, 2~3 minutes at 20°C+5°C-1°C, total 5 continuous cycles no visible damage Attenuation 0.5~ 2dB : within ±0.1dB Attenuation 3~ 5dB : within ±0.2dB Attenuation 6~ 20dB : within ±0.3dB Load life (endurance) Clause 4.25 1000 +48/-0 hours, loaded with RCWV or Vmax in chamber no visible damage controller 85±2ºC, 1.5 hours on and 0.5 hours off Attenuation 0.5~ 2dB : within ±0.1dB Attenuation 3~ 5dB : within ±0.2dB Attenuation 6~ 20dB : within ±0.3dB Dielectric Withstand Apply the maximum overload voltage (AC) for 1 minute Voltage No breakdown or flashover Clause 4.7 Page 5 of 6 ASC_WA04P_V14 Feb. 2012 Approval sheet PACKAGING Paper Tape specifications (unit :mm) (mm) A0 B0 W F E 1.20±0.05 1.20±0.05 8.00±0.20 3.50±0.05 1.75±0.10 P1 P2 2.00±0.10 (mm) P0 2.00±0.05 T ØD0 1.50 +−00.10 4.00±0.10 0.45±0.10 Reel dimensions Page 6 of 6 Symbol A B C D (unit : mm) Φ178.0±2.0 Φ60.0±1.0 13.0±0.2 9.0±0.5 ASC_WA04P_V14 Feb. 2012
WA04P010XCTL 价格&库存
很抱歉,暂时无法提供与“WA04P010XCTL”相匹配的价格&库存,您可以联系我们找货
