www.passivecomponent.com
Chip Resistors
Ϯ WT04X Chip Resistor Network 10P8R
Ϯ Description
The resistor array is constructed in a high grade ceramic body (aluminum oxide).
Internal metal electrodes are added at each end and connected by a resistive
paste that is applied to the top surface of the substrate. The composition of the
paste is adjusted to give the approximate resistance required and the value is
trimmed to within tolerance by laser cutting of this resistive layer.
The resistive layer is covered with a protective coat. Finally, the two external end
terminations are added. For ease of soldering the outer layer of these end
termination is Tin (Pb free) solder alloy.
Ϯ Quick Reference Data
Item
General Specification
Series No.
WT04X
Size
0402x8 (1005x8)
Termination construction
Convex type
Resistance Tolerance
±5% (E24 series)
Resistance Range
10ȍ ~ 100Kȍ
TCR (ppm/к)
± 200
Max. dissipation @ Tamb=70к
1/16 W
Max. Operation Voltage (DC or RMS)
25V
Max. Overload Voltage (DC or RMS)
50V
Climatic category (IEC 60068)
55/155/56
Circuit Mode:
Resistor elements on pin1 ~ pin4, pin6 ~ pin9;
R1=R2=R3=R4=R6=R7=R8=R9
Note :
1. Power derating curve and detail specification please refer to specific data sheets.
Ϯ Physical Dimensions:
11
ppm/к
Unit: mm
Symbol
ʳ
L
3.30±0.20
W
1.60±0.15
T
0.55±0.10
P
0.64±0.05
A
0.50±0.05
B
0.40±0.15
C
0.40±0.15
G
0.40±0.15
Chip Resistors
Ϯ WA04P Chip Attenuator
Ϯ Typical Application of Chip Attenuator
WA04
P
001
X
B
T
L
Size code
Type code
Characteristic Impedance
Attenuation Tolerance
Termination
Packaging
WA04: 0402
per element
P: convex, S type
attenuator
Attenuation Range
000 = 0dB
R05 = 0.5dB
001 = 1dB
R15 = 1,5dB
002 = 2dB
003 = 3dB
004 = 4dB
005 = 5dB
006 = 6dB
007 = 7dB
008 = 8dB
009 = 9dB
010 =10dB
011 = 11dB
012 = 12dB
013 = 13dB
014 = 14dB
015 = 15dB
016 = 16dB
017 = 17dB
018 = 18dB
019 = 19dB
020 = 20dB
T=7'' reel taped
L=Sn base
(lead free)
X:50ȍ
A:
B:
C:
D:
E:
F:
G:
H:
P:
Γ̈́
Γ̈́
Γ̈́
Γ̈́
Γ̈́
Γ̈́
Γ̈́
Γ̈́
0.1dB
0.3dB
0.4dB
0.8dB
1.0dB
1.5dB
2.0dB
2.5dB
S type Attenuator (-6dB, 50W) for VSWR improvement and output frequency level matching on VCO application.
Item
Series No.
Size
WA04P
0402×2 (1005×2)
Convex type
Attenuation Range
0dB
0.5dB
1dB~ 5dB
6dB~ 10dB
11dB~ 13dB
14dB
15dB~ 16dB
17dB~ 19dB
20dB
Characteristic impedance
0dB, 0.5dB ~ 20dB
Rated power at Tamb=70ɗ
0.1dB
0.3dB
0.4dB
0.8dB
1.0dB
1.5dB
2.0dB
2.5dB
50
0.1 W / package
Limiting Voltage (DC)
50V
Frequency range (DC)
MAX. 3 GHz
VSWR (Voltage Standing Wave Ratio)
MAX. 1.2
Number of Resistors
3 resistors
Number of Terminals
4 terminals
-40 ~ 125’C
Ϯʳ Physical Dimensions:
Unit: mmʳ
WA04P
L
1.00±0.10
W
1.00+0.10/-0
T
0.35±0.10
P
0.65±0.20
A
0.33±0.10
Ta
0.15±0.10
Tb
0.25±0.10
12
2
很抱歉,暂时无法提供与“WA04P016XFTL”相匹配的价格&库存,您可以联系我们找货
