Approval sheet
WA04P
π type chip attenuator
50Ω, 0dB, 0.5dB to 20dB
Size 1.0 x 1.0 mm
Page 1 of 6
ASC_WA04P_V14
Feb. 2012
Approval sheet
FEATURE
1. Unbalanced π type attenuator circuit in one chip (1.0mm x 1.0mm)
2. Mounting occupation area reduction
3. Mounting assembly cost saving
APPLICATION
Attenuation, level control, impedance matching of high frequency signals of communication equipment;
Mobile phone (GSM, CDMA, PDC, etc,…)
Telecom
DESCRIPTION
The attenuator is constructed in a high grade ceramic body (aluminum oxide). Internal circuit is applied to the top
surface of the substrate, and its design determines the required attenuation value. The attenuation layer is
covered with a protective coating and a rectangular marker indicates input pin1 as shown in circuit configuration.
Fig 1. Outline of WA04P Chip attenuator
CIRCUIT CONFIGURATION
Page 2 of 6
ASC_WA04P_V14
Feb. 2012
Approval sheet
QUICK REFERENCE DATA
Item
General Specification
Series No.
WA04P(Convex type)
Size
1.0 x 1.0 mm
Attenuation Range
0dB, 0.5 dB ~ 20dB
Attenuation Tolerance
0dB
±0.1dB
0.5 dB
1dB ~ 5dB
±0.3dB
6dB ~ 10dB
±0.4dB
11dB ~ 13dB
±0.8dB
14dB
±1.0dB
15 ~ 16dB
±1.5dB
17 ~ 19dB
±2.0dB
20dB
±2.5dB
Characteristic impedance
50Ω
Rated power at Tamb=70°C
0.1 W / package
Limiting voltage (DC)
50V
Frequency range (DC)
Max. 3GHz
VSWR (Voltage Standing Wave Ratio)
Max. 1.2
Number of Resistors
3 resistors
Number of Terminals
4 terminals
category temperature range
-40 ~ +125
DIMENSIONS(mm)
WA04P
L
1.00 ± 0.10
W
1.00 +0.10 / -0
T
0.35 ± 0.10
P
0.65 ± 0.10
A
0.33 ± 0.10
Ta
0.15 ± 0.10
Tb
0.25 ± 0.10
MARKING
Page 3 of 6
ASC_WA04P_V14
Feb. 2012
Approval sheet
code
X
1
Y
2
3
4
5
6
7
8
9
A
B
C
D
E
F
G
H
J
K
L
dB
1
1
5
2
3
4
5
6
7
8
9
1
1
1
2
1
3
1
4
1
5
1
6
1
7
1
8
1
9
2
FUNCTIONAL DESCRIPTION
Product characterization
Standard attenuation values include 0, 0.5dB to 20dB with a tolerance as defined in quick reference data.
CATALOGUE NUMBERS AND PACKAGING
The attenuators have a catalogue number starting with .
WA04
P
Size code
Type code
WA04 :
P : convex, π type
attenuator
0402 per element
001
X
Attenuation code
Impedance
000 = 0dB
B
Tolerance
X : 50Ω
A : ±0.1dB
001 = 1dB
B : ±0.3dB
005 = 5dB
C : ±0.4dB
010 = 10dB
D : ±0.8dB
020 = 20dB
E : ±1.0dB
R05 = 0.5dB
F : ±1.5dB
R15 = 1.5dB
T
L
Packaging code
Termination code
T : 7” reel taped
L = Sn base
(lead free)
G : ±2.0dB
H : ±2.5dB
P :-
Packaging : 8mm width paper taping 10,000pcs per reel.
SOLDERING CONDITION
The robust construction of chip resistors
allows them to be completely immersed in a
solder bath of 260°C for 10 seconds.
Therefore, it is possible to mount Surface
Mount Resistors on one side of a PCB and
other discrete components on the reverse
(mixed PCBs).
Surface Mount Resistors are tested for
solderability at 235°C during 2 seconds. The
test condition for no leaching is 260°C for 30
seconds. Typical examples of soldering
processes that provide reliable joints without
any damage are given in Fig 3.
Fig 3. Infrared soldering profile
Page 4 of 6
ASC_WA04P_V14
Feb. 2012
Approval sheet
TEST AND REQUIREMENTS (JIS C 5201-1 : 1998)
TEST
PROCEDURE
REQUIREMENT
Characteristic
Impedance
Measuring circuit
50Ω
Insulation
resistance
Apply the 50VDC for 1minute
At least 100MΩ
Clause 4.6
Clause 4.17
Solderability
Un-mounted chips completely immersed for 2±0.5 second in a SAC good tinning (>95% covered)
solder bath at 235℃±5℃
no visible damage
Resistance to
soldering
heat(R.S.H)
Clause 4.18
Un-mounted chips completely immersed for 10±1 second in a SAC no visible damage
solder bath at 260℃±5ºC
Attenuation 0.5~ 2dB : within
±0.1dB
Attenuation 3~ 5dB : within
±0.2dB
Attenuation 6~ 20dB : within
±0.3dB
Temperature
cycling
Clause 4.19
30 minutes at -55°C±3°C, 2~3 minutes at 20°C+5°C-1°C, 30
minutes at +125°C±3°C, 2~3 minutes at 20°C+5°C-1°C, total
5 continuous cycles
no visible damage
±0.1dB
±0.2dB
±0.3dB
Load life
(endurance)
Clause 4.25
1000 +48/-0 hours, loaded with RCWV or Vmax in chamber no visible damage
controller 85±2ºC, 1.5 hours on and 0.5 hours off
±0.1dB
±0.2dB
±0.3dB
Dielectric Withstand Apply the maximum overload voltage (AC) for 1 minute
Voltage
No breakdown or flashover
Clause 4.7
Page 5 of 6
ASC_WA04P_V14
Feb. 2012
Approval sheet
PACKAGING
Paper Tape specifications (unit :mm)
(mm)
A0
B0
W
F
E
1.20±0.05
1.20±0.05
8.00±0.20
3.50±0.05
1.75±0.10
P1
P2
2.00±0.10
(mm)
P0
2.00±0.05
T
ØD0
1.50 +−00.10
4.00±0.10
0.45±0.10
Reel dimensions
Page 6 of 6
Symbol
A
B
C
D
(unit : mm)
Φ178.0±2.0
Φ60.0±1.0
13.0±0.2
9.0±0.5
ASC_WA04P_V14
Feb. 2012
很抱歉,暂时无法提供与“WA04P020XHTL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10000+0.3386310000+0.04387
- 20000+0.3245120000+0.04204
- 30000+0.3166130000+0.04102
- 50000+0.3070550000+0.03978
- 70000+0.3009770000+0.03899
- 100000+0.29471100000+0.03818
- 国内价格
- 1+0.10574
- 200+0.04094
- 500+0.03953
- 1000+0.03878
- 国内价格 香港价格
- 1+0.886541+0.11484
- 10+0.5297910+0.06863
- 25+0.5015925+0.06498
- 100+0.45577100+0.05904
- 250+0.42892250+0.05556
- 500+0.40984500+0.05309
- 1000+0.391731000+0.05075
- 5000+0.353585000+0.04580
